[PATCH v4 00/31] dm: Add programmatic generation of ACPI tables (part A)
This is split from the original series in an attempt to get things applied in chunks.
The first 20 or so patches here have been reviewed and the changes here incorporate those comments.
Changes in v4: - Add a new patch with some string tests - Add a new patch to convert a string to upper case - Fix indentation of unused - Calculate the padding - Put 'interrupts-extended' property on one line - Rename acpi-probed to linux,probed - Note that linux,probed is an out-of-tree feature - Move ACPI makefile line outside the ifdef CONFIG_SPL_BUILD - Add a comment about the MADT table version - Add SPCR - Update comment to include tables defined or reserved by ACPI - Separate out the log newline - Update comment in acpi_inc_align() to show the alignment - Put back cast on table_compute_checksum() - Rename list_fact() to list_fadt() - Add a comment to dump_hdr()
Changes in v3: Drop acpi,name in example - Fix indenting error mentioned by Andy Shevchenko - Fix stray #endif - Drop 'Intel' from 'Intel ACPI' - Reword commit message to drop the bit about ACPI being complicated - Compute ACPI_NAME_MAX from ACPI_NAME_LEN - Rename acpi_return_name() to acpi_copy_name() - Use strncpy() instead of strcpy() in acpi_copy_name() - Split out hid-over-i2c into its own patch - Drop mention of PRIC - Rename acpi,desc to acpi,ddn - Correct description of acpi,probed - Drop hid-descr-addr - Just add the device.txt binding file in this patch - Change the example to ELAN - Add a pointer to information about acpi,compatible - Add new patch to move acpi_s3.h to include/acpi/ - Update commit message to say that we move most of its contents - Move acpi_table.h to include/acpi - Add forward declarations for the functions - Fix file comment for acpi_table.c - Fix a few typos - Make use of BIT() - Fix DMA_ typo - Add missing error check in acpi_create_dmar() - Drop duplicate assert - Drop ASL_REVISION - Add new patch to add hexdump.h to the unit test header - Rename acpi_align_large() to acpi_align64() - Fix 'RSDP' typo - Fix 'XDST' typo - Move acpi_align_large() out of dm_test_acpi_setup_base_tables() - Beef up the comment explaining how the unaligned address is used
Changes in v2: - Don't bracket the definitions with DM_SPI - Add trailing commas to enum - Drop the other comment change since it is already applied - Drop the Chrome OS pieces - Rename the 'coreboot' console to 'U-Boot' - Move LOGC_ACPI definition to this patch - Fix definition of HID - Infer hid-over-i2c CID value - Add the hid-over-i2c binding document - Add in the acpi_table.h header file to this patch - Move the sandbox acpi_table.h header file to an earlier patch - Use #defines for MADT and MCFG version numbers - Drop two unnecessary __packed - Move __packed to after struct - Drop definition of ACPI_TABLE_CREATOR - Make _acpi_write_dev_tables() static and switch argument order - Generalise the ACPI function recursion with acpi_recurse_method()
Simon Glass (31): test: Add the beginnings of some string tests lib: Add a function to convert a string to upper case cpu: Support querying the address width spi: Add SPI mode enums tpm: cr50: Release locality on exit tpm: cr50: Add a comment for cr50_priv tpm: cr50: Use the correct GPIO binding tpm: Don't cleanup unless an error happens dm: pci: Allow disabling auto-config for a device x86: Correct wording of coreboot source code x86: apl: Move p2sb ofdata reading to the correct method pci: Adjust dm_pci_read_bar32() to return errors correctly x86: apl: Add Global NVS table header dm: core: Add basic ACPI support dts: Add a binding for hid-over-i2c acpi: Add a binding for ACPI settings in the device tree acpi: Add a simple sandbox test x86: Move acpi_s3.h to include/acpi/ x86: Move acpi_table header to main include/ directory acpi: Add an __ACPI__ preprocessor symbol acpi: Add a central location for table version numbers acpi: Add support for DMAR test: Add hexdump.h to the unit test header acpi: Add a method to write tables for a device acpi: Convert part of acpi_table to use acpi_ctx x86: Allow devices to write ACPI tables acpi: Drop code for missing XSDT from acpi_write_rsdp() acpi: Move acpi_add_table() to generic code acpi: Put table-setup code in its own function acpi: Move the xsdt pointer to acpi_ctx acpi: Add an acpi command
arch/sandbox/dts/test.dts | 8 + arch/sandbox/include/asm/acpi_table.h | 9 + arch/sandbox/include/asm/global_data.h | 1 + arch/x86/cpu/apollolake/cpu_spl.c | 2 +- arch/x86/cpu/apollolake/fsp_s.c | 2 +- arch/x86/cpu/apollolake/pmc.c | 2 +- arch/x86/cpu/baytrail/acpi.c | 6 +- arch/x86/cpu/coreboot/timestamp.c | 4 +- arch/x86/cpu/cpu.c | 4 +- arch/x86/cpu/intel_common/p2sb.c | 33 +- arch/x86/cpu/quark/acpi.c | 2 +- arch/x86/cpu/tangier/acpi.c | 4 +- arch/x86/cpu/wakeup.S | 2 +- arch/x86/dts/chromebook_coral.dts | 2 +- arch/x86/include/asm/acpi_table.h | 381 +----------- .../include/asm/arch-apollolake/global_nvs.h | 36 ++ .../x86/include/asm/arch-coreboot/timestamp.h | 4 +- arch/x86/include/asm/global_data.h | 1 + arch/x86/include/asm/intel_pinctrl_defs.h | 2 - arch/x86/lib/acpi.c | 2 +- arch/x86/lib/acpi_s3.c | 4 +- arch/x86/lib/acpi_table.c | 241 ++------ arch/x86/lib/coreboot_table.c | 2 +- arch/x86/lib/fsp/fsp_common.c | 2 +- arch/x86/lib/fsp1/fsp_common.c | 2 +- arch/x86/lib/fsp2/fsp_dram.c | 2 +- arch/x86/lib/tables.c | 2 +- arch/x86/lib/zimage.c | 2 +- cmd/Kconfig | 14 + cmd/Makefile | 1 + cmd/acpi.c | 186 ++++++ doc/device-tree-bindings/device.txt | 36 ++ .../gpio/intel,apl-gpio.txt | 2 +- .../input/hid-over-i2c.txt | 44 ++ .../interrupt-controller/intel,acpi-gpe.txt | 2 +- doc/device-tree-bindings/pci/x86-pci.txt | 23 + drivers/core/Kconfig | 9 + drivers/core/Makefile | 1 + drivers/core/acpi.c | 95 +++ drivers/cpu/cpu_sandbox.c | 1 + drivers/pci/pci-uclass.c | 11 +- drivers/pci/pci_rom.c | 4 +- drivers/power/acpi_pmc/acpi-pmc-uclass.c | 2 +- drivers/sysreset/sysreset_x86.c | 2 +- drivers/tpm/cr50_i2c.c | 24 +- drivers/tpm/tpm-uclass.c | 13 +- fs/fat/fat_write.c | 13 +- include/{ => acpi}/acpi_s3.h | 0 include/acpi/acpi_table.h | 579 ++++++++++++++++++ include/cpu.h | 2 + include/dm/acpi.h | 114 ++++ include/dm/device.h | 5 + include/dm/uclass-id.h | 1 + include/log.h | 2 + include/spi.h | 33 + include/test/suites.h | 1 + include/test/ut.h | 1 + include/vsprintf.h | 12 + lib/Makefile | 1 + lib/acpi/Makefile | 4 + lib/acpi/acpi_table.c | 259 ++++++++ lib/efi_loader/efi_acpi.c | 2 +- lib/strto.c | 8 + scripts/Makefile.lib | 4 +- test/Makefile | 1 + test/cmd_ut.c | 5 + test/dm/Makefile | 1 + test/dm/acpi.c | 317 ++++++++++ test/dm/cpu.c | 1 + test/str_ut.c | 105 ++++ 70 files changed, 2056 insertions(+), 649 deletions(-) create mode 100644 arch/sandbox/include/asm/acpi_table.h create mode 100644 arch/x86/include/asm/arch-apollolake/global_nvs.h create mode 100644 cmd/acpi.c create mode 100644 doc/device-tree-bindings/device.txt create mode 100644 doc/device-tree-bindings/input/hid-over-i2c.txt create mode 100644 drivers/core/acpi.c rename include/{ => acpi}/acpi_s3.h (100%) create mode 100644 include/acpi/acpi_table.h create mode 100644 include/dm/acpi.h create mode 100644 lib/acpi/Makefile create mode 100644 lib/acpi/acpi_table.c create mode 100644 test/dm/acpi.c create mode 100644 test/str_ut.c
There are quite a few string functions in U-Boot with no tests. Make a start by adding a test for strtoul().
include/test/suites.h | 1 + test/Makefile | 1 + test/cmd_ut.c | 5 ++++ test/str_ut.c | 68 +++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 75 insertions(+) create mode 100644 test/str_ut.c
diff --git a/include/test/suites.h b/include/test/suites.h index 0748185eaf7..6d4270fa33b 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -32,6 +32,7 @@ int do_ut_env(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); int do_ut_lib(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); int do_ut_optee(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); int do_ut_overlay(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +int do_ut_str(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]); int do_ut_time(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); int do_ut_unicode(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
diff --git a/test/Makefile b/test/Makefile index 2fe41f489c3..917e54a3fcc 100644 --- a/test/Makefile +++ b/test/Makefile @@ -8,6 +8,7 @@ obj-$(CONFIG_UNIT_TEST) += ut.o obj-$(CONFIG_SANDBOX) += command_ut.o obj-$(CONFIG_SANDBOX) += compression.o obj-$(CONFIG_SANDBOX) += print_ut.o +obj-$(CONFIG_SANDBOX) += str_ut.o obj-$(CONFIG_UT_TIME) += time_ut.o obj-$(CONFIG_UT_UNICODE) += unicode_ut.o obj-$(CONFIG_$(SPL_)LOG) += log/ diff --git a/test/cmd_ut.c b/test/cmd_ut.c index a3a9d49f7ec..b342c35e68e 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -71,6 +71,8 @@ static cmd_tbl_t cmd_ut_sub[] = { "", ""), U_BOOT_CMD_MKENT(bloblist, CONFIG_SYS_MAXARGS, 1, do_ut_bloblist, "", ""), + U_BOOT_CMD_MKENT(str, CONFIG_SYS_MAXARGS, 1, do_ut_str, + "", ""), #endif };
@@ -131,6 +133,9 @@ static char ut_help_text[] = #ifdef CONFIG_UT_OVERLAY "ut overlay [test-name]\n" #endif +#ifdef CONFIG_SANDBOX + "ut str - Basic test of string functions\n" +#endif #ifdef CONFIG_UT_TIME "ut time - Very basic test of time functions\n" #endif diff --git a/test/str_ut.c b/test/str_ut.c new file mode 100644 index 00000000000..0ce6b055792 --- /dev/null +++ b/test/str_ut.c @@ -0,0 +1,68 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 Google LLC + */ + +#include <common.h> +#include <vsprintf.h> +#include <test/suites.h> +#include <test/test.h> +#include <test/ut.h> + +/* This is large enough for any of the test strings */ +#define TEST_STR_SIZE 200 + +static const char str1[] = "I'm sorry I'm late."; +static const char str2[] = "1099abNo, don't bother apologising."; +static const char str3[] = "0xbI'm sorry you're alive."; + +/* Declare a new str test */ +#define STR_TEST(_name, _flags) UNIT_TEST(_name, _flags, str_test) + +static int run_strtoul(struct unit_test_state *uts, const char *str, int base, + ulong expect_val, int expect_endp_offset) +{ + char *endp; + ulong val; + + val = simple_strtoul(str, &endp, base); + ut_asserteq(expect_val, val); + ut_asserteq(expect_endp_offset, endp - str); + + return 0; +} + +static int str_simple_strtoul(struct unit_test_state *uts) +{ + /* Base 10 and base 16 */ + ut_assertok(run_strtoul(uts, str2, 10, 1099, 4)); + ut_assertok(run_strtoul(uts, str2, 16, 0x1099ab, 6)); + + /* Invalid string */ + ut_assertok(run_strtoul(uts, str1, 10, 0, 0)); + + /* Base 0 */ + ut_assertok(run_strtoul(uts, str1, 0, 0, 0)); + ut_assertok(run_strtoul(uts, str2, 0, 1099, 4)); + ut_assertok(run_strtoul(uts, str3, 0, 0xb, 3)); + + /* Base 2 */ + ut_assertok(run_strtoul(uts, str1, 2, 0, 0)); + ut_assertok(run_strtoul(uts, str2, 2, 2, 2)); + + /* Check endp being NULL */ + ut_asserteq(1099, simple_strtoul(str2, NULL, 0)); + + return 0; +} +STR_TEST(str_simple_strtoul, 0); + + +int do_ut_str(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + struct unit_test *tests = ll_entry_start(struct unit_test, + str_test); + const int n_ents = ll_entry_count(struct unit_test, str_test); + + return cmd_ut_category("str", "str_", tests, n_ents, argc, argv); +}
Add a helper function for this operation. Update the strtoul() tests to check upper case as well.
Update FAT writing to use this new function.
Changes in v4: - Add a new patch to convert a string to upper case
fs/fat/fat_write.c | 13 ++------- include/vsprintf.h | 12 ++++++++ lib/strto.c | 8 +++++ test/str_ut.c | 73 ++++++++++++++++++++++++++++++++++------------ 4 files changed, 77 insertions(+), 29 deletions(-)
diff --git a/fs/fat/fat_write.c b/fs/fat/fat_write.c index 4f96699e363..472c206f64c 100644 --- a/fs/fat/fat_write.c +++ b/fs/fat/fat_write.c @@ -10,6 +10,7 @@ #include <config.h> #include <fat.h> #include <malloc.h> +#include <vsprintf.h> #include <asm/byteorder.h> #include <part.h> #include <linux/ctype.h> @@ -17,16 +18,6 @@ #include <linux/math64.h> #include "fat.c"
-static void uppercase(char *str, int len) -{ - int i; - - for (i = 0; i < len; i++) { - *str = toupper(*str); - str++; - } -} - static int total_sector; static int disk_write(__u32 block, __u32 nr_blocks, void *buf) { @@ -65,7 +56,7 @@ static void set_name(dir_entry *dirent, const char *filename) return;
strcpy(s_name, filename); - uppercase(s_name, len); + str_to_upper(s_name, s_name, len);
period = strchr(s_name, '.'); if (period == NULL) { diff --git a/include/vsprintf.h b/include/vsprintf.h index 56844dd2de8..d3f1292ae4d 100644 --- a/include/vsprintf.h +++ b/include/vsprintf.h @@ -222,4 +222,16 @@ bool str2long(const char *p, ulong *num); * @hz: Value to convert */ char *strmhz(char *buf, unsigned long hz); + +/** + * str_to_upper() - Convert a string to upper case + * + * This simply uses toupper() on each character of the string. + * + * @in: String to convert (must be large enough to hold the output string) + * @out: Converting string + * @len: Number of characters to convert (-1 for all) + */ +void str_to_upper(const char *in, char *out, int len); + #endif diff --git a/lib/strto.c b/lib/strto.c index 55ff9f7437d..563892a52c0 100644 --- a/lib/strto.c +++ b/lib/strto.c @@ -163,3 +163,11 @@ long trailing_strtol(const char *str) { return trailing_strtoln(str, NULL); } + +void str_to_upper(const char *in, char *out, int len) +{ + while ((len == -1 || len-- > 0) && *in) + *out++ = toupper(*in++); + if (len && !*in) + *out = '\0'; +} diff --git a/test/str_ut.c b/test/str_ut.c index 0ce6b055792..09726b076fe 100644 --- a/test/str_ut.c +++ b/test/str_ut.c @@ -19,36 +19,73 @@ static const char str3[] = "0xbI'm sorry you're alive."; /* Declare a new str test */ #define STR_TEST(_name, _flags) UNIT_TEST(_name, _flags, str_test)
+static int str_test_upper(struct unit_test_state *uts) +{ + char out[TEST_STR_SIZE]; + + /* Make sure it adds a terminator */ + out[strlen(str1)] = 'a'; + str_to_upper(str1, out, -1); + ut_asserteq_str("I'M SORRY I'M LATE.", out); + + /* In-place operation */ + strcpy(out, str2); + str_to_upper(out, out, -1); + ut_asserteq_str("1099ABNO, DON'T BOTHER APOLOGISING.", out); + + /* Limited length */ + str_to_upper(str1, out, 7); + ut_asserteq_str("I'M SORO, DON'T BOTHER APOLOGISING.", out); + + /* In-place with limited length */ + strcpy(out, str2); + str_to_upper(out, out, 7); + ut_asserteq_str("1099ABNo, don't bother apologising.", out); + + return 0; +} +STR_TEST(str_test_upper, 0); + static int run_strtoul(struct unit_test_state *uts, const char *str, int base, - ulong expect_val, int expect_endp_offset) + ulong expect_val, int expect_endp_offset, bool upper) { + char out[TEST_STR_SIZE]; char *endp; ulong val;
- val = simple_strtoul(str, &endp, base); + strcpy(out, str); + if (upper) + str_to_upper(out, out, -1); + + val = simple_strtoul(out, &endp, base); ut_asserteq(expect_val, val); - ut_asserteq(expect_endp_offset, endp - str); + ut_asserteq(expect_endp_offset, endp - out);
return 0; }
static int str_simple_strtoul(struct unit_test_state *uts) { - /* Base 10 and base 16 */ - ut_assertok(run_strtoul(uts, str2, 10, 1099, 4)); - ut_assertok(run_strtoul(uts, str2, 16, 0x1099ab, 6)); - - /* Invalid string */ - ut_assertok(run_strtoul(uts, str1, 10, 0, 0)); - - /* Base 0 */ - ut_assertok(run_strtoul(uts, str1, 0, 0, 0)); - ut_assertok(run_strtoul(uts, str2, 0, 1099, 4)); - ut_assertok(run_strtoul(uts, str3, 0, 0xb, 3)); - - /* Base 2 */ - ut_assertok(run_strtoul(uts, str1, 2, 0, 0)); - ut_assertok(run_strtoul(uts, str2, 2, 2, 2)); + int upper; + + /* Check that it is case-insentive */ + for (upper = 0; upper < 2; upper++) { + /* Base 10 and base 16 */ + ut_assertok(run_strtoul(uts, str2, 10, 1099, 4, upper)); + ut_assertok(run_strtoul(uts, str2, 16, 0x1099ab, 6, upper)); + + /* Invalid string */ + ut_assertok(run_strtoul(uts, str1, 10, 0, 0, upper)); + + /* Base 0 */ + ut_assertok(run_strtoul(uts, str1, 0, 0, 0, upper)); + ut_assertok(run_strtoul(uts, str2, 0, 1099, 4, upper)); + ut_assertok(run_strtoul(uts, str3, 0, 0xb, 3, upper)); + + /* Base 2 */ + ut_assertok(run_strtoul(uts, str1, 2, 0, 0, upper)); + ut_assertok(run_strtoul(uts, str2, 2, 2, 2, upper)); + }
/* Check endp being NULL */ ut_asserteq(1099, simple_strtoul(str2, NULL, 0));
Am April 8, 2020 3:00:38 AM UTC schrieb Simon Glass sjg@chromium.org:
Changes in v4:
- int i;
str++;
- @hz: Value to convert
- str_to_upper() - Convert a string to upper case
- This simply uses toupper() on each character of the string.
- @in: String to convert (must be large enough to hold the output
string)
- @out: Converting string
- @len: Number of characters to convert (-1 for all)
Wouldn't we prefer size_t like in other string functions for len?
- while ((len == -1 || len-- > 0) && *in)
Why a special logic for -1? Just use SIZE_MAX when calling the function.
- if (len && !*in)
*out = '\0';
We shouldn't check len and *in twice in the loop.
Please, add a test for
str_to_upper("", SIZE_MAX) which your code is handling incorrectly. - You miss copying 0x00 here.
Best regards
Heinrich
- char out[TEST_STR_SIZE];
- /* Make sure it adds a terminator */
- out[strlen(str1)] = 'a';
- str_to_upper(str1, out, -1);
- ut_asserteq_str("I'M SORRY I'M LATE.", out);
- /* In-place operation */
- strcpy(out, str2);
- str_to_upper(out, out, -1);
- ut_asserteq_str("1099ABNO, DON'T BOTHER APOLOGISING.", out);
- /* Limited length */
- str_to_upper(str1, out, 7);
- ut_asserteq_str("I'M SORO, DON'T BOTHER APOLOGISING.", out);
- /* In-place with limited length */
- str_to_upper(out, out, 7);
- ut_asserteq_str("1099ABNo, don't bother apologising.", out);
- char out[TEST_STR_SIZE]; char *endp; ulong val;
- strcpy(out, str);
- if (upper)
- val = simple_strtoul(out, &endp, base); ut_asserteq(expect_val, val);
- /* Base 0 */
- /* Base 2 */
int upper;
/* Base 0 */
/* Base 2 */
Am April 8, 2020 4:18:12 AM UTC schrieb Heinrich Schuchardt xypron.glpk@gmx.de:
to
Changes in v4:
- int i;
str++;
We should not use toupper() here. We have to consider the FAT charset defined by CONFIG_FAT_DEFAULT_CODEPAGE.
Best regards
Heinrich
string)
- if (len && !*in)
*out = '\0';
Best regards
Heinrich
- strcpy(out, str);
- if (upper)
- /* Base 0 */
- /* Base 2 */
int upper;
/* Base 0 */
/* Base 2 */
Hi Heinrich,
to
Changes in v4:
int i;
str++;
It seems to match the existing code. Is there a pending patch somewhere for changing it?
Am April 8, 2020 2:20:47 PM UTC schrieb Simon Glass sjg@chromium.org:
Hi Heinrich,
tests
to
Changes in v4:
int i;
str++;
This is an open TODO. We have capitalization.h which contains the relevant codepoints, e.g. in CP437_CAPITALIZATION_TABLE.
