[U-Boot] [PATCH 1/4 v4] arm: add support for the mgcoge2_arm_p1a board from keymile
Add support for the ARM part of the mgcoge2. This board is based on the Marvell Kirkwood (88F6281) SoC. As there come more board variants, common code is stored in board/keymile/km_arm/km_arm.c
Signed-off-by: Holger Brunck holger.brunck@keymile.com Signed-off-by: Stefan Roese sr@denx.de Signed-off-by: Heiko Schocher hs@denx.de --- - changes since v1: added comments from Wolfgang Denk: get rid of flash_info_t define in board config (to get this working patch 1/2 is introduced/needed)
- changes since v2: added comments from Wolfgang Denk - rearranged if/else in do_spi_toggle() - added I/O accessor functions for bootcounter
- changes since v3: added comment Scott Wood - removed nand_init in do_spi_toggle()
added comments from Prafulla Wadagaskar - km-arm.h renamed to km_arm.h - reworked eeprom_write_enable() (deleted it) (when reviewing this function, it cropped up, that this pin is connected through a gpio pin, not as in previous version, through the boco (a FPGA)) - moved set_sda(), set_scl(), get_sda(), get_scl() to km_arm.c - split patch in 4 patches (for each board an extra patch) - renamed sdramregs.txt in kwbimage.cfg, also license info added.
MAINTAINERS | 2 + MAKEALL | 1 + Makefile | 3 + board/keymile/common/common.c | 6 +- board/keymile/km_arm/Makefile | 51 ++++++ board/keymile/km_arm/config.mk | 28 +++ board/keymile/km_arm/km_arm.c | 339 +++++++++++++++++++++++++++++++++++++ board/keymile/km_arm/kwbimage.cfg | 59 +++++++ include/configs/km_arm.h | 191 +++++++++++++++++++++ include/configs/mgcoge2_arm_p1a.h | 96 +++++++++++ 10 files changed, 774 insertions(+), 2 deletions(-) create mode 100644 board/keymile/km_arm/Makefile create mode 100644 board/keymile/km_arm/config.mk create mode 100644 board/keymile/km_arm/km_arm.c create mode 100644 board/keymile/km_arm/kwbimage.cfg create mode 100644 include/configs/km_arm.h create mode 100644 include/configs/mgcoge2_arm_p1a.h
diff --git a/MAINTAINERS b/MAINTAINERS index fe63a9f..eda15c8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -384,6 +384,8 @@ Stefan Roese sr@denx.de
P3M750 PPC750FX/GX/GL
+ mgcoge2_arm_p1a ARM926EJS (Kirkwood SoC) + Yusdi Santoso yusdi_santoso@adaptec.com
HIDDEN_DRAGON MPC8241/MPC8245 diff --git a/MAKEALL b/MAKEALL index 684db67..1c18734 100755 --- a/MAKEALL +++ b/MAKEALL @@ -557,6 +557,7 @@ LIST_ARM9=" \ da830evm \ imx27lite \ lpd7a400 \ + mgcoge2_arm_p1a \ mv88f6281gtw_ge \ mx1ads \ mx1fs2 \ diff --git a/Makefile b/Makefile index e4431f7..990f932 100644 --- a/Makefile +++ b/Makefile @@ -2950,6 +2950,9 @@ lpd7a400_config \ lpd7a404_config: unconfig @$(MKCONFIG) $(@:_config=) arm lh7a40x lpd7a40x
+mgcoge2_arm_p1a_config: unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs km_arm keymile kirkwood + mv88f6281gtw_ge_config: unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs $(@:_config=) Marvell kirkwood
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index ec27bda..7b4eefd 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -35,6 +35,7 @@ #include <libfdt.h> #endif
+#include "../common/common.h" #if defined(CONFIG_HARD_I2C) || defined(CONFIG_SOFT_I2C) #include <i2c.h>
@@ -421,7 +422,6 @@ static int get_scl (void)
return ((val & SCL_BIT) == SCL_BIT); } - #endif
#if !defined(CONFIG_KMETER1) @@ -500,7 +500,7 @@ void i2c_init_board(void) out_8 (&dev->cr, (I2C_CR_MEN));
