[U-Boot] [PATCH 1/3] rockchip: rk3399-evb: add script for atf fit
Add a script to generate binaries from bl31.elf, and generate u-boot.its file for FIT image including u-boot, dtb and atf binaries.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
board/rockchip/evb_rk3399/mk_fit_atf.sh | 110 ++++++++++++++++++++++++++++++++ 1 file changed, 110 insertions(+) create mode 100755 board/rockchip/evb_rk3399/mk_fit_atf.sh
diff --git a/board/rockchip/evb_rk3399/mk_fit_atf.sh b/board/rockchip/evb_rk3399/mk_fit_atf.sh new file mode 100755 index 0000000..146550a --- /dev/null +++ b/board/rockchip/evb_rk3399/mk_fit_atf.sh @@ -0,0 +1,110 @@ +#!/bin/sh +# +# script to generate FIT image source for rk3399 boards with +# ARM Trusted Firmware and multiple device trees (given on the command line) +# +# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] + +[ -z "$BL31" ] && BL31="bl31.elf" + +if [ ! -f $BL31 ]; then + echo "WARNING: BL31 file $BL31 NOT found, resulting binary is non-functional" >&2 + BL31=/dev/null +fi + +#tools/mkimage -n rk3399 -T rksd -d spl/u-boot-spl.bin idbspl.img + +cat << __HEADER_EOF +/dts-v1/; + +/ { + description = "Configuration to load ATF before U-Boot"; + #address-cells = <1>; + + images { + uboot@1 { + description = "U-Boot (64-bit)"; + data = /incbin/("u-boot-nodtb.bin"); + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <0x00200000>; + }; +__HEADER_EOF + +atf_cnt=1 + +for l in `readelf -l $BL31 | grep -A1 LOAD | gawk --non-decimal-data \ + '{if (NR % 2) {printf "%d:0x%x:", $2,$4} else {printf "%d\n", $1}}'` +do + offset=${l%%:*} + ll=${l#*:} + phy_offset=${ll%:*} + filesz=${ll##*:} + + #echo "$offset/$phy_offset/$filesz" + + of=rk3399bl31_${phy_offset}.bin + dd if=$BL31 of=$of bs=1 skip=$offset count=$filesz + + out_string="${out_string}:${phy_offset}" + + cat << __ATF1_EOF + atf@$atf_cnt { + description = "ARM Trusted Firmware"; + data = /incbin/("$of"); + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <$phy_offset>; +__ATF1_EOF + if [ "$atf_cnt" -eq 1 ]; then + cat << __ATF2_EOF + entry = <$phy_offset>; +__ATF2_EOF + fi + cat << __ATF3_EOF + }; +__ATF3_EOF + atf_cnt=$((atf_cnt + 1)) +done + +cnt=1 +for dtname in $* +do + cat << __FDT_IMAGE_EOF + fdt@$cnt { + description = "$(basename $dtname .dtb)"; + data = /incbin/("$dtname"); + type = "flat_dt"; + compression = "none"; + }; +__FDT_IMAGE_EOF + cnt=$((cnt+1)) +done + +cat << __CONF_HEADER_EOF + }; + configurations { + default = "config@1"; + +__CONF_HEADER_EOF + +cnt=1 +for dtname in $* +do + cat << __CONF_SECTION_EOF + config@$cnt { + description = "$(basename $dtname .dtb)"; + firmware = "uboot@1"; + loadables = "atf@1","atf@2","atf@3"; + fdt = "fdt@1"; + }; +__CONF_SECTION_EOF + cnt=$((cnt+1)) +done + +cat << __ITS_EOF + }; +}; +__ITS_EOF
Enable SPL_FIT_GENERATOR with path for it. With this patch you can get u-boot.itb for rk3399-evb with:
make u-boot.itb
configs/firefly-rk3399_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 67e14c1..2572933 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="board/rockchip/evb_rk3399/mk_fit_atf.sh" CONFIG_ENV_IS_IN_MMC=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_STACK_R=y
From: Kever Yang kever.yang@rock-chips.com Date: Fri, 18 Aug 2017 13:07:05 +0800
You mean rk3399-firefly ;).
make u-boot.itb
Reviewed-by: Mark Kettenis kettenis@openbsd.org Tested-by: Mark Kettenis kettenis@openbsd.org
diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 67e14c1..2572933 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="board/rockchip/evb_rk3399/mk_fit_atf.sh" CONFIG_ENV_IS_IN_MMC=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_STACK_R=y -- 1.9.1
Since we support ATF in SPL and add script for it, let's make the document up to date.
