[U-Boot] [PATCH 1/2] rockchip: rk3399: fix force power on reset
Currently code doesn't even compile since it uses wrong define for ifdef. Fix that and also add missing include
Fixes: 07586ee4322a ("rockchip: rk3399: Support common spl_board_init") Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/mach-rockchip/rk3399/rk3399.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index 863024d071..eeb99dd11b 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -11,6 +11,7 @@ #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/cru_rk3399.h> #include <asm/arch-rockchip/gpio.h> #include <asm/arch-rockchip/grf_rk3399.h> #include <asm/arch-rockchip/hardware.h> @@ -213,7 +214,7 @@ void spl_perform_fixups(struct spl_image_info *spl_image) "u-boot,spl-boot-device", boot_ofpath); }
-#if defined(SPL_GPIO_SUPPORT) +#if defined(CONFIG_SPL_GPIO_SUPPORT) static void rk3399_force_power_on_reset(void) { ofnode node; @@ -239,7 +240,7 @@ static void rk3399_force_power_on_reset(void)
void spl_board_init(void) { -#if defined(SPL_GPIO_SUPPORT) +#if defined(CONFIG_SPL_GPIO_SUPPORT) struct rk3399_cru *cru = rockchip_get_cru();
Rockpro64 doesn't boot reliably after soft reset, so let's force power on reset by asserting sysreset pin if we detected soft reset.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/dts/rk3399-rockpro64-u-boot.dtsi | 8 ++++++++ configs/rockpro64-rk3399_defconfig | 1 + 2 files changed, 9 insertions(+)
diff --git a/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi b/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi index 4648513ea9..bb94bcf7be 100644 --- a/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi +++ b/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi @@ -6,11 +6,19 @@ #include "rk3399-u-boot.dtsi" #include "rk3399-sdram-lpddr4-100.dtsi" / { + config { + sysreset-gpio = <&gpio1 RK_PA6 GPIO_ACTIVE_HIGH>; + }; + chosen { u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; }; };
+&gpio1 { + u-boot,dm-pre-reloc; +}; + &vdd_center { regulator-min-microvolt = <950000>; regulator-max-microvolt = <950000>; diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 49e27c91cb..d153ac5485 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO_SUPPORT=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ENV_OFFSET=0x3F8000 CONFIG_TARGET_ROCKPRO64_RK3399=y
Hi Vasily,
I think this should not be needed, see comments below.
Hi Philipp, Klaus and Christoph:
Could you help to check why do you need below patch for your board?
ae0d33a729 rockchip: rk3399-puma: add code to allow forcing a power-on reset
I think we don't need this workaround for rk3399 CPU_B voltage supply, and here is what I got: - rockchip use cru glb_rst_1 for reboot in kernel; - the glb_rst_1 will reset all the GPIO logic to default state; - the cpu_b voltage supplier syr83x have a VSEL connect to rk3399, which may be a pull up/down IO, - the syr83x output with the hardware default state of the VSEL(with RK3399 default IO output) should be normal output(1.0V), and another state output for suspend(disabled), - In order to make the syr83x works as expected, the kernel setting of syr83x should be correct, check property: fcs,suspend-voltage-selector = <1>; This is correct for rockpro64(vsel connect to a gpio with default pull down) on upstream, but I don't have a puma schematic, so I don't know if this is correct for puma. - With correct setting in syr83x, the cpu_b should always have power supply after reboot/reset with cru glb_rst_1 reg. So no workaround is needed in U-Boot, please correct me if anything is missing.
- config {
- chosen { u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; }; };
+&gpio1 {
- u-boot,dm-pre-reloc;
- &vdd_center { regulator-min-microvolt = <950000>; regulator-max-microvolt = <950000>;
On Thu, Nov 28, 2019 at 1:23 AM Kever Yang kever.yang@rock-chips.com wrote:
Hi Vasily,
Hi Kever,
I've spent 2 weeks of my evenings debugging this issue but unfortunately I don't have a proper fix. This is the only solution that makes my rockpro64 reboot reliably with mainline u-boot and ATF. See my comments below.
I already tried re-initializing SYR83x, see [1] (and thus fixed couple of the bugs in FAN53555 driver which has been broken since it was merged into u-boot) but it doesn't help with reboot issue on RockPro64. I checked VSEL gpio status and it's identical on cold boot and on soft reboot, so I doubt SYR83X settings are related since I checked regulators settings and they're correct.
I tried to boot with CPUFREQ disabled - that didn't help, linux hangs when booted after soft reset.
Also tried to boot with big cluster disabled - that didn't help either.
So could you merge this patch please unless someone else wants to work on this issue?
Thanks, Vasily.
[1] https://github.com/anarsoul/u-boot-pine64/commit/7a50e58f09c68efe08f0b991280...
Thanks,
- Kever
config {
};chosen { u-boot,spl-boot-order = "same-as-spl", &sdmmc, &sdhci; };
+&gpio1 {
Hi Vasily,
Hi Vasily,
Hi Kever,
I can understand you work pretty hard on make it work, it's not so easy to identify the root cause
some times, thanks very much for working on this.
Could you help to provide some more info?
- For code boot, syr83x VSEL is low, and what is its output voltage?