#else -#if defined(CONFIG_HARD_I2C) +#if defined(CONFIG_HARD_I2C) && !defined(CONFIG_MACH_SUEN3) volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR ; volatile i2c8260_t *i2c = (i2c8260_t *)&immap->im_i2c;
@@ -578,10 +578,12 @@ int fdt_get_node_and_value (void *blob, } #endif
+#if !defined(CONFIG_MACH_SUEN3) int ethernet_present (void) { return (in_8((u8 *)CONFIG_SYS_PIGGY_BASE + CONFIG_SYS_SLOT_ID_OFF) & 0x80); } +#endif
int board_eth_init (bd_t *bis) { diff --git a/board/keymile/km_arm/Makefile b/board/keymile/km_arm/Makefile new file mode 100644 index 0000000..fffc6a3 --- /dev/null +++ b/board/keymile/km_arm/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Prafulla Wadaskar prafulla@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := $(BOARD).o ../common/common.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/keymile/km_arm/config.mk b/board/keymile/km_arm/config.mk new file mode 100644 index 0000000..b9e81b2 --- /dev/null +++ b/board/keymile/km_arm/config.mk @@ -0,0 +1,28 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Prafulla Wadaskar prafulla@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +TEXT_BASE = 0x004000000 + +# Kirkwood Boot Image configuration file +KWD_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/kwbimage.cfg diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c new file mode 100644 index 0000000..e1cf379 --- /dev/null +++ b/board/keymile/km_arm/km_arm.c @@ -0,0 +1,339 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * (C) Copyright 2009 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <i2c.h> +#include <nand.h> +#include <netdev.h> +#include <miiphy.h> +#include <asm/io.h> +#include <asm/arch/kirkwood.h> +#include <asm/arch/mpp.h> + +#include "../common/common.h" + +DECLARE_GLOBAL_DATA_PTR; + +static int io_dev; +extern I2C_MUX_DEVICE *i2c_mux_ident_muxstring (uchar *buf); + +/* Multi-Purpose Pins Functionality configuration */ +u32 kwmpp_config[] = { + MPP0_NF_IO2, + MPP1_NF_IO3, + MPP2_NF_IO4, + MPP3_NF_IO5, + MPP4_NF_IO6, + MPP5_NF_IO7, + MPP6_SYSRST_OUTn, + MPP7_PEX_RST_OUTn, +#if defined(CONFIG_KIRKWOOD_GPIO) + MPP8_GPIO, /* SDA */ + MPP9_GPIO, /* SCL */ +#else + MPP8_TW_SDA, + MPP9_TW_SCK, +#endif + MPP10_UART0_TXD, + MPP11_UART0_RXD, + MPP12_GPO, /* Reserved */ + MPP13_UART1_TXD, + MPP14_UART1_RXD, + MPP15_GPIO, /* Not used */ + MPP16_GPIO, /* Not used */ + MPP17_GPIO, /* Reserved */ + MPP18_NF_IO0, + MPP19_NF_IO1, + MPP20_GPIO, + MPP21_GPIO, + MPP22_GPIO, + MPP23_GPIO, + MPP24_GPIO, + MPP25_GPIO, + MPP26_GPIO, + MPP27_GPIO, + MPP28_GPIO, + MPP29_GPIO, + MPP30_GPIO, + MPP31_GPIO, + MPP32_GPIO, + MPP33_GPIO, + MPP34_GPIO, /* CDL1 (input) */ + MPP35_GPIO, /* CDL2 (input) */ + MPP36_GPIO, /* MAIN_IRQ (input) */ + MPP37_GPIO, /* BOARD_LED */ + MPP38_GPIO, /* Piggy3 LED[1] */ + MPP39_GPIO, /* Piggy3 LED[2] */ + MPP40_GPIO, /* Piggy3 LED[3] */ + MPP41_GPIO, /* Piggy3 LED[4] */ + MPP42_GPIO, /* Piggy3 LED[5] */ + MPP43_GPIO, /* Piggy3 LED[6] */ + MPP44_GPIO, /* Piggy3 LED[7] */ + MPP45_GPIO, /* Piggy3 LED[8] */ + MPP46_GPIO, /* Reserved */ + MPP47_GPIO, /* Reserved */ + MPP48_GPIO, /* Reserved */ + MPP49_GPIO, /* SW_INTOUTn */ + 0 +}; + +int ethernet_present(void) +{ + uchar buf; + int ret = 0; + +#if defined(CONFIG_SUEN_P1A) + int oldbusnum = i2c_get_bus_num(); + + i2c_set_bus_num(io_dev); + if (i2c_read(0x74, 0, 1, &buf, 1) != 0) { + printf ("%s: Error reading EEprom\n", __FUNCTION__); + i2c_set_bus_num(oldbusnum); + return -1; + } + if ((buf & 0x80) == 0x80) { + ret = 1; + } + i2c_set_bus_num(oldbusnum); +#else + if (i2c_read(0x10, 2, 1, &buf, 1) != 0) { + printf ("%s: Error reading Boco\n", __FUNCTION__); + return -1; + } + if ((buf & 0x40) == 0x40) { + ret = 1; + } +#endif + return ret; +} + +int misc_init_r(void) +{ + I2C_MUX_DEVICE *i2cdev; + char *str; + int mach_type; + + /* add I2C Bus for I/O Expander */ + i2cdev = i2c_mux_ident_muxstring((uchar *)"pca9554a:70:a"); + io_dev = i2cdev->busid; + puts("Piggy:"); + if (ethernet_present() == 0) + puts (" not"); + puts(" present\n"); + + str = getenv("mach_type"); + if (str != NULL) { + mach_type = simple_strtoul(str, NULL, 10); + printf("Overwriting MACH_TYPE with %d!!!\n", mach_type); + gd->bd->bi_arch_number = mach_type; + } + return 0; +} + +int board_init(void) +{ + u32 tmp; + + kirkwood_mpp_conf(kwmpp_config); + + /* + * The FLASH_GPIO_PIN switches between using a + * NAND or a SPI FLASH. Set this pin on start + * to NAND mode. + */ + tmp = readl(KW_GPIO0_BASE); + writel(tmp | FLASH_GPIO_PIN , KW_GPIO0_BASE); + tmp = readl(KW_GPIO0_BASE + 4); + writel(tmp & (~FLASH_GPIO_PIN) , KW_GPIO0_BASE + 4); + printf("KM: setting NAND mode\n"); + + /* + * arch number of board + */ + gd->bd->bi_arch_number = MACH_TYPE_SUEN3; + + /* address of boot parameters */ + gd->bd->bi_boot_params = kw_sdram_bar(0) + 0x100; + +#if defined(CONFIG_KIRKWOOD_GPIO) + /* init the GPIO for I2C Bitbang driver */ + kw_gpio_set_valid(SUEN3_SDA_PIN, 1); + kw_gpio_set_valid(SUEN3_SCL_PIN, 1); + kw_gpio_direction_output(SUEN3_SDA_PIN, 0); + kw_gpio_direction_output(SUEN3_SCL_PIN, 0); +#if defined(CONFIG_SYS_EEPROM_WREN) + kw_gpio_set_valid(SUEN3_ENV_WP, 38); + kw_gpio_direction_output(SUEN3_ENV_WP, 1); +#endif +#endif + return 0; +} + +#if defined(CONFIG_CMD_SF) +int do_spi_toggle(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + u32 tmp; + if (argc < 2) { + cmd_usage(cmdtp); + return 1; + } + + if ((strcmp(argv[1], "off") == 0)) { + printf("SPI FLASH disabled, NAND enabled\n"); + /* Multi-Purpose Pins Functionality configuration */ + kwmpp_config[0] = MPP0_NF_IO2; + kwmpp_config[1] = MPP1_NF_IO3; + kwmpp_config[2] = MPP2_NF_IO4; + kwmpp_config[3] = MPP3_NF_IO5; + + kirkwood_mpp_conf(kwmpp_config); + tmp = readl(KW_GPIO0_BASE); + writel(tmp | FLASH_GPIO_PIN , KW_GPIO0_BASE); + } else if ((strcmp(argv[1], "on") == 0)) { + printf("SPI FLASH enabled, NAND disabled\n"); + /* Multi-Purpose Pins Functionality configuration */ + kwmpp_config[0] = MPP0_SPI_SCn; + kwmpp_config[1] = MPP1_SPI_MOSI; + kwmpp_config[2] = MPP2_SPI_SCK; + kwmpp_config[3] = MPP3_SPI_MISO; + + kirkwood_mpp_conf(kwmpp_config); + tmp = readl(KW_GPIO0_BASE); + writel(tmp & (~FLASH_GPIO_PIN) , KW_GPIO0_BASE); + } else { + cmd_usage(cmdtp); + return 1; + } + + return 0; +} + +U_BOOT_CMD( + spitoggle, 2, 0, do_spi_toggle, + "En-/disable SPI FLASH access", + "<on|off> - Enable (on) or disable (off) SPI FLASH access\n" + ); +#endif + +int dram_init(void) +{ + int i; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + gd->bd->bi_dram[i].start = kw_sdram_bar(i); + gd->bd->bi_dram[i].size = get_ram_size((long *)kw_sdram_bar(i), + kw_sdram_bs(i)); + } + return 0; +} + +/* Configure and enable MV88E1118 PHY */ +void reset_phy(void) +{ + char *name = "egiga0"; + + if (miiphy_set_current_dev(name)) + return; + + /* reset the phy */ + miiphy_reset(name, CONFIG_PHY_BASE_ADR); +} + +#if defined(CONFIG_HUSH_INIT_VAR) +int hush_init_var (void) +{ + ivm_read_eeprom (); + return 0; +} +#endif + +#if defined(CONFIG_BOOTCOUNT_LIMIT) +void bootcount_store (ulong a) +{ + volatile ulong *save_addr; + volatile ulong size = 0; + int i; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + size += gd->bd->bi_dram[i].size; + } + save_addr = (ulong*)(size - BOOTCOUNT_ADDR); + writel(a, save_addr); + writel(BOOTCOUNT_MAGIC, &save_addr[1]); +} + +ulong bootcount_load (void) +{ + volatile ulong *save_addr; + volatile ulong size = 0; + int i; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + size += gd->bd->bi_dram[i].size; + } + save_addr = (ulong*)(size - BOOTCOUNT_ADDR); + if (readl(&save_addr[1]) != BOOTCOUNT_MAGIC) + return 0; + else + return readl(save_addr); +} +#endif + +#if (defined(CONFIG_MACH_SUEN3) && defined(CONFIG_HARD_I2C)) +#error I2C bus resetsequence not implemented yet. +#endif + +#if (defined(CONFIG_MACH_SUEN3) && defined(CONFIG_SOFT_I2C)) +void set_sda (int state) +{ + I2C_ACTIVE; + I2C_SDA(state); +} + +void set_scl (int state) +{ + I2C_SCL(state); +} + +int get_sda (void) +{ + I2C_TRISTATE; + return I2C_READ; +} + +int get_scl (void) +{ + return (kw_gpio_get_value(SUEN3_SCL_PIN) ? 1 : 0); +} +#endif + +#if defined(CONFIG_SYS_EEPROM_WREN) +int eeprom_write_enable (unsigned dev_addr, int state) +{ + kw_gpio_set_value(SUEN3_ENV_WP, !state); + + return !kw_gpio_get_value(SUEN3_ENV_WP); +} +#endif diff --git a/board/keymile/km_arm/kwbimage.cfg b/board/keymile/km_arm/kwbimage.cfg new file mode 100644 index 0000000..bfe0889 --- /dev/null +++ b/board/keymile/km_arm/kwbimage.cfg @@ -0,0 +1,59 @@ +# +# (C) Copyright 2010 +# Heiko Schocher, DENX Software Engineering, hs@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi # Boot from SPI flash + +DATA 0xFFD10000 0x01111111 +DATA 0xFFD10008 0x00001100 +DATA 0xFFD100E0 0x1B1B1B1B +DATA 0xFFD20134 0xBBBBBBBB +DATA 0xFFD20138 0x00BBBBBB +DATA 0xFFD20154 0x00000200 +DATA 0xFFD2014C 0x00001C00 +DATA 0xFFD20148 0x00000001 +DATA 0xFFD01400 0x43000400 +DATA 0xFFD01404 0x36343000 +DATA 0xFFD01408 0x2302544B +DATA 0xFFD0140C 0x00000032 +DATA 0xFFD01410 0x0000000D +DATA 0xFFD01414 0x00000000 +DATA 0xFFD01418 0x00000000 +DATA 0xFFD0141C 0x00000642 +DATA 0xFFD01420 0x00000040 +DATA 0xFFD01424 0x0000F07F +DATA 0xFFD01504 0x07FFFFF1 +DATA 0xFFD01508 0x00000000 +DATA 0xFFD0150C 0x00000000 +DATA 0xFFD01514 0x00000000 +DATA 0xFFD0151C 0x00000000 +DATA 0xFFD01494 0x00000000 +DATA 0xFFD01498 0x00000000 +DATA 0xFFD0149C 0x0000E90F +DATA 0xFFD01480 0x00000001 + +# End of Header extension +DATA 0x0 0x0 diff --git a/include/configs/km_arm.h b/include/configs/km_arm.h new file mode 100644 index 0000000..091e941 --- /dev/null +++ b/include/configs/km_arm.h @@ -0,0 +1,191 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * (C) Copyright 2009 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +/* for linking errors see http://lists.denx.de/pipermail/u-boot/2009-July/057350.html */ + +#ifndef _CONFIG_KM_ARM_H +#define _CONFIG_KM_ARM_H + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_MARVELL +#define CONFIG_ARM926EJS /* Basic Architecture */ +#define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ +#define CONFIG_KIRKWOOD /* SOC Family Name */ +#define