Best regards
Heinrich
Different CPUs may support different address widths, meaning the amount of memory they can address. Add a property for this to the cpu_info struct.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v4: None Changes in v3: None Changes in v2: None
drivers/cpu/cpu_sandbox.c | 1 + include/cpu.h | 2 ++ test/dm/cpu.c | 1 + 3 files changed, 4 insertions(+)
diff --git a/drivers/cpu/cpu_sandbox.c b/drivers/cpu/cpu_sandbox.c index ff87e8adca3..05b384f6a45 100644 --- a/drivers/cpu/cpu_sandbox.c +++ b/drivers/cpu/cpu_sandbox.c @@ -19,6 +19,7 @@ int cpu_sandbox_get_info(struct udevice *dev, struct cpu_info *info) { info->cpu_freq = 42 * 42 * 42 * 42 * 42; info->features = 0x42424242; + info->address_width = IS_ENABLED(CONFIG_PHYS_64BIT) ? 64 : 32;
return 0; } diff --git a/include/cpu.h b/include/cpu.h index 28dd48feb8f..6b1b6b37b3b 100644 --- a/include/cpu.h +++ b/include/cpu.h @@ -44,10 +44,12 @@ enum { * * @cpu_freq: Current CPU frequency in Hz * @features: Flags for supported CPU features + * @address_width: Width of the CPU address space in bits (e.g. 32) */ struct cpu_info { ulong cpu_freq; ulong features; + uint address_width; };
struct cpu_ops { diff --git a/test/dm/cpu.c b/test/dm/cpu.c index f5f1caef716..e6dc576ea3c 100644 --- a/test/dm/cpu.c +++ b/test/dm/cpu.c @@ -33,6 +33,7 @@ static int dm_test_cpu(struct unit_test_state *uts) ut_assertok(cpu_get_info(dev, &info)); ut_asserteq(info.cpu_freq, 42 * 42 * 42 * 42 * 42); ut_asserteq(info.features, 0x42424242); + ut_asserteq(info.address_width, 32);
ut_asserteq(cpu_get_count(dev), 42);
With ACPI we need to describe the settings of the SPI bus. Add enums to handle this.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com ---
Changes in v4: None Changes in v3: None Changes in v2: - Don't bracket the definitions with DM_SPI - Add trailing commas to enum
include/spi.h | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/include/spi.h b/include/spi.h index 852f570eaa8..2b4929fc79d 100644 --- a/include/spi.h +++ b/include/spi.h @@ -66,6 +66,39 @@ struct dm_spi_slave_platdata {
#endif /* CONFIG_DM_SPI */
+/** + * enum spi_clock_phase - indicates the clock phase to use for SPI (CPHA) + * + * @SPI_CLOCK_PHASE_FIRST: Data sampled on the first phase + * @SPI_CLOCK_PHASE_SECOND: Data sampled on the second phase + */ +enum spi_clock_phase { + SPI_CLOCK_PHASE_FIRST, + SPI_CLOCK_PHASE_SECOND, +}; + +/** + * enum spi_wire_mode - indicates the number of wires used for SPI + * + * @SPI_4_WIRE_MODE: Normal bidirectional mode with MOSI and MISO + * @SPI_3_WIRE_MODE: Unidirectional version with a single data line SISO + */ +enum spi_wire_mode { + SPI_4_WIRE_MODE, + SPI_3_WIRE_MODE, +}; + +/** + * enum spi_polarity - indicates the polarity of the SPI bus (CPOL) + * + * @SPI_POLARITY_LOW: Clock is low in idle state + * @SPI_POLARITY_HIGH: Clock is high in idle state + */ +enum spi_polarity { + SPI_POLARITY_LOW, + SPI_POLARITY_HIGH, +}; + /** * struct spi_slave - Representation of a SPI slave *
At present the cr50 driver claims the locality and does not release it for Linux. This causes problems. Fix this by tracking what is claimed, and adding a 'remove' method.
drivers/tpm/cr50_i2c.c | 13 +++++++++++-- 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/drivers/tpm/cr50_i2c.c b/drivers/tpm/cr50_i2c.c index b904a7d426e..b30f55b40d3 100644 --- a/drivers/tpm/cr50_i2c.c +++ b/drivers/tpm/cr50_i2c.c @@ -206,7 +206,7 @@ static int release_locality(struct udevice *dev, int force) cr50_i2c_write(dev, addr, &buf, 1); }
- priv->locality = 0; + priv->locality = -1;
return 0; } @@ -499,6 +499,7 @@ static int process_reset(struct udevice *dev) static int claim_locality(struct udevice *dev, int loc) { const u8 mask = TPM_ACCESS_VALID | TPM_ACCESS_ACTIVE_LOCALITY; + struct cr50_priv *priv = dev_get_priv(dev); u8 access; int ret;
@@ -525,6 +526,7 @@ static int claim_locality(struct udevice *dev, int loc) return -EPERM; } log_info("Claimed locality %d\n", loc); + priv->locality = loc;
return 0; } @@ -559,7 +561,11 @@ static int cr50_i2c_open(struct udevice *dev)
static int cr50_i2c_cleanup(struct udevice *dev) { - release_locality(dev, 1); + struct cr50_priv *priv = dev_get_priv(dev); + + printf("%s: cleanup %d\n", __func__, priv->locality); + if (priv->locality != -1) + release_locality(dev, 1);
return 0; } @@ -631,6 +637,7 @@ static int cr50_i2c_probe(struct udevice *dev) return log_msg_ret("vendor-id", -EXDEV); } priv->vendor = vendor; + priv->locality = -1;
return 0; } @@ -655,5 +662,7 @@ U_BOOT_DRIVER(cr50_i2c) = { .ops = &cr50_i2c_ops, .ofdata_to_platdata = cr50_i2c_ofdata_to_platdata, .probe = cr50_i2c_probe, + .remove = cr50_i2c_cleanup, .priv_auto_alloc_size = sizeof(struct cr50_priv), + .flags = DM_FLAG_OS_PREPARE, };
Add a comment for the private structure
Changes in v4: None Changes in v3: None Changes in v2: - Drop the other comment change since it is already applied
drivers/tpm/cr50_i2c.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/tpm/cr50_i2c.c b/drivers/tpm/cr50_i2c.c index b30f55b40d3..c1d2d2fa381 100644 --- a/drivers/tpm/cr50_i2c.c +++ b/drivers/tpm/cr50_i2c.c @@ -34,6 +34,15 @@ enum { CR50_MAX_BUF_SIZE = 63, };
+/** + * struct cr50_priv - Private driver data + * + * @ready_gpio: GPIO to use to check if the TPM is ready + * @irq: IRQ to use check if the TPM is ready (has priority over @ready_gpio) + * @locality: Currenttly claimed locality (-1 if none) + * @vendor: vendor: Vendor ID for TPM + * @use_irq: true to use @irq, false to use @ready if available + */ struct cr50_priv { struct gpio_desc ready_gpio; struct irq irq;
This device should use ready-gpios rather than ready-gpio. Fix it.
arch/x86/dts/chromebook_coral.dts | 2 +- doc/device-tree-bindings/gpio/intel,apl-gpio.txt | 2 +- .../interrupt-controller/intel,acpi-gpe.txt | 2 +- drivers/tpm/cr50_i2c.c | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index af52e11c89a..d48ef3573ec 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -292,7 +292,7 @@ reg = <0x50>; compatible = "google,cr50"; u-boot,i2c-offset-len = <0>; - ready-gpio = <&gpio_n 28 GPIO_ACTIVE_LOW>; + ready-gpios = <&gpio_n 28 GPIO_ACTIVE_LOW>; interrupts-extended = <&acpi_gpe 0x3c 0>; }; }; diff --git a/doc/device-tree-bindings/gpio/intel,apl-gpio.txt b/doc/device-tree-bindings/gpio/intel,apl-gpio.txt index cf0659b70ec..8422ff63abd 100644 --- a/doc/device-tree-bindings/gpio/intel,apl-gpio.txt +++ b/doc/device-tree-bindings/gpio/intel,apl-gpio.txt @@ -47,7 +47,7 @@ Example: reg = <0x50>; compatible = "google,cr50"; u-boot,i2c-offset-len = <0>; - ready-gpio = <&gpio_n GPIO_28 GPIO_ACTIVE_LOW>; + ready-gpios = <&gpio_n GPIO_28 GPIO_ACTIVE_LOW>; }; };
diff --git a/doc/device-tree-bindings/interrupt-controller/intel,acpi-gpe.txt b/doc/device-tree-bindings/interrupt-controller/intel,acpi-gpe.txt index d9252bf29f7..2fe02d8a227 100644 --- a/doc/device-tree-bindings/interrupt-controller/intel,acpi-gpe.txt +++ b/doc/device-tree-bindings/interrupt-controller/intel,acpi-gpe.txt @@ -25,6 +25,6 @@ Example: tpm@50 { reg = <0x50>; compatible = "google,cr50"; - ready-gpio = <&gpio_n 0x1c GPIO_ACTIVE_LOW>; + ready-gpios = <&gpio_n 0x1c GPIO_ACTIVE_LOW>; interrupts-extended = <&acpi_gpe 0x3c 0>; }; diff --git a/drivers/tpm/cr50_i2c.c b/drivers/tpm/cr50_i2c.c index c1d2d2fa381..b67051af26a 100644 --- a/drivers/tpm/cr50_i2c.c +++ b/drivers/tpm/cr50_i2c.c @@ -607,7 +607,7 @@ static int cr50_i2c_ofdata_to_platdata(struct udevice *dev) priv->irq = irq; priv->use_irq = true; } else { - ret = gpio_request_by_name(dev, "ready-gpio", 0, + ret = gpio_request_by_name(dev, "ready-gpios", 0, &priv->ready_gpio, GPIOD_IS_IN); if (ret) { log_warning("Cr50 does not have an ready GPIO/interrupt (err=%d)\n",
At present the cleanup() method is called on every transfer. It should only be called on failing transfers. Fix this and tidy up the error handling a little.
drivers/tpm/tpm-uclass.c | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c index 1b11c93194d..71d58070062 100644 --- a/drivers/tpm/tpm-uclass.c +++ b/drivers/tpm/tpm-uclass.c @@ -72,7 +72,7 @@ int tpm_xfer(struct udevice *dev, const uint8_t *sendbuf, size_t send_size, struct tpm_ops *ops = tpm_get_ops(dev); ulong start, stop; uint count, ordinal; - int ret, ret2; + int ret, ret2 = 0;
if (ops->xfer) return ops->xfer(dev, sendbuf, send_size, recvbuf, recv_size); @@ -120,9 +120,16 @@ int tpm_xfer(struct udevice *dev, const uint8_t *sendbuf, size_t send_size, } } while (ret);
- ret2 = ops->cleanup ? ops->cleanup(dev) : 0; + if (ret) { + if (ops->cleanup) { + ret2 = ops->cleanup(dev); + if (ret2) + return log_msg_ret("cleanup", ret2); + } + return log_msg_ret("xfer", ret); + }
- return ret2 ? ret2 : ret; + return 0; }
UCLASS_DRIVER(tpm) = {
Add a means to avoid configuring a device when needed. Add an explanation of why this is useful to the binding file.
Changes in v4: None Changes in v3: Drop acpi,name in example
Changes in v2: None
doc/device-tree-bindings/pci/x86-pci.txt | 23 +++++++++++++++++++++++ drivers/pci/pci-uclass.c | 2 ++ 2 files changed, 25 insertions(+)
diff --git a/doc/device-tree-bindings/pci/x86-pci.txt b/doc/device-tree-bindings/pci/x86-pci.txt index 3aa5bd9a46c..95e370b3e72 100644 --- a/doc/device-tree-bindings/pci/x86-pci.txt +++ b/doc/device-tree-bindings/pci/x86-pci.txt @@ -10,6 +10,17 @@ Optional properties: configuration in TPL/SPL to reduce code size and boot time, since these phases only know about a small subset of PCI devices.
+For PCI devices the following optional property is available: + +- pci,no-autoconfig : Don't automatically configure this PCI device at all. + This is used when the device is statically configured and must maintain + this same config throughout the boot process. An example is a serial + UART being used to debug PCI configuration, since reconfiguring it stops + the UART from working until the driver is re-probed, and this can cause + output to be lost. This should not generally be used in production code, + although it is often harmless. + + Example:
pci { @@ -21,4 +32,16 @@ pci { 0x42000000 0x0 0xb0000000 0xb0000000 0 0x10000000 0x01000000 0x0 0x1000 0x1000 0 0xefff>; u-boot,skip-auto-config-until-reloc; + + + serial: serial@18,2 { + reg = <0x0200c210 0 0 0 0>; + u-boot,dm-pre-reloc; + compatible = "intel,apl-ns16550"; + early-regs = <0xde000000 0x20>; + reg-shift = <2>; + clock-frequency = <1843200>; + current-speed = <115200>; + pci,no-autoconfig; + }; }; diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index e2882e3b634..ceb64517047 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -536,6 +536,8 @@ int pci_auto_config_devices(struct udevice *bus) int ret;
debug("%s: device %s\n", __func__, dev->name); + if (dev_read_bool(dev, "pci,no-autoconfig")) + continue; ret = dm_pciauto_config_device(dev); if (ret < 0) return ret;
Some files are taken or modified from coreboot, but the files are no-longer part of the coreboot project. Fix the wording in a few places.
arch/x86/cpu/coreboot/timestamp.c | 4 ++-- arch/x86/include/asm/arch-coreboot/timestamp.h | 4 ++-- arch/x86/include/asm/intel_pinctrl_defs.h | 2 -- 3 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/arch/x86/cpu/coreboot/timestamp.c b/arch/x86/cpu/coreboot/timestamp.c index e698200d704..e8ccaf22129 100644 --- a/arch/x86/cpu/coreboot/timestamp.c +++ b/arch/x86/cpu/coreboot/timestamp.c @@ -1,8 +1,8 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * This file is part of the coreboot project. - * * Copyright (C) 2011 The ChromiumOS Authors. All rights reserved. + * + * Modified from the coreboot version */
#include <common.h> diff --git a/arch/x86/include/asm/arch-coreboot/timestamp.h b/arch/x86/include/asm/arch-coreboot/timestamp.h index 9320afba561..85d42c02c46 100644 --- a/arch/x86/include/asm/arch-coreboot/timestamp.h +++ b/arch/x86/include/asm/arch-coreboot/timestamp.h @@ -1,8 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * This file is part of the coreboot project. - * * Copyright (C) 2011 The ChromiumOS Authors. All rights reserved. + * + * Taken from the coreboot version */
#ifndef __COREBOOT_TIMESTAMP_H__ diff --git a/arch/x86/include/asm/intel_pinctrl_defs.h b/arch/x86/include/asm/intel_pinctrl_defs.h index 6da06bb52b4..1ea141f082f 100644 --- a/arch/x86/include/asm/intel_pinctrl_defs.h +++ b/arch/x86/include/asm/intel_pinctrl_defs.h @@ -1,7 +1,5 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * This file is part of the coreboot project. - * * Copyright (C) 2015-2016 Intel Corp. * Copyright 2019 Google LLC *
With P2SB the initial BAR (base-address register) is set up by TPL and this is used unchanged right through U-Boot.
At present the reading of this address is split between the ofdata() and probe() methods. There are a few problems that are unique to the p2sb. One is that its children need to call pcr_read32(), etc. which needs to have the p2sb address correct. Also some of its children are pinctrl devices and pinctrl is used when any device is probed. So p2sb really needs to get its base address set up in ofdata_to_platdata(), before it is probed.
Another point is that reading the p2sb BAR will not work if the p2sb is hidden. The FSP-S seems to hide it, presumably to avoid confusing PCI enumeration.
Reading ofdata in ofdata_to_platdata() is the correct place anyway, so this is easy to fix.
Move the code into one place and use the early-regs property in all cases for simplicity and to avoid needing to probe any PCI devices just to read the BAR.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com Tested-by: Wolfgang Wallner wolfgang.wallner@br-automation.com ---
Changes in v4: None Changes in v3: - Fix indenting error mentioned by Andy Shevchenko
Changes in v2: None
arch/x86/cpu/intel_common/p2sb.c | 33 +++++++++++--------------------- 1 file changed, 11 insertions(+), 22 deletions(-)
diff --git a/arch/x86/cpu/intel_common/p2sb.c b/arch/x86/cpu/intel_common/p2sb.c index d5b4846e0a2..6f3c4416186 100644 --- a/arch/x86/cpu/intel_common/p2sb.c +++ b/arch/x86/cpu/intel_common/p2sb.c @@ -92,46 +92,35 @@ int p2sb_ofdata_to_platdata(struct udevice *dev)
#if !CONFIG_IS_ENABLED(OF_PLATDATA) int ret; + u32 base[2];
+ ret = dev_read_u32_array(dev, "early-regs", base, ARRAY_SIZE(base)); + if (ret) + return log_msg_ret("Missing/short early-regs", ret); + plat->mmio_base = base[0]; + /* TPL sets up the initial BAR */ if (spl_phase() == PHASE_TPL) { - u32 base[2]; - - /* TPL sets up the initial BAR */ - ret = dev_read_u32_array(dev, "early-regs", base, - ARRAY_SIZE(base)); - if (ret) - return log_msg_ret("Missing/short early-regs", ret); - plat->mmio_base = base[0]; plat->bdf = pci_get_devfn(dev); if (plat->bdf < 0) return log_msg_ret("Cannot get p2sb PCI address", plat->bdf); } + upriv->mmio_base = plat->mmio_base; #else plat->mmio_base = plat->dtplat.early_regs[0]; plat->bdf = pci_ofplat_get_devfn(plat->dtplat.reg[0]); -#endif upriv->mmio_base = plat->mmio_base; - debug("p2sb: mmio_base=%x\n", (uint)plat->mmio_base); +#endif
return 0; }
static int p2sb_probe(struct udevice *dev) { - if (spl_phase() == PHASE_TPL) { + if (spl_phase() == PHASE_TPL) return p2sb_early_init(dev); - } else { - struct p2sb_platdata *plat = dev_get_platdata(dev); - - plat->mmio_base = dev_read_addr_pci(dev); - /* Don't set BDF since it should not be used */ - if (!plat->mmio_base || plat->mmio_base == FDT_ADDR_T_NONE) - return -EINVAL; - - if (spl_phase() == PHASE_SPL) - return p2sb_spl_init(dev); - } + else if (spl_phase() == PHASE_SPL) + return p2sb_spl_init(dev);
return 0; }
At present if reading a BAR returns 0xffffffff (e.g. the device is not present) then the value is masked and a different value is returned. This makes it harder to detect the problem when debugging.
Update the function to avoid masking in this case.
drivers/pci/pci-uclass.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index ceb64517047..d2e10d6868a 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -1213,7 +1213,14 @@ u32 dm_pci_read_bar32(const struct udevice *dev, int barnum)
bar = PCI_BASE_ADDRESS_0 + barnum * 4; dm_pci_read_config32(dev, bar, &addr); - if (addr & PCI_BASE_ADDRESS_SPACE_IO) + + /* + * If we get an invalid address, return this so that comparisons with + * FDT_ADDR_T_NONE work correctly + */ + if (addr == 0xffffffff) + return addr; + else if (addr & PCI_BASE_ADDRESS_SPACE_IO) return addr & PCI_BASE_ADDRESS_IO_MASK; else return addr & PCI_BASE_ADDRESS_MEM_MASK;
Add the C version of this header. It includes a few Chrome OS bits which are disabled for a normal build.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Wolfgang Wallner wolgang.wallner@br-automation.com ---
Changes in v4: - Fix indentation of unused - Calculate the padding
Changes in v3: - Fix stray #endif
Changes in v2: - Drop the Chrome OS pieces - Rename the 'coreboot' console to 'U-Boot'
.../include/asm/arch-apollolake/global_nvs.h | 36 +++++++++++++++++++ 1 file changed, 36 insertions(+) create mode 100644 arch/x86/include/asm/arch-apollolake/global_nvs.h
diff --git a/arch/x86/include/asm/arch-apollolake/global_nvs.h b/arch/x86/include/asm/arch-apollolake/global_nvs.h new file mode 100644 index 00000000000..9351a008f2f --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/global_nvs.h @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2015-2017 Intel Corp. + * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + * Copyright Google LLC 2019 + * + * Modified from coreboot apollolake/include/soc/nvs.h + */ + +#ifndef _GLOBAL_NVS_H_ +#define _GLOBAL_NVS_H_ + +struct __packed acpi_global_nvs { + /* Miscellaneous */ + u8 pcnt; /* 0x00 - Processor Count */ + u8 ppcm; /* 0x01 - Max PPC State */ + u8 lids; /* 0x02 - LID State */ + u8 pwrs; /* 0x03 - AC Power State */ + u8 dpte; /* 0x04 - Enable DPTF */ + u32 cbmc; /* 0x05 - 0x08 - U-Boot Console */ + u64 pm1i; /* 0x09 - 0x10 - System Wake Source - PM1 Index */ + u64 gpei; /* 0x11 - 0x18 - GPE Wake Source */ + u64 nhla; /* 0x19 - 0x20 - NHLT Address */ + u32 nhll; /* 0x21 - 0x24 - NHLT Length */ + u32 prt0; /* 0x25 - 0x28 - PERST_0 Address */ + u8 scdp; /* 0x29 - SD_CD GPIO portid */ + u8 scdo; /* 0x2a - GPIO pad offset relative to the community */ + u8 uior; /* 0x2b - UART debug controller init on S3 resume */ + u8 ecps; /* 0x2c - SGX Enabled status */ + u64 emna; /* 0x2d - 0x34 EPC base address */ + u64 elng; /* 0x35 - 0x3c EPC Length */ + u8 unused[0x100 - 0x3d]; /* Pad out to 0x100 */ + u8 unused2[0x1000 - 0x100]; /* Pad out to 4KB */ +}; + +#endif /* _GLOBAL_NVS_H_ */
- u8 unused[0x100 - 0x3d]; /* Pad out to 0x100 */
- u8 unused2[0x1000 - 0x100]; /* Pad out to 4KB */
Inconsistent size representation in the comment: 256 bytes, 4096 bytes? Also I would rather name unused1 and unused2.
ACPI (Advanced Configuration and Power Interface) is a standard for specifying information about a platform. It is a little like device tree but the bindings are part of the specification and it supports an interpreted bytecode language.
Driver model does not use ACPI for U-Boot's configuration, but it is convenient to have it support generation of ACPI tables for passing to Linux, etc.
As a starting point, add an optional set of ACPI operations to each device. Initially only a single operation is available, to obtain the ACPI name for the device. More operations are added later.
Enable ACPI for sandbox to ensure build coverage and so that we can add tests.
Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v4: None Changes in v3: - Drop 'Intel' from 'Intel ACPI' - Reword commit message to drop the bit about ACPI being complicated - Compute ACPI_NAME_MAX from ACPI_NAME_LEN - Rename acpi_return_name() to acpi_copy_name() - Use strncpy() instead of strcpy() in acpi_copy_name()
Changes in v2: - Move LOGC_ACPI definition to this patch
drivers/core/Kconfig | 9 ++++++ drivers/core/Makefile | 1 + drivers/core/acpi.c | 33 +++++++++++++++++++ include/dm/acpi.h | 73 +++++++++++++++++++++++++++++++++++++++++++ include/dm/device.h | 5 +++ include/log.h | 2 ++ 6 files changed, 123 insertions(+) create mode 100644 drivers/core/acpi.c create mode 100644 include/dm/acpi.h
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 3b95b5387b9..a3b03993423 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -261,4 +261,13 @@ config DM_DEV_READ_INLINE bool default y if !OF_LIVE
+config ACPIGEN + bool "Support ACPI table generation in driver model" + default y if SANDBOX || GENERATE_ACPI_TABLE + help + This option enables generation of ACPI tables using driver-model + devices. It adds a new operation struct to each driver, to support + things like generating device-specific tables and returning the ACPI + name of a device. + endmenu diff --git a/drivers/core/Makefile b/drivers/core/Makefile index bce7467da1d..c707026a3a0 100644 --- a/drivers/core/Makefile +++ b/drivers/core/Makefile @@ -3,6 +3,7 @@ # Copyright (c) 2013 Google, Inc
obj-y += device.o fdtaddr.o lists.o root.o uclass.o util.o +obj-$(CONFIG_$(SPL_TPL_)ACPIGEN) += acpi.o obj-$(CONFIG_DEVRES) += devres.o obj-$(CONFIG_$(SPL_)DM_DEVICE_REMOVE) += device-remove.o obj-$(CONFIG_$(SPL_)SIMPLE_BUS) += simple-bus.o diff --git a/drivers/core/acpi.c b/drivers/core/acpi.c new file mode 100644 index 00000000000..0e64c21bf5b --- /dev/null +++ b/drivers/core/acpi.c @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Core driver model support for ACPI table generation + * + * Copyright 2019 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#define LOG_CATEOGRY LOGC_ACPI + +#include <common.h> +#include <dm.h> +#include <dm/acpi.h> +#include <dm/root.h> + +int acpi_copy_name(char *out_name, const char *name) +{ + strncpy(out_name, name, ACPI_NAME_MAX); + out_name[ACPI_NAME_LEN] = '\0'; + + return 0; +} + +int acpi_get_name(const struct udevice *dev, char *out_name) +{ + struct acpi_ops *aops; + + aops = device_get_acpi_ops(dev); + if (aops && aops->get_name) + return aops->get_name(dev, out_name); + + return -ENOSYS; +} diff --git a/include/dm/acpi.h b/include/dm/acpi.h new file mode 100644 index 00000000000..c13d0c8448a --- /dev/null +++ b/include/dm/acpi.h @@ -0,0 +1,73 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Core ACPI (Advanced Configuration and Power Interface) support + * + * Copyright 2019 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#ifndef __DM_ACPI_H__ +#define __DM_ACPI_H__ + +/* Allow operations to be optional for ACPI */ +#if CONFIG_IS_ENABLED(ACPIGEN) +#define acpi_ops_ptr(_ptr) .acpi_ops = _ptr, +#else +#define acpi_ops_ptr(_ptr) +#endif + +/* Length of an ACPI name string, excluding nul terminator */ +#define ACPI_NAME_LEN 4 + +/* Length of an ACPI name string including nul terminator */ +#define ACPI_NAME_MAX (ACPI_NAME_LEN + 1) + +/** + * struct acpi_ops - ACPI operations supported by driver model + */ +struct acpi_ops { + /** + * get_name() - Obtain the ACPI name of a device + * + * @dev: Device to check + * @out_name: Place to put the name, must hold at least ACPI_NAME_MAX + * bytes + * @return 0 if OK, -ENOENT if no name is available, other -ve value on + * other error + */ + int (*get_name)(const struct udevice *dev, char *out_name); +}; + +#define device_get_acpi_ops(dev) ((dev)->driver->acpi_ops) + +/** + * acpi_get_name() - Obtain the ACPI name of a device + * + * @dev: Device to check + * @out_name: Place to put the name, must hold at least ACPI_NAME_MAX + * bytes + * @return 0 if OK, -ENOENT if no name is available, other -ve value on + * other error + */ +int acpi_get_name(const struct udevice *dev, char *out_name); + +/** + * acpi_copy_name() - Copy an ACPI name to an output buffer + * + * This convenience function can be used to return a literal string as a name + * in functions that implement the get_name() method. + * + * For example: + * + * static int mydev_get_name(const struct udevice *dev, char *out_name) + * { + * return acpi_copy_name(out_name, "WIBB"); + * } + * + * @out_name: Place to put the name + * @name: Name to copy + * @return 0 (always) + */ +int acpi_copy_name(char *out_name, const char *name); + +#endif diff --git a/include/dm/device.h b/include/dm/device.h index a56164b19bb..35e19d87005 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -245,6 +245,8 @@ struct udevice_id { * pointers defined by the driver, to implement driver functions required by * the uclass. * @flags: driver flags - see DM_FLAGS_... + * @acpi_ops: Advanced Configuration and Power Interface (ACPI) operations, + * allowing the device to add things to the ACPI tables passed to Linux */ struct driver { char *name; @@ -264,6 +266,9 @@ struct driver { int per_child_platdata_auto_alloc_size; const void *ops; /* driver-specific operations */ uint32_t flags; +#if CONFIG_IS_ENABLED(ACPIGEN) + struct acpi_ops *acpi_ops; +#endif };
/* Declare a new U-Boot driver */ diff --git a/include/log.h b/include/log.h index 62fb8afbd0e..fbcbd42fb4b 100644 --- a/include/log.h +++ b/include/log.h @@ -51,6 +51,8 @@ enum log_category_t { LOGC_SANDBOX, /* Related to the sandbox board */ LOGC_BLOBLIST, /* Bloblist */ LOGC_DEVRES, /* Device resources (devres_... functions) */ + /* Advanced Configuration and Power Interface (ACPI) */ + LOGC_ACPI,
LOGC_COUNT, /* Number of log categories */ LOGC_END, /* Sentinel value for a list of log categories */
Add this binding from Linux v5.4.
