[U-Boot] [PATCH] OMAP3EVM: Increase bootargs string length.
Increase the bootargs string length as multiple options (especially for Video settings) are passed to the kernel through bootargs. Also increase the number of args.
Signed-off-by: Sriramakrishnan srk@ti.com --- include/configs/omap3_evm.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index a5514ae..fe7b0e2 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -200,11 +200,11 @@ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_PROMPT V_PROMPT -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command */ +#define CONFIG_SYS_MAXARGS 32 /* max number of command */ /* args */ /* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE)
Signed-off-by: Sriramakrishnansrk@ti.com
Should we do this for some more OMAP3 boards, too? E.g. Overo and Beagle? Or for all OMAP3 boards?
Best regards
Dirk
Best regards
Dirk
I believe the change is relevant for other OMAP3 boards as well. I can repost the patch with changes for all OMAP3 boards but I will not be able to Test this on boards other than omap3evm.
Regards Sriram
<snip>
It seems like a lot of the omap3 boards share common config options. What do you think about consolidating the common options to a sub config file ?
Tom
Best regards
Dirk
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Tom Sent: Thursday, December 17, 2009 9:25 PM To: Dirk Behme Cc: u-boot@lists.denx.de Subject: [U-Boot] RFC common omap3 subconfig ? was Re: [PATCH] OMAP3EVM: Increase bootargs string length.
<snip> > > Should we do this for some more OMAP3 boards, too? E.g. Overo and > Beagle? Or for all OMAP3 boards? >
Seems a good idea; only if we are sure that the next board doesn't break the current list of common configs. Else, we would be having patches to move config options back to board specific files.
~sanjeev
Tom
Best regards
Dirk
Does Wolfgang have a basic opinion about sub-configs for configuration stuff common for similar boards?
Best regards
Dirk
Hi Dirk,
We already have some similar common config files. Take a look for example at the AMCC config header:
include/configs/amcc-common.h
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hello Stefan,
I vote for collecting "common config files" in a subdir:
include/configs/common
for example: include/configs/common/mpc83xx.h
collects all common config options for 83xx boards. and so on for all other architectures/manufacturer ...
And a "#include "configs/common/..." provides enough information, what will come in with that include ...
bye Heiko
Hi Heiko,
Yes, such a directory could make sense. But please note that we already have something similar:
include/asm-ppc/config.h
The other architectures have this file as well, but most of them don't define much in it. Not sure how to best merge/consolidate this.
Cheers, Stefan
participants (7)
Dirk Behme
Govindarajan, Sriramakrishnan
Heiko Schocher
Premi, Sanjeev
Sriramakrishnan
Stefan Roese
Tom