CONFIG_KW88F6281 /* SOC Name */ +#define CONFIG_MACH_SUEN3 /* Machine type */ + +/* include common defines/options for all Keymile boards */ +#include "keymile-common.h" +#undef CONFIG_CMD_DTT +#undef CONFIG_BOOTCOUNT_LIMIT + +#define CONFIG_MD5 /* get_random_hex on krikwood needs MD5 support */ +#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ +#define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ +#undef CONFIG_KIRKWOOD_PCIE_INIT /* Disable PCIE Port0 for kernel */ +#define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ + +#define CONFIG_MISC_INIT_R + +/* + * NS16550 Configuration + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK CONFIG_SYS_TCLK +#define CONFIG_SYS_NS16550_COM1 KW_UART0_BASE + +/* + * Serial Port configuration + * The following definitions let you select what serial you want to use + * for your console driver. + */ + +#define CONFIG_CONS_INDEX 1 /* Console on UART0 */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_BOOTMAPSZ (8 << 20) /* Initial Memmap for Linux */ +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_INITRD_TAG /* enable INITRD tag */ +#define CONFIG_SETUP_MEMORY_TAGS /* enable memory tag */ + +/* + * Commands configuration + */ +#define CONFIG_CMD_ELF +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NFS + +/* + * Without NOR FLASH we need this + */ +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS + +/* + * NAND Flash configuration + */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define NAND_MAX_CHIPS 1 +#define CONFIG_NAND_KIRKWOOD +#define CONFIG_SYS_NAND_BASE 0xd8000000 + +#define BOOTFLASH_START 0x0 + +#define CONFIG_KM_CONSOLE_TTY "ttyS0" + +/* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +/* + * Other required minimal configurations + */ +#define CONFIG_CONSOLE_INFO_QUIET /* some code reduction */ +#define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ +#define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ +#define CONFIG_DISPLAY_CPUINFO /* Display cpu info */ +#define CONFIG_NR_DRAM_BANKS 4 +#define CONFIG_STACKSIZE 0x00100000 /* regular stack- 1M */ +#define CONFIG_SYS_RESET_ADDRESS 0xffff0000 /* Rst Vector Adr */ + +/* + * Ethernet Driver configuration + */ +#define CONFIG_NETCONSOLE /* include NetConsole support */ +#define CONFIG_NET_MULTI /* specify more that one ports available */ +#define CONFIG_MII /* expose smi ove miiphy interface */ +#define CONFIG_KIRKWOOD_EGIGA /* Enable kirkwood Gbe Controller Driver */ +#define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ +#define CONFIG_KIRKWOOD_EGIGA_PORTS {1,0} /* enable port 0 only */ +#define CONFIG_PHY_BASE_ADR 0 +#define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ +#define CONFIG_RESET_PHY_R /* use reset_phy() to init 88E1118 PHY */ + +/* + * UBI related stuff + */ +#define CONFIG_SYS_USE_UBI + +/* + * I2C related stuff + */ +#undef CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_SOFT_I2C /* I2C bit-banged */ + +#if defined(CONFIG_HARD_I2C) +#define CONFIG_I2C_KIRKWOOD +#define CONFIG_I2C_KW_REG_BASE KW_TWSI_BASE +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 +#endif + +#if defined(CONFIG_SOFT_I2C) +#define CONFIG_KIRKWOOD_GPIO /* Enable GPIO Support */ +#ifndef __ASSEMBLY__ +#include <asm/arch-kirkwood/gpio.h> +extern void __set_direction(unsigned pin, int high); +void set_sda (int state); +void set_scl (int state); +int get_sda (void); +int get_scl (void); +#define SUEN3_SDA_PIN 8 +#define SUEN3_SCL_PIN 9 +#define SUEN3_ENV_WP 38 + +#define I2C_ACTIVE __set_direction(SUEN3_SDA_PIN, 0) +#define I2C_TRISTATE __set_direction(SUEN3_SDA_PIN, 1) +#define I2C_READ (kw_gpio_get_value(SUEN3_SDA_PIN) ? 