Changes in v4: None Changes in v3: - Split out hid-over-i2c into its own patch
Changes in v2: None
.../input/hid-over-i2c.txt | 44 +++++++++++++++++++ 1 file changed, 44 insertions(+) create mode 100644 doc/device-tree-bindings/input/hid-over-i2c.txt
diff --git a/doc/device-tree-bindings/input/hid-over-i2c.txt b/doc/device-tree-bindings/input/hid-over-i2c.txt new file mode 100644 index 00000000000..c76bafaf98d --- /dev/null +++ b/doc/device-tree-bindings/input/hid-over-i2c.txt @@ -0,0 +1,44 @@ +* HID over I2C Device-Tree bindings + +HID over I2C provides support for various Human Interface Devices over the +I2C bus. These devices can be for example touchpads, keyboards, touch screens +or sensors. + +The specification has been written by Microsoft and is currently available here: +http://msdn.microsoft.com/en-us/library/windows/hardware/hh852380.aspx + +If this binding is used, the kernel module i2c-hid will handle the communication +with the device and the generic hid core layer will handle the protocol. + +Required properties: +- compatible: must be "hid-over-i2c" +- reg: i2c slave address +- hid-descr-addr: HID descriptor address +- interrupts: interrupt line + +Additional optional properties: + +Some devices may support additional optional properties to help with, e.g., +power sequencing. The following properties can be supported by one or more +device-specific compatible properties, which should be used in addition to the +"hid-over-i2c" string. + +- compatible: + * "wacom,w9013" (Wacom W9013 digitizer). Supports: + - vdd-supply (3.3V) + - vddl-supply (1.8V) + - post-power-on-delay-ms + +- vdd-supply: phandle of the regulator that provides the supply voltage. +- post-power-on-delay-ms: time required by the device after enabling its regulators + or powering it on, before it is ready for communication. + +Example: + + i2c-hid-dev@2c { + compatible = "hid-over-i2c"; + reg = <0x2c>; + hid-descr-addr = <0x0020>; + interrupt-parent = <&gpx3>; + interrupts = <3 2>; + };
Devices need to report various identifiers in the ACPI tables. Rather than hard-coding these in drivers it is typically better to put them in the device tree.
Add a binding file to describe this.
Changes in v4: - Put 'interrupts-extended' property on one line - Rename acpi-probed to linux,probed - Note that linux,probed is an out-of-tree feature
Changes in v3: - Drop mention of PRIC - Rename acpi,desc to acpi,ddn - Correct description of acpi,probed - Drop hid-descr-addr - Just add the device.txt binding file in this patch - Change the example to ELAN - Add a pointer to information about acpi,compatible
Changes in v2: - Fix definition of HID - Infer hid-over-i2c CID value - Add the hid-over-i2c binding document
doc/device-tree-bindings/device.txt | 36 +++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+) create mode 100644 doc/device-tree-bindings/device.txt
diff --git a/doc/device-tree-bindings/device.txt b/doc/device-tree-bindings/device.txt new file mode 100644 index 00000000000..27bd3978d98 --- /dev/null +++ b/doc/device-tree-bindings/device.txt @@ -0,0 +1,36 @@ +Devices +======= + +Device bindings are described by their own individual binding files. + +U-Boot provides for some optional properties which are documented here. See +also hid-over-i2c.txt which describes HID devices. See also +Documentation/firmware-guide/acpi/enumeration.rst in the Linux kernel for +the acpi,compatible property. + + - acpi,has-power-resource : (boolean) true if this device has a power resource. + This causes an ACPI PowerResource to be written containing the properties + provided by this binding, to describe how to handle powering the device up + and down using GPIOs + - acpi,compatible : compatible string to report + - acpi,ddn : Contains the string to use as the _DDN (DOS (Disk Operating + System) Device Name) + - acpi,hid : Contains the string to use as the HID (Hardware ID) + identifier _HID + - acpi,uid : _UID value for device + - linux,probed : Tells U-Boot to add 'linux,probed' to the ACPI tables so that + Linux will only load the driver if the device can be detected (e.g. on I2C + bus). Note that this is an out-of-tree Linux feature. + + +Example +------- + +elan_touchscreen: elan-touchscreen@10 { + compatible = "i2c-chip"; + reg = <0x10>; + acpi,hid = "ELAN0001"; + acpi,ddn = "ELAN Touchscreen"; + interrupts-extended = <&acpi_gpe GPIO_21_IRQ IRQ_TYPE_EDGE_FALLING>; + linux,probed; +};
Add a sandbox test for the basic ACPI functionality we have so far.
Changes in v4: None Changes in v3: None Changes in v2: - Add in the acpi_table.h header file to this patch
arch/sandbox/dts/test.dts | 4 ++ arch/sandbox/include/asm/acpi_table.h | 9 +++++ include/dm/uclass-id.h | 1 + test/dm/Makefile | 1 + test/dm/acpi.c | 55 +++++++++++++++++++++++++++ 5 files changed, 70 insertions(+) create mode 100644 arch/sandbox/include/asm/acpi_table.h create mode 100644 test/dm/acpi.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 4a277934a71..5fa951ad4b6 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -206,6 +206,10 @@ compatible = "denx,u-boot-devres-test"; };
+ acpi-test { + compatible = "denx,u-boot-acpi-test"; + }; + clocks { clk_fixed: clk-fixed { compatible = "fixed-clock"; diff --git a/arch/sandbox/include/asm/acpi_table.h b/arch/sandbox/include/asm/acpi_table.h new file mode 100644 index 00000000000..921c7f4201d --- /dev/null +++ b/arch/sandbox/include/asm/acpi_table.h @@ -0,0 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 Google LLC + */ + +#ifndef __ASM_ACPI_TABLE_H__ +#define __ASM_ACPI_TABLE_H__ + +#endif /* __ASM_ACPI_TABLE_H__ */ diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 598f65ea7a3..37ada51f9f7 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -20,6 +20,7 @@ enum uclass_id { UCLASS_TEST_PROBE, UCLASS_TEST_DUMMY, UCLASS_TEST_DEVRES, + UCLASS_TEST_ACPI, UCLASS_SPI_EMUL, /* sandbox SPI device emulator */ UCLASS_I2C_EMUL, /* sandbox I2C device emulator */ UCLASS_I2C_EMUL_PARENT, /* parent for I2C device emulators */ diff --git a/test/dm/Makefile b/test/dm/Makefile index dd1ceff86c0..3daf8a544ea 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -13,6 +13,7 @@ obj-$(CONFIG_UT_DM) += test-uclass.o # subsystem you must add sandbox tests here. obj-$(CONFIG_UT_DM) += core.o ifneq ($(CONFIG_SANDBOX),) +obj-$(CONFIG_ACPIGEN) += acpi.o obj-$(CONFIG_SOUND) += audio.o obj-$(CONFIG_BLK) += blk.o obj-$(CONFIG_BOARD) += board.o diff --git a/test/dm/acpi.c b/test/dm/acpi.c new file mode 100644 index 00000000000..429993b9cc0 --- /dev/null +++ b/test/dm/acpi.c @@ -0,0 +1,55 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Tests for ACPI table generation + * + * Copyright 2019 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <dm.h> +#include <dm/acpi.h> +#include <dm/test.h> +#include <test/ut.h> + +#define ACPI_TEST_DEV_NAME "ABCD" + +static int testacpi_get_name(const struct udevice *dev, char *out_name) +{ + return acpi_copy_name(out_name, ACPI_TEST_DEV_NAME); +} + +struct acpi_ops testacpi_ops = { + .get_name = testacpi_get_name, +}; + +static const struct udevice_id testacpi_ids[] = { + { .compatible = "denx,u-boot-acpi-test" }, + { } +}; + +U_BOOT_DRIVER(testacpi_drv) = { + .name = "testacpi_drv", + .of_match = testacpi_ids, + .id = UCLASS_TEST_ACPI, + acpi_ops_ptr(&testacpi_ops) +}; + +UCLASS_DRIVER(testacpi) = { + .name = "testacpi", + .id = UCLASS_TEST_ACPI, +}; + +/* Test ACPI get_name() */ +static int dm_test_acpi_get_name(struct unit_test_state *uts) +{ + char name[ACPI_NAME_MAX]; + struct udevice *dev; + + ut_assertok(uclass_first_device_err(UCLASS_TEST_ACPI, &dev)); + ut_assertok(acpi_get_name(dev, name)); + ut_asserteq_str(ACPI_TEST_DEV_NAME, name); + + return 0; +} +DM_TEST(dm_test_acpi_get_name, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
This header relates to ACPI and we are about to add some more ACPI headers. Move this one into a new directory so they are together.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Andy Shevchenko andriy.shevchenko@linux.intel.com ---
Changes in v4: None Changes in v3: - Add new patch to move acpi_s3.h to include/acpi/
Changes in v2: None
arch/x86/cpu/apollolake/cpu_spl.c | 2 +- arch/x86/cpu/apollolake/fsp_s.c | 2 +- arch/x86/cpu/apollolake/pmc.c | 2 +- arch/x86/cpu/baytrail/acpi.c | 4 ++-- arch/x86/cpu/cpu.c | 2 +- arch/x86/cpu/wakeup.S | 2 +- arch/x86/lib/acpi_s3.c | 2 +- arch/x86/lib/coreboot_table.c | 2 +- arch/x86/lib/fsp/fsp_common.c | 2 +- arch/x86/lib/fsp1/fsp_common.c | 2 +- arch/x86/lib/fsp2/fsp_dram.c | 2 +- drivers/pci/pci_rom.c | 4 +--- drivers/power/acpi_pmc/acpi-pmc-uclass.c | 2 +- drivers/sysreset/sysreset_x86.c | 2 +- include/{ => acpi}/acpi_s3.h | 0 15 files changed, 15 insertions(+), 17 deletions(-) rename include/{ => acpi}/acpi_s3.h (100%)
diff --git a/arch/x86/cpu/apollolake/cpu_spl.c b/arch/x86/cpu/apollolake/cpu_spl.c index 8a39c3128e0..e2509e391fa 100644 --- a/arch/x86/cpu/apollolake/cpu_spl.c +++ b/arch/x86/cpu/apollolake/cpu_spl.c @@ -6,13 +6,13 @@ */
#include <common.h> -#include <acpi_s3.h> #include <dm.h> #include <ec_commands.h> #include <log.h> #include <spi_flash.h> #include <spl.h> #include <syscon.h> +#include <acpi/acpi_s3.h> #include <asm/cpu.h> #include <asm/cpu_common.h> #include <asm/cpu_x86.h> diff --git a/arch/x86/cpu/apollolake/fsp_s.c b/arch/x86/cpu/apollolake/fsp_s.c index 1f22c1ea3c6..17cf1682ad0 100644 --- a/arch/x86/cpu/apollolake/fsp_s.c +++ b/arch/x86/cpu/apollolake/fsp_s.c @@ -5,11 +5,11 @@ */
#include <common.h> -#include <acpi_s3.h> #include <binman.h> #include <dm.h> #include <irq.h> #include <malloc.h> +#include <acpi/acpi_s3.h> #include <asm/intel_pinctrl.h> #include <asm/io.h> #include <asm/intel_regs.h> diff --git a/arch/x86/cpu/apollolake/pmc.c b/arch/x86/cpu/apollolake/pmc.c index aec0c8394c2..4ea7c7447bc 100644 --- a/arch/x86/cpu/apollolake/pmc.c +++ b/arch/x86/cpu/apollolake/pmc.c @@ -9,10 +9,10 @@ #define LOG_CATEGORY UCLASS_ACPI_PMC
#include <common.h> -#include <acpi_s3.h> #include <dt-structs.h> #include <dm.h> #include <spl.h> +#include <acpi/acpi_s3.h> #include <asm/io.h> #include <asm/pci.h> #include <power/acpi_pmc.h> diff --git a/arch/x86/cpu/baytrail/acpi.c b/arch/x86/cpu/baytrail/acpi.c index f44228e6939..3c27391873c 100644 --- a/arch/x86/cpu/baytrail/acpi.c +++ b/arch/x86/cpu/baytrail/acpi.c @@ -4,15 +4,15 @@ */
#include <common.h> -#include <acpi_s3.h> #include <cpu.h> #include <dm.h> -#include <dm/uclass-internal.h> +#include <acpi/acpi_s3.h> #include <asm/acpi_table.h> #include <asm/io.h> #include <asm/tables.h> #include <asm/arch/global_nvs.h> #include <asm/arch/iomap.h> +#include <dm/uclass-internal.h>
void acpi_create_fadt(struct acpi_fadt *fadt, struct acpi_facs *facs, void *dsdt) diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index dae06949cc6..246ee50948c 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -19,7 +19,6 @@ */
#include <common.h> -#include <acpi_s3.h> #include <command.h> #include <cpu_func.h> #include <dm.h> @@ -27,6 +26,7 @@ #include <init.h> #include <malloc.h> #include <syscon.h> +#include <acpi/acpi_s3.h> #include <asm/acpi.h> #include <asm/acpi_table.h> #include <asm/control_regs.h> diff --git a/arch/x86/cpu/wakeup.S b/arch/x86/cpu/wakeup.S index 244ca1276af..093bf3bcc5c 100644 --- a/arch/x86/cpu/wakeup.S +++ b/arch/x86/cpu/wakeup.S @@ -5,7 +5,7 @@ * From coreboot src/arch/x86/wakeup.S */
-#include <acpi_s3.h> +#include <acpi/acpi_s3.h> #include <asm/processor.h> #include <asm/processor-flags.h>
diff --git a/arch/x86/lib/acpi_s3.c b/arch/x86/lib/acpi_s3.c index 197636c4b50..c3759ec8492 100644 --- a/arch/x86/lib/acpi_s3.c +++ b/arch/x86/lib/acpi_s3.c @@ -4,7 +4,7 @@ */
#include <common.h> -#include <acpi_s3.h> +#include <acpi/acpi_s3.h> #include <asm/acpi.h> #include <asm/acpi_table.h> #include <asm/post.h> diff --git a/arch/x86/lib/coreboot_table.c b/arch/x86/lib/coreboot_table.c index 2943e11d2a4..c996fc588df 100644 --- a/arch/x86/lib/coreboot_table.c +++ b/arch/x86/lib/coreboot_table.c @@ -4,9 +4,9 @@ */
#include <common.h> -#include <acpi_s3.h> #include <malloc.h> #include <vbe.h> +#include <acpi/acpi_s3.h> #include <asm/coreboot_tables.h> #include <asm/e820.h>
diff --git a/arch/x86/lib/fsp/fsp_common.c b/arch/x86/lib/fsp/fsp_common.c index 5eff0f99aad..267527eb344 100644 --- a/arch/x86/lib/fsp/fsp_common.c +++ b/arch/x86/lib/fsp/fsp_common.c @@ -4,11 +4,11 @@ */
#include <common.h> -#include <acpi_s3.h> #include <cpu_func.h> #include <dm.h> #include <errno.h> #include <rtc.h> +#include <acpi/acpi_s3.h> #include <asm/cmos_layout.h> #include <asm/early_cmos.h> #include <asm/io.h> diff --git a/arch/x86/lib/fsp1/fsp_common.c b/arch/x86/lib/fsp1/fsp_common.c index aee2a05044f..0a726807c2b 100644 --- a/arch/x86/lib/fsp1/fsp_common.c +++ b/arch/x86/lib/fsp1/fsp_common.c @@ -4,11 +4,11 @@ */
#include <common.h> -#include <acpi_s3.h> #include <dm.h> #include <errno.h> #include <malloc.h> #include <rtc.h> +#include <acpi/acpi_s3.h> #include <asm/cmos_layout.h> #include <asm/early_cmos.h> #include <asm/io.h> diff --git a/arch/x86/lib/fsp2/fsp_dram.c b/arch/x86/lib/fsp2/fsp_dram.c index 90a238a2245..c8f2c09b6a7 100644 --- a/arch/x86/lib/fsp2/fsp_dram.c +++ b/arch/x86/lib/fsp2/fsp_dram.c @@ -5,9 +5,9 @@ */
#include <common.h> -#include <acpi_s3.h> #include <handoff.h> #include <spl.h> +#include <acpi/acpi_s3.h> #include <asm/arch/cpu.h> #include <asm/fsp/fsp_support.h> #include <asm/fsp2/fsp_api.h> diff --git a/drivers/pci/pci_rom.c b/drivers/pci/pci_rom.c index 90f224b0452..6b17f18bc07 100644 --- a/drivers/pci/pci_rom.c +++ b/drivers/pci/pci_rom.c @@ -33,12 +33,10 @@ #include <vbe.h> #include <video.h> #include <video_fb.h> +#include <acpi/acpi_s3.h> #include <linux/screen_info.h>
-#ifdef CONFIG_X86 -#include <acpi_s3.h> DECLARE_GLOBAL_DATA_PTR; -#endif
__weak bool board_should_run_oprom(struct udevice *dev) { diff --git a/drivers/power/acpi_pmc/acpi-pmc-uclass.c b/drivers/power/acpi_pmc/acpi-pmc-uclass.c index d43de87126c..1c79f835c66 100644 --- a/drivers/power/acpi_pmc/acpi-pmc-uclass.c +++ b/drivers/power/acpi_pmc/acpi-pmc-uclass.c @@ -6,9 +6,9 @@ #define LOG_CATEGORY UCLASS_ACPI_PMC
#include <common.h> -#include <acpi_s3.h> #include <dm.h> #include <log.h> +#include <acpi/acpi_s3.h> #ifdef CONFIG_X86 #include <asm/intel_pinctrl.h> #endif diff --git a/drivers/sysreset/sysreset_x86.c b/drivers/sysreset/sysreset_x86.c index 8e2d1eaa7a1..bc911435602 100644 --- a/drivers/sysreset/sysreset_x86.c +++ b/drivers/sysreset/sysreset_x86.c @@ -6,11 +6,11 @@ */
#include <common.h> -#include <acpi_s3.h> #include <dm.h> #include <efi_loader.h> #include <pch.h> #include <sysreset.h> +#include <acpi/acpi_s3.h> #include <asm/io.h> #include <asm/processor.h>
diff --git a/include/acpi_s3.h b/include/acpi/acpi_s3.h similarity index 100% rename from include/acpi_s3.h rename to include/acpi/acpi_s3.h
This file is potentially useful to other architectures saddled with ACPI so move most of its contents to a common location.