- For reboot, syr83x VSEL is low, what is its output voltage?
- For reboot, after this patch, the syr83x VSEL is high, what is its output voltage?
I think the setting of syr83x is wrong if the output voltage is not the same for code boot and reboot.
This is strange, this patch only affects the big cluster CPU, if big cluster is disabled, then there is
no reason this patch can work. Have you double check the big cluster is truly _DISABLED_?
Thanks,
- Kever
Thanks, Vasily.
Thanks,
- Kever
config {
+&gpio1 {
On Thu, Nov 28, 2019 at 4:59 PM Kever Yang kever.yang@rock-chips.com wrote:
Hi Vasily,
Hi Vasily,
Hi Kever,
I'll double check later tonight.
output voltage?
This patch doesn't touch VSEL. It sets OTP_OUT to 1, see [1] "Over-Temperature Protection" and thus forces board reset.
OTP_OUT is GPIO1 A6.
VSEL (or rather CPU_B_SLEEP_H) is different pin, it's wired to GPIO1 C1
http://files.pine64.org/doc/rockpro64/rockpro64_v21-SCH.pdf
See explanation above.
Thanks,
- Kever
Thanks, Vasily.
Thanks,
- Kever
config {
+&gpio1 {
Hi Vasily,
Hi Vasily,
Hi Vasily,
Hi Kever,
I also had a problem where Linux would hang or panic after rebooting, with mainline u-boot and ATF on a rockpro64. This patch does fix the issue for me, I have tested it by performing 10 reboots from Linux in a row and I've seen no hangs or panics.
I noticed the Armbian project have recently included a patch to ATF [1] which switches all power domains on before ATF performs a soft reset. I have also tested using u-boot mainline, without any patches to u-boot, but including ATF patched with your reset fix [2] and the Armbian power domains patch [1]. This also fixes the same hanging on reboot issue for me without modifications to u-boot, I've also tested 10 reboots in a row with this ATF and seen no hangs.
So this u-boot patch may not be needed if ATF is patched instead to switch power domains on before soft reset.
FWIW, when I was able to see panic messages from Linux when it panicked on boot, the call trace always seemed to include rockchip_pd_power_off() [3].
[1] https://github.com/armbian/build/blob/master/patch/atf/atf-rk3399/switch-pow... [2] https://review.trustedfirmware.org/c/TF-A/trusted-firmware-a/+/2512 [3] https://gist.github.com/sigmaris/c0e155c8cb0a325d84f549185f9a568c
output voltage?
Thanks,
- Kever
Thanks, Vasily.
Thanks,
- Kever
config {
+&gpio1 {
Hi Huge Cole-Baker,
On 2019/12/1 下午10:12, Hugh Cole-Baker wrote:
Hi Vasily,
Hi Vasily,
Hi Vasily,
Hi Kever,
Thanks very much for your detail info about this issue, I have sync with my colleague, rockchip bl31.elf in rkbin do open all the power domain before reboot, so I believe this would be a better solution in ATF for it can resolve issue on all the rk3399 boards instead of add one by one in U-Boot. Does any one of you would like to upstream the patch in ATF?
Thanks,
- Kever
output voltage?
Thanks,
- Kever
Thanks, Vasily.
Thanks,
- Kever
config {
+&gpio1 {
Looping int a few relevant/active kernel people/lists for full coverage.
On Sun, 01 Dec 2019, Hugh Cole-Baker wrote:
On 29 Nov 2019, at 01:06, Vasily Khoruzhick anarsoul@gmail.com wrote: On Thu, Nov 28, 2019 at 4:59 PM Kever Yang kever.yang@rock-chips.com wrote:
Hi Vasily,
Hi Vasily,
Hi Kever,
This last paste looks remarkably similar to an issue currently seen on the Radxa ROCK Pi 4B (RK3399) during power-up after a soft reboot (`sudo reboot`) is issued. We're presently running v5.15.35 [0].
It's not clear how this issue (present 3 years ago) was finally resolved. From the thread, it looks as if the fix might have made its way into ATF, but I'm 87.6% sure ATF is not running on this platform (yet).
Note that the u-boot we're using is also quite old:
U-Boot 2019.10-09248-g8511c75bb4 (Jan 08 2020 - 17:13:03 -0800)
... so this could easily be the root cause. The current plan is to try to update this ASAP. However early attempts are yet to result in a successful boot.
I see that Brian recently added a few patches related to PD/DVFS, but again, these appear to be ATF related.
Would anyone be able to shed some light onto this for me please?
As always, any help would be gratefully received.
