[U-Boot-Users] do_bootm_linux problem
Hi all,
I try port U-Boot 1.1.1 to a board with MPC8280. It seems to work but booting the Linux kernel failed without any print after "Uncompressing Kernel Image ... OK" I have already checked the cases mentioned in DULG 13.2.5. I found that within the function do_bootm_linux the pointer "kernel" is 0. Within the global structure header I found the following: header = ( ih_magic = 0x27051956, ih_hcrc = 0x0, ih_time = 0x40EBFB9A, ih_size = 0x000863D7, ih_load = 0x0, ih_ep = 0x0, ih_dcrc = 0xC3C4EF02, ih_os = 0x5, ih_arch = 0x7, ih_type = 0x2, ih_comp = 0x1, ih_name = 'L', 'i', 'n', 'u', 'x', '-', '2', '.', '4', '.', '2', '4', '-', 'p', 'r', 'e', '2', '.')
The kernel is the one shipped with ELDK 3.0 made by make uImage.
What could be wrong?
Thanks in advance, Oliver
Hello,
I recommend to use the top-of-trunk in the CVS for all ongoing work.
execellent!
Whichi s perfectly OK.
This does not matter here at all.
The adaption of the Linux kernel for your board?
Oliver Fuchs
