[U-Boot] [PATCH] net: phy: supplement support for Micrel's KSZ9031
Add function ksz9031_phy_extended_write and ksz9031_phy_extended_read
Signed-off-by: Leo Sartre lsartre@adeneo-embedded.com --- drivers/net/phy/micrel.c | 35 ++++++++++++++++++++++++++++++++++- include/micrel.h | 9 +++++++++ 2 files changed, 43 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/micrel.c b/drivers/net/phy/micrel.c index a35e915..d3b573d 100644 --- a/drivers/net/phy/micrel.c +++ b/drivers/net/phy/micrel.c @@ -63,6 +63,7 @@ static struct phy_driver KS8721_driver = { #define MIIM_KSZ90xx_PHYCTL_10 (1 << 4) #define MIIM_KSZ90xx_PHYCTL_DUPLEX (1 << 3)
+ static int ksz90xx_startup(struct phy_device *phydev) { unsigned phy_ctl; @@ -143,9 +144,43 @@ static struct phy_driver ksz9021_driver = { }; #endif
-/* +/** * KSZ9031 */ +/* PHY Registers */ +#define MII_KSZ9031_MMD_ACCES_CTRL 0x0d +#define MII_KSZ9031_MMD_REG_DATA 0x0e + +/* Accessors to extended registers*/ +int ksz9031_phy_extended_write(struct phy_device *phydev, + int devaddr, int regnum, u16 mode, u16 val) +{ + /*select register addr for mmd*/ + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_ACCES_CTRL, devaddr); + /*select register for mmd*/ + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_REG_DATA, regnum); + /*setup mode*/ + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_ACCES_CTRL, (mode | devaddr)); + /*write the value*/ + return phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_REG_DATA, val); +} + +int ksz9031_phy_extended_read(struct phy_device *phydev, int devaddr, + int regnum, u16 mode) +{ + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_ACCES_CTRL, devaddr); + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_REG_DATA, regnum); + phy_write(phydev, MDIO_DEVAD_NONE, + MII_KSZ9031_MMD_ACCES_CTRL, (devaddr | mode)); + return phy_read(phydev, MDIO_DEVAD_NONE, MII_KSZ9031_MMD_REG_DATA); +} + static struct phy_driver ksz9031_driver = { .name = "Micrel ksz9031", .uid = 0x221620, diff --git a/include/micrel.h b/include/micrel.h index 25e8a46..aa54f87 100644 --- a/include/micrel.h +++ b/include/micrel.h @@ -8,10 +8,21 @@ #define MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW 0x105 #define MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW 0x106 #define MII_KSZ9021_EXT_ANALOG_TEST 0x107 +/* Register operations */ +#define MII_KSZ9031_MOD_REG 0x0000 +/* Data operations */ +#define MII_KSZ9031_MOD_DATA_NO_POST_INC 0x4000 +#define MII_KSZ9031_MOD_DATA_POST_INC_RW 0x8000 +#define MII_KSZ9031_MOD_DATA_POST_INC_W 0xC000
struct phy_device; int ksz9021_phy_extended_write(struct phy_device *phydev, int regnum, u16 val); int ksz9021_phy_extended_read(struct phy_device *phydev, int regnum);
+int ksz9031_phy_extended_write(struct phy_device *phydev, + int devaddr, int regnum, u16 mode, + u16 val); +int ksz9031_phy_extended_read(struct phy_device *phydev, int devaddr, + int regnum, u16 mode); + #endif
On Tue, Apr 30, 2013 at 9:57 AM, SARTRE Leo lsartre@adeneo-embedded.com wrote:
Applied, Thanks. -Joe
Joe Hershberger
SARTRE Leo