Kind regards, Lee
[0] Full reboot log can be seen at: https://pastebin.ubuntu.com/p/MjZP2V6kQ3/
[ 0.699736][ T1] initcall __initstub__kmod_iommu__362_155_iommu_subsys_init4+0x0/0x8 returned 0 after 0 usecs [ 0.700737][ T1] calling __initstub__kmod_rockchip_iommu__348_1415_rk_iommu_init4+0x0/0x8 @ 1 [ 0.702238][ C5] SError Interrupt on CPU5, code 0xbf000002 -- SError [ 0.702248][ C5] CPU: 5 PID: 48 Comm: kworker/5:1 Not tainted 5.15.35-android13-5-00092-g525d77310a20 #1 [ 0.702261][ C5] Hardware name: Radxa ROCK Pi 4B (DT) [ 0.702266][ C5] Workqueue: pm genpd_power_off_work_fn.cfi_jt [ 0.702289][ C5] pstate: 804000c5 (Nzcv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 0.702301][ C5] pc : regmap_mmio_read32le+0x14/0x2c [ 0.702318][ C5] lr : regmap_mmio_read+0x68/0xd0 [ 0.702331][ C5] sp : ffffffc00b6d3b40 [ 0.702335][ C5] x29: ffffffc00b6d3b40 x28: 0000000000000000 x27: 0000000000000000 [ 0.702351][ C5] x26: ffffff8000923680 x25: ffffffc009abc2a0 x24: ffffff8000930c00 [ 0.702364][ C5] x23: 0000000000000014 x22: ffffff8000930c00 x21: 0000000000000008 [ 0.702378][ C5] x20: ffffff8000922300 x19: ffffff8000923680 x18: ffffffc00b66d058 [ 0.702391][ C5] x17: 000000000000ba7e x16: ffffffc00a4dee04 x15: 000000000000b67e [ 0.702405][ C5] x14: 00000000028dd7a0 x13: 0000000000000040 x12: 0000000000000000 [ 0.702419][ C5] x11: 0000000000000000 x10: 0000000000000000 x9 : 0000000000000005 [ 0.702432][ C5] x8 : 0000000000000000 x7 : 00756d6d6f692e30 x6 : 3030383035366666 [ 0.702445][ C5] x5 : 0000000000000001 x4 : 028dea248fba33d6 x3 : 0000000000000000 [ 0.702457][ C5] x2 : ffffff8000923680 x1 : 0000000000000008 x0 : 0000000000000000 [ 0.702472][ C5] Kernel panic - not syncing: Asynchronous SError Interrupt [ 0.702477][ C5] CPU: 5 PID: 48 Comm: kworker/5:1 Not tainted 5.15.35-android13-5-00092-g525d77310a20 #1 [ 0.702487][ C5] Hardware name: Radxa ROCK Pi 4B (DT) [ 0.702492][ C5] Workqueue: pm genpd_power_off_work_fn.cfi_jt [ 0.702506][ C5] Call trace: [ 0.702508][ C5] dump_backtrace.cfi_jt+0x0/0x8 [ 0.702525][ C5] dump_stack_lvl+0x80/0xb8 [ 0.702536][ C5] panic+0x180/0x444 [ 0.702547][ C5] arm64_serror_panic+0x1c0/0x210 [ 0.702561][ C5] do_serror+0x17c/0x218 [ 0.702572][ C5] el1h_64_error_handler+0x38/0x50 [ 0.702581][ C5] el1h_64_error+0x7c/0x80 [ 0.702589][ C5] regmap_mmio_read32le+0x14/0x2c [ 0.702603][ C5] _regmap_bus_reg_read+0x3c/0x90 [ 0.702614][ C5] _regmap_read+0xb0/0x24c [ 0.702623][ C5] rockchip_pd_power+0x6c4/0xbc0 [ 0.702638][ C5] rockchip_pd_power_off+0x18/0x28 [ 0.702652][ C5] _genpd_power_off+0x178/0x388 [ 0.702663][ C5] genpd_power_off+0x188/0x2e4 [ 0.702673][ C5] genpd_power_off_work_fn+0x54/0xe4 [ 0.702683][ C5] process_one_work+0x254/0x5a0 [ 0.702696][ C5] worker_thread+0x3ec/0x920 [ 0.702707][ C5] kthread+0x168/0x1dc [ 0.702716][ C5] ret_from_fork+0x10/0x20 [ 0.702726][ C5] SMP: stopping secondary CPUs
Hi Vasily,
Hi Vasily,
Hi Kever,
Good Evening,
That's definitely not stock v5.15.35, it's been tagged as an android kernel. 5.15.35-android13-5-00092-g525d77310a20
The rk3399 SoC has a hardware bug where the power domains are not reset upon a soft reset. This leads to situations like this one where power domains are shut down during shutdown but aren't restored on reboot. Mainline TF-A was patched to force all power domains online when a soft reboot is triggered, which solved that issue. What particular issues are you having initializing modern u-boot on this device? Is there a particular reason it isn't using Mainline TF-A?
I've also run into issues on rk356x where the regulator powering a power domain isn't powered due to a soft reset, which also causes faults like this. Set your main regulators to always-on and see if it helps with the issue.
Very Respectfully, Peter Geis
Kind regards, Lee
-- Lee Jones [李琼斯] Principal Technical Lead - Developer Services Linaro.org │ Open source software for Arm SoCs Follow Linaro: Facebook | Twitter | Blog
Linux-rockchip mailing list Linux-rockchip@lists.infradead.org http://lists.infradead.org/mailman/listinfo/linux-rockchip
Hi Vasily,
On Thu, Nov 28, 2019 at 1:23 AM Kever Yang kever.yang@rock-chips.com wrote: > Hi Vasily, > > I think this should not be needed, see comments below. Hi Kever,
Good Evening,
Hi, Peter,
Thank you so much for your reply.
