[U-Boot] [PATCH 0/5] FSL/Layerscape gen 3: export serdes cfg to env
Exports the serdes configuration as an environment variable for LS gen 3 SoCs, so it can be used in u-boot command line. It should particularly be useful for applying Linux DT overlays for the given serdes configuration. First 4 patches free up arch_misc_init, which is now implemented in arch/arm/cpu/armv8/fsl-layerscape/cpu.c. For LS1028A and LX2 the board_mux_init code is now under misc_init_r. MISC_INIT_R is now enabled for the relavant boards.
Alex Marginean (5): board: fsl: lx2160a: free up arch_misc_init board: fsl: ls2080a/ls2081a: remove empty arch_misc_init board: fsl: ls1088a: remove empty arch_misc_init board: fsl: ls1028a: free up arch_misc_init arch: armv8: fsl-layerscape: export serdes config to environment
arch/arm/Kconfig | 10 ----- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 14 +++++++ .../armv8/fsl-layerscape/fsl_lsch3_serdes.c | 42 +++++++++++++++++++ board/freescale/ls1028a/ls1028a.c | 4 +- board/freescale/ls1088a/ls1088a.c | 7 ---- board/freescale/ls2080a/ls2080a.c | 7 ---- board/freescale/ls2080aqds/ls2080aqds.c | 7 ---- board/freescale/ls2080ardb/ls2080ardb.c | 7 ---- board/freescale/lx2160a/lx2160a.c | 4 +- configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1028aqds_tfa_defconfig | 1 + configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160aqds_tfa_defconfig | 1 + configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + 16 files changed, 67 insertions(+), 42 deletions(-)
Currently LX2 board code uses arch_misc_init to set up the board mux on RDB and QDS. Move this code to misc_init_r. This is consistent with LS gen 2 and T series SoCs/boards.
Signed-off-by: Alex Marginean alexandru.marginean@nxp.com --- arch/arm/Kconfig | 2 -- board/freescale/lx2160a/lx2160a.c | 4 ++-- configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160aqds_tfa_defconfig | 1 + configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/lx2160ardb_tfa_defconfig | 1 + 6 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f96841c777..3a3d77b04f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1190,7 +1190,6 @@ config TARGET_LS2081ARDB config TARGET_LX2160ARDB bool "Support lx2160ardb" select ARCH_LX2160A - select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select ARCH_SUPPORT_TFABOOT @@ -1204,7 +1203,6 @@ config TARGET_LX2160ARDB config TARGET_LX2160AQDS bool "Support lx2160aqds" select ARCH_LX2160A - select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select ARCH_SUPPORT_TFABOOT diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index eff12747b4..413aaa6baf 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -579,8 +579,8 @@ void detail_board_ddr_info(void) print_ddr_info(0); }
-#if defined(CONFIG_ARCH_MISC_INIT) -int arch_misc_init(void) +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) { config_board_mux();
diff --git a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig index 4ab7582fc7..43a2b8328d 100644 --- a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_GPT=y diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index a35f1cc38d..06ed9ba83d 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_GPT=y diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig index 87c54b00f6..40ccc1f569 100644 --- a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_GPT=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index 18057b20b1..8478404dd6 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyAMA0,115200 root=/dev/ram0 earlycon=pl011,mmio32,0x21c0000 ramdisk_size=0x2000000 default_hugepagesz=1024m hugepagesz=1024m hugepages=2 pci=pcie_bus_perf" # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_MISC_INIT_R=y CONFIG_CMD_GREPENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_GPT=y
The arch_misc_init function is emtpy on LS2 SoCs/boards, remove it.
Signed-off-by: Alex Marginean alexandru.marginean@nxp.com --- arch/arm/Kconfig | 5 ----- board/freescale/ls2080a/ls2080a.c | 7 ------- board/freescale/ls2080aqds/ls2080aqds.c | 7 ------- board/freescale/ls2080ardb/ls2080ardb.c | 7 ------- 4 files changed, 26 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3a3d77b04f..459876b543 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1096,7 +1096,6 @@ config TARGET_VEXPRESS64_JUNO config TARGET_LS2080A_EMU bool "Support ls2080a_emu" select ARCH_LS2080A - select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select FSL_DDR_SYNC_REFRESH @@ -1109,7 +1108,6 @@ config TARGET_LS2080A_EMU config TARGET_LS2080A_SIMU bool "Support ls2080a_simu" select ARCH_LS2080A - select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select BOARD_LATE_INIT @@ -1138,7 +1136,6 @@ config TARGET_LS1088AQDS config TARGET_LS2080AQDS bool "Support ls2080aqds" select ARCH_LS2080A - select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select ARCH_SUPPORT_TFABOOT @@ -1157,7 +1154,6 @@ config TARGET_LS2080AQDS config TARGET_LS2080ARDB bool "Support ls2080ardb" select ARCH_LS2080A - select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select ARCH_SUPPORT_TFABOOT @@ -1176,7 +1172,6 @@ config TARGET_LS2080ARDB config TARGET_LS2081ARDB bool "Support ls2081ardb" select ARCH_LS2080A - select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select BOARD_LATE_INIT diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 413a698511..bc68f99625 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -48,13 +48,6 @@ void detail_board_ddr_info(void) #endif }
-#if defined(CONFIG_ARCH_MISC_INIT) -int arch_misc_init(void) -{ - return 0; -} -#endif - int board_eth_init(bd_t *bis) { int error = 0; diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 25e80c8ac6..fce433461a 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -289,13 +289,6 @@ void detail_board_ddr_info(void) #endif }
-#if defined(CONFIG_ARCH_MISC_INIT) -int arch_misc_init(void) -{ - return 0; -} -#endif - #if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) void fdt_fixup_board_enet(void *fdt) { diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 6a1b8e3f53..282aaf47fb 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -318,13 +318,6 @@ void detail_board_ddr_info(void) #endif }
-#if defined(CONFIG_ARCH_MISC_INIT) -int arch_misc_init(void) -{ - return 0; -} -#endif - #ifdef CONFIG_FSL_MC_ENET void fdt_fixup_board_enet(void *fdt) {
s/emtpy/empty/
-} -#endif
-} -#endif
-} -#endif
The arch_misc_init function is emtpy on LS108x SoCs/boards, remove it.