1 : 0) +#define I2C_SDA(bit) kw_gpio_set_value(SUEN3_SDA_PIN, bit); +#define I2C_SCL(bit) kw_gpio_set_value(SUEN3_SCL_PIN, bit); +#endif + +#define I2C_DELAY udelay(3) /* 1/4 I2C clock duration */ +#define I2C_SOFT_DECLARATIONS + +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_SYS_I2C_SPEED 100000 +#endif + +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 + +#if defined(CONFIG_SYS_NO_FLASH) +#define CONFIG_KM_UBI_PARTITION_NAME "ubi0" +#undef CONFIG_FLASH_CFI_MTD +#undef CONFIG_JFFS2_CMDLINE +#endif + +#endif /* _CONFIG_KM_ARM_H */ diff --git a/include/configs/mgcoge2_arm_p1a.h b/include/configs/mgcoge2_arm_p1a.h new file mode 100644 index 0000000..db38915 --- /dev/null +++ b/include/configs/mgcoge2_arm_p1a.h @@ -0,0 +1,96 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Prafulla Wadaskar prafulla@marvell.com + * + * (C) Copyright 2009 + * Stefan Roese, DENX Software Engineering, sr@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +/* + * for linking errors see + * http://lists.denx.de/pipermail/u-boot/2009-July/057350.html + */ + +#ifndef _CONFIG_MGCOGE2_ARM_P1A_H +#define _CONFIG_MGCOGE2_ARM_P1A_H + +/* include common defines/options for all arm based Keymile boards */ +#include "km_arm.h" + +/* + * Version number information + */ +#define CONFIG_IDENT_STRING "\nKeymile mgcoge2" + +#define CONFIG_HOSTNAME mgcoge2 + +/* + * Environment variables configurations + */ +#define CONFIG_ENV_IS_IN_EEPROM /* use EEPROM for environment vars */ +#define CONFIG_SYS_DEF_EEPROM_ADDR 0x50 +#define CONFIG_ENV_EEPROM_IS_ON_I2C 1 +#define CONFIG_SYS_EEPROM_WREN 1 +#define CONFIG_ENV_OFFSET 0x40 /* no bracets! */ +#undef CONFIG_ENV_SIZE +#define CONFIG_ENV_SIZE (0x2000 - CONFIG_ENV_OFFSET) +#define CONFIG_I2C_ENV_EEPROM_BUS "pca9544a:70:8\0" + +#define CONFIG_CMD_SF + +#define CONFIG_SPI_FLASH +#define CONFIG_HARD_SPI +#define CONFIG_KIRKWOOD_SPI +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 50000000 /* 50Mhz */ + +#define FLASH_GPIO_PIN 0x00010000 + +#define MTDIDS_DEFAULT "nand0=orion_nand" +/* test-only: partitioning needs some tuning, this is just for tests */ +#define MTDPARTS_DEFAULT "mtdparts=" \ + "orion_nand:" \ + "-(" CONFIG_KM_UBI_PARTITION_NAME ")" + +#define CONFIG_KM_DEF_ENV_UPDATE \ + "update=" \ + "spi on;sf probe 0;sf erase 0 50000;" \ + "sf write ${u-boot_addr_r} 0 ${filesize};" \ + "spi off\0" + +/* + * Default environment variables + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_KM_DEF_ENV \ + "memsize=0x8000000\0" \ + "newenv=setenv addr 0x100000 && " \ + "i2c dev 1; mw.b ${addr} 0 4 && " \ + "eeprom write " xstr(CONFIG_SYS_DEF_EEPROM_ADDR) \ + " ${addr} " xstr(CONFIG_ENV_OFFSET) " 4\0" \ + "rootpath=/opt/eldk/arm\0" \ + "EEprom_ivm=pca9544a:70:9\0" \ + "" + +#endif /* _CONFIG_SUEN3_H */
Hi Heiko
Pls find my inlined comments
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: Friday, February 12, 2010 1:36 PM To: U-Boot user list Cc: Wolfgang Denk; Prafulla Wadaskar; Scott Wood; Stefan Roese Subject: [PATCH 1/4 v4] arm: add support for the mgcoge2_arm_p1a board from keymile
Can't you use "common.h" here ?