It's not stock, no.
Although the differences from RockPi's perspective are minimal.
The main difference is the way the kernel is configured.
It's GKI:
https://android.googlesource.com/kernel/common/+/refs/heads/android13-5.15/a...
Plus a few non-GKI specifics:
I assume this isn't something we can patch in the kernel driver?
Okay, this is what I figured.
This is the output: https://pastebin.ubuntu.com/p/d5DmsSBnrR/
Speaking with one of the guys who supports RockPi 4 in AOSP, he suspects the DDR settings. Apparently settings for older SoCs sometimes get clobbered when support for newer SoCs is added.
I am yet to investigate the u-boot story in any detail.
It's on my TODO list for today.
We're not using Trusted Firmware yet.
Although I'm starting to think this should be re-prioritised.
I'll do that. Thanks for the tip.
Our main issue currently is an RCU-lock-up, again on soft reboot:
[ 21.226951][ C0] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks: [ 21.227637][ C0] rcu: 5-...!: (1 GPs behind) idle=3de/1/0x4000000000000000 softirq=9/10 fqs=3 last_accelerate: 0000/efb9 dyntick_enabled: 0 [ 21.228890][ C0] (detected by 0, t=5252 jiffies, g=-1167, q=46)
Do you think these issues could all be related?
Thanks ever so much for your reply Peter.
You've potentially saved us hours and hours of debugging.
Kind regards, Lee
Kind regards, Lee
Hi Vasily,
On 2019/11/28 下午11:51, Vasily Khoruzhick wrote: > On Thu, Nov 28, 2019 at 1:23 AM Kever Yang kever.yang@rock-chips.com wrote: >> Hi Vasily, >> >> I think this should not be needed, see comments below. > Hi Kever, > > I've spent 2 weeks of my evenings debugging this issue but
> unfortunately I don't have a proper fix. This is the only solution > that makes my rockpro64 reboot reliably with mainline u-boot and ATF. > See my comments below.
Good Evening,
Hi, Peter,
It's not stock, no.
It's GKI:
Ah, so close enough to not matter much.
As far as I know it's being worked on by others, I have some ideas for this as well but I've been focused on rk356x lately.
The rk3399 TPL code is specific to the rk3399 and it really hasn't been touched much recently. I'm using the latest Mainline U-Boot on both my Rockpro64 and Pinephone-Pro. I don't see TF-A being loaded, which should happen between:
Trying to boot from BOOTROM Returning to boot ROM...
Otherwise it just looks like the TPL code doesn't like being in a single channel configuration. Does the 2GB model just forgo the second ram chip? Or is this actually a 4GB model and it isn't detecting the second chip in both downstream and mainline? Could you include the TPL/SPL portion of downstream's output?
This platform does not work at all without TF-A. Optee is optional. Either you are using the downstream blob from Rockchip or Mainline built yourself. Personally I prefer using Mainline everything. If you build Mainline U-Boot without TF-A it will throw a warning at the end that says the created binary is non-functional.
If you've powered down a minor power domain while a driver was still active, sure.
Not a problem!
Kind regards, Lee
Kind regards, Lee
Thanks for the update.
TPL/SPL are mostly silent on the downstream build:
https://pastebin.ubuntu.com/p/m2bBdjF8Wq/
Not sure if it helps at all, but ArmBian is pretty noisy:
https://pastebin.ubuntu.com/p/fdPjmmqBDM/
Right. Played a lot with this today.
Our build was using TF-A which was built-in to the primary loader.
I had 2 interesting results today. No idea how to explain them.
First one was with Mainline u-boot and Mainline TF-A, which found, but was seemingly unable to boot the kernel:
https://pastebin.ubuntu.com/p/9HRhPyfjYK/
The second interesting result I had was using our downstream u-boot with Mainline TF-A. It booted perfectly from cold, but managed to get stuck in the TPL on soft reboot in a very similar way to the one I reported earlier when not booting with TF-A ("Channel 1: col error"):
https://pastebin.ubuntu.com/p/hwmBzxDBgc/
Thanks again for your insight.
Kind regards, Lee
Weird that downstream and mainline are being built with none of the debug stuff enabled. Armbian clearly shows the initial setup occuring correctly, and that it's a 4GB board. It's using both the Rockchip miniloader with a Rockchip TF-A blob as well.
Mainline TF-A defaults to 115200 for its uart messages, so you need to either A. pass the uart config from U-Boot to TF-A with a platform config option (unreliable in my experience), B. change U-Boot to 115200, or C. change TF-A to 1.5M (the path I take). Your mainline hang is exactly where you expect to hang with a non-functional TF-A. I enable some additional prints in my U-Boot tree to know exactly what gets loaded during SPL. There are also debug prints you can enable in TPL to get the setup results.
Would you be willing to run make savedefconfig from your mainline setup and share the result?