board/rockchip/evb_rk3399/README | 79 ++++++++++++++++++++++++++++++++-------- 1 file changed, 63 insertions(+), 16 deletions(-)
diff --git a/board/rockchip/evb_rk3399/README b/board/rockchip/evb_rk3399/README index fb8bb19..9982848 100644 --- a/board/rockchip/evb_rk3399/README +++ b/board/rockchip/evb_rk3399/README @@ -18,8 +18,8 @@ evb key features: * PMIC: rk808 * debug console: UART2
-In order to support Arm Trust Firmware(ATF), we need to use the -miniloader from rockchip which: +In order to support Arm Trust Firmware(ATF), we can use either SPL or +miniloader from rockchip to do: * do DRAM init * load and verify ATF image * load and verify U-Boot image @@ -32,8 +32,8 @@ Get the Source and prebuild binary
mkdir ~/evb_rk3399 cd ~/evb_rk3399 git clone https://github.com/ARM-software/arm-trusted-firmware.git
- > git clone https://github.com/rockchip-linux/rkbin - > git clone https://github.com/rockchip-linux/rkflashtool + > git clone https://github.com/rockchip-linux/rkbin.git + > git clone https://github.com/rockchip-linux/rkdeveloptool.git
Compile the ATF =============== @@ -42,32 +42,79 @@ Compile the ATF
make realclean make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 bl31
+ Or you can get the bl31.elf directly from Rockchip: + cp rkbin/rk33/rk3399_bl31_v1.00.elf ../u-boot/bl31.elf + + Get bl31.elf in this step, copy it to U-Boot root dir: + > cp bl31.elf ../u-boot/ + Compile the U-Boot ==================
cd ../u-boot
- > make CROSS_COMPILE=aarch64-linux-gnu- evb-rk3399_defconfig all + > export ARCH=arm64 + > export CROSS_COMPILE=aarch64-linux-gnu- + > make evb-rk3399_defconfig + for firefly-rk3399, use below instead: + > make evb-firefly_defconfig + > make + > make u-boot.itb
-Compile the rkflashtool -======================= + Get spl/u-boot-spl.bin and u-boot.itb in this step.
+Compile the rkdeveloptool +======================= + Follow instructions in latest README
cd ../rkflashtool
+ > autoreconf -i + > ./configure
make
+ > sudo make install + + Get rkdeveloptool in you Host in this step. + +Both origin binaries and Tool are ready now, choose either option 1 or +option 2 to deploy U-Boot. + +Package the image +=================
-Package the image for miniloader -================================ +Package the image for U-Boot SPL(option 1) +--------------------------------
cd ..
- > cp arm-trusted-firmware/build/rk3399/release/bl31.bin rkbin/rk33 + > tools/mkimage -n rk3399 -T rksd -d spl/u-boot-spl.bin idbspl.img + + Get idbspl.img in this step. + +Package the image for Rockchip miniloader(option 2) +------------------------------------------ + > cd .. + > cp arm-trusted-firmware/build/rk3399/release/bl31.elf rkbin/rk33
./rkbin/tools/trust_merger rkbin/tools/RK3399TRUST.ini ./rkbin/tools/loaderimage --pack --uboot u-boot/u-boot-dtb.bin uboot.img
- > mkdir image - > mv trust.img ./image/ - > mv uboot.img ./image/rk3399evb-uboot.bin
-Flash the image -=============== + Get trust.img and uboot.img in this step. + +Flash the image to eMMC +======================= + +Flash the image with U-Boot SPL(option 1) +------------------------------- Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin + > rkdeveloptool wl 64 u-boot/idbspl.img + > rkdeveloptool wl 512 u-boot/u-boot.itb + > rkdeveloptool rd
- > ./rkflashtool/rkflashloader rk3399evb +Flash the image with Rockchip miniloader(option 2) +---------------------------------------- +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin + > rkdeveloptool ul rkbin/rk33/rk3399_loader_v1.08.106.bin + > rkdeveloptool wl 0x4000 u-boot/uboot.img + > rkdeveloptool wl 0x6000 u-boot/trust.img + > rkdeveloptool rd
You should be able to get U-Boot log message in console/UART2 now. +For more detail, please reference to: +http://opensource.rock-chips.com/wiki_Boot_option
From: Kever Yang kever.yang@rock-chips.com Date: Fri, 18 Aug 2017 13:07:06 +0800
- PMIC: rk808
- debug console: UART2
- do DRAM init
- load and verify ATF image
- load and verify U-Boot image
git clone https://github.com/rockchip-linux/rkbin git clone https://github.com/rockchip-linux/rkflashtool
git clone https://github.com/rockchip-linux/rkbin.git git clone https://github.com/rockchip-linux/rkdeveloptool.gitCompile the ATF
- Or you can get the bl31.elf directly from Rockchip:
- cp rkbin/rk33/rk3399_bl31_v1.00.elf ../u-boot/bl31.elf
- Get bl31.elf in this step, copy it to U-Boot root dir:
cp bl31.elf ../u-boot/Compile the U-Boot
cd ../u-boot
export ARCH=arm64 export CROSS_COMPILE=aarch64-linux-gnu- make evb-rk3399_defconfig- for firefly-rk3399, use below instead:
That should be firefly-rk3399_defconfig
make make u-boot.itb-Compile the rkflashtool
- Get spl/u-boot-spl.bin and u-boot.itb in this step.