Changes in v4: None Changes in v3: - Update commit message to say that we move most of its contents - Move acpi_table.h to include/acpi - Add forward declarations for the functions
Changes in v2: None
arch/x86/cpu/baytrail/acpi.c | 2 +- arch/x86/cpu/cpu.c | 2 +- arch/x86/cpu/quark/acpi.c | 2 +- arch/x86/cpu/tangier/acpi.c | 4 +- arch/x86/include/asm/acpi_table.h | 381 +---------------------------- arch/x86/lib/acpi.c | 2 +- arch/x86/lib/acpi_s3.c | 2 +- arch/x86/lib/acpi_table.c | 2 +- arch/x86/lib/tables.c | 2 +- arch/x86/lib/zimage.c | 2 +- include/acpi/acpi_table.h | 394 ++++++++++++++++++++++++++++++ lib/efi_loader/efi_acpi.c | 2 +- 12 files changed, 412 insertions(+), 385 deletions(-) create mode 100644 include/acpi/acpi_table.h
diff --git a/arch/x86/cpu/baytrail/acpi.c b/arch/x86/cpu/baytrail/acpi.c index 3c27391873c..57723109796 100644 --- a/arch/x86/cpu/baytrail/acpi.c +++ b/arch/x86/cpu/baytrail/acpi.c @@ -7,7 +7,7 @@ #include <cpu.h> #include <dm.h> #include <acpi/acpi_s3.h> -#include <asm/acpi_table.h> +#include <acpi/acpi_table.h> #include <asm/io.h> #include <asm/tables.h> #include <asm/arch/global_nvs.h> diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index 246ee50948c..cec04b481b9 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -27,8 +27,8 @@ #include <malloc.h> #include <syscon.h> #include <acpi/acpi_s3.h> +#include <acpi/acpi_table.h> #include <asm/acpi.h> -#include <asm/acpi_table.h> #include <asm/control_regs.h> #include <asm/coreboot_tables.h> #include <asm/cpu.h> diff --git a/arch/x86/cpu/quark/acpi.c b/arch/x86/cpu/quark/acpi.c index 7b6fc2f4a53..26cda3b3376 100644 --- a/arch/x86/cpu/quark/acpi.c +++ b/arch/x86/cpu/quark/acpi.c @@ -4,7 +4,7 @@ */
#include <common.h> -#include <asm/acpi_table.h> +#include <acpi/acpi_table.h> #include <asm/tables.h> #include <asm/arch/global_nvs.h> #include <asm/arch/iomap.h> diff --git a/arch/x86/cpu/tangier/acpi.c b/arch/x86/cpu/tangier/acpi.c index 8b128138b0d..4ec8fdd6f89 100644 --- a/arch/x86/cpu/tangier/acpi.c +++ b/arch/x86/cpu/tangier/acpi.c @@ -8,13 +8,13 @@ #include <common.h> #include <cpu.h> #include <dm.h> -#include <dm/uclass-internal.h> -#include <asm/acpi_table.h> +#include <acpi/acpi_table.h> #include <asm/ioapic.h> #include <asm/mpspec.h> #include <asm/tables.h> #include <asm/arch/global_nvs.h> #include <asm/arch/iomap.h> +#include <dm/uclass-internal.h>
void acpi_create_fadt(struct acpi_fadt *fadt, struct acpi_facs *facs, void *dsdt) diff --git a/arch/x86/include/asm/acpi_table.h b/arch/x86/include/asm/acpi_table.h index 7588913f937..928475cef4e 100644 --- a/arch/x86/include/asm/acpi_table.h +++ b/arch/x86/include/asm/acpi_table.h @@ -9,381 +9,14 @@ #ifndef __ASM_ACPI_TABLE_H__ #define __ASM_ACPI_TABLE_H__
-#define RSDP_SIG "RSD PTR " /* RSDP pointer signature */ -#define OEM_ID "U-BOOT" /* U-Boot */ -#define OEM_TABLE_ID "U-BOOTBL" /* U-Boot Table */ -#define ASLC_ID "INTL" /* Intel ASL Compiler */ - -#define ACPI_RSDP_REV_ACPI_1_0 0 -#define ACPI_RSDP_REV_ACPI_2_0 2 - -/* - * RSDP (Root System Description Pointer) - * Note: ACPI 1.0 didn't have length, xsdt_address, and ext_checksum - */ -struct acpi_rsdp { - char signature[8]; /* RSDP signature */ - u8 checksum; /* Checksum of the first 20 bytes */ - char oem_id[6]; /* OEM ID */ - u8 revision; /* 0 for ACPI 1.0, others 2 */ - u32 rsdt_address; /* Physical address of RSDT (32 bits) */ - u32 length; /* Total RSDP length (incl. extended part) */ - u64 xsdt_address; /* Physical address of XSDT (64 bits) */ - u8 ext_checksum; /* Checksum of the whole table */ - u8 reserved[3]; -}; - -/* Generic ACPI header, provided by (almost) all tables */ -struct __packed acpi_table_header { - char signature[4]; /* ACPI signature (4 ASCII characters) */ - u32 length; /* Table length in bytes (incl. header) */ - u8 revision; /* Table version (not ACPI version!) */ - volatile u8 checksum; /* To make sum of entire table == 0 */ - char oem_id[6]; /* OEM identification */ - char oem_table_id[8]; /* OEM table identification */ - u32 oem_revision; /* OEM revision number */ - char aslc_id[4]; /* ASL compiler vendor ID */ - u32 aslc_revision; /* ASL compiler revision number */ -}; - -/* A maximum number of 32 ACPI tables ought to be enough for now */ -#define MAX_ACPI_TABLES 32 - -/* RSDT (Root System Description Table) */ -struct acpi_rsdt { - struct acpi_table_header header; - u32 entry[MAX_ACPI_TABLES]; -}; - -/* XSDT (Extended System Description Table) */ -struct acpi_xsdt { - struct acpi_table_header header; - u64 entry[MAX_ACPI_TABLES]; -}; - -/* FADT Preferred Power Management Profile */ -enum acpi_pm_profile { - ACPI_PM_UNSPECIFIED = 0, - ACPI_PM_DESKTOP, - ACPI_PM_MOBILE, - ACPI_PM_WORKSTATION, - ACPI_PM_ENTERPRISE_SERVER, - ACPI_PM_SOHO_SERVER, - ACPI_PM_APPLIANCE_PC, - ACPI_PM_PERFORMANCE_SERVER, - ACPI_PM_TABLET -}; - -/* FADT flags for p_lvl2_lat and p_lvl3_lat */ -#define ACPI_FADT_C2_NOT_SUPPORTED 101 -#define ACPI_FADT_C3_NOT_SUPPORTED 1001 - -/* FADT Boot Architecture Flags */ -#define ACPI_FADT_LEGACY_FREE 0x00 -#define ACPI_FADT_LEGACY_DEVICES (1 << 0) -#define ACPI_FADT_8042 (1 << 1) -#define ACPI_FADT_VGA_NOT_PRESENT (1 << 2) -#define ACPI_FADT_MSI_NOT_SUPPORTED (1 << 3) -#define ACPI_FADT_NO_PCIE_ASPM_CONTROL (1 << 4) - -/* FADT Feature Flags */ -#define ACPI_FADT_WBINVD (1 << 0) -#define ACPI_FADT_WBINVD_FLUSH (1 << 1) -#define ACPI_FADT_C1_SUPPORTED (1 << 2) -#define ACPI_FADT_C2_MP_SUPPORTED (1 << 3) -#define ACPI_FADT_POWER_BUTTON (1 << 4) -#define ACPI_FADT_SLEEP_BUTTON (1 << 5) -#define ACPI_FADT_FIXED_RTC (1 << 6) -#define ACPI_FADT_S4_RTC_WAKE (1 << 7) -#define ACPI_FADT_32BIT_TIMER (1 << 8) -#define ACPI_FADT_DOCKING_SUPPORTED (1 << 9) -#define ACPI_FADT_RESET_REGISTER (1 << 10) -#define ACPI_FADT_SEALED_CASE (1 << 11) -#define ACPI_FADT_HEADLESS (1 << 12) -#define ACPI_FADT_SLEEP_TYPE (1 << 13) -#define ACPI_FADT_PCI_EXPRESS_WAKE (1 << 14) -#define ACPI_FADT_PLATFORM_CLOCK (1 << 15) -#define ACPI_FADT_S4_RTC_VALID (1 << 16) -#define ACPI_FADT_REMOTE_POWER_ON (1 << 17) -#define ACPI_FADT_APIC_CLUSTER (1 << 18) -#define ACPI_FADT_APIC_PHYSICAL (1 << 19) -#define ACPI_FADT_HW_REDUCED_ACPI (1 << 20) -#define ACPI_FADT_LOW_PWR_IDLE_S0 (1 << 21) - -enum acpi_address_space_type { - ACPI_ADDRESS_SPACE_MEMORY = 0, /* System memory */ - ACPI_ADDRESS_SPACE_IO, /* System I/O */ - ACPI_ADDRESS_SPACE_PCI, /* PCI config space */ - ACPI_ADDRESS_SPACE_EC, /* Embedded controller */ - ACPI_ADDRESS_SPACE_SMBUS, /* SMBus */ - ACPI_ADDRESS_SPACE_PCC = 0x0a, /* Platform Comm. Channel */ - ACPI_ADDRESS_SPACE_FIXED = 0x7f /* Functional fixed hardware */ -}; - -enum acpi_address_space_size { - ACPI_ACCESS_SIZE_UNDEFINED = 0, - ACPI_ACCESS_SIZE_BYTE_ACCESS, - ACPI_ACCESS_SIZE_WORD_ACCESS, - ACPI_ACCESS_SIZE_DWORD_ACCESS, - ACPI_ACCESS_SIZE_QWORD_ACCESS -}; - -struct acpi_gen_regaddr { - u8 space_id; /* Address space ID */ - u8 bit_width; /* Register size in bits */ - u8 bit_offset; /* Register bit offset */ - u8 access_size; /* Access size */ - u32 addrl; /* Register address, low 32 bits */ - u32 addrh; /* Register address, high 32 bits */ -}; - -/* FADT (Fixed ACPI Description Table) */ -struct __packed acpi_fadt { - struct acpi_table_header header; - u32 firmware_ctrl; - u32 dsdt; - u8 res1; - u8 preferred_pm_profile; - u16 sci_int; - u32 smi_cmd; - u8 acpi_enable; - u8 acpi_disable; - u8 s4bios_req; - u8 pstate_cnt; - u32 pm1a_evt_blk; - u32 pm1b_evt_blk; - u32 pm1a_cnt_blk; - u32 pm1b_cnt_blk; - u32 pm2_cnt_blk; - u32 pm_tmr_blk; - u32 gpe0_blk; - u32 gpe1_blk; - u8 pm1_evt_len; - u8 pm1_cnt_len; - u8 pm2_cnt_len; - u8 pm_tmr_len; - u8 gpe0_blk_len; - u8 gpe1_blk_len; - u8 gpe1_base; - u8 cst_cnt; - u16 p_lvl2_lat; - u16 p_lvl3_lat; - u16 flush_size; - u16 flush_stride; - u8 duty_offset; - u8 duty_width; - u8 day_alrm; - u8 mon_alrm; - u8 century; - u16 iapc_boot_arch; - u8 res2; - u32 flags; - struct acpi_gen_regaddr reset_reg; - u8 reset_value; - u16 arm_boot_arch; - u8 minor_revision; - u32 x_firmware_ctl_l; - u32 x_firmware_ctl_h; - u32 x_dsdt_l; - u32 x_dsdt_h; - struct acpi_gen_regaddr x_pm1a_evt_blk; - struct acpi_gen_regaddr x_pm1b_evt_blk; - struct acpi_gen_regaddr x_pm1a_cnt_blk; - struct acpi_gen_regaddr x_pm1b_cnt_blk; - struct acpi_gen_regaddr x_pm2_cnt_blk; - struct acpi_gen_regaddr x_pm_tmr_blk; - struct acpi_gen_regaddr x_gpe0_blk; - struct acpi_gen_regaddr x_gpe1_blk; -}; - -/* FACS flags */ -#define ACPI_FACS_S4BIOS_F (1 << 0) -#define ACPI_FACS_64BIT_WAKE_F (1 << 1) - -/* FACS (Firmware ACPI Control Structure) */ -struct acpi_facs { - char signature[4]; /* "FACS" */ - u32 length; /* Length in bytes (>= 64) */ - u32 hardware_signature; /* Hardware signature */ - u32 firmware_waking_vector; /* Firmware waking vector */ - u32 global_lock; /* Global lock */ - u32 flags; /* FACS flags */ - u32 x_firmware_waking_vector_l; /* X FW waking vector, low */ - u32 x_firmware_waking_vector_h; /* X FW waking vector, high */ - u8 version; /* Version 2 */ - u8 res1[3]; - u32 ospm_flags; /* OSPM enabled flags */ - u8 res2[24]; -}; - -/* MADT flags */ -#define ACPI_MADT_PCAT_COMPAT (1 << 0) - -/* MADT (Multiple APIC Description Table) */ -struct acpi_madt { - struct acpi_table_header header; - u32 lapic_addr; /* Local APIC address */ - u32 flags; /* Multiple APIC flags */ -}; - -/* MADT: APIC Structure Type*/ -enum acpi_apic_types { - ACPI_APIC_LAPIC = 0, /* Processor local APIC */ - ACPI_APIC_IOAPIC, /* I/O APIC */ - ACPI_APIC_IRQ_SRC_OVERRIDE, /* Interrupt source override */ - ACPI_APIC_NMI_SRC, /* NMI source */ - ACPI_APIC_LAPIC_NMI, /* Local APIC NMI */ - ACPI_APIC_LAPIC_ADDR_OVERRIDE, /* Local APIC address override */ - ACPI_APIC_IOSAPIC, /* I/O SAPIC */ - ACPI_APIC_LSAPIC, /* Local SAPIC */ - ACPI_APIC_PLATFORM_IRQ_SRC, /* Platform interrupt sources */ - ACPI_APIC_LX2APIC, /* Processor local x2APIC */ - ACPI_APIC_LX2APIC_NMI, /* Local x2APIC NMI */ -}; - -/* MADT: Processor Local APIC Structure */ - -#define LOCAL_APIC_FLAG_ENABLED (1 << 0) - -struct acpi_madt_lapic { - u8 type; /* Type (0) */ - u8 length; /* Length in bytes (8) */ - u8 processor_id; /* ACPI processor ID */ - u8 apic_id; /* Local APIC ID */ - u32 flags; /* Local APIC flags */ -}; - -/* MADT: I/O APIC Structure */ -struct acpi_madt_ioapic { - u8 type; /* Type (1) */ - u8 length; /* Length in bytes (12) */ - u8 ioapic_id; /* I/O APIC ID */ - u8 reserved; - u32 ioapic_addr; /* I/O APIC address */ - u32 gsi_base; /* Global system interrupt base */ -}; - -/* MADT: Interrupt Source Override Structure */ -struct __packed acpi_madt_irqoverride { - u8 type; /* Type (2) */ - u8 length; /* Length in bytes (10) */ - u8 bus; /* ISA (0) */ - u8 source; /* Bus-relative int. source (IRQ) */ - u32 gsirq; /* Global system interrupt */ - u16 flags; /* MPS INTI flags */ -}; - -/* MADT: Local APIC NMI Structure */ -struct __packed acpi_madt_lapic_nmi { - u8 type; /* Type (4) */ - u8 length; /* Length in bytes (6) */ - u8 processor_id; /* ACPI processor ID */ - u16 flags; /* MPS INTI flags */ - u8 lint; /* Local APIC LINT# */ -}; - -/* MCFG (PCI Express MMIO config space BAR description table) */ -struct acpi_mcfg { - struct acpi_table_header header; - u8 reserved[8]; -}; - -struct acpi_mcfg_mmconfig { - u32 base_address_l; - u32 base_address_h; - u16 pci_segment_group_number; - u8 start_bus_number; - u8 end_bus_number; - u8 reserved[4]; -}; - -/* PM1_CNT bit defines */ -#define PM1_CNT_SCI_EN (1 << 0) - -/* ACPI global NVS structure */ +struct acpi_facs; +struct acpi_fadt; struct acpi_global_nvs; - -/* CSRT (Core System Resource Table) */ -struct acpi_csrt { - struct acpi_table_header header; -}; - -struct acpi_csrt_group { - u32 length; - u32 vendor_id; - u32 subvendor_id; - u16 device_id; - u16 subdevice_id; - u16 revision; - u16 reserved; - u32 shared_info_length; -}; - -struct acpi_csrt_shared_info { - u16 major_version; - u16 minor_version; - u32 mmio_base_low; - u32 mmio_base_high; - u32 gsi_interrupt; - u8 interrupt_polarity; - u8 interrupt_mode; - u8 num_channels; - u8 dma_address_width; - u16 base_request_line; - u16 num_handshake_signals; - u32 max_block_size; -}; - -/* DBG2 definitions are partially used for SPCR interface_type */ - -/* Types for port_type field */ - -#define ACPI_DBG2_SERIAL_PORT 0x8000 -#define ACPI_DBG2_1394_PORT 0x8001 -#define ACPI_DBG2_USB_PORT 0x8002 -#define ACPI_DBG2_NET_PORT 0x8003 - -/* Subtypes for port_subtype field */ - -#define ACPI_DBG2_16550_COMPATIBLE 0x0000 -#define ACPI_DBG2_16550_SUBSET 0x0001 -#define ACPI_DBG2_ARM_PL011 0x0003 -#define ACPI_DBG2_ARM_SBSA_32BIT 0x000D -#define ACPI_DBG2_ARM_SBSA_GENERIC 0x000E -#define ACPI_DBG2_ARM_DCC 0x000F -#define ACPI_DBG2_BCM2835 0x0010 - -#define ACPI_DBG2_1394_STANDARD 0x0000 - -#define ACPI_DBG2_USB_XHCI 0x0000 -#define ACPI_DBG2_USB_EHCI 0x0001 - -#define ACPI_DBG2_UNKNOWN 0x00FF - -/* SPCR (Serial Port Console Redirection table) */ -struct __packed acpi_spcr { - struct acpi_table_header header; - u8 interface_type; - u8 reserved[3]; - struct acpi_gen_regaddr serial_port; - u8 interrupt_type; - u8 pc_interrupt; - u32 interrupt; /* Global system interrupt */ - u8 baud_rate; - u8 parity; - u8 stop_bits; - u8 flow_control; - u8 terminal_type; - u8 reserved1; - u16 pci_device_id; /* Must be 0xffff if not PCI device */ - u16 pci_vendor_id; /* Must be 0xffff if not PCI device */ - u8 pci_bus; - u8 pci_device; - u8 pci_function; - u32 pci_flags; - u8 pci_segment; - u32 reserved2; -}; +struct acpi_madt_ioapic; +struct acpi_madt_irqoverride; +struct acpi_madt_lapic_nmi; +struct acpi_mcfg_mmconfig; +struct acpi_table_header;
/* These can be used by the target port */
diff --git a/arch/x86/lib/acpi.c b/arch/x86/lib/acpi.c index cba9c24dd45..7431458dcf2 100644 --- a/arch/x86/lib/acpi.c +++ b/arch/x86/lib/acpi.c @@ -4,7 +4,7 @@ */
#include <common.h> -#include <asm/acpi_table.h> +#include <acpi/acpi_table.h> #include <asm/io.h> #include <asm/tables.h>
diff --git a/arch/x86/lib/acpi_s3.c b/arch/x86/lib/acpi_s3.c index c3759ec8492..52410a515df 100644 --- a/arch/x86/lib/acpi_s3.c +++ b/arch/x86/lib/acpi_s3.c @@ -5,8 +5,8 @@
#include <common.h> #include <acpi/acpi_s3.h> +#include <acpi/acpi_table.h> #include <asm/acpi.h> -#include <asm/acpi_table.h> #include <asm/post.h> #include <linux/linkage.h>
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 66e32f21bdb..4832364f3ca 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -12,8 +12,8 @@ #include <dm/uclass-internal.h> #include <serial.h> #include <version.h> +#include <acpi/acpi_table.h> #include <asm/acpi/global_nvs.h> -#include <asm/acpi_table.h> #include <asm/ioapic.h> #include <asm/lapic.h> #include <asm/mpspec.h> diff --git a/arch/x86/lib/tables.c b/arch/x86/lib/tables.c index 7aea722d0b8..574d331d76f 100644 --- a/arch/x86/lib/tables.c +++ b/arch/x86/lib/tables.c @@ -6,10 +6,10 @@ #include <common.h> #include <malloc.h> #include <smbios.h> +#include <acpi/acpi_table.h> #include <asm/sfi.h> #include <asm/mpspec.h> #include <asm/tables.h> -#include <asm/acpi_table.h> #include <asm/coreboot_tables.h>
/** diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index 9b5e767ccc2..ffc09630b7d 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -16,7 +16,7 @@ #include <env.h> #include <irq_func.h> #include <malloc.h> -#include <asm/acpi_table.h> +#include <acpi/acpi_table.h> #include <asm/io.h> #include <asm/ptrace.h> #include <asm/zimage.h> diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h new file mode 100644 index 00000000000..b4404a632c0 --- /dev/null +++ b/include/acpi/acpi_table.h @@ -0,0 +1,394 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Helpers for ACPI table generation + * + * Based on acpi.c from coreboot + * + * Copyright 2019 Google LLC + * + * Copyright (C) 2015, Saket Sinha saket.sinha89@gmail.com + * Copyright (C) 2016, Bin Meng bmeng.cn@gmail.com + */ + +#ifndef __ACPI_TABLE_H__ +#define __ACPI_TABLE_H__ + +#define RSDP_SIG "RSD PTR " /* RSDP pointer signature */ +#define OEM_ID "U-BOOT" /* U-Boot */ +#define OEM_TABLE_ID "U-BOOTBL" /* U-Boot Table */ +#define ASLC_ID "INTL" /* Intel ASL Compiler */ + +#define ACPI_RSDP_REV_ACPI_1_0 0 +#define ACPI_RSDP_REV_ACPI_2_0 2 + +/* + * RSDP (Root System Description Pointer) + * Note: ACPI 1.0 didn't have length, xsdt_address, and ext_checksum + */ +struct acpi_rsdp { + char signature[8]; /* RSDP signature */ + u8 checksum; /* Checksum of the first 20 bytes */ + char oem_id[6]; /* OEM ID */ + u8 revision; /* 0 for ACPI 1.0, others 2 */ + u32 rsdt_address; /* Physical address of RSDT (32 bits) */ + u32 length; /* Total RSDP length (incl. extended part) */ + u64 xsdt_address; /* Physical address of XSDT (64 bits) */ + u8 ext_checksum; /* Checksum of the whole table */ + u8 reserved[3]; +}; + +/* Generic ACPI header, provided by (almost) all tables */ +struct __packed acpi_table_header { + char signature[4]; /* ACPI signature (4 ASCII characters) */ + u32 length; /* Table length in bytes (incl. header) */ + u8 revision; /* Table version (not ACPI version!) */ + volatile u8 checksum; /* To make sum of entire table == 0 */ + char oem_id[6]; /* OEM identification */ + char oem_table_id[8]; /* OEM table identification */ + u32 oem_revision; /* OEM revision number */ + char aslc_id[4]; /* ASL compiler vendor ID */ + u32 aslc_revision; /* ASL compiler revision number */ +}; + +/* A maximum number of 32 ACPI tables ought to be enough for now */ +#define MAX_ACPI_TABLES 32 + +/* RSDT (Root System Description Table) */ +struct acpi_rsdt { + struct acpi_table_header header; + u32 entry[MAX_ACPI_TABLES]; +}; + +/* XSDT (Extended System Description Table) */ +struct acpi_xsdt { + struct acpi_table_header header; + u64 entry[MAX_ACPI_TABLES]; +}; + +/* FADT Preferred Power Management Profile */ +enum acpi_pm_profile { + ACPI_PM_UNSPECIFIED = 0, + ACPI_PM_DESKTOP, + ACPI_PM_MOBILE, + ACPI_PM_WORKSTATION, + ACPI_PM_ENTERPRISE_SERVER, + ACPI_PM_SOHO_SERVER, + ACPI_PM_APPLIANCE_PC, + ACPI_PM_PERFORMANCE_SERVER, + ACPI_PM_TABLET +}; + +/* FADT flags for p_lvl2_lat and p_lvl3_lat */ +#define ACPI_FADT_C2_NOT_SUPPORTED 101 +#define ACPI_FADT_C3_NOT_SUPPORTED 1001 + +/* FADT Boot Architecture Flags */ +#define ACPI_FADT_LEGACY_FREE 0x00 +#define ACPI_FADT_LEGACY_DEVICES BIT(0) +#define ACPI_FADT_8042 BIT(1) +#define ACPI_FADT_VGA_NOT_PRESENT BIT(2) +#define ACPI_FADT_MSI_NOT_SUPPORTED