Kind regards, Lee
Hopefully this is enough:
diff --git a/plat/rockchip/rk3399/rk3399_def.h b/plat/rockchip/rk3399/rk3399_def.h index ba83242eb..24ad94ae7 100644 --- a/plat/rockchip/rk3399/rk3399_def.h +++ b/plat/rockchip/rk3399/rk3399_def.h @@ -17,7 +17,8 @@ /************************************************************************** * UART related constants **************************************************************************/ -#define RK3399_BAUDRATE 115200 +//#define RK3399_BAUDRATE 115200 +#define RK3399_BAUDRATE 1500000 #define RK3399_UART_CLOCK 24000000
Would you be kind enough to point me to the u-boot/TF-A prints please?
u-boot or TF-A?
Kind regards, Lee
> It's not clear how this issue (present 3 years ago) was finally > resolved. From the thread, it looks as if the fix might have made its > way into ATF, but I'm 87.6% sure ATF is not running on this platform > (yet).
- UART related constants
u-boot or TF-A?
Looks as though savedefconfig aren't u-boot or TF-A commands, so I'm guessing you mean kernel:
> > It's not clear how this issue (present 3 years ago) was finally > > resolved. From the thread, it looks as if the fix might have made its > > way into ATF, but I'm 87.6% sure ATF is not running on this platform > > (yet). > > The rk3399 SoC has a hardware bug where the power domains are not > reset upon a soft reset. This leads to situations like this one where > power domains are shut down during shutdown but aren't restored on > reboot.
> Mainline TF-A was patched to force all power domains online > when a soft reboot is triggered, which solved that issue.
> What particular issues are you having initializing modern u-boot on > this device?
Yes, that is sufficient.
u-boot or TF-A?
make savedefconfig causes the make system to output a defconfig file in your current tree directory. It's a part of the kernel make system, which also works in U-Boot mainline since it utilizes the same system. It's how the configs in configs/ are generated. I can use that simplified config to examine your current setup.
Or if you want to just host a git repository of your current U-Boot mainline tree with an intact .config, that works as well.
> > > It's not clear how this issue (present 3 years ago) was finally > > > resolved. From the thread, it looks as if the fix might have made its > > > way into ATF, but I'm 87.6% sure ATF is not running on this platform > > > (yet). > > > > The rk3399 SoC has a hardware bug where the power domains are not > > reset upon a soft reset. This leads to situations like this one where > > power domains are shut down during shutdown but aren't restored on > > reboot. > > I assume this isn't something we can patch in the kernel driver?
> > Mainline TF-A was patched to force all power domains online > > when a soft reboot is triggered, which solved that issue. > > Okay, this is what I figured. > > > What particular issues are you having initializing modern u-boot on > > this device? > > This is the output: https://pastebin.ubuntu.com/p/d5DmsSBnrR/ > > Speaking with one of the guys who supports RockPi 4 in AOSP, he > suspects the DDR settings. Apparently settings for older SoCs > sometimes get clobbered when support for newer SoCs is added.
> I am yet to investigate the u-boot story in any detail. > > It's on my TODO list for today. > > > Is there a particular reason it isn't using Mainline TF-A? > > We're not using Trusted Firmware yet.
u-boot or TF-A?
Yes, I know what savedefconfig does. :)
I'm afraid it's not as easy as that. The build system I'm using is wrapped up in Android build-system-ness. I'll have a look to see if I can roll a defconfig by hand some how.
Okay, so it's the u-boot defconfig you're after.
And Mainline, right, not our Android one?
> > > > It's not clear how this issue (present 3 years ago) was finally > > > > resolved. From the thread, it looks as if the fix might have made its > > > > way into ATF, but I'm 87.6% sure ATF is not running on this platform > > > > (yet). > > > > > > The rk3399 SoC has a hardware bug where the power domains are not > > > reset upon a soft reset. This leads to situations like this one where > > > power domains are shut down during shutdown but aren't restored on > > > reboot. > > > > I assume this isn't something we can patch in the kernel driver? > > As far as I know it's being worked on by others, I have some ideas for > this as well but I've been focused on rk356x lately.
> > > Mainline TF-A was patched to force all power domains online > > > when a soft reboot is triggered, which solved that issue. > > > > Okay, this is what I figured. > > > > > What particular issues are you having initializing modern u-boot on > > > this device? > > > > This is the output: https://pastebin.ubuntu.com/p/d5DmsSBnrR/ > > > > Speaking with one of the guys who supports RockPi 4 in AOSP, he > > suspects the DDR settings. Apparently settings for older SoCs > > sometimes get clobbered when support for newer SoCs is added. > > The rk3399 TPL code is specific to the rk3399 and it really hasn't > been touched much recently. I'm using the latest Mainline U-Boot on > both my Rockpro64 and Pinephone-Pro. I don't see TF-A being loaded, > which should happen between: > > Trying to boot from BOOTROM > Returning to boot ROM... > > Otherwise it just looks like the TPL code doesn't like being in a > single channel configuration. Does the 2GB model just forgo the second > ram chip? Or is this actually a 4GB model and it isn't detecting the > second chip in both downstream and mainline? Could you include the > TPL/SPL portion of downstream's output?
> > I am yet to investigate the u-boot story in any detail. > > > > It's on my TODO list for today. > > > > > Is there a particular reason it isn't using Mainline TF-A? > > > > We're not using Trusted Firmware yet. > > This platform does not work at all without TF-A. Optee is optional. > Either you are using the downstream blob from Rockchip or Mainline > built yourself. Personally I prefer using Mainline everything. If you > build Mainline U-Boot without TF-A it will throw a warning at the end > that says the created binary is non-functional.