#endif
This is not with reference to this board
Ditto
+clean:
+distclean: clean
+############################################################# ############ diff --git a/board/keymile/km_arm/config.mk b/board/keymile/km_arm/config.mk new file mode 100644 index 0000000..b9e81b2 --- /dev/null +++ b/board/keymile/km_arm/config.mk @@ -0,0 +1,28 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Prafulla Wadaskar prafulla@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +#
- (C) Copyright 2009
- Marvell Semiconductor <www.marvell.com>
- Prafulla Wadaskar prafulla@marvell.com
- Stefan Roese, DENX Software Engineering, sr@denx.de.
- project.
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
MPP0_NF_IO2,
MPP1_NF_IO3,
MPP2_NF_IO4,
MPP3_NF_IO5,
MPP4_NF_IO6,
MPP5_NF_IO7,
MPP6_SYSRST_OUTn,
MPP7_PEX_RST_OUTn,
Why does you need this ifdef here? for a particular board this should be pre-defined.
+#else
MPP8_TW_SDA,
MPP9_TW_SCK,
MPP10_UART0_TXD,
MPP11_UART0_RXD,
MPP13_UART1_TXD,
MPP14_UART1_RXD,
MPP18_NF_IO0,
MPP19_NF_IO1,
MPP20_GPIO,
MPP21_GPIO,
MPP22_GPIO,
MPP23_GPIO,
MPP24_GPIO,
MPP25_GPIO,
MPP26_GPIO,
MPP27_GPIO,
MPP28_GPIO,
MPP29_GPIO,
MPP30_GPIO,
MPP31_GPIO,
MPP32_GPIO,
MPP33_GPIO,
0
uchar buf;
int ret = 0;
Ditto
return -1;
ret = 1;
+#else
return -1;
ret = 1;
return ret;
char *str;
int mach_type;
puts("Piggy:");
puts (" not");
puts(" present\n");
if (str != NULL) {
u32 tmp;
* to NAND mode.
This does not match with the board you are supporting, better to use similar name
Avoid this at least for this board patch
+#endif +#endif
u32 tmp;
if (argc < 2) {
cmd_usage(cmdtp);
return 1;
} else {
cmd_usage(cmdtp);
return 1;
+U_BOOT_CMD(
int i;
*)kw_sdram_bar(i),
kw_sdram_bs(i));
return;
/* reset the phy */
ivm_read_eeprom ();
+} +#endif
int i;
int i;
else
+} +#endif
Ditto..
Ditto..
I2C_ACTIVE;
I2C_SDA(state);
I2C_SCL(state);
I2C_TRISTATE;
return I2C_READ;
+} +#endif
Where these are used, I could not find any reference in this patch
It is better to explain each settings here about what exactly you are programming
- project.
- MA 02110-1301 USA
- High Level Configuration Options (easy to change)
- NS16550 Configuration
- Serial Port configuration
- The following definitions let you select what serial you
want to use
- for your console driver.
- For booting Linux, the board info and command line data
- have to be in the first 8 MB of memory, since this is
- the maximum mapped by the Linux kernel during initialization.
- Commands configuration
- Without NOR FLASH we need this
- NAND Flash configuration
- Other required minimal configurations
- Ethernet Driver configuration
- UBI related stuff
- I2C related stuff
Not valid for this board, this patch should explain only about mgcoge2
- project.