BIT(3) +#define ACPI_FADT_NO_PCIE_ASPM_CONTROL BIT(4) + +/* FADT Feature Flags */ +#define ACPI_FADT_WBINVD BIT(0) +#define ACPI_FADT_WBINVD_FLUSH BIT(1) +#define ACPI_FADT_C1_SUPPORTED BIT(2) +#define ACPI_FADT_C2_MP_SUPPORTED BIT(3) +#define ACPI_FADT_POWER_BUTTON BIT(4) +#define ACPI_FADT_SLEEP_BUTTON BIT(5) +#define ACPI_FADT_FIXED_RTC BIT(6) +#define ACPI_FADT_S4_RTC_WAKE BIT(7) +#define ACPI_FADT_32BIT_TIMER BIT(8) +#define ACPI_FADT_DOCKING_SUPPORTED BIT(9) +#define ACPI_FADT_RESET_REGISTER BIT(10) +#define ACPI_FADT_SEALED_CASE BIT(11) +#define ACPI_FADT_HEADLESS BIT(12) +#define ACPI_FADT_SLEEP_TYPE BIT(13) +#define ACPI_FADT_PCI_EXPRESS_WAKE BIT(14) +#define ACPI_FADT_PLATFORM_CLOCK BIT(15) +#define ACPI_FADT_S4_RTC_VALID BIT(16) +#define ACPI_FADT_REMOTE_POWER_ON BIT(17) +#define ACPI_FADT_APIC_CLUSTER BIT(18) +#define ACPI_FADT_APIC_PHYSICAL BIT(19) +#define ACPI_FADT_HW_REDUCED_ACPI BIT(20) +#define ACPI_FADT_LOW_PWR_IDLE_S0 BIT(21) + +enum acpi_address_space_type { + ACPI_ADDRESS_SPACE_MEMORY = 0, /* System memory */ + ACPI_ADDRESS_SPACE_IO, /* System I/O */ + ACPI_ADDRESS_SPACE_PCI, /* PCI config space */ + ACPI_ADDRESS_SPACE_EC, /* Embedded controller */ + ACPI_ADDRESS_SPACE_SMBUS, /* SMBus */ + ACPI_ADDRESS_SPACE_PCC = 0x0a, /* Platform Comm. Channel */ + ACPI_ADDRESS_SPACE_FIXED = 0x7f /* Functional fixed hardware */ +}; + +enum acpi_address_space_size { + ACPI_ACCESS_SIZE_UNDEFINED = 0, + ACPI_ACCESS_SIZE_BYTE_ACCESS, + ACPI_ACCESS_SIZE_WORD_ACCESS, + ACPI_ACCESS_SIZE_DWORD_ACCESS, + ACPI_ACCESS_SIZE_QWORD_ACCESS +}; + +struct acpi_gen_regaddr { + u8 space_id; /* Address space ID */ + u8 bit_width; /* Register size in bits */ + u8 bit_offset; /* Register bit offset */ + u8 access_size; /* Access size */ + u32 addrl; /* Register address, low 32 bits */ + u32 addrh; /* Register address, high 32 bits */ +}; + +/* FADT (Fixed ACPI Description Table) */ +struct __packed acpi_fadt { + struct acpi_table_header header; + u32 firmware_ctrl; + u32 dsdt; + u8 res1; + u8 preferred_pm_profile; + u16 sci_int; + u32 smi_cmd; + u8 acpi_enable; + u8 acpi_disable; + u8 s4bios_req; + u8 pstate_cnt; + u32 pm1a_evt_blk; + u32 pm1b_evt_blk; + u32 pm1a_cnt_blk; + u32 pm1b_cnt_blk; + u32 pm2_cnt_blk; + u32 pm_tmr_blk; + u32 gpe0_blk; + u32 gpe1_blk; + u8 pm1_evt_len; + u8 pm1_cnt_len; + u8 pm2_cnt_len; + u8 pm_tmr_len; + u8 gpe0_blk_len; + u8 gpe1_blk_len; + u8 gpe1_base; + u8 cst_cnt; + u16 p_lvl2_lat; + u16 p_lvl3_lat; + u16 flush_size; + u16 flush_stride; + u8 duty_offset; + u8 duty_width; + u8 day_alrm; + u8 mon_alrm; + u8 century; + u16 iapc_boot_arch; + u8 res2; + u32 flags; + struct acpi_gen_regaddr reset_reg; + u8 reset_value; + u16 arm_boot_arch; + u8 minor_revision; + u32 x_firmware_ctl_l; + u32 x_firmware_ctl_h; + u32 x_dsdt_l; + u32 x_dsdt_h; + struct acpi_gen_regaddr x_pm1a_evt_blk; + struct acpi_gen_regaddr x_pm1b_evt_blk; + struct acpi_gen_regaddr x_pm1a_cnt_blk; + struct acpi_gen_regaddr x_pm1b_cnt_blk; + struct acpi_gen_regaddr x_pm2_cnt_blk; + struct acpi_gen_regaddr x_pm_tmr_blk; + struct acpi_gen_regaddr x_gpe0_blk; + struct acpi_gen_regaddr x_gpe1_blk; +}; + +/* FACS flags */ +#define ACPI_FACS_S4BIOS_F BIT(0) +#define ACPI_FACS_64BIT_WAKE_F BIT(1) + +/* FACS (Firmware ACPI Control Structure) */ +struct acpi_facs { + char signature[4]; /* "FACS" */ + u32 length; /* Length in bytes (>= 64) */ + u32 hardware_signature; /* Hardware signature */ + u32 firmware_waking_vector; /* Firmware waking vector */ + u32 global_lock; /* Global lock */ + u32 flags; /* FACS flags */ + u32 x_firmware_waking_vector_l; /* X FW waking vector, low */ + u32 x_firmware_waking_vector_h; /* X FW waking vector, high */ + u8 version; /* Version 2 */ + u8 res1[3]; + u32 ospm_flags; /* OSPM enabled flags */ + u8 res2[24]; +}; + +/* MADT flags */ +#define ACPI_MADT_PCAT_COMPAT BIT(0) + +/* MADT (Multiple APIC Description Table) */ +struct acpi_madt { + struct acpi_table_header header; + u32 lapic_addr; /* Local APIC address */ + u32 flags; /* Multiple APIC flags */ +}; + +/* MADT: APIC Structure Type*/ +enum acpi_apic_types { + ACPI_APIC_LAPIC = 0, /* Processor local APIC */ + ACPI_APIC_IOAPIC, /* I/O APIC */ + ACPI_APIC_IRQ_SRC_OVERRIDE, /* Interrupt source override */ + ACPI_APIC_NMI_SRC, /* NMI source */ + ACPI_APIC_LAPIC_NMI, /* Local APIC NMI */ + ACPI_APIC_LAPIC_ADDR_OVERRIDE, /* Local APIC address override */ + ACPI_APIC_IOSAPIC, /* I/O SAPIC */ + ACPI_APIC_LSAPIC, /* Local SAPIC */ + ACPI_APIC_PLATFORM_IRQ_SRC, /* Platform interrupt sources */ + ACPI_APIC_LX2APIC, /* Processor local x2APIC */ + ACPI_APIC_LX2APIC_NMI, /* Local x2APIC NMI */ +}; + +/* MADT: Processor Local APIC Structure */ + +#define LOCAL_APIC_FLAG_ENABLED BIT(0) + +struct acpi_madt_lapic { + u8 type; /* Type (0) */ + u8 length; /* Length in bytes (8) */ + u8 processor_id; /* ACPI processor ID */ + u8 apic_id; /* Local APIC ID */ + u32 flags; /* Local APIC flags */ +}; + +/* MADT: I/O APIC Structure */ +struct acpi_madt_ioapic { + u8 type; /* Type (1) */ + u8 length; /* Length in bytes (12) */ + u8 ioapic_id; /* I/O APIC ID */ + u8 reserved; + u32 ioapic_addr; /* I/O APIC address */ + u32 gsi_base; /* Global system interrupt base */ +}; + +/* MADT: Interrupt Source Override Structure */ +struct __packed acpi_madt_irqoverride { + u8 type; /* Type (2) */ + u8 length; /* Length in bytes (10) */ + u8 bus; /* ISA (0) */ + u8 source; /* Bus-relative int. source (IRQ) */ + u32 gsirq; /* Global system interrupt */ + u16 flags; /* MPS INTI flags */ +}; + +/* MADT: Local APIC NMI Structure */ +struct __packed acpi_madt_lapic_nmi { + u8 type; /* Type (4) */ + u8 length; /* Length in bytes (6) */ + u8 processor_id; /* ACPI processor ID */ + u16 flags; /* MPS INTI flags */ + u8 lint; /* Local APIC LINT# */ +}; + +/* MCFG (PCI Express MMIO config space BAR description table) */ +struct acpi_mcfg { + struct acpi_table_header header; + u8 reserved[8]; +}; + +struct acpi_mcfg_mmconfig { + u32 base_address_l; + u32 base_address_h; + u16 pci_segment_group_number; + u8 start_bus_number; + u8 end_bus_number; + u8 reserved[4]; +}; + +/* PM1_CNT bit defines */ +#define PM1_CNT_SCI_EN BIT(0) + +/* ACPI global NVS structure */ +struct acpi_global_nvs; + +/* CSRT (Core System Resource Table) */ +struct acpi_csrt { + struct acpi_table_header header; +}; + +struct acpi_csrt_group { + u32 length; + u32 vendor_id; + u32 subvendor_id; + u16 device_id; + u16 subdevice_id; + u16 revision; + u16 reserved; + u32 shared_info_length; +}; + +struct acpi_csrt_shared_info { + u16 major_version; + u16 minor_version; + u32 mmio_base_low; + u32 mmio_base_high; + u32 gsi_interrupt; + u8 interrupt_polarity; + u8 interrupt_mode; + u8 num_channels; + u8 dma_address_width; + u16 base_request_line; + u16 num_handshake_signals; + u32 max_block_size; +}; + +/* DBG2 definitions are partially used for SPCR interface_type */ + +/* Types for port_type field */ + +#define ACPI_DBG2_SERIAL_PORT 0x8000 +#define ACPI_DBG2_1394_PORT 0x8001 +#define ACPI_DBG2_USB_PORT 0x8002 +#define ACPI_DBG2_NET_PORT 0x8003 + +/* Subtypes for port_subtype field */ + +#define ACPI_DBG2_16550_COMPATIBLE 0x0000 +#define ACPI_DBG2_16550_SUBSET 0x0001 +#define ACPI_DBG2_ARM_PL011 0x0003 +#define ACPI_DBG2_ARM_SBSA_32BIT 0x000D +#define ACPI_DBG2_ARM_SBSA_GENERIC 0x000E +#define ACPI_DBG2_ARM_DCC 0x000F +#define ACPI_DBG2_BCM2835 0x0010 + +#define ACPI_DBG2_1394_STANDARD 0x0000 + +#define ACPI_DBG2_USB_XHCI 0x0000 +#define ACPI_DBG2_USB_EHCI 0x0001 + +#define ACPI_DBG2_UNKNOWN 0x00FF + +/* SPCR (Serial Port Console Redirection table) */ +struct __packed acpi_spcr { + struct acpi_table_header header; + u8 interface_type; + u8 reserved[3]; + struct acpi_gen_regaddr serial_port; + u8 interrupt_type; + u8 pc_interrupt; + u32 interrupt; /* Global system interrupt */ + u8 baud_rate; + u8 parity; + u8 stop_bits; + u8 flow_control; + u8 terminal_type; + u8 reserved1; + u16 pci_device_id; /* Must be 0xffff if not PCI device */ + u16 pci_vendor_id; /* Must be 0xffff if not PCI device */ + u8 pci_bus; + u8 pci_device; + u8 pci_function; + u32 pci_flags; + u8 pci_segment; + u32 reserved2; +}; + +#include <asm/acpi_table.h> + +#endif /* __ACPI_TABLE_H__ */ diff --git a/lib/efi_loader/efi_acpi.c b/lib/efi_loader/efi_acpi.c index a4e5e53d15e..9ae9c25c51e 100644 --- a/lib/efi_loader/efi_acpi.c +++ b/lib/efi_loader/efi_acpi.c @@ -7,7 +7,7 @@
#include <common.h> #include <efi_loader.h> -#include <asm/acpi_table.h> +#include <acpi/acpi_table.h>
static const efi_guid_t acpi_guid = EFI_ACPI_TABLE_GUID;
The ASL compiler cannot handle C structures and the like so needs some sort of header guard around these.
We already have an __ASSEMBLY__ #define but it seems best to create a new one for ACPI since the rules may be different.
Add the check to a few files that ACPI always includes.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com ---
Changes in v4: None Changes in v3: None Changes in v2: None
include/acpi/acpi_table.h | 4 ++++ include/dm/acpi.h | 4 ++++ scripts/Makefile.lib | 4 ++-- 3 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index b4404a632c0..dd748958136 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -21,6 +21,8 @@ #define ACPI_RSDP_REV_ACPI_1_0 0 #define ACPI_RSDP_REV_ACPI_2_0 2
+#if !defined(__ACPI__) + /* * RSDP (Root System Description Pointer) * Note: ACPI 1.0 didn't have length, xsdt_address, and ext_checksum @@ -389,6 +391,8 @@ struct __packed acpi_spcr { u32 reserved2; };
+#endif /* !__ACPI__*/ + #include <asm/acpi_table.h>
#endif /* __ACPI_TABLE_H__ */ diff --git a/include/dm/acpi.h b/include/dm/acpi.h index c13d0c8448a..ee218b44e85 100644 --- a/include/dm/acpi.h +++ b/include/dm/acpi.h @@ -22,6 +22,8 @@ /* Length of an ACPI name string including nul terminator */ #define ACPI_NAME_MAX (ACPI_NAME_LEN + 1)
+#if !defined(__ACPI__) + /** * struct acpi_ops - ACPI operations supported by driver model */ @@ -70,4 +72,6 @@ int acpi_get_name(const struct udevice *dev, char *out_name); */ int acpi_copy_name(char *out_name, const char *name);
+#endif /* __ACPI__ */ + #endif diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 30f392fdfb0..aebdb38d0d2 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -413,8 +413,8 @@ ASL_TMP = $(patsubst %.c,%.asl.tmp,$@)
quiet_cmd_acpi_c_asl= ASL $< cmd_acpi_c_asl= \ - $(CPP) -x assembler-with-cpp -D__ASSEMBLY__ -P $(UBOOTINCLUDE) \ - -o $(ASL_TMP) $< && \ + $(CPP) -x assembler-with-cpp -D__ASSEMBLY__ -D__ACPI__ \ + -P $(UBOOTINCLUDE) -o $(ASL_TMP) $< && \ iasl -p $@ -tc $(ASL_TMP) $(if $(KBUILD_VERBOSE:1=), >/dev/null) && \ mv $(patsubst %.c,%.hex,$@) $@
Each ACPI table has its own version number. Add the version numbers in a single function so we can keep them consistent and easily see what versions are supported.
Start a new acpi_table file in a generic directory to house this function. We can move things over to this file from x86 as needed.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com ---
Changes in v4: - Move ACPI makefile line outside the ifdef CONFIG_SPL_BUILD - Add a comment about the MADT table version - Add SPCR - Update comment to include tables defined or reserved by ACPI
Changes in v3: - Fix file comment for acpi_table.c - Fix a few typos
Changes in v2: - Move the sandbox acpi_table.h header file to an earlier patch - Use #defines for MADT and MCFG version numbers
include/acpi/acpi_table.h | 62 +++++++++++++++++++++++++++++++++++++++ lib/Makefile | 1 + lib/acpi/Makefile | 4 +++ lib/acpi/acpi_table.c | 62 +++++++++++++++++++++++++++++++++++++++ test/dm/acpi.c | 14 +++++++++ 5 files changed, 143 insertions(+) create mode 100644 lib/acpi/Makefile create mode 100644 lib/acpi/acpi_table.c
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index dd748958136..286ff2a20d6 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -202,6 +202,26 @@ struct __packed acpi_fadt { struct acpi_gen_regaddr x_gpe1_blk; };
+/* FADT TABLE Revision values */ +#define ACPI_FADT_REV_ACPI_1_0 1 +#define ACPI_FADT_REV_ACPI_2_0 3 +#define ACPI_FADT_REV_ACPI_3_0 4 +#define ACPI_FADT_REV_ACPI_4_0 4 +#define ACPI_FADT_REV_ACPI_5_0 5 +#define ACPI_FADT_REV_ACPI_6_0 6 + +/* MADT TABLE Revision values - note these do not match the ACPI revision */ +#define ACPI_MADT_REV_ACPI_3_0 2 +#define ACPI_MADT_REV_ACPI_4_0 3 +#define ACPI_MADT_REV_ACPI_5_0 3 +#define ACPI_MADT_REV_ACPI_6_0 5 + +#define ACPI_MCFG_REV_ACPI_3_0 1 + +/* IVRS Revision Field */ +#define IVRS_FORMAT_FIXED 0x01 /* Type 10h & 11h only */ +#define IVRS_FORMAT_MIXED 0x02 /* Type 10h, 11h, & 40h */ + /* FACS flags */ #define ACPI_FACS_S4BIOS_F BIT(0) #define ACPI_FACS_64BIT_WAKE_F BIT(1) @@ -391,6 +411,48 @@ struct __packed acpi_spcr { u32 reserved2; };
+/* Tables defined/reserved by ACPI and generated by U-Boot */ +enum acpi_tables { + ACPITAB_BERT, + ACPITAB_DBG2, + ACPITAB_DMAR, + ACPITAB_DSDT, + ACPITAB_ECDT, + ACPITAB_FACS, + ACPITAB_FADT, + ACPITAB_HEST, + ACPITAB_HPET, + ACPITAB_IVRS, + ACPITAB_MADT, + ACPITAB_MCFG, + ACPITAB_RSDP, + ACPITAB_RSDT, + ACPITAB_SLIT, + ACPITAB_SPCR, + ACPITAB_SRAT, + ACPITAB_SSDT, + ACPITAB_TCPA, + ACPITAB_TPM2, + ACPITAB_XSDT, + + /* Additional proprietary tables */ + ACPITAB_NHLT, + ACPITAB_SPMI, + ACPITAB_VFCT, + + ACPITAB_COUNT, +}; + +/** + * acpi_get_table_revision() - Get the revision number generated for a table + * + * This keeps the version-number information in one place + * + * @table: ACPI table to check + * @return version number that U-Boot generates + */ +int acpi_get_table_revision(enum acpi_tables table); + #endif /* !__ACPI__*/
#include <asm/acpi_table.h> diff --git a/lib/Makefile b/lib/Makefile index 15259d0473c..5bd6f57482e 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -58,6 +58,7 @@ obj-$(CONFIG_TPM_V1) += tpm-v1.o obj-$(CONFIG_TPM_V2) += tpm-v2.o endif
+obj-$(CONFIG_$(SPL_)ACPIGEN) += acpi/ obj-$(CONFIG_$(SPL_)RSA) += rsa/ obj-$(CONFIG_SHA1) += sha1.o obj-$(CONFIG_SHA256) += sha256.o diff --git a/lib/acpi/Makefile b/lib/acpi/Makefile new file mode 100644 index 00000000000..660491ef711 --- /dev/null +++ b/lib/acpi/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += acpi_table.o diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c new file mode 100644 index 00000000000..3268430cd1e --- /dev/null +++ b/lib/acpi/acpi_table.c @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Generic code used to generate ACPI tables + * + * Copyright 2019 Google LLC + */ + +#include <common.h> +#include <acpi/acpi_table.h> + +int acpi_get_table_revision(enum acpi_tables table) +{ + switch (table) { + case ACPITAB_FADT: + return ACPI_FADT_REV_ACPI_3_0; + case ACPITAB_MADT: + return ACPI_MADT_REV_ACPI_3_0; + case ACPITAB_MCFG: + return ACPI_MCFG_REV_ACPI_3_0; + case ACPITAB_TCPA: + /* This version and the rest are open-coded */ + return 2; + case ACPITAB_TPM2: + return 4; + case ACPITAB_SSDT: /* ACPI 3.0 upto 6.3: 2 */ + return 2; + case ACPITAB_SRAT: /* ACPI 2.0: 1, ACPI 3.0: 2, ACPI 4.0 to 6.3: 3 */ + return 1; /* TODO Should probably be upgraded to 2 */ + case ACPITAB_DMAR: + return 1; + case ACPITAB_SLIT: /* ACPI 2.0 upto 6.3: 1 */ + return 1; + case ACPITAB_SPMI: /* IMPI 2.0 */ + return 5; + case ACPITAB_HPET: /* Currently 1. Table added in ACPI 2.0 */ + return 1; + case ACPITAB_VFCT: /* ACPI 2.0/3.0/4.0: 1 */ + return 1; + case ACPITAB_IVRS: + return IVRS_FORMAT_FIXED; + case ACPITAB_DBG2: + return 0; + case ACPITAB_FACS: /* ACPI 2.0/3.0: 1, ACPI 4.0 to 6.3: 2 */ + return 1; + case ACPITAB_RSDT: /* ACPI 1.0 upto 6.3: 1 */ + return 1; + case ACPITAB_XSDT: /* ACPI 2.0 upto 6.3: 1 */ + return 1; + case ACPITAB_RSDP: /* ACPI 2.0 upto 6.3: 2 */ + return 2; + case ACPITAB_HEST: + return 1; + case ACPITAB_NHLT: + return 5; + case ACPITAB_BERT: + return 1; + case ACPITAB_SPCR: + return 2; + default: + return -EINVAL; + } +} diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 429993b9cc0..e5510e4323b 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -8,6 +8,7 @@
#include <common.h> #include <dm.h> +#include <acpi/acpi_table.h> #include <dm/acpi.h> #include <dm/test.h> #include <test/ut.h> @@ -53,3 +54,16 @@ static int dm_test_acpi_get_name(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_acpi_get_name, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test acpi_get_table_revision() */ +static int dm_test_acpi_get_table_revision(struct unit_test_state *uts) +{ + ut_asserteq(1, acpi_get_table_revision(ACPITAB_MCFG)); + ut_asserteq(2, acpi_get_table_revision(ACPITAB_RSDP)); + ut_asserteq(4, acpi_get_table_revision(ACPITAB_TPM2)); + ut_asserteq(-EINVAL, acpi_get_table_revision(ACPITAB_COUNT)); + + return 0; +} +DM_TEST(dm_test_acpi_get_table_revision, + DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Same comment?
/* MCFG TABLE Revision values */
+enum acpi_tables {
- ACPITAB_BERT,
- ACPITAB_DBG2,
- ACPITAB_DMAR,
- ACPITAB_DSDT,
- ACPITAB_ECDT,
- ACPITAB_FACS,
- ACPITAB_FADT,
- ACPITAB_HEST,
- ACPITAB_HPET,
- ACPITAB_IVRS,
- ACPITAB_MADT,
- ACPITAB_MCFG,
- ACPITAB_RSDP,
- ACPITAB_RSDT,
- ACPITAB_SLIT,
- ACPITAB_SPCR,
- ACPITAB_SRAT,
- ACPITAB_SSDT,
- ACPITAB_TCPA,
- ACPITAB_TPM2,
- ACPITAB_XSDT,
- /* Additional proprietary tables */
- ACPITAB_NHLT,
I didn't get the division. What proprietary means? For example NHLT spec is public now AFAIK. But SPCR, for instance, is an extension by Microsoft.
Perhaps the division can be 1st group: ACPI spec defined 2nd: PCI SIG defined 3rd: UEFI ACPI extensions
- ACPITAB_SPMI,
- ACPITAB_VFCT,
- ACPITAB_COUNT,
Comma at the end, if it is a terminator line, is redundant.
Hi Andy,
On Wed, 8 Apr 2020 at 11:20, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
Same comment?
From below? OK
+enum acpi_tables {
ACPITAB_BERT,
ACPITAB_DBG2,
ACPITAB_DMAR,
ACPITAB_DSDT,
ACPITAB_ECDT,
ACPITAB_FACS,
ACPITAB_FADT,
ACPITAB_HEST,
ACPITAB_HPET,
ACPITAB_IVRS,
ACPITAB_MADT,
ACPITAB_MCFG,
ACPITAB_RSDP,
ACPITAB_RSDT,
ACPITAB_SLIT,
ACPITAB_SPCR,
ACPITAB_SRAT,
ACPITAB_SSDT,
ACPITAB_TCPA,
ACPITAB_TPM2,
ACPITAB_XSDT,
ACPITAB_NHLT,
This seems silly. Let's just have them in alpha order.
ACPITAB_SPMI,
ACPITAB_VFCT,
ACPITAB_COUNT,
Indeed, but it is the typical style in U-Boot. I can change it.
The DMA Remapping Reporting (DMAR) table contains information about DMA remapping.
Add a version simple version of this table with only the minimum fields filled out. i.e. no entries.
