[U-Boot] [PATCH 1/3] mxs: Use SoC agnostic configuration option for power switch setting
The power switch option is compatible with i.MX23 and i.MX28 so the configration option needs to reflect it. We choose 'CONFIG_SPL_MXS_PSWITCH_WAIT' for the option name.
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- arch/arm/cpu/arm926ejs/mxs/mxs_init.h | 2 +- arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/mxs_init.h b/arch/arm/cpu/arm926ejs/mxs/mxs_init.h index 2ddc5bc..084def5 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxs_init.h +++ b/arch/arm/cpu/arm926ejs/mxs/mxs_init.h @@ -30,7 +30,7 @@ void early_delay(int delay);
void mxs_power_init(void);
-#ifdef CONFIG_SPL_MX28_PSWITCH_WAIT +#ifdef CONFIG_SPL_MXS_PSWITCH_WAIT void mxs_power_wait_pswitch(void); #else static inline void mxs_power_wait_pswitch(void) { } diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c index e9d6302..287c698 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c @@ -921,7 +921,7 @@ void mxs_power_init(void) early_delay(1000); }
-#ifdef CONFIG_SPL_MX28_PSWITCH_WAIT +#ifdef CONFIG_SPL_MXS_PSWITCH_WAIT void mxs_power_wait_pswitch(void) { struct mxs_power_regs *power_regs =
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c index 836e636..a9efd87 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c @@ -90,7 +90,7 @@ static uint32_t dram_vals[] = { #elif defined(CONFIG_MX23) 0x01010001, 0x00010100, 0x01000101, 0x00000001, 0x00000101, 0x00000000, 0x00010000, 0x01000001, - 0x00000000, 0x00000001, 0x07000200, 0x00070202, + 0x01000000, 0x00000001, 0x07000200, 0x00070202, 0x02020000, 0x04040a01, 0x00000201, 0x02040000, 0x02000000, 0x19000f08, 0x0d0d0000, 0x02021313, 0x02061521, 0x0000000a, 0x00080008, 0x00200020,
Dear Otavio Salvador,
What does "bit 24" mean and what impact does it have? Commit message is missing. Also, I don't see patch 3/3
- 0x01000000, 0x00000001, 0x07000200, 0x00070202, 0x02020000, 0x04040a01, 0x00000201, 0x02040000, 0x02000000, 0x19000f08, 0x0d0d0000, 0x02021313, 0x02061521, 0x0000000a, 0x00080008, 0x00200020,
Best regards, Marek Vasut
Signed-off-by: Otavio Salvador otavio@ossystems.com.br --- board/freescale/mx23evk/spl_boot.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/board/freescale/mx23evk/spl_boot.c b/board/freescale/mx23evk/spl_boot.c index 6007433..b6f4e7e 100644 --- a/board/freescale/mx23evk/spl_boot.c +++ b/board/freescale/mx23evk/spl_boot.c @@ -98,6 +98,16 @@ const iomux_cfg_t iomux_setup[] = { (MXS_PAD_4MA | MXS_PAD_3V3 | MXS_PAD_NOPULL), };
+#define HW_DRAM_CTL14 (0x38 >> 2) +#define CS_MAP 0x3 +#define INTAREF 0x2 +#define HW_DRAM_CTL14_CONFIG (INTAREF << 8 | CS_MAP) + +void mxs_adjust_memory_params(uint32_t *dram_vals) +{ + dram_vals[HW_DRAM_CTL14] = HW_DRAM_CTL14_CONFIG; +} + void board_init_ll(void) { mxs_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup));
The Subject should be "Rename CONFIG_SPL_MX28_PSWITCH_WAIT to CONFIG_SPL_MXS_PSWITCH_WAIT" or something
Otavio Salvador