- MA 02110-1301 USA
- for linking errors see
- Version number information
- Environment variables configurations
"orion_nand:" \
"update=" \
"spi off\0"
- Default environment variables
CONFIG_KM_DEF_ENV \
"eeprom write "
Wrong comment...
Regards.. Prafulla . .
-- 1.6.2.5
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Hello Prafulla,
No, this is "just" a keymile specific header for including functions, which are "common" for all keymile boards ...
#endif
It is defined in include/configs/km_arm.h line 41
(As I said, this "4" boards are all the same, just different hardwarerevisions ...)
Ditto
See comment above.
MPP0_NF_IO2,
MPP1_NF_IO3,
MPP2_NF_IO4,
MPP3_NF_IO5,
MPP4_NF_IO6,
MPP5_NF_IO7,
MPP6_SYSRST_OUTn,
MPP7_PEX_RST_OUTn,
Yep, this define should be CONFIG_SOFT_I2C.
+#else
MPP8_TW_SDA,
MPP9_TW_SCK,
MPP10_UART0_TXD,
MPP11_UART0_RXD,
MPP13_UART1_TXD,
MPP14_UART1_RXD,
MPP18_NF_IO0,
MPP19_NF_IO1,
MPP20_GPIO,
MPP21_GPIO,
MPP22_GPIO,
MPP23_GPIO,
MPP24_GPIO,
MPP25_GPIO,
MPP26_GPIO,
MPP27_GPIO,
MPP28_GPIO,
MPP29_GPIO,
MPP30_GPIO,
MPP31_GPIO,
MPP32_GPIO,
MPP33_GPIO,
0
uchar buf;
int ret = 0;
Ditto
I correct this.
return -1;
ret = 1;
+#else
return -1;
ret = 1;
return ret;
char *str;
int mach_type;
puts("Piggy:");
puts (" not");
puts(" present\n");
if (str != NULL) {
u32 tmp;
* to NAND mode.
As I said above, this boards are all the same, just different hardwarerevisions, so theys all have one MACH_TYPE_ ...
Don;t understand this! Why? The board uses this pins for I2C bitbang, so I must initialize the pins ...
+#endif +#endif
Ditto..
What do you mean here?
Ditto..
I2C_ACTIVE;
I2C_SDA(state);
I2C_SCL(state);
I2C_TRISTATE;
return I2C_READ;
+} +#endif
They are used in board/keymile/common/common.c for the I2C deblocking sequence. (This is one of the common code used for all keymile boards)
Ok, I try it.
- I2C related stuff
No, they are valid, because it uses the i2c bitbang driver... (This file is used by *all* 4 boards ...)
I know the board name mgcoge2_arm_p1a is a little bit confusing, but this is because this was the first hardware version of the "suen3" board, which is a part of a hardware, where also is a powerpc piece named "mgcoge2", and so the first version was named to mgcoge2_arm_p1a ... the next hardware revison was named "suen3" ...
Wrong comment...
Yep, correct it.
Thanks for reviewing!
bye Heiko
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: Monday, February 15, 2010 1:37 PM To: Prafulla Wadaskar Cc: U-Boot user list; Wolfgang Denk; Scott Wood; Stefan Roese Subject: Re: [PATCH 1/4 v4] arm: add support for the mgcoge2_arm_p1a board from keymile
Hello Prafulla,
...snip...
More important common.h that you are referring here is missing in this patch. Secondly, since you are in the same folder you should use "common.h" instead of absolute path"
...snip...
To me, two boards are two different hardware and must have associated with two different machine ids. How will you manage picking different board setups in kernel for same machine ID?
If not Machine ID, you can think of using EEPROM available on board to store board version info and use it selectively.
why you need to ifdef this? For this particular board it should be hard coded, I think you can do this for other board support if needed.
First patch in this series has to be clean standard board support without any ifdefs, subsequent patches add support for different hardware version, there if you use ifdef it makes more sense
+#endif +#endif
Hello Prafulla,
Hello Prafulla,
...snip...
No, it is in mainline, see:
http://git.denx.de/?p=u-boot.git;a=blob;f=board/keymile/common/common.h;h=a3...
This is a header common for all keymile boards, so it sit in the board/manufacturer/common/ directory.
This is used also used for some ppc based boards.
...snip...
They all use the *same* kernel!
Ok, I delete this.
bye Heiko
Heiko Schocher
Prafulla Wadaskar