Changes in v4: None Changes in v3: - Make use of BIT() - Fix DMA_ typo - Add missing error check in acpi_create_dmar() - Drop duplicate assert - Drop ASL_REVISION
Changes in v2: - Drop two unnecessary __packed - Move __packed to after struct
include/acpi/acpi_table.h | 54 +++++++++++++++++++++++++++++++++++++++ lib/acpi/acpi_table.c | 28 ++++++++++++++++++++ test/dm/acpi.c | 13 ++++++++++ 3 files changed, 95 insertions(+)
diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 286ff2a20d6..16048437a3f 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -360,6 +360,51 @@ struct acpi_csrt_shared_info { u32 max_block_size; };
+enum dmar_type { + DMAR_DRHD = 0, + DMAR_RMRR = 1, + DMAR_ATSR = 2, + DMAR_RHSA = 3, + DMAR_ANDD = 4 +}; + +enum { + DRHD_INCLUDE_PCI_ALL = BIT(0) +}; + +enum dmar_flags { + DMAR_INTR_REMAP = BIT(0), + DMAR_X2APIC_OPT_OUT = BIT(1), + DMAR_CTRL_PLATFORM_OPT_IN_FLAG = BIT(2), +}; + +struct dmar_entry { + u16 type; + u16 length; + u8 flags; + u8 reserved; + u16 segment; + u64 bar; +}; + +struct dmar_rmrr_entry { + u16 type; + u16 length; + u16 reserved; + u16 segment; + u64 bar; + u64 limit; +}; + +/* DMAR (DMA Remapping Reporting Structure) */ +struct __packed acpi_dmar { + struct acpi_table_header header; + u8 host_address_width; + u8 flags; + u8 reserved[10]; + struct dmar_entry structure[0]; +}; + /* DBG2 definitions are partially used for SPCR interface_type */
/* Types for port_type field */ @@ -453,6 +498,15 @@ enum acpi_tables { */ int acpi_get_table_revision(enum acpi_tables table);
+/** + * acpi_create_dmar() - Create a DMA Remapping Reporting (DMAR) table + * + * @dmar: Place to put the table + * @flags: DMAR flags to use + * @return 0 if OK, -ve on error + */ +int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags); + #endif /* !__ACPI__*/
#include <asm/acpi_table.h> diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 3268430cd1e..ec354102f87 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -7,6 +7,34 @@
#include <common.h> #include <acpi/acpi_table.h> +#include <dm.h> +#include <cpu.h> + +int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags) +{ + struct acpi_table_header *header = &dmar->header; + struct cpu_info info; + struct udevice *cpu; + int ret; + + ret = uclass_first_device(UCLASS_CPU, &cpu); + if (ret) + return log_msg_ret("cpu", ret); + ret = cpu_get_info(cpu, &info); + if (ret) + return log_msg_ret("info", ret); + memset((void *)dmar, 0, sizeof(struct acpi_dmar)); + + /* Fill out header fields. */ + acpi_fill_header(&dmar->header, "DMAR"); + header->length = sizeof(struct acpi_dmar); + header->revision = acpi_get_table_revision(ACPITAB_DMAR); + + dmar->host_address_width = info.address_width - 1; + dmar->flags = flags; + + return 0; +}
int acpi_get_table_revision(enum acpi_tables table) { diff --git a/test/dm/acpi.c b/test/dm/acpi.c index e5510e4323b..21ed7c74409 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -67,3 +67,16 @@ static int dm_test_acpi_get_table_revision(struct unit_test_state *uts) } DM_TEST(dm_test_acpi_get_table_revision, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test acpi_create_dmar() */ +static int dm_test_acpi_create_dmar(struct unit_test_state *uts) +{ + struct acpi_dmar dmar; + + ut_assertok(acpi_create_dmar(&dmar, DMAR_INTR_REMAP)); + ut_asserteq(DMAR_INTR_REMAP, dmar.flags); + ut_asserteq(32 - 1, dmar.host_address_width); + + return 0; +} +DM_TEST(dm_test_acpi_create_dmar, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Since ut_asserteq_mem() uses bin2hex() we should include this header in ut.h to avoid errors. Add it.
Changes in v4: None Changes in v3: - Add new patch to add hexdump.h to the unit test header
Changes in v2: None
include/test/ut.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/test/ut.h b/include/test/ut.h index 04df8ba3af3..39d15953ed3 100644 --- a/include/test/ut.h +++ b/include/test/ut.h @@ -8,6 +8,7 @@ #ifndef __TEST_UT_H #define __TEST_UT_H
+#include <hexdump.h> #include <linux/err.h>
struct unit_test_state;
A device may want to write out ACPI tables to describe itself to Linux. Add a method to permit this.
Reviewed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v4: - Separate out the log newline
Changes in v3: None Changes in v2: - Drop definition of ACPI_TABLE_CREATOR - Make _acpi_write_dev_tables() static and switch argument order - Generalise the ACPI function recursion with acpi_recurse_method()
arch/sandbox/dts/test.dts | 4 +++ arch/x86/lib/acpi_table.c | 9 ----- drivers/core/acpi.c | 62 ++++++++++++++++++++++++++++++++++ include/acpi/acpi_table.h | 10 ++++++ include/dm/acpi.h | 30 +++++++++++++++++ lib/acpi/acpi_table.c | 10 ++++++ test/dm/acpi.c | 71 +++++++++++++++++++++++++++++++++++++++ 7 files changed, 187 insertions(+), 9 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 5fa951ad4b6..1204c14b079 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -210,6 +210,10 @@ compatible = "denx,u-boot-acpi-test"; };
+ acpi-test2 { + compatible = "denx,u-boot-acpi-test"; + }; + clocks { clk_fixed: clk-fixed { compatible = "fixed-clock"; diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 4832364f3ca..98f97208339 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -60,15 +60,6 @@ static void acpi_write_rsdp(struct acpi_rsdp *rsdp, struct acpi_rsdt *rsdt, sizeof(struct acpi_rsdp)); }
-void acpi_fill_header(struct acpi_table_header *header, char *signature) -{ - memcpy(header->signature, signature, 4); - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, OEM_TABLE_ID, 8); - header->oem_revision = U_BOOT_BUILD_DATE; - memcpy(header->aslc_id, ASLC_ID, 4); -} - static void acpi_write_rsdt(struct acpi_rsdt *rsdt) { struct acpi_table_header *header = &(rsdt->header); diff --git a/drivers/core/acpi.c b/drivers/core/acpi.c index 0e64c21bf5b..8a6570c3b95 100644 --- a/drivers/core/acpi.c +++ b/drivers/core/acpi.c @@ -11,8 +11,17 @@ #include <common.h> #include <dm.h> #include <dm/acpi.h> +#include <dm/device-internal.h> #include <dm/root.h>
+/* Type of method to call */ +enum method_t { + METHOD_WRITE_TABLES, +}; + +/* Prototype for all methods */ +typedef int (*acpi_method)(const struct udevice *dev, struct acpi_ctx *ctx); + int acpi_copy_name(char *out_name, const char *name) { strncpy(out_name, name, ACPI_NAME_MAX); @@ -31,3 +40,56 @@ int acpi_get_name(const struct udevice *dev, char *out_name)
return -ENOSYS; } + +acpi_method acpi_get_method(struct udevice *dev, enum method_t method) +{ + struct acpi_ops *aops; + + aops = device_get_acpi_ops(dev); + if (aops) { + switch (method) { + case METHOD_WRITE_TABLES: + return aops->write_tables; + } + } + + return NULL; +} + +int acpi_recurse_method(struct acpi_ctx *ctx, struct udevice *parent, + enum method_t method) +{ + struct udevice *dev; + acpi_method func; + int ret; + + func = acpi_get_method(parent, method); + if (func) { + log_debug("\n"); + log_debug("- %s %p\n", parent->name, func); + ret = device_ofdata_to_platdata(parent); + if (ret) + return log_msg_ret("ofdata", ret); + ret = func(parent, ctx); + if (ret) + return log_msg_ret("func", ret); + } + device_foreach_child(dev, parent) { + ret = acpi_recurse_method(ctx, dev, method); + if (ret) + return log_msg_ret("recurse", ret); + } + + return 0; +} + +int acpi_write_dev_tables(struct acpi_ctx *ctx) +{ + int ret; + + log_debug("Writing device tables\n"); + ret = acpi_recurse_method(ctx, dm_root(), METHOD_WRITE_TABLES); + log_debug("Writing finished, err=%d\n", ret); + + return ret; +} diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 16048437a3f..7f44b0434b9 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -507,6 +507,16 @@ int acpi_get_table_revision(enum acpi_tables table); */ int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags);
+/** + * acpi_fill_header() - Set up a new table header + * + * This sets all fields except length, revision, checksum and aslc_revision + * + * @header: ACPI header to update + * @signature: Table signature to use (4 characters) + */ +void acpi_fill_header(struct acpi_table_header *header, char *signature); + #endif /* !__ACPI__*/
#include <asm/acpi_table.h> diff --git a/include/dm/acpi.h b/include/dm/acpi.h index ee218b44e85..9a0a437dd03 100644 --- a/include/dm/acpi.h +++ b/include/dm/acpi.h @@ -24,6 +24,17 @@
+/** + * struct acpi_ctx - Context used for writing ACPI tables + * + * This contains a few useful pieces of information used when writing + * + * @current: Current address for writing + */ +struct acpi_ctx { + void *current; +}; + /** * struct acpi_ops - ACPI operations supported by driver model */ @@ -38,6 +49,15 @@ struct acpi_ops { * other error */ int (*get_name)(const struct udevice *dev, char *out_name); + + /** + * write_tables() - Write out any tables required by this device + * + * @dev: Device to write + * @ctx: ACPI context to use + * @return 0 if OK, -ve on error + */ + int (*write_tables)(const struct udevice *dev, struct acpi_ctx *ctx); };
#define device_get_acpi_ops(dev) ((dev)->driver->acpi_ops) @@ -72,6 +92,16 @@ int acpi_get_name(const struct udevice *dev, char *out_name); */ int acpi_copy_name(char *out_name, const char *name);
+/** + * acpi_write_dev_tables() - Write ACPI tables required by devices + * + * This scans through all devices and tells them to write any tables they want + * to write. + * + * @return 0 if OK, -ve if any device returned an error + */ +int acpi_write_dev_tables(struct acpi_ctx *ctx); + #endif /* __ACPI__ */
#endif diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index ec354102f87..372f19b16d5 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -9,6 +9,7 @@ #include <acpi/acpi_table.h> #include <dm.h> #include <cpu.h> +#include <version.h>
int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags) { @@ -88,3 +89,12 @@ int acpi_get_table_revision(enum acpi_tables table) return -EINVAL; } } + +void acpi_fill_header(struct acpi_table_header *header, char *signature) +{ + memcpy(header->signature, signature, 4); + memcpy(header->oem_id, OEM_ID, 6); + memcpy(header->oem_table_id, OEM_TABLE_ID, 8); + header->oem_revision = U_BOOT_BUILD_DATE; + memcpy(header->aslc_id, ASLC_ID, 4); +} diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 21ed7c74409..5743530a3a5 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -8,12 +8,26 @@
#include <common.h> #include <dm.h> +#include <version.h> #include <acpi/acpi_table.h> #include <dm/acpi.h> #include <dm/test.h> #include <test/ut.h>
#define ACPI_TEST_DEV_NAME "ABCD" +#define BUF_SIZE 4096 + +static int testacpi_write_tables(const struct udevice *dev, + struct acpi_ctx *ctx) +{ + struct acpi_dmar *dmar; + + dmar = (struct acpi_dmar *)ctx->current; + acpi_create_dmar(dmar, DMAR_INTR_REMAP); + ctx->current += sizeof(struct acpi_dmar); + + return 0; +}
static int testacpi_get_name(const struct udevice *dev, char *out_name) { @@ -22,6 +36,7 @@ static int testacpi_get_name(const struct udevice *dev, char *out_name)
struct acpi_ops testacpi_ops = { .get_name = testacpi_get_name, + .write_tables = testacpi_write_tables, };
static const struct udevice_id testacpi_ids[] = { @@ -80,3 +95,59 @@ static int dm_test_acpi_create_dmar(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_acpi_create_dmar, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test acpi_fill_header() */ +static int dm_test_acpi_fill_header(struct unit_test_state *uts) +{ + struct acpi_table_header hdr; + + /* Make sure these 5 fields are not changed */ + hdr.length = 0x11; + hdr.revision = 0x22; + hdr.checksum = 0x33; + hdr.aslc_revision = 0x44; + acpi_fill_header(&hdr, "ABCD"); + + ut_asserteq_mem("ABCD", hdr.signature, sizeof(hdr.signature)); + ut_asserteq(0x11, hdr.length); + ut_asserteq(0x22, hdr.revision); + ut_asserteq(0x33, hdr.checksum); + ut_asserteq_mem(OEM_ID, hdr.oem_id, sizeof(hdr.oem_id)); + ut_asserteq_mem(OEM_TABLE_ID, hdr.oem_table_id, + sizeof(hdr.oem_table_id)); + ut_asserteq(U_BOOT_BUILD_DATE, hdr.oem_revision); + ut_asserteq_mem(ASLC_ID, hdr.aslc_id, sizeof(hdr.aslc_id)); + ut_asserteq(0x44, hdr.aslc_revision); + + return 0; +} +DM_TEST(dm_test_acpi_fill_header, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test ACPI write_tables() */ +static int dm_test_acpi_write_tables(struct unit_test_state *uts) +{ + struct acpi_dmar *dmar; + struct acpi_ctx ctx; + void *buf; + + buf = malloc(BUF_SIZE); + ut_assertnonnull(buf); + + ctx.current = buf; + ut_assertok(acpi_write_dev_tables(&ctx)); + dmar = buf; + + /* + * We should have two dmar tables, one for each "denx,u-boot-acpi-test" + * device + */ + ut_asserteq_ptr(dmar + 2, ctx.current); + ut_asserteq(DMAR_INTR_REMAP, dmar->flags); + ut_asserteq(32 - 1, dmar->host_address_width); + + ut_asserteq(DMAR_INTR_REMAP, dmar[1].flags); + ut_asserteq(32 - 1, dmar[1].host_address_width); + + return 0; +} +DM_TEST(dm_test_acpi_write_tables, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
The current code uses an address but a pointer would result in fewer casts. Also it repeats the alignment code in a lot of places so this would be better done in a helper function.
Update write_acpi_tables() to make use of the new acpi_ctx structure, adding a few helpers to clean things up.
Changes in v4: - Update comment in acpi_inc_align() to show the alignment
Changes in v3: - Rename acpi_align_large() to acpi_align64()
Changes in v2: None
arch/x86/lib/acpi_table.c | 88 +++++++++++++++++++-------------------- include/acpi/acpi_table.h | 36 ++++++++++++++++ lib/acpi/acpi_table.c | 24 ++++++++++- test/dm/acpi.c | 28 +++++++++++++ 4 files changed, 130 insertions(+), 46 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 98f97208339..484cf66bf4e 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -10,6 +10,7 @@ #include <cpu.h> #include <dm.h> #include <dm/uclass-internal.h> +#include <mapmem.h> #include <serial.h> #include <version.h> #include <acpi/acpi_table.h> @@ -19,6 +20,7 @@ #include <asm/mpspec.h> #include <asm/tables.h> #include <asm/arch/global_nvs.h> +#include <dm/acpi.h>
/* * IASL compiles the dsdt entries and writes the hex values @@ -469,9 +471,9 @@ static void acpi_create_spcr(struct acpi_spcr *spcr) /* * QEMU's version of write_acpi_tables is defined in drivers/misc/qfw.c */ -ulong write_acpi_tables(ulong start) +ulong write_acpi_tables(ulong start_addr) { - u32 current; + struct acpi_ctx sctx, *ctx = &sctx; struct acpi_rsdp *rsdp; struct acpi_rsdt *rsdt; struct acpi_xsdt *xsdt; @@ -482,60 +484,61 @@ ulong write_acpi_tables(ulong start) struct acpi_madt *madt; struct acpi_csrt *csrt; struct acpi_spcr *spcr; + void *start; + ulong addr; int i;
- current = start; + start = map_sysmem(start_addr, 0); + ctx->current = start;
/* Align ACPI tables to 16 byte */ - current = ALIGN(current, 16); + acpi_align(ctx);
- debug("ACPI: Writing ACPI tables at %lx\n", start); + debug("ACPI: Writing ACPI tables at %lx\n", start_addr);
/* We need at least an RSDP and an RSDT Table */ - rsdp = (struct acpi_rsdp *)current; - current += sizeof(struct acpi_rsdp); - current = ALIGN(current, 16); - rsdt = (struct acpi_rsdt *)current; - current += sizeof(struct acpi_rsdt); - current = ALIGN(current, 16); - xsdt = (struct acpi_xsdt *)current; - current += sizeof(struct acpi_xsdt); + rsdp = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_rsdp)); + rsdt = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_rsdt)); + xsdt = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_xsdt)); /* * Per ACPI spec, the FACS table address must be aligned to a 64 byte * boundary (Windows checks this, but Linux does not). */ - current = ALIGN(current, 64); + acpi_align64(ctx);
/* clear all table memory */ - memset((void *)start, 0, current - start); + memset((void *)start, 0, ctx->current - start);
acpi_write_rsdp(rsdp, rsdt, xsdt); acpi_write_rsdt(rsdt); acpi_write_xsdt(xsdt);
debug("ACPI: * FACS\n"); - facs = (struct acpi_facs *)current; - current += sizeof(struct acpi_facs); - current = ALIGN(current, 16); + facs = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_facs));
acpi_create_facs(facs);
debug("ACPI: * DSDT\n"); - dsdt = (struct acpi_table_header *)current; + dsdt = ctx->current; memcpy(dsdt, &AmlCode, sizeof(struct acpi_table_header)); - current += sizeof(struct acpi_table_header); - memcpy((char *)current, + acpi_inc(ctx, sizeof(struct acpi_table_header)); + memcpy(ctx->current, (char *)&AmlCode + sizeof(struct acpi_table_header), dsdt->length - sizeof(struct acpi_table_header)); - current += dsdt->length - sizeof(struct acpi_table_header); - current = ALIGN(current, 16); + acpi_inc_align(ctx, dsdt->length - sizeof(struct acpi_table_header));
/* Pack GNVS into the ACPI table area */ for (i = 0; i < dsdt->length; i++) { u32 *gnvs = (u32 *)((u32)dsdt + i); if (*gnvs == ACPI_GNVS_ADDR) { - debug("Fix up global NVS in DSDT to 0x%08x\n", current); - *gnvs = current; + ulong addr = (ulong)map_to_sysmem(ctx->current); + + debug("Fix up global NVS in DSDT to %#08lx\n", addr); + *gnvs = addr; break; } } @@ -545,51 +548,46 @@ ulong write_acpi_tables(ulong start) dsdt->checksum = table_compute_checksum((void *)dsdt, dsdt->length);
/* Fill in platform-specific global NVS variables */ - acpi_create_gnvs((struct acpi_global_nvs *)current); - current += sizeof(struct acpi_global_nvs); - current = ALIGN(current, 16); + acpi_create_gnvs(ctx->current); + acpi_inc_align(ctx, sizeof(struct acpi_global_nvs));
debug("ACPI: * FADT\n"); - fadt = (struct acpi_fadt *)current; - current += sizeof(struct acpi_fadt); - current = ALIGN(current, 16); + fadt = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_fadt)); acpi_create_fadt(fadt, facs, dsdt); acpi_add_table(rsdp, fadt);
debug("ACPI: * MADT\n"); - madt = (struct acpi_madt *)current; + madt = ctx->current; acpi_create_madt(madt); - current += madt->header.length; + acpi_inc_align(ctx, madt->header.length); acpi_add_table(rsdp, madt); - current = ALIGN(current, 16);
debug("ACPI: * MCFG\n"); - mcfg = (struct acpi_mcfg *)current; + mcfg = ctx->current; acpi_create_mcfg(mcfg); - current += mcfg->header.length; + acpi_inc_align(ctx, mcfg->header.length); acpi_add_table(rsdp, mcfg); - current = ALIGN(current, 16);
debug("ACPI: * CSRT\n"); - csrt = (struct acpi_csrt *)current; + csrt = ctx->current; acpi_create_csrt(csrt); - current += csrt->header.length; + acpi_inc_align(ctx, csrt->header.length); acpi_add_table(rsdp, csrt); - current = ALIGN(current, 16);
debug("ACPI: * SPCR\n"); - spcr = (struct acpi_spcr *)current; + spcr = ctx->current; acpi_create_spcr(spcr); - current += spcr->header.length; + acpi_inc_align(ctx, spcr->header.length); acpi_add_table(rsdp, spcr); - current = ALIGN(current, 16);
- debug("current = %x\n", current); + addr = map_to_sysmem(ctx->current); + debug("current = %lx\n", addr);
acpi_rsdp_addr = (unsigned long)rsdp; debug("ACPI: done\n");
- return current; + return addr; }
ulong acpi_get_rsdp_addr(void) diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 7f44b0434b9..6cca092b965 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -23,6 +23,8 @@
+struct acpi_ctx; + /* * RSDP (Root System Description Pointer) * Note: ACPI 1.0 didn't have length, xsdt_address, and ext_checksum @@ -517,6 +519,40 @@ int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags); */ void acpi_fill_header(struct acpi_table_header *header, char *signature);
+/** + * acpi_align() - Align the ACPI output pointer to a 16-byte boundary + * + * @ctx: ACPI context + */ +void acpi_align(struct acpi_ctx *ctx); + +/** + * acpi_align64() - Align the ACPI output pointer to a 64-byte boundary + * + * @ctx: ACPI context + */ +void acpi_align64(struct acpi_ctx *ctx); + +/** + * acpi_inc() - Increment the ACPI output pointer by a bit + * + * The pointer is NOT aligned afterwards. + * + * @ctx: ACPI context + * @amount: Amount to increment by + */ +void acpi_inc(struct acpi_ctx *ctx, uint amount); + +/** + * acpi_inc_align() - Increment the ACPI output pointer by a bit and align + * + * The pointer is aligned afterwards to a 16-byte boundary + * + * @ctx: ACPI context + * @amount: Amount to increment by + */ +void acpi_inc_align(struct acpi_ctx *ctx, uint amount); + #endif /* !__ACPI__*/
#include <asm/acpi_table.h> diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 372f19b16d5..07d9bbb0afa 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -6,10 +6,11 @@ */
#include <common.h> -#include <acpi/acpi_table.h> #include <dm.h> #include <cpu.h> #include <version.h> +#include <acpi/acpi_table.h> +#include <dm/acpi.h>
int acpi_create_dmar(struct acpi_dmar *dmar, enum dmar_flags flags) { @@ -98,3 +99,24 @@ void acpi_fill_header(struct acpi_table_header *header, char *signature) header->oem_revision = U_BOOT_BUILD_DATE; memcpy(header->aslc_id, ASLC_ID, 4); } + +void acpi_align(struct acpi_ctx *ctx) +{ + ctx->current = (void *)ALIGN((ulong)ctx->current, 16); +} + +void acpi_align64(struct acpi_ctx *ctx) +{ + ctx->current = (void *)ALIGN((ulong)ctx->current, 64); +} + +void acpi_inc(struct acpi_ctx *ctx, uint amount) +{ + ctx->current += amount; +} + +void acpi_inc_align(struct acpi_ctx *ctx, uint amount) +{ + ctx->current += amount; + acpi_align(ctx); +} diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 5743530a3a5..17e208ee80e 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -151,3 +151,31 @@ static int dm_test_acpi_write_tables(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_acpi_write_tables, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test basic ACPI functions */ +static int dm_test_acpi_basic(struct unit_test_state *uts) +{ + struct acpi_ctx ctx; + + /* Check align works */ + ctx.current = (void *)5; + acpi_align(&ctx); + ut_asserteq_ptr((void *)16, ctx.current); + + /* Check that align does nothing if already aligned */ + acpi_align(&ctx); + ut_asserteq_ptr((void *)16, ctx.current); + acpi_align64(&ctx); + ut_asserteq_ptr((void *)64, ctx.current); + acpi_align64(&ctx); + ut_asserteq_ptr((void *)64, ctx.current); + + /* Check incrementing */ + acpi_inc(&ctx, 3); + ut_asserteq_ptr((void *)67, ctx.current); + acpi_inc_align(&ctx, 3); + ut_asserteq_ptr((void *)80, ctx.current); + + return 0; +} +DM_TEST(dm_test_acpi_basic, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Call the new core function to permit devices to write their own ACPI tables. These tables will appear after all other tables.
arch/x86/lib/acpi_table.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 484cf66bf4e..99523473a17 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -581,6 +581,8 @@ ulong write_acpi_tables(ulong start_addr) acpi_inc_align(ctx, spcr->header.length); acpi_add_table(rsdp, spcr);
+ acpi_write_dev_tables(ctx); + addr = map_to_sysmem(ctx->current); debug("current = %lx\n", addr);
We don't actually support tables without an XSDT so we can drop this dead code.
arch/x86/lib/acpi_table.c | 15 ++------------- 1 file changed, 2 insertions(+), 13 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index 99523473a17..e8f0bb18fc5 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -42,19 +42,8 @@ static void acpi_write_rsdp(struct acpi_rsdp *rsdp, struct acpi_rsdt *rsdt, rsdp->length = sizeof(struct acpi_rsdp); rsdp->rsdt_address = (u32)rsdt;
- /* - * Revision: ACPI 1.0: 0, ACPI 2.0/3.0/4.0: 2 - * - * Some OSes expect an XSDT to be present for RSD PTR revisions >= 2. - * If we don't have an ACPI XSDT, force ACPI 1.0 (and thus RSD PTR - * revision 0) - */ - if (xsdt == NULL) { - rsdp->revision = ACPI_RSDP_REV_ACPI_1_0; - } else { - rsdp->xsdt_address = (u64)(u32)xsdt; - rsdp->revision = ACPI_RSDP_REV_ACPI_2_0; - } + rsdp->xsdt_address = (u64)(u32)xsdt; + rsdp->revision = ACPI_RSDP_REV_ACPI_2_0;
/* Calculate checksums */ rsdp->checksum = table_compute_checksum((void *)rsdp, 20);
Move this code to a generic location so that we can test it with sandbox. This requires adding a few new fields to acpi_ctx, so drop the local variables used in the original code.