- Follow instructions in latest README
cd ../rkflashtool autoreconf -i ./configure make sudo make install- Get rkdeveloptool in you Host in this step.
cd ..
tools/mkimage -n rk3399 -T rksd -d spl/u-boot-spl.bin idbspl.img- Get idbspl.img in this step.
cd .. cp arm-trusted-firmware/build/rk3399/release/bl31.elf rkbin/rk33 ./rkbin/tools/trust_merger rkbin/tools/RK3399TRUST.ini ./rkbin/tools/loaderimage --pack --uboot u-boot/u-boot-dtb.bin uboot.img
mkdir image mv trust.img ./image/ mv uboot.img ./image/rk3399evb-uboot.bin-Flash the image
- Get trust.img and uboot.img in this step.
rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin rkdeveloptool wl 64 u-boot/idbspl.img rkdeveloptool wl 512 u-boot/u-boot.itb rkdeveloptool rd
./rkflashtool/rkflashloader rk3399evb+Flash the image with Rockchip miniloader(option 2) +---------------------------------------- +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then:
rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin rkdeveloptool ul rkbin/rk33/rk3399_loader_v1.08.106.bin rkdeveloptool wl 0x4000 u-boot/uboot.img rkdeveloptool wl 0x6000 u-boot/trust.img rkdeveloptool rdYou should be able to get U-Boot log message in console/UART2 now. +For more detail, please reference to:
1.9.1
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
From: Kever Yang kever.yang@rock-chips.com Date: Fri, 18 Aug 2017 13:07:04 +0800
This doesn't work if the ATF BL31_BASE is 0x1000 instead of 0x10000, but there are other reasons why 0x1000 doesn't work. Tested this with ATF v1.4 with BL31_BASE moved back to 0x10000, and that works fine. So this is defenitely progress! This allows me to build my own firmware for the Firefly-RK3399 with a sane console speed of 115200.
- echo "WARNING: BL31 file $BL31 NOT found, resulting binary is non-functional" >&2
- BL31=/dev/null
+fi
- description = "Configuration to load ATF before U-Boot";
- #address-cells = <1>;
- images {
uboot@1 {
arch = "arm64";
+__HEADER_EOF
+atf_cnt=1
- '{if (NR % 2) {printf "%d:0x%x:", $2,$4} else {printf "%d\n", $1}}'`
+do
- offset=${l%%:*}
- ll=${l#*:}
- phy_offset=${ll%:*}
- filesz=${ll##*:}
- #echo "$offset/$phy_offset/$filesz"
- of=rk3399bl31_${phy_offset}.bin
- dd if=$BL31 of=$of bs=1 skip=$offset count=$filesz
- out_string="${out_string}:${phy_offset}"
- cat << __ATF1_EOF
atf@$atf_cnt {
type = "firmware";
arch = "arm64";
+__ATF1_EOF
- if [ "$atf_cnt" -eq 1 ]; then
cat << __ATF2_EOF
+__ATF2_EOF
fi
- cat << __ATF3_EOF
+__ATF3_EOF
- atf_cnt=$((atf_cnt + 1))
+done
- cat << __FDT_IMAGE_EOF
fdt@$cnt {
type = "flat_dt";
+__FDT_IMAGE_EOF
- cnt=$((cnt+1))
+done
- configurations {
+__CONF_HEADER_EOF
- cat << __CONF_SECTION_EOF
config@$cnt {
fdt = "fdt@1";
+__CONF_SECTION_EOF
- cnt=$((cnt+1))
+done
+cat << __ITS_EOF
+__ITS_EOF
1.9.1
Can you instead write this in python and put it in binman?
That is the tool which should be used to generate more complex firmware images.
Kever Yang
Mark Kettenis
Philipp Tomsich