That's interesting. Would this change result in me now being able to see the console output from this (apparently) failed attempt:
However the result is the same as the downstream kernel where it fails in the TPL on soft reboot:
https://pastebin.ubuntu.com/p/TZBYqTMCnN/
No TF-A messages seen though still.
Is it possible that u-boot only runs TF-A on cold boot? Seems odd.
What was the extra logging you mentioned before?
On Thu, May 19, 2022 at 10:56 AM Lee Jones lee.jones@linaro.org wrote: > > > > > > It's not clear how this issue (present 3 years ago) was finally > > > > > resolved. From the thread, it looks as if the fix might have made its > > > > > way into ATF, but I'm 87.6% sure ATF is not running on this platform > > > > > (yet). > > > > > > > > The rk3399 SoC has a hardware bug where the power domains are not > > > > reset upon a soft reset. This leads to situations like this one where > > > > power domains are shut down during shutdown but aren't restored on > > > > reboot. > > > > > > I assume this isn't something we can patch in the kernel driver? > > > > As far as I know it's being worked on by others, I have some ideas for > > this as well but I've been focused on rk356x lately. > > Thanks for the update. > > > > > Mainline TF-A was patched to force all power domains online > > > > when a soft reboot is triggered, which solved that issue. > > > > > > Okay, this is what I figured. > > > > > > > What particular issues are you having initializing modern u-boot on > > > > this device? > > > > > > This is the output: https://pastebin.ubuntu.com/p/d5DmsSBnrR/ > > > > > > Speaking with one of the guys who supports RockPi 4 in AOSP, he > > > suspects the DDR settings. Apparently settings for older SoCs > > > sometimes get clobbered when support for newer SoCs is added. > > > > The rk3399 TPL code is specific to the rk3399 and it really hasn't > > been touched much recently. I'm using the latest Mainline U-Boot on > > both my Rockpro64 and Pinephone-Pro. I don't see TF-A being loaded, > > which should happen between: > > > > Trying to boot from BOOTROM > > Returning to boot ROM... > > > > Otherwise it just looks like the TPL code doesn't like being in a > > single channel configuration. Does the 2GB model just forgo the second > > ram chip? Or is this actually a 4GB model and it isn't detecting the > > second chip in both downstream and mainline? Could you include the > > TPL/SPL portion of downstream's output? > > TPL/SPL are mostly silent on the downstream build: > > https://pastebin.ubuntu.com/p/m2bBdjF8Wq/ > > Not sure if it helps at all, but ArmBian is pretty noisy: > > https://pastebin.ubuntu.com/p/fdPjmmqBDM/
> > > > I am yet to investigate the u-boot story in any detail. > > > > > > It's on my TODO list for today. > > > > > > > Is there a particular reason it isn't using Mainline TF-A? > > > > > > We're not using Trusted Firmware yet. > > > > This platform does not work at all without TF-A. Optee is optional. > > Either you are using the downstream blob from Rockchip or Mainline > > built yourself. Personally I prefer using Mainline everything. If you > > build Mainline U-Boot without TF-A it will throw a warning at the end > > that says the created binary is non-functional. > > Right. Played a lot with this today. > > Our build was using TF-A which was built-in to the primary loader. > > I had 2 interesting results today. No idea how to explain them. > > First one was with Mainline u-boot and Mainline TF-A, which found, but > was seemingly unable to boot the kernel: > > https://pastebin.ubuntu.com/p/9HRhPyfjYK/ > > The second interesting result I had was using our downstream u-boot > with Mainline TF-A. It booted perfectly from cold, but managed to get > stuck in the TPL on soft reboot in a very similar way to the one I > reported earlier when not booting with TF-A ("Channel 1: col error"):
I'm convinced that TF-A is not functional on your mainline config. No, TF-A will execute on any reset that triggers SPL, as SPL loads TF-A and jumps to it as part of the FIT load.
This is what my rockpro64 looks like with TF-A executing. Note I've enabled a bit of extra TF-A debugging, normally it just prints out the TF-A version number. TF-A reports itself as BL31.
U-Boot TPL 2022.04-rc2-00234-g017a8901ae3a-dirty (Mar 02 2022 - 18:36:55) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... rockchip_sdram_size ff320308 32c1f2c1 rank 1 cs0_col 10 bk 3 cs0_row 16 bw 2 row_3_4 0 rank 1 cs0_col 10 bk 3 cs0_row 16 bw 2 row_3_4 0 SDRAM base=0, size=100000000
U-Boot SPL 2022.04-rc2-00234-g017a8901ae3a-dirty (Mar 02 2022 - 18:36:55 -0500) Trying to boot from MMC2 NOTICE: BL31: v2.6(release):v2.6-138-g929f064f69d0-dirty NOTICE: BL31: Built : 11:27:48, Feb 2 2022 INFO: GICv3 with legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: Maximum SPI INTID supported: 287 INFO: plat_rockchip_pmu_init(1710): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9
U-Boot 2022.04-rc2-00234-g017a8901ae3a-dirty (Mar 02 2022 - 18:36:55 -0500)
SoC: Rockchip rk3399 Reset cause: POR Model: Pine64 RockPro64 v2.1 DRAM: rockchip_sdram_size ff320308 32c1f2c1 rank 1 cs0_col 10 bk 3 cs0_row 16 bw 2 row_3_4 0 rank 1 cs0_col 10 bk 3 cs0_row 16 bw 2 row_3_4 0 SDRAM base=0, size=100000000 3.9 GiB PMIC: RK808 Core: 292 devices, 29 uclasses, devicetree: separate MMC: mmc@fe310000: 3, mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from SPIFlash... SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB *** Warning - bad CRC, using default environment
I'm currently pulling the rk3399-rock-pi-4b.dts that's in mainline linux to build a quick image for you, if you're interested.