Also use mapmem to avoid pointer-to-address casts which don't work on sandbox.
Changes in v4: None Changes in v3: - Fix 'RSDP' typo
Changes in v2: None
arch/x86/lib/acpi_table.c | 83 +++++---------------------------------- include/acpi/acpi_table.h | 9 +++++ include/dm/acpi.h | 5 +++ lib/acpi/acpi_table.c | 61 ++++++++++++++++++++++++++++ test/dm/acpi.c | 4 ++ 5 files changed, 89 insertions(+), 73 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index e8f0bb18fc5..d4af56eabf4 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -83,67 +83,6 @@ static void acpi_write_xsdt(struct acpi_xsdt *xsdt) sizeof(struct acpi_xsdt)); }
-/** - * Add an ACPI table to the RSDT (and XSDT) structure, recalculate length - * and checksum. - */ -static void acpi_add_table(struct acpi_rsdp *rsdp, void *table) -{ - int i, entries_num; - struct acpi_rsdt *rsdt; - struct acpi_xsdt *xsdt; - - /* The RSDT is mandatory while the XSDT is not */ - rsdt = (struct acpi_rsdt *)rsdp->rsdt_address; - - /* This should always be MAX_ACPI_TABLES */ - entries_num = ARRAY_SIZE(rsdt->entry); - - for (i = 0; i < entries_num; i++) { - if (rsdt->entry[i] == 0) - break; - } - - if (i >= entries_num) { - debug("ACPI: Error: too many tables\n"); - return; - } - - /* Add table to the RSDT */ - rsdt->entry[i] = (u32)table; - - /* Fix RSDT length or the kernel will assume invalid entries */ - rsdt->header.length = sizeof(struct acpi_table_header) + - sizeof(u32) * (i + 1); - - /* Re-calculate checksum */ - rsdt->header.checksum = 0; - rsdt->header.checksum = table_compute_checksum((u8 *)rsdt, - rsdt->header.length); - - /* The RSDT is mandatory while the XSDT is not */ - if (!rsdp->xsdt_address) - return; - - /* - * And now the same thing for the XSDT. We use the same index as for - * now we want the XSDT and RSDT to always be in sync in U-Boot - */ - xsdt = (struct acpi_xsdt *)((u32)rsdp->xsdt_address); - - /* Add table to the XSDT */ - xsdt->entry[i] = (u64)(u32)table; - - /* Fix XSDT length */ - xsdt->header.length = sizeof(struct acpi_table_header) + - sizeof(u64) * (i + 1); - - /* Re-calculate checksum */ - xsdt->header.checksum = 0; - xsdt->header.checksum = table_compute_checksum((u8 *)xsdt, - xsdt->header.length); -} - static void acpi_create_facs(struct acpi_facs *facs) { memset((void *)facs, 0, sizeof(struct acpi_facs)); @@ -463,8 +402,6 @@ static void acpi_create_spcr(struct acpi_spcr *spcr) ulong write_acpi_tables(ulong start_addr) { struct acpi_ctx sctx, *ctx = &sctx; - struct acpi_rsdp *rsdp; - struct acpi_rsdt *rsdt; struct acpi_xsdt *xsdt; struct acpi_facs *facs; struct acpi_table_header *dsdt; @@ -486,9 +423,9 @@ ulong write_acpi_tables(ulong start_addr) debug("ACPI: Writing ACPI tables at %lx\n", start_addr);
/* We need at least an RSDP and an RSDT Table */ - rsdp = ctx->current; + ctx->rsdp = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_rsdp)); - rsdt = ctx->current; + ctx->rsdt = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_rsdt)); xsdt = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_xsdt)); @@ -501,8 +438,8 @@ ulong write_acpi_tables(ulong start_addr) /* clear all table memory */ memset((void *)start, 0, ctx->current - start);
- acpi_write_rsdp(rsdp, rsdt, xsdt); - acpi_write_rsdt(rsdt); + acpi_write_rsdp(ctx->rsdp, ctx->rsdt, xsdt); + acpi_write_rsdt(ctx->rsdt); acpi_write_xsdt(xsdt);
debug("ACPI: * FACS\n"); @@ -544,38 +481,38 @@ ulong write_acpi_tables(ulong start_addr) fadt = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_fadt)); acpi_create_fadt(fadt, facs, dsdt); - acpi_add_table(rsdp, fadt); + acpi_add_table(ctx, fadt);
debug("ACPI: * MADT\n"); madt = ctx->current; acpi_create_madt(madt); acpi_inc_align(ctx, madt->header.length); - acpi_add_table(rsdp, madt); + acpi_add_table(ctx, madt);
debug("ACPI: * MCFG\n"); mcfg = ctx->current; acpi_create_mcfg(mcfg); acpi_inc_align(ctx, mcfg->header.length); - acpi_add_table(rsdp, mcfg); + acpi_add_table(ctx, mcfg);
debug("ACPI: * CSRT\n"); csrt = ctx->current; acpi_create_csrt(csrt); acpi_inc_align(ctx, csrt->header.length); - acpi_add_table(rsdp, csrt); + acpi_add_table(ctx, csrt);
debug("ACPI: * SPCR\n"); spcr = ctx->current; acpi_create_spcr(spcr); acpi_inc_align(ctx, spcr->header.length); - acpi_add_table(rsdp, spcr); + acpi_add_table(ctx, spcr);
- acpi_rsdp_addr = (unsigned long)rsdp; + acpi_rsdp_addr = (unsigned long)ctx->rsdp; debug("ACPI: done\n");
return addr; diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 6cca092b965..6225a4c5ccb 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -553,6 +553,15 @@ void acpi_inc(struct acpi_ctx *ctx, uint amount); */ void acpi_inc_align(struct acpi_ctx *ctx, uint amount);
+/** + * acpi_add_table() - Add a new table to the RSDP and XSDT + * + * @ctx: ACPI context + * @table: Table to add + * @return 0 if OK, -E2BIG if too many tables + */ +int acpi_add_table(struct acpi_ctx *ctx, void *table); + #endif /* !__ACPI__*/
#include <asm/acpi_table.h> diff --git a/include/dm/acpi.h b/include/dm/acpi.h index 9a0a437dd03..ee6f7a63e79 100644 --- a/include/dm/acpi.h +++ b/include/dm/acpi.h @@ -30,9 +30,14 @@ * This contains a few useful pieces of information used when writing * * @current: Current address for writing + * @rsdp: Pointer to the Root System Description Pointer, typically used when + * adding a new table. The RSDP holds pointers to the RSDT and XSDT. + * @rsdt: Pointer to the Root System Description Table */ struct acpi_ctx { void *current; + struct acpi_rsdp *rsdp; + struct acpi_rsdt *rsdt; };
/** diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 07d9bbb0afa..5311ae9368b 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -8,6 +8,8 @@ #include <common.h> #include <dm.h> #include <cpu.h> +#include <mapmem.h> +#include <tables_csum.h> #include <version.h> #include <acpi/acpi_table.h> #include <dm/acpi.h> @@ -120,3 +122,62 @@ void acpi_inc_align(struct acpi_ctx *ctx, uint amount) ctx->current += amount; acpi_align(ctx); } + +/** + * Add an ACPI table to the RSDT (and XSDT) structure, recalculate length + * and checksum. + */ +int acpi_add_table(struct acpi_ctx *ctx, void *table) +{ + int i, entries_num; + struct acpi_rsdt *rsdt; + struct acpi_xsdt *xsdt; + + /* The RSDT is mandatory while the XSDT is not */ + rsdt = ctx->rsdt; + + /* This should always be MAX_ACPI_TABLES */ + entries_num = ARRAY_SIZE(rsdt->entry); + + for (i = 0; i < entries_num; i++) { + if (rsdt->entry[i] == 0) + break; + } + + if (i >= entries_num) { + debug("ACPI: Error: too many tables\n"); + return -E2BIG; + } + + /* Add table to the RSDT */ + rsdt->entry[i] = map_to_sysmem(table); + + /* Fix RSDT length or the kernel will assume invalid entries */ + rsdt->header.length = sizeof(struct acpi_table_header) + + (sizeof(u32) * (i + 1)); + + /* Re-calculate checksum */ + rsdt->header.checksum = 0; + rsdt->header.checksum = table_compute_checksum((u8 *)rsdt, + rsdt->header.length); + + /* + * And now the same thing for the XSDT. We use the same index as for + * now we want the XSDT and RSDT to always be in sync in U-Boot + */ + xsdt = (struct acpi_xsdt *)((uintptr_t)ctx->rsdp->xsdt_address); + + /* Add table to the XSDT */ + xsdt->entry[i] = map_to_sysmem(table); + + /* Fix XSDT length */ + xsdt->header.length = sizeof(struct acpi_table_header) + + (sizeof(u64) * (i + 1)); + + /* Re-calculate checksum */ + xsdt->header.checksum = 0; + xsdt->header.checksum = table_compute_checksum((u8 *)xsdt, + xsdt->header.length); + + return 0; +} diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 17e208ee80e..4dd4a540967 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -21,10 +21,14 @@ static int testacpi_write_tables(const struct udevice *dev, struct acpi_ctx *ctx) { struct acpi_dmar *dmar; + int ret;
dmar = (struct acpi_dmar *)ctx->current; acpi_create_dmar(dmar, DMAR_INTR_REMAP); ctx->current += sizeof(struct acpi_dmar); + ret = acpi_add_table(ctx, dmar); + if (ret) + return log_msg_ret("add", ret);
return 0; }
We always write three basic tables to ACPI at the start. Move this into its own function, along with acpi_fill_header(), so we can write a test for this code.
Changes in v4: - Put back cast on table_compute_checksum()
Changes in v3: - Fix 'XDST' typo - Move acpi_align_large() out of dm_test_acpi_setup_base_tables() - Beef up the comment explaining how the unaligned address is used
Changes in v2: None
arch/x86/lib/acpi_table.c | 72 +----------------------------------- include/acpi/acpi_table.h | 10 +++++ lib/acpi/acpi_table.c | 77 +++++++++++++++++++++++++++++++++++++++ test/dm/acpi.c | 58 ++++++++++++++++++++++++++++- 4 files changed, 144 insertions(+), 73 deletions(-)
diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c index d4af56eabf4..4a7b0739394 100644 --- a/arch/x86/lib/acpi_table.c +++ b/arch/x86/lib/acpi_table.c @@ -31,58 +31,6 @@ extern const unsigned char AmlCode[]; /* ACPI RSDP address to be used in boot parameters */ static ulong acpi_rsdp_addr;
-static void acpi_write_rsdp(struct acpi_rsdp *rsdp, struct acpi_rsdt *rsdt, - struct acpi_xsdt *xsdt) -{ - memset(rsdp, 0, sizeof(struct acpi_rsdp)); - - memcpy(rsdp->signature, RSDP_SIG, 8); - memcpy(rsdp->oem_id, OEM_ID, 6); - - rsdp->length = sizeof(struct acpi_rsdp); - rsdp->rsdt_address = (u32)rsdt; - - rsdp->xsdt_address = (u64)(u32)xsdt; - rsdp->revision = ACPI_RSDP_REV_ACPI_2_0; - - /* Calculate checksums */ - rsdp->checksum = table_compute_checksum((void *)rsdp, 20); - rsdp->ext_checksum = table_compute_checksum((void *)rsdp, - sizeof(struct acpi_rsdp)); -} - -static void acpi_write_rsdt(struct acpi_rsdt *rsdt) -{ - struct acpi_table_header *header = &(rsdt->header); - - /* Fill out header fields */ - acpi_fill_header(header, "RSDT"); - header->length = sizeof(struct acpi_rsdt); - header->revision = 1; - - /* Entries are filled in later, we come with an empty set */ - - /* Fix checksum */ - header->checksum = table_compute_checksum((void *)rsdt, - sizeof(struct acpi_rsdt)); -} - -static void acpi_write_xsdt(struct acpi_xsdt *xsdt) -{ - struct acpi_table_header *header = &(xsdt->header); - - /* Fill out header fields */ - acpi_fill_header(header, "XSDT"); - header->length = sizeof(struct acpi_xsdt); - header->revision = 1; - - /* Entries are filled in later, we come with an empty set */ - - /* Fix checksum */ - header->checksum = table_compute_checksum((void *)xsdt, - sizeof(struct acpi_xsdt)); -} - static void acpi_create_facs(struct acpi_facs *facs) { memset((void *)facs, 0, sizeof(struct acpi_facs)); @@ -402,7 +350,6 @@ static void acpi_create_spcr(struct acpi_spcr *spcr) ulong write_acpi_tables(ulong start_addr) { struct acpi_ctx sctx, *ctx = &sctx; - struct acpi_xsdt *xsdt; struct acpi_facs *facs; struct acpi_table_header *dsdt; struct acpi_fadt *fadt; @@ -415,33 +362,16 @@ ulong write_acpi_tables(ulong start_addr) int i;
start = map_sysmem(start_addr, 0); - ctx->current = start; - - /* Align ACPI tables to 16 byte */ - acpi_align(ctx);
- /* We need at least an RSDP and an RSDT Table */ - ctx->rsdp = ctx->current; - acpi_inc_align(ctx, sizeof(struct acpi_rsdp)); - ctx->rsdt = ctx->current; - acpi_inc_align(ctx, sizeof(struct acpi_rsdt)); - xsdt = ctx->current; - acpi_inc_align(ctx, sizeof(struct acpi_xsdt)); + acpi_setup_base_tables(ctx, start); /* * Per ACPI spec, the FACS table address must be aligned to a 64 byte * boundary (Windows checks this, but Linux does not). */ acpi_align64(ctx);
- /* clear all table memory */ - memset((void *)start, 0, ctx->current - start); - - acpi_write_rsdp(ctx->rsdp, ctx->rsdt, xsdt); - acpi_write_rsdt(ctx->rsdt); - acpi_write_xsdt(xsdt); - debug("ACPI: * FACS\n"); facs = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_facs)); diff --git a/include/acpi/acpi_table.h b/include/acpi/acpi_table.h index 6225a4c5ccb..48bf189c570 100644 --- a/include/acpi/acpi_table.h +++ b/include/acpi/acpi_table.h @@ -562,6 +562,16 @@ void acpi_inc_align(struct acpi_ctx *ctx, uint amount); */ int acpi_add_table(struct acpi_ctx *ctx, void *table);
+/** + * acpi_setup_base_tables() - Set up context along with RSDP, RSDT and XSDT + * + * Set up the context with the given start position. Some basic tables are + * always needed, so set them up as well. + * + * @ctx: Context to set up + */ +void acpi_setup_base_tables(struct acpi_ctx *ctx, void *start); + #endif /* !__ACPI__*/
#include <asm/acpi_table.h> diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 5311ae9368b..85193c49e45 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -181,3 +181,80 @@ int acpi_add_table(struct acpi_ctx *ctx, void *table)
return 0; } + +static void acpi_write_rsdp(struct acpi_rsdp *rsdp, struct acpi_rsdt *rsdt, + struct acpi_xsdt *xsdt) +{ + memset(rsdp, 0, sizeof(struct acpi_rsdp)); + + memcpy(rsdp->signature, RSDP_SIG, 8); + memcpy(rsdp->oem_id, OEM_ID, 6); + + rsdp->length = sizeof(struct acpi_rsdp); + rsdp->rsdt_address = map_to_sysmem(rsdt); + + rsdp->xsdt_address = map_to_sysmem(xsdt); + rsdp->revision = ACPI_RSDP_REV_ACPI_2_0; + + /* Calculate checksums */ + rsdp->checksum = table_compute_checksum(rsdp, 20); + rsdp->ext_checksum = table_compute_checksum(rsdp, + sizeof(struct acpi_rsdp)); +} + +static void acpi_write_rsdt(struct acpi_rsdt *rsdt) +{ + struct acpi_table_header *header = &rsdt->header; + + /* Fill out header fields */ + acpi_fill_header(header, "RSDT"); + header->length = sizeof(struct acpi_rsdt); + header->revision = 1; + + /* Entries are filled in later, we come with an empty set */ + + /* Fix checksum */ + header->checksum = table_compute_checksum(rsdt, + sizeof(struct acpi_rsdt)); +} + +static void acpi_write_xsdt(struct acpi_xsdt *xsdt) +{ + struct acpi_table_header *header = &xsdt->header; + + /* Fill out header fields */ + acpi_fill_header(header, "XSDT"); + header->length = sizeof(struct acpi_xsdt); + header->revision = 1; + + /* Entries are filled in later, we come with an empty set */ + + /* Fix checksum */ + header->checksum = table_compute_checksum(xsdt, + sizeof(struct acpi_xsdt)); +} + +void acpi_setup_base_tables(struct acpi_ctx *ctx, void *start) +{ + struct acpi_xsdt *xsdt; + + ctx->current = start; + + /* Align ACPI tables to 16 byte */ + acpi_align(ctx); + + /* We need at least an RSDP and an RSDT Table */ + ctx->rsdp = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_rsdp)); + ctx->rsdt = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_rsdt)); + xsdt = ctx->current; + acpi_inc_align(ctx, sizeof(struct acpi_xsdt)); + + /* clear all table memory */ + memset((void *)start, '\0', ctx->current - start); + + acpi_write_rsdp(ctx->rsdp, ctx->rsdt, xsdt); + acpi_write_rsdt(ctx->rsdt); + acpi_write_xsdt(xsdt); +} diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 4dd4a540967..5d5e46e2944 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -8,6 +8,9 @@
#include <common.h> #include <dm.h> +#include <malloc.h> +#include <mapmem.h> +#include <tables_csum.h> #include <version.h> #include <acpi/acpi_table.h> #include <dm/acpi.h> @@ -137,9 +140,9 @@ static int dm_test_acpi_write_tables(struct unit_test_state *uts) buf = malloc(BUF_SIZE); ut_assertnonnull(buf);
- ctx.current = buf; + acpi_setup_base_tables(&ctx, buf); + dmar = ctx.current; ut_assertok(acpi_write_dev_tables(&ctx)); - dmar = buf;
/* * We should have two dmar tables, one for each "denx,u-boot-acpi-test" @@ -152,6 +155,11 @@ static int dm_test_acpi_write_tables(struct unit_test_state *uts) ut_asserteq(DMAR_INTR_REMAP, dmar[1].flags); ut_asserteq(32 - 1, dmar[1].host_address_width);
+ /* Check that the pointers were added correctly */ + ut_asserteq(map_to_sysmem(dmar), ctx.rsdt->entry[0]); + ut_asserteq(map_to_sysmem(dmar + 1), ctx.rsdt->entry[1]); + ut_asserteq(0, ctx.rsdt->entry[2]); + return 0; } DM_TEST(dm_test_acpi_write_tables, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); @@ -183,3 +191,49 @@ static int dm_test_acpi_basic(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_acpi_basic, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test acpi_setup_base_tables */ +static int dm_test_acpi_setup_base_tables(struct unit_test_state *uts) +{ + struct acpi_rsdp *rsdp; + struct acpi_rsdt *rsdt; + struct acpi_xsdt *xsdt; + struct acpi_ctx ctx; + void *buf, *end; + + /* + * Use an unaligned address deliberately, by allocating an aligned + * address and then adding 4 to it + */ + buf = memalign(64, BUF_SIZE); + ut_assertnonnull(buf); + acpi_setup_base_tables(&ctx, buf + 4); + + rsdp = buf + 16; + ut_asserteq_ptr(rsdp, ctx.rsdp); + ut_assertok(memcmp(RSDP_SIG, rsdp->signature, sizeof(rsdp->signature))); + ut_asserteq(sizeof(*rsdp), rsdp->length); + ut_assertok(table_compute_checksum(rsdp, 20)); + ut_assertok(table_compute_checksum(rsdp, sizeof(*rsdp))); + + rsdt = PTR_ALIGN((void *)rsdp + sizeof(*rsdp), 16); + ut_asserteq_ptr(rsdt, ctx.rsdt); + ut_assertok(memcmp("RSDT", rsdt->header.signature, ACPI_NAME_LEN)); + ut_asserteq(sizeof(*rsdt), rsdt->header.length); + ut_assertok(table_compute_checksum(rsdt, sizeof(*rsdt))); + + xsdt = PTR_ALIGN((void *)rsdt + sizeof(*rsdt), 16); + ut_assertok(memcmp("XSDT", xsdt->header.signature, ACPI_NAME_LEN)); + ut_asserteq(sizeof(*xsdt), xsdt->header.length); + ut_assertok(table_compute_checksum(xsdt, sizeof(*xsdt))); + + end = PTR_ALIGN((void *)xsdt + sizeof(*xsdt), 64); + ut_asserteq_ptr(end, ctx.current); + + ut_asserteq(map_to_sysmem(rsdt), rsdp->rsdt_address); + ut_asserteq(map_to_sysmem(xsdt), rsdp->xsdt_address); + + return 0; +} +DM_TEST(dm_test_acpi_setup_base_tables, + DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Put this in the context along with the other important pointers.
include/dm/acpi.h | 2 ++ lib/acpi/acpi_table.c | 10 ++++------ test/dm/acpi.c | 5 +++++ 3 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/include/dm/acpi.h b/include/dm/acpi.h index ee6f7a63e79..288310b5128 100644 --- a/include/dm/acpi.h +++ b/include/dm/acpi.h @@ -33,11 +33,13 @@ * @rsdp: Pointer to the Root System Description Pointer, typically used when * adding a new table. The RSDP holds pointers to the RSDT and XSDT. * @rsdt: Pointer to the Root System Description Table + * @xsdt: Pointer to the Extended System Description Table */ struct acpi_ctx { void *current; struct acpi_rsdp *rsdp; struct acpi_rsdt *rsdt; + struct acpi_xsdt *xsdt; };
/** diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 85193c49e45..9d2b49f8ba5 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -165,7 +165,7 @@ int acpi_add_table(struct acpi_ctx *ctx, void *table) * And now the same thing for the XSDT. We use the same index as for * now we want the XSDT and RSDT to always be in sync in U-Boot */ - xsdt = (struct acpi_xsdt *)((uintptr_t)ctx->rsdp->xsdt_address); + xsdt = ctx->xsdt;
/* Add table to the XSDT */ xsdt->entry[i] = map_to_sysmem(table); @@ -236,8 +236,6 @@ static void acpi_write_xsdt(struct acpi_xsdt *xsdt)
void acpi_setup_base_tables(struct acpi_ctx *ctx, void *start) { - struct acpi_xsdt *xsdt; - ctx->current = start;
/* Align ACPI tables to 16 byte */ @@ -248,13 +246,13 @@ void acpi_setup_base_tables(struct acpi_ctx *ctx, void *start) acpi_inc_align(ctx, sizeof(struct acpi_rsdp)); ctx->rsdt = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_rsdt)); - xsdt = ctx->current; + ctx->xsdt = ctx->current; acpi_inc_align(ctx, sizeof(struct acpi_xsdt));
/* clear all table memory */ memset((void *)start, '\0', ctx->current - start);
- acpi_write_rsdp(ctx->rsdp, ctx->rsdt, xsdt); + acpi_write_rsdp(ctx->rsdp, ctx->rsdt, ctx->xsdt); acpi_write_rsdt(ctx->rsdt); - acpi_write_xsdt(xsdt); + acpi_write_xsdt(ctx->xsdt); } diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 5d5e46e2944..8e160d2cf4e 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -160,6 +160,10 @@ static int dm_test_acpi_write_tables(struct unit_test_state *uts) ut_asserteq(map_to_sysmem(dmar + 1), ctx.rsdt->entry[1]); ut_asserteq(0, ctx.rsdt->entry[2]);
+ ut_asserteq(map_to_sysmem(dmar), ctx.xsdt->entry[0]); + ut_asserteq(map_to_sysmem(dmar + 1), ctx.xsdt->entry[1]); + ut_asserteq(0, ctx.xsdt->entry[2]); + return 0; } DM_TEST(dm_test_acpi_write_tables, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); @@ -223,6 +227,7 @@ static int dm_test_acpi_setup_base_tables(struct unit_test_state *uts) ut_assertok(table_compute_checksum(rsdt, sizeof(*rsdt)));
xsdt = PTR_ALIGN((void *)rsdt + sizeof(*rsdt), 16); + ut_asserteq_ptr(xsdt, ctx.xsdt); ut_assertok(memcmp("XSDT", xsdt->header.signature, ACPI_NAME_LEN)); ut_asserteq(sizeof(*xsdt), xsdt->header.length); ut_assertok(table_compute_checksum(xsdt, sizeof(*xsdt)));
It is useful to dump ACPI tables in U-Boot to see what has been generated. Add a command to handle this.