Signed-off-by: Alex Marginean alexandru.marginean@nxp.com --- arch/arm/Kconfig | 2 -- board/freescale/ls1088a/ls1088a.c | 7 ------- 2 files changed, 9 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 459876b543..8a190bab8c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1120,7 +1120,6 @@ config TARGET_LS2080A_SIMU config TARGET_LS1088AQDS bool "Support ls1088aqds" select ARCH_LS1088A - select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select ARCH_SUPPORT_TFABOOT @@ -1342,7 +1341,6 @@ config TARGET_LS1028ARDB config TARGET_LS1088ARDB bool "Support ls1088ardb" select ARCH_LS1088A - select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select ARCH_SUPPORT_TFABOOT diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 4ecf6dce68..0bd397a0be 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -811,13 +811,6 @@ void detail_board_ddr_info(void) print_ddr_info(0); }
-#if defined(CONFIG_ARCH_MISC_INIT) -int arch_misc_init(void) -{ - return 0; -} -#endif - #ifdef CONFIG_FSL_MC_ENET void board_quiesce_devices(void) {
Currently LS1028A board code uses arch_misc_init to set up the board mux on QDS. Move this code to misc_init_r. This is consistent with LS gen 2 and T series SoCs/boards.
Signed-off-by: Alex Marginean alexandru.marginean@nxp.com --- arch/arm/Kconfig | 1 - board/freescale/ls1028a/ls1028a.c | 4 ++-- configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1028aqds_tfa_defconfig | 1 + 4 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 8a190bab8c..77a5ed5a40 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1319,7 +1319,6 @@ config TARGET_LS1028AQDS select ARMV8_MULTIENTRY select ARCH_SUPPORT_TFABOOT select BOARD_LATE_INIT - select ARCH_MISC_INIT help Support for Freescale LS1028AQDS platform The LS1028A Development System (QDS) is a high-performance diff --git a/board/freescale/ls1028a/ls1028a.c b/board/freescale/ls1028a/ls1028a.c index a9606b8865..3977ecf896 100644 --- a/board/freescale/ls1028a/ls1028a.c +++ b/board/freescale/ls1028a/ls1028a.c @@ -96,8 +96,8 @@ int board_eth_init(bd_t *bis) return pci_eth_init(bis); }
diff --git a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig index b5dceb4471..77860a568b 100644 --- a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256 video=1920x1080-32@60 cma=256M" +CONFIG_MISC_INIT_R=y CONFIG_CMD_GREPENV=y CONFIG_CMD_DM=y CONFIG_CMD_GPT=y diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index e75d140e94..75871e5569 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -17,6 +17,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 ramdisk_size=0x2000000 default_hugepagesz=2m hugepagesz=2m hugepages=256 video=1920x1080-32@60 cma=256M" +CONFIG_MISC_INIT_R=y CONFIG_CMD_GREPENV=y CONFIG_CMD_DM=y CONFIG_CMD_GPT=y
Exports the serdes configuration as an environment variable for LS gen 3 SoCs, so it can be used in u-boot command line. It should particularly be useful for applying Linux DT overlays for the given serdes configuration. This code is called from arch_misc_init and not from the existing serdes_init function because it depends on U-Boot environment being set up.