> On Thu, May 19, 2022 at 10:56 AM Lee Jones lee.jones@linaro.org wrote: > > > > > > > > It's not clear how this issue (present 3 years ago) was finally > > > > > > resolved. From the thread, it looks as if the fix might have made its > > > > > > way into ATF, but I'm 87.6% sure ATF is not running on this platform > > > > > > (yet). > > > > > > > > > > The rk3399 SoC has a hardware bug where the power domains are not > > > > > reset upon a soft reset. This leads to situations like this one where > > > > > power domains are shut down during shutdown but aren't restored on > > > > > reboot. > > > > > > > > I assume this isn't something we can patch in the kernel driver? > > > > > > As far as I know it's being worked on by others, I have some ideas for > > > this as well but I've been focused on rk356x lately. > > > > Thanks for the update. > > > > > > > Mainline TF-A was patched to force all power domains online > > > > > when a soft reboot is triggered, which solved that issue. > > > > > > > > Okay, this is what I figured. > > > > > > > > > What particular issues are you having initializing modern u-boot on > > > > > this device? > > > > > > > > This is the output: https://pastebin.ubuntu.com/p/d5DmsSBnrR/ > > > > > > > > Speaking with one of the guys who supports RockPi 4 in AOSP, he > > > > suspects the DDR settings. Apparently settings for older SoCs > > > > sometimes get clobbered when support for newer SoCs is added. > > > > > > The rk3399 TPL code is specific to the rk3399 and it really hasn't > > > been touched much recently. I'm using the latest Mainline U-Boot on > > > both my Rockpro64 and Pinephone-Pro. I don't see TF-A being loaded, > > > which should happen between: > > > > > > Trying to boot from BOOTROM > > > Returning to boot ROM... > > > > > > Otherwise it just looks like the TPL code doesn't like being in a > > > single channel configuration. Does the 2GB model just forgo the second > > > ram chip? Or is this actually a 4GB model and it isn't detecting the > > > second chip in both downstream and mainline? Could you include the > > > TPL/SPL portion of downstream's output? > > > > TPL/SPL are mostly silent on the downstream build: > > > > https://pastebin.ubuntu.com/p/m2bBdjF8Wq/ > > > > Not sure if it helps at all, but ArmBian is pretty noisy: > > > > https://pastebin.ubuntu.com/p/fdPjmmqBDM/ > > Weird that downstream and mainline are being built with none of the > debug stuff enabled. Armbian clearly shows the initial setup occuring > correctly, and that it's a 4GB board. It's using both the Rockchip > miniloader with a Rockchip TF-A blob as well. > > > > > > > I am yet to investigate the u-boot story in any detail. > > > > > > > > It's on my TODO list for today. > > > > > > > > > Is there a particular reason it isn't using Mainline TF-A? > > > > > > > > We're not using Trusted Firmware yet. > > > > > > This platform does not work at all without TF-A. Optee is optional. > > > Either you are using the downstream blob from Rockchip or Mainline > > > built yourself. Personally I prefer using Mainline everything. If you > > > build Mainline U-Boot without TF-A it will throw a warning at the end > > > that says the created binary is non-functional. > > > > Right. Played a lot with this today. > > > > Our build was using TF-A which was built-in to the primary loader. > > > > I had 2 interesting results today. No idea how to explain them. > > > > First one was with Mainline u-boot and Mainline TF-A, which found, but > > was seemingly unable to boot the kernel: > > > > https://pastebin.ubuntu.com/p/9HRhPyfjYK/ > > > > The second interesting result I had was using our downstream u-boot > > with Mainline TF-A. It booted perfectly from cold, but managed to get > > stuck in the TPL on soft reboot in a very similar way to the one I > > reported earlier when not booting with TF-A ("Channel 1: col error"): > > > Mainline TF-A defaults to 115200 for its uart messages, so you need to > either A. pass the uart config from U-Boot to TF-A with a platform > config option (unreliable in my experience), B. change U-Boot to > 115200, or C. change TF-A to 1.5M (the path I take). Your mainline
I see that mainline U-Boot has support already for this device. So I'm building a debug image for you with that.