To allow the command to find the tables, add a position into the global data.
Support subcommands to list and dump the tables.
Changes in v4: - Rename list_fact() to list_fadt() - Add a comment to dump_hdr()
arch/sandbox/include/asm/global_data.h | 1 + arch/x86/include/asm/global_data.h | 1 + cmd/Kconfig | 14 ++ cmd/Makefile | 1 + cmd/acpi.c | 186 +++++++++++++++++++++++++ lib/acpi/acpi_table.c | 1 + test/dm/acpi.c | 73 ++++++++++ 7 files changed, 277 insertions(+) create mode 100644 cmd/acpi.c
diff --git a/arch/sandbox/include/asm/global_data.h b/arch/sandbox/include/asm/global_data.h index f4ce72d5660..f95ddb058a2 100644 --- a/arch/sandbox/include/asm/global_data.h +++ b/arch/sandbox/include/asm/global_data.h @@ -13,6 +13,7 @@ struct arch_global_data { uint8_t *ram_buf; /* emulated RAM buffer */ void *text_base; /* pointer to base of text region */ + ulong acpi_start; /* Start address of ACPI tables */ };
#include <asm-generic/global_data.h> diff --git a/arch/x86/include/asm/global_data.h b/arch/x86/include/asm/global_data.h index f4c1839104e..4aee2f3e8c4 100644 --- a/arch/x86/include/asm/global_data.h +++ b/arch/x86/include/asm/global_data.h @@ -123,6 +123,7 @@ struct arch_global_data { #ifdef CONFIG_FSP_VERSION2 struct fsp_header *fsp_s_hdr; /* Pointer to FSP-S header */ #endif + ulong acpi_start; /* Start address of ACPI tables */ };
#endif diff --git a/cmd/Kconfig b/cmd/Kconfig index 6403bc45a5e..2d3bfe0ab91 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -190,6 +190,20 @@ comment "Commands"
menu "Info commands"
+config CMD_ACPI + bool "acpi" + default y if ACPIGEN + help + List and dump ACPI tables. ACPI (Advanced Configuration and Power + Interface) is used mostly on x86 for providing information to the + Operating System about devices in the system. The tables are set up + by the firmware, typically U-Boot but possibly an earlier firmware + module, if U-Boot is chain-loaded from something else. ACPI tables + can also include code, to perform hardware-specific tasks required + by the Operating Systems. This allows some amount of separation + between the firmware and OS, and is particularly useful when you + want to make hardware changes without the OS needing to be adjusted. + config CMD_BDI bool "bdinfo" default y diff --git a/cmd/Makefile b/cmd/Makefile index f1dd513a4b4..15a9693ed0e 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -11,6 +11,7 @@ obj-y += help.o obj-y += version.o
# command +obj-$(CONFIG_CMD_ACPI) += acpi.o obj-$(CONFIG_CMD_AES) += aes.o obj-$(CONFIG_CMD_AB_SELECT) += ab_select.o obj-$(CONFIG_CMD_ADC) += adc.o diff --git a/cmd/acpi.c b/cmd/acpi.c new file mode 100644 index 00000000000..203bd93bd5d --- /dev/null +++ b/cmd/acpi.c @@ -0,0 +1,186 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 Google LLC + * Written by Simon Glass sjg@chromium.org + */ +#include <common.h> +#include <command.h> +#include <mapmem.h> +#include <acpi/acpi_table.h> +#include <asm/acpi_table.h> +#include <dm/acpi.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * dump_hdr() - Dump an ACPI header + * + * If the header is for FACS then it shows the revision information as well + * + * @hdr: ACPI header to dump + */ +static void dump_hdr(struct acpi_table_header *hdr) +{ + bool has_hdr = memcmp(hdr->signature, "FACS", ACPI_NAME_LEN); + + printf("%.*s %08lx %06x", ACPI_NAME_LEN, hdr->signature, + (ulong)map_to_sysmem(hdr), hdr->length); + if (has_hdr) { + printf(" (v%02d %.6s %.8s %u %.4s %d)\n", hdr->revision, + hdr->oem_id, hdr->oem_table_id, hdr->oem_revision, + hdr->aslc_id, hdr->aslc_revision); + } else { + printf("\n"); + } +} + +/** + * find_table() - Look up an ACPI table + * + * @sig: Signature of table (4 characters, upper case) + * @return pointer to table header, or NULL if not found + */ +struct acpi_table_header *find_table(const char *sig) +{ + struct acpi_rsdp *rsdp; + struct acpi_rsdt *rsdt; + int len, i, count; + + rsdp = map_sysmem(gd->arch.acpi_start, 0); + if (!rsdp) + return NULL; + rsdt = map_sysmem(rsdp->rsdt_address, 0); + len = rsdt->header.length - sizeof(rsdt->header); + count = len / sizeof(u32); + for (i = 0; i < count; i++) { + struct acpi_table_header *hdr; + + hdr = map_sysmem(rsdt->entry[i], 0); + if (!memcmp(hdr->signature, sig, ACPI_NAME_LEN)) + return hdr; + if (!memcmp(hdr->signature, "FACP", ACPI_NAME_LEN)) { + struct acpi_fadt *fadt = (struct acpi_fadt *)hdr; + + if (!memcmp(sig, "DSDT", ACPI_NAME_LEN) && fadt->dsdt) + return map_sysmem(fadt->dsdt, 0); + if (!memcmp(sig, "FACS", ACPI_NAME_LEN) && + fadt->firmware_ctrl) + return map_sysmem(fadt->firmware_ctrl, 0); + } + } + + return NULL; +} + +static int dump_table_name(const char *sig) +{ + struct acpi_table_header *hdr; + + hdr = find_table(sig); + if (!hdr) + return -ENOENT; + printf("%.*s @ %08lx\n", ACPI_NAME_LEN, hdr->signature, + (ulong)map_to_sysmem(hdr)); + print_buffer(0, hdr, 1, hdr->length, 0); + + return 0; +} + +static void list_fadt(struct acpi_fadt *fadt) +{ + if (fadt->dsdt) + dump_hdr(map_sysmem(fadt->dsdt, 0)); + if (fadt->firmware_ctrl) + dump_hdr(map_sysmem(fadt->firmware_ctrl, 0)); +} + +static int list_rsdt(struct acpi_rsdt *rsdt, struct acpi_xsdt *xsdt) +{ + int len, i, count; + + dump_hdr(&rsdt->header); + if (xsdt) + dump_hdr(&xsdt->header); + len = rsdt->header.length - sizeof(rsdt->header); + count = len / sizeof(u32); + for (i = 0; i < count; i++) { + struct acpi_table_header *hdr; + + if (!rsdt->entry[i]) + break; + hdr = map_sysmem(rsdt->entry[i], 0); + dump_hdr(hdr); + if (!memcmp(hdr->signature, "FACP", ACPI_NAME_LEN)) + list_fadt((struct acpi_fadt *)hdr); + if (xsdt) { + if (xsdt->entry[i] != rsdt->entry[i]) { + printf(" (xsdt mismatch %llx)\n", + xsdt->entry[i]); + } + } + } + + return 0; +} + +static int list_rsdp(struct acpi_rsdp *rsdp) +{ + struct acpi_rsdt *rsdt; + struct acpi_xsdt *xsdt; + + printf("RSDP %08lx %06x (v%02d %.6s)\n", (ulong)map_to_sysmem(rsdp), + rsdp->length, rsdp->revision, rsdp->oem_id); + rsdt = map_sysmem(rsdp->rsdt_address, 0); + xsdt = map_sysmem(rsdp->xsdt_address, 0); + list_rsdt(rsdt, xsdt); + + return 0; +} + +static int do_acpi_list(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct acpi_rsdp *rsdp; + + rsdp = map_sysmem(gd->arch.acpi_start, 0); + if (!rsdp) { + printf("No ACPI tables present\n"); + return 0; + } + printf("ACPI tables start at %lx\n", gd->arch.acpi_start); + list_rsdp(rsdp); + + return 0; +} + +static int do_acpi_dump(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + const char *name; + char sig[ACPI_NAME_LEN]; + int ret; + + if (argc < 2) + return CMD_RET_USAGE; + name = argv[1]; + if (strlen(name) != ACPI_NAME_LEN) { + printf("Table name '%s' must be four characters\n", name); + return CMD_RET_FAILURE; + } + str_to_upper(name, sig, -1); + ret = dump_table_name(sig); + if (ret) { + printf("Table '%.*s' not found\n", ACPI_NAME_LEN, sig); + return CMD_RET_FAILURE; + } + + return 0; +} + +static char acpi_help_text[] = + "list - list ACPI tables\n" + "acpi dump <name> - Dump ACPI table"; + +U_BOOT_CMD_WITH_SUBCMDS(acpi, "ACPI tables", acpi_help_text, + U_BOOT_SUBCMD_MKENT(list, 1, 1, do_acpi_list), + U_BOOT_SUBCMD_MKENT(dump, 2, 1, do_acpi_dump)); diff --git a/lib/acpi/acpi_table.c b/lib/acpi/acpi_table.c index 9d2b49f8ba5..5abf1cad50f 100644 --- a/lib/acpi/acpi_table.c +++ b/lib/acpi/acpi_table.c @@ -240,6 +240,7 @@ void acpi_setup_base_tables(struct acpi_ctx *ctx, void *start)
/* Align ACPI tables to 16 byte */ acpi_align(ctx); + gd->arch.acpi_start = map_to_sysmem(ctx->current);
/* We need at least an RSDP and an RSDT Table */ ctx->rsdp = ctx->current; diff --git a/test/dm/acpi.c b/test/dm/acpi.c index 8e160d2cf4e..4eabf53128a 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -7,9 +7,11 @@ */
#include <common.h> +#include <console.h> #include <dm.h> #include <malloc.h> #include <mapmem.h> +#include <version.h> #include <tables_csum.h> #include <version.h> #include <acpi/acpi_table.h> @@ -212,6 +214,7 @@ static int dm_test_acpi_setup_base_tables(struct unit_test_state *uts) buf = memalign(64, BUF_SIZE); ut_assertnonnull(buf); acpi_setup_base_tables(&ctx, buf + 4); + ut_asserteq(map_to_sysmem(PTR_ALIGN(buf + 4, 16)), gd->arch.acpi_start);
rsdp = buf + 16; ut_asserteq_ptr(rsdp, ctx.rsdp); @@ -242,3 +245,73 @@ static int dm_test_acpi_setup_base_tables(struct unit_test_state *uts) } DM_TEST(dm_test_acpi_setup_base_tables, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test 'acpi list' command */ +static int dm_test_acpi_cmd_list(struct unit_test_state *uts) +{ + struct acpi_ctx ctx; + ulong addr; + void *buf; + + buf = memalign(16, BUF_SIZE); + ut_assertnonnull(buf); + acpi_setup_base_tables(&ctx, buf); + + ut_assertok(acpi_write_dev_tables(&ctx)); + + console_record_reset(); + run_command("acpi list", 0); + addr = (ulong)map_to_sysmem(buf); + ut_assert_nextline("ACPI tables start at %lx", addr); + ut_assert_nextline("RSDP %08lx %06lx (v02 U-BOOT)", addr, + sizeof(struct acpi_rsdp)); + addr = ALIGN(addr + sizeof(struct acpi_rsdp), 16); + ut_assert_nextline("RSDT %08lx %06lx (v01 U-BOOT U-BOOTBL %u INTL 0)", + addr, sizeof(struct acpi_table_header) + + 2 * sizeof(u32), U_BOOT_BUILD_DATE); + addr = ALIGN(addr + sizeof(struct acpi_rsdt), 16); + ut_assert_nextline("XSDT %08lx %06lx (v01 U-BOOT U-BOOTBL %u INTL 0)", + addr, sizeof(struct acpi_table_header) + + 2 * sizeof(u64), U_BOOT_BUILD_DATE); + addr = ALIGN(addr + sizeof(struct acpi_xsdt), 64); + ut_assert_nextline("DMAR %08lx %06lx (v01 U-BOOT U-BOOTBL %u INTL 0)", + addr, sizeof(struct acpi_dmar), U_BOOT_BUILD_DATE); + addr = ALIGN(addr + sizeof(struct acpi_dmar), 16); + ut_assert_nextline("DMAR %08lx %06lx (v01 U-BOOT U-BOOTBL %u INTL 0)", + addr, sizeof(struct acpi_dmar), U_BOOT_BUILD_DATE); + ut_assert_console_end(); + + return 0; +} +DM_TEST(dm_test_acpi_cmd_list, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test 'acpi dump' command */ +static int dm_test_acpi_cmd_dump(struct unit_test_state *uts) +{ + struct acpi_ctx ctx; + ulong addr; + void *buf; + + buf = memalign(16, BUF_SIZE); + ut_assertnonnull(buf); + acpi_setup_base_tables(&ctx, buf); + + ut_assertok(acpi_write_dev_tables(&ctx)); + + /* First search for a non-existent table */ + console_record_reset(); + run_command("acpi dump rdst", 0); + ut_assert_nextline("Table 'RDST' not found"); + ut_assert_console_end(); + + /* Now a real table */ + console_record_reset(); + run_command("acpi dump dmar", 0); + addr = ALIGN(map_to_sysmem(ctx.xsdt) + sizeof(struct acpi_xsdt), 64); + ut_assert_nextline("DMAR @ %08lx", addr); + ut_assert_nextlines_are_dump(0x30); + ut_assert_console_end(); + + return 0; +} +DM_TEST(dm_test_acpi_cmd_dump, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
On Tue, Apr 07, 2020 at 09:00:36PM -0600, Simon Glass wrote:
This is split from the original series in an attempt to get things applied in chunks.
The first 20 or so patches here have been reviewed and the changes here incorporate those comments.
You sent patches without settlement on the previous version, so, this has same problems.
Changes in v4:
- Add a new patch with some string tests
- Add a new patch to convert a string to upper case
- Fix indentation of unused
- Calculate the padding
- Put 'interrupts-extended' property on one line
- Rename acpi-probed to linux,probed
- Note that linux,probed is an out-of-tree feature
- Move ACPI makefile line outside the ifdef CONFIG_SPL_BUILD
- Add a comment about the MADT table version
- Add SPCR
- Update comment to include tables defined or reserved by ACPI
Changes in v3: Drop acpi,name in example
- Fix indenting error mentioned by Andy Shevchenko
- Fix stray #endif
- Drop 'Intel' from 'Intel ACPI'
- Reword commit message to drop the bit about ACPI being complicated
- Compute ACPI_NAME_MAX from ACPI_NAME_LEN
- Rename acpi_return_name() to acpi_copy_name()
- Use strncpy() instead of strcpy() in acpi_copy_name()
- Split out hid-over-i2c into its own patch
- Drop mention of PRIC
- Rename acpi,desc to acpi,ddn
- Correct description of acpi,probed
- Drop hid-descr-addr
- Just add the device.txt binding file in this patch
- Change the example to ELAN
- Add a pointer to information about acpi,compatible
- Add new patch to move acpi_s3.h to include/acpi/
- Update commit message to say that we move most of its contents
- Move acpi_table.h to include/acpi
- Add forward declarations for the functions
- Fix file comment for acpi_table.c
- Fix a few typos
- Make use of BIT()
- Fix DMA_ typo
- Drop ASL_REVISION
- Fix 'RSDP' typo
- Fix 'XDST' typo
Changes in v2:
- Don't bracket the definitions with DM_SPI
- Add trailing commas to enum
- Drop the other comment change since it is already applied
- Drop the Chrome OS pieces
- Rename the 'coreboot' console to 'U-Boot'
- Move LOGC_ACPI definition to this patch
- Fix definition of HID
- Infer hid-over-i2c CID value
- Add the hid-over-i2c binding document
- Add in the acpi_table.h header file to this patch
- Move the sandbox acpi_table.h header file to an earlier patch
- Use #defines for MADT and MCFG version numbers
Simon Glass (31): test: Add the beginnings of some string tests lib: Add a function to convert a string to upper case cpu: Support querying the address width spi: Add SPI mode enums tpm: cr50: Release locality on exit tpm: cr50: Add a comment for cr50_priv tpm: cr50: Use the correct GPIO binding tpm: Don't cleanup unless an error happens dm: pci: Allow disabling auto-config for a device x86: Correct wording of coreboot source code x86: apl: Move p2sb ofdata reading to the correct method pci: Adjust dm_pci_read_bar32() to return errors correctly x86: apl: Add Global NVS table header dm: core: Add basic ACPI support dts: Add a binding for hid-over-i2c acpi: Add a binding for ACPI settings in the device tree acpi: Add a simple sandbox test x86: Move acpi_s3.h to include/acpi/ x86: Move acpi_table header to main include/ directory acpi: Add an __ACPI__ preprocessor symbol acpi: Add a central location for table version numbers acpi: Add support for DMAR test: Add hexdump.h to the unit test header acpi: Add a method to write tables for a device acpi: Convert part of acpi_table to use acpi_ctx x86: Allow devices to write ACPI tables acpi: Drop code for missing XSDT from acpi_write_rsdp() acpi: Move acpi_add_table() to generic code acpi: Put table-setup code in its own function acpi: Move the xsdt pointer to acpi_ctx acpi: Add an acpi command
arch/sandbox/dts/test.dts | 8 + arch/sandbox/include/asm/acpi_table.h | 9 + arch/sandbox/include/asm/global_data.h | 1 + arch/x86/cpu/apollolake/cpu_spl.c | 2 +- arch/x86/cpu/apollolake/fsp_s.c | 2 +- arch/x86/cpu/apollolake/pmc.c | 2 +- arch/x86/cpu/baytrail/acpi.c | 6 +- arch/x86/cpu/coreboot/timestamp.c | 4 +- arch/x86/cpu/cpu.c | 4 +- arch/x86/cpu/intel_common/p2sb.c | 33 +- arch/x86/cpu/quark/acpi.c | 2 +- arch/x86/cpu/tangier/acpi.c | 4 +- arch/x86/cpu/wakeup.S | 2 +- arch/x86/dts/chromebook_coral.dts | 2 +- arch/x86/include/asm/acpi_table.h | 381 +----------- .../include/asm/arch-apollolake/global_nvs.h | 36 ++ .../x86/include/asm/arch-coreboot/timestamp.h | 4 +- arch/x86/include/asm/global_data.h | 1 + arch/x86/include/asm/intel_pinctrl_defs.h | 2 - arch/x86/lib/acpi.c | 2 +- arch/x86/lib/acpi_s3.c | 4 +- arch/x86/lib/acpi_table.c | 241 ++------ arch/x86/lib/coreboot_table.c | 2 +- arch/x86/lib/fsp/fsp_common.c | 2 +- arch/x86/lib/fsp1/fsp_common.c | 2 +- arch/x86/lib/fsp2/fsp_dram.c | 2 +- arch/x86/lib/tables.c | 2 +- arch/x86/lib/zimage.c | 2 +- cmd/Kconfig | 14 + cmd/Makefile | 1 + cmd/acpi.c | 186 ++++++ doc/device-tree-bindings/device.txt | 36 ++ .../gpio/intel,apl-gpio.txt | 2 +- .../input/hid-over-i2c.txt | 44 ++ .../interrupt-controller/intel,acpi-gpe.txt | 2 +- doc/device-tree-bindings/pci/x86-pci.txt | 23 + drivers/core/Kconfig | 9 + drivers/core/Makefile | 1 + drivers/core/acpi.c | 95 +++ drivers/cpu/cpu_sandbox.c | 1 + drivers/pci/pci-uclass.c | 11 +- drivers/pci/pci_rom.c | 4 +- drivers/power/acpi_pmc/acpi-pmc-uclass.c | 2 +- drivers/sysreset/sysreset_x86.c | 2 +- drivers/tpm/cr50_i2c.c | 24 +- drivers/tpm/tpm-uclass.c | 13 +- fs/fat/fat_write.c | 13 +- include/{ => acpi}/acpi_s3.h | 0 include/acpi/acpi_table.h | 579 ++++++++++++++++++ include/cpu.h | 2 + include/dm/acpi.h | 114 ++++ include/dm/device.h | 5 + include/dm/uclass-id.h | 1 + include/log.h | 2 + include/spi.h | 33 + include/test/suites.h | 1 + include/test/ut.h | 1 + include/vsprintf.h | 12 + lib/Makefile | 1 + lib/acpi/Makefile | 4 + lib/acpi/acpi_table.c | 259 ++++++++ lib/efi_loader/efi_acpi.c | 2 +- lib/strto.c | 8 + scripts/Makefile.lib | 4 +- test/Makefile | 1 + test/cmd_ut.c | 5 + test/dm/Makefile | 1 + test/dm/acpi.c | 317 ++++++++++ test/dm/cpu.c | 1 + test/str_ut.c | 105 ++++ 70 files changed, 2056 insertions(+), 649 deletions(-) create mode 100644 arch/sandbox/include/asm/acpi_table.h create mode 100644 arch/x86/include/asm/arch-apollolake/global_nvs.h create mode 100644 cmd/acpi.c create mode 100644 doc/device-tree-bindings/device.txt create mode 100644 doc/device-tree-bindings/input/hid-over-i2c.txt create mode 100644 drivers/core/acpi.c rename include/{ => acpi}/acpi_s3.h (100%) create mode 100644 include/acpi/acpi_table.h create mode 100644 include/dm/acpi.h create mode 100644 lib/acpi/Makefile create mode 100644 lib/acpi/acpi_table.c create mode 100644 test/dm/acpi.c create mode 100644 test/str_ut.c
-- 2.26.0.292.g33ef6b2f38-goog
Hi Andy,
On Wed, 8 Apr 2020 at 11:02, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
I think I did the best I could based on the feedback I got. If something needs to be changed let's talk about it on the individual patches.
Andy Shevchenko
