[U-Boot] [PATCH] imx: mx6ull: fix USB bmode for i.MX 6UL and 6ULL
i.MX 6UL and 6ULL have different boot device capabilities and use therefor use a different boot device selection table than other i.MX 6 devices. Particularly, the value which has been used so far (b0001) is assigned to QSPI boot for these two devices.
There is no common reserved value for all i.MX 6devices. Use b0010 for i.MX 6UL and 6ULL via compile time ifdef.
Reported-by: Joël Esponde joel.esponde@honeywell.com Signed-off-by: Stefan Agner stefan.agner@toradex.com --- arch/arm/cpu/armv7/mx6/soc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index dd94797514..9416bb8947 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -548,7 +548,11 @@ void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) const struct boot_mode soc_boot_modes[] = { {"normal", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x00)}, /* reserved value should start rom usb */ +#if defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) + {"usb", MAKE_CFGVAL(0x20, 0x00, 0x00, 0x00)}, +#else {"usb", MAKE_CFGVAL(0x10, 0x00, 0x00, 0x00)}, +#endif {"sata", MAKE_CFGVAL(0x20, 0x00, 0x00, 0x00)}, {"ecspi1:0", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x08)}, {"ecspi1:1", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x18)},
Thanks for the patch.
Joël, could you please test it and reply with your Tested-by?
Thanks
Hi Stefan,
Why did you take the value 0x20 in the table entry instead of the value 0x00 as it is, for example, in the NXP U-Boot?
Is it because this boot mode does not exist in the iMX6UL SOC?
Joël Esponde Honeywell | Safety and Productivity Solutions
-----Message d'origine----- De : Fabio Estevam [mailto:festevam@gmail.com] Envoyé : samedi 10 juin 2017 00:10 À : Stefan Agner stefan@agner.ch; Esponde, Joel Joel.Esponde@Honeywell.com Cc : Stefano Babic sbabic@denx.de; Fabio Estevam fabio.estevam@nxp.com; Stefan Agner stefan.agner@toradex.com; U- Boot-Denx u-boot@lists.denx.de Objet : Re: [U-Boot] [PATCH] imx: mx6ull: fix USB bmode for i.MX 6UL and 6ULL
Thanks
On 2017-06-12 01:51, Esponde, Joel wrote:
Hi Stefan,
0x00 would mean b0000, which is WEIM (OneNAND/NOR flash, which is probably a likely boot device).
0x20 is no defined boot device, and since it works, it will make sure that bmode usb works for all users of i.MX 6UL/ULL...
-- Stefan
Thanks
Thanks
Tested-by: Joël Esponde joel.esponde@honeywell.com
PS: I tested the patch with an iMX6UL and a QSPI flash.
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
- {"usb", MAKE_CFGVAL(0x20, 0x00, 0x00, 0x00)},
Applied to u-boot-imx, -next, thanks !
Best regards, Stefano Babic
Esponde, Joel
Fabio Estevam
Stefan Agner
Stefano Babic