> On Thu, 19 May 2022, Peter Geis wrote: > > > On Thu, May 19, 2022 at 10:56 AM Lee Jones lee.jones@linaro.org wrote: > > > > > > > > > > It's not clear how this issue (present 3 years ago) was finally > > > > > > > resolved. From the thread, it looks as if the fix might have made its > > > > > > > way into ATF, but I'm 87.6% sure ATF is not running on this platform > > > > > > > (yet). > > > > > > > > > > > > The rk3399 SoC has a hardware bug where the power domains are not > > > > > > reset upon a soft reset. This leads to situations like this one where > > > > > > power domains are shut down during shutdown but aren't restored on > > > > > > reboot. > > > > > > > > > > I assume this isn't something we can patch in the kernel driver? > > > > > > > > As far as I know it's being worked on by others, I have some ideas for > > > > this as well but I've been focused on rk356x lately. > > > > > > Thanks for the update. > > > > > > > > > Mainline TF-A was patched to force all power domains online > > > > > > when a soft reboot is triggered, which solved that issue. > > > > > > > > > > Okay, this is what I figured. > > > > > > > > > > > What particular issues are you having initializing modern u-boot on > > > > > > this device? > > > > > > > > > > This is the output: https://pastebin.ubuntu.com/p/d5DmsSBnrR/ > > > > > > > > > > Speaking with one of the guys who supports RockPi 4 in AOSP, he > > > > > suspects the DDR settings. Apparently settings for older SoCs > > > > > sometimes get clobbered when support for newer SoCs is added. > > > > > > > > The rk3399 TPL code is specific to the rk3399 and it really hasn't > > > > been touched much recently. I'm using the latest Mainline U-Boot on > > > > both my Rockpro64 and Pinephone-Pro. I don't see TF-A being loaded, > > > > which should happen between: > > > > > > > > Trying to boot from BOOTROM > > > > Returning to boot ROM... > > > > > > > > Otherwise it just looks like the TPL code doesn't like being in a > > > > single channel configuration. Does the 2GB model just forgo the second > > > > ram chip? Or is this actually a 4GB model and it isn't detecting the > > > > second chip in both downstream and mainline? Could you include the > > > > TPL/SPL portion of downstream's output? > > > > > > TPL/SPL are mostly silent on the downstream build: > > > > > > https://pastebin.ubuntu.com/p/m2bBdjF8Wq/ > > > > > > Not sure if it helps at all, but ArmBian is pretty noisy: > > > > > > https://pastebin.ubuntu.com/p/fdPjmmqBDM/ > > > > Weird that downstream and mainline are being built with none of the > > debug stuff enabled. Armbian clearly shows the initial setup occuring > > correctly, and that it's a 4GB board. It's using both the Rockchip > > miniloader with a Rockchip TF-A blob as well. > > > > > > > > > > I am yet to investigate the u-boot story in any detail. > > > > > > > > > > It's on my TODO list for today. > > > > > > > > > > > Is there a particular reason it isn't using Mainline TF-A? > > > > > > > > > > We're not using Trusted Firmware yet. > > > > > > > > This platform does not work at all without TF-A. Optee is optional. > > > > Either you are using the downstream blob from Rockchip or Mainline > > > > built yourself. Personally I prefer using Mainline everything. If you > > > > build Mainline U-Boot without TF-A it will throw a warning at the end > > > > that says the created binary is non-functional. > > > > > > Right. Played a lot with this today. > > > > > > Our build was using TF-A which was built-in to the primary loader. > > > > > > I had 2 interesting results today. No idea how to explain them. > > > > > > First one was with Mainline u-boot and Mainline TF-A, which found, but > > > was seemingly unable to boot the kernel: > > > > > > https://pastebin.ubuntu.com/p/9HRhPyfjYK/ > > > > > > The second interesting result I had was using our downstream u-boot > > > with Mainline TF-A. It booted perfectly from cold, but managed to get > > > stuck in the TPL on soft reboot in a very similar way to the one I > > > reported earlier when not booting with TF-A ("Channel 1: col error"): > > > > > > Mainline TF-A defaults to 115200 for its uart messages, so you need to > > either A. pass the uart config from U-Boot to TF-A with a platform > > config option (unreliable in my experience), B. change U-Boot to > > 115200, or C. change TF-A to 1.5M (the path I take). Your mainline > > Hopefully this is enough: > > diff --git a/plat/rockchip/rk3399/rk3399_def.h b/plat/rockchip/rk3399/rk3399_def.h > index ba83242eb..24ad94ae7 100644 > --- a/plat/rockchip/rk3399/rk3399_def.h > +++ b/plat/rockchip/rk3399/rk3399_def.h > @@ -17,7 +17,8 @@ > /************************************************************************** > * UART related constants > **************************************************************************/ > -#define RK3399_BAUDRATE 115200 > +//#define RK3399_BAUDRATE 115200 > +#define RK3399_BAUDRATE 1500000 > #define RK3399_UART_CLOCK 24000000 > > /******************************************************************************
Yes, very interested, thank you.
Yes, that's what I'm using.
Just the default config with BL31 exported.
BL31=<PROJECTS>/rockpi/arm-trusted-firmware/build/rk3399/release/bl31/bl31.elf
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- config {
+&gpio1 {
Thanks, - Kever
participants (5)
Hugh Cole-Baker
Kever Yang
Lee Jones
Peter Geis
Vasily Khoruzhick