Signed-off-by: Alex Marginean alexandru.marginean@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 14 ++++++ .../armv8/fsl-layerscape/fsl_lsch3_serdes.c | 43 +++++++++++++++++++ 3 files changed, 58 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index f1578b10bc..40cbea0e12 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -241,6 +241,7 @@ config FSL_LSCH2 select SYS_FSL_SEC_BE
config FSL_LSCH3 + select ARCH_MISC_INIT bool
config NXP_LSCH3_2 diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index c6490556e6..ddbc07037f 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -1627,3 +1627,17 @@ __weak int dram_init(void)
return 0; } + +#ifdef CONFIG_ARCH_MISC_INIT +__weak int serdes_misc_init(void) +{ + return 0; +} + +int arch_misc_init(void) +{ + serdes_misc_init(); + + return 0; +} +#endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index 1a747a9e3d..8b9f5a4e29 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -600,3 +600,46 @@ void fsl_serdes_init(void) serdes3_prtcl_map); #endif } + +int serdes_set_env(int sd, int rcwsr, int sd_prctl_mask, int sd_prctl_shift) +{ + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + char scfg[16], snum[16]; + int i, cfgr = 0; + u32 cfg; + + cfg = gur_in32(&gur->rcwsr[rcwsr - 1]) & sd_prctl_mask; + cfg >>= sd_prctl_shift; + cfg = serdes_get_number(sd, cfg); + + /* reverse lanes, lane 0 should be printed first */ + for (i = 0; i < SRDS_MAX_LANES; i++) + cfgr |= (cfg >> (i * 4) & 0xf) << (SRDS_MAX_LANES - i - 1) * 4; + + snprintf(snum, 16, "serdes%d", sd); + snprintf(scfg, 16, "%x", cfgr); + env_set(snum, scfg); + + return 0; +} + +int serdes_misc_init(void) +{ +#ifdef CONFIG_SYS_FSL_SRDS_1 + serdes_set_env(FSL_SRDS_1, FSL_CHASSIS3_SRDS1_REGSR, + FSL_CHASSIS3_SRDS1_PRTCL_MASK, + FSL_CHASSIS3_SRDS1_PRTCL_SHIFT); +#endif +#ifdef CONFIG_SYS_FSL_SRDS_2 + serdes_set_env(FSL_SRDS_2, FSL_CHASSIS3_SRDS2_REGSR, + FSL_CHASSIS3_SRDS2_PRTCL_MASK, + FSL_CHASSIS3_SRDS2_PRTCL_SHIFT); +#endif +#ifdef CONFIG_SYS_NXP_SRDS_3 + serdes_set_env(NXP_SRDS_3, FSL_CHASSIS3_SRDS3_REGSR, + FSL_CHASSIS3_SRDS3_PRTCL_MASK, + FSL_CHASSIS3_SRDS3_PRTCL_SHIFT); +#endif + + return 0; +}
-----Original Message----- From: Alex Marginean alexandru.marginean@nxp.com Sent: Tuesday, December 3, 2019 4:16 PM To: u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com; Pankaj Bansal pankaj.bansal@nxp.com; Andy Tang andy.tang@nxp.com; Vladimir Oltean vladimir.oltean@nxp.com; Claudiu Manoil claudiu.manoil@nxp.com; Florin Laurentiu Chiculita florinlaurentiu.chiculita@nxp.com; Razvan Ionut Cirjan razvanionut.cirjan@nxp.com; Madalin Bucur madalin.bucur@nxp.com; Alexandru Marginean alexandru.marginean@nxp.com Subject: [PATCH 5/5] arch: armv8: fsl-layerscape: export serdes config to environment
config FSL_LSCH3
- select ARCH_MISC_INIT bool
return 0; }
- serdes_misc_init();
+int serdes_set_env(int sd, int rcwsr, int sd_prctl_mask, int +sd_prctl_shift) {
- struct ccsr_gur __iomem *gur = (void
- char scfg[16], snum[16];
- int i, cfgr = 0;
- u32 cfg;
- cfg = gur_in32(&gur->rcwsr[rcwsr - 1]) & sd_prctl_mask;
- cfg >>= sd_prctl_shift;
- cfg = serdes_get_number(sd, cfg);
- /* reverse lanes, lane 0 should be printed first */
- for (i = 0; i < SRDS_MAX_LANES; i++)
- snprintf(snum, 16, "serdes%d", sd);
- snprintf(scfg, 16, "%x", cfgr);
- env_set(snum, scfg);
- serdes_set_env(FSL_SRDS_1, FSL_CHASSIS3_SRDS1_REGSR,
FSL_CHASSIS3_SRDS1_PRTCL_SHIFT); #endif #ifdef
Need new lines in between
+CONFIG_SYS_FSL_SRDS_2
- serdes_set_env(FSL_SRDS_2, FSL_CHASSIS3_SRDS2_REGSR,
FSL_CHASSIS3_SRDS2_PRTCL_SHIFT); #endif #ifdef
Same as above
+CONFIG_SYS_NXP_SRDS_3
- serdes_set_env(NXP_SRDS_3, FSL_CHASSIS3_SRDS3_REGSR,
FSL_CHASSIS3_SRDS3_PRTCL_SHIFT); #endif
Same as above
2.17.1
Priyanka
Alex Marginean
Alexandru Marginean
Priyanka Jain
