[PATCH] colibri-imx8x: Fix sc_misc_otp_fuse_read() error check
Commit aa6e698a7acd ("imx: toradex/colibri-imx8x: correct SCU API usage") made an incorrect logic change in the error code check of sc_misc_otp_fuse_read():
- if (sc_err == SC_ERR_NONE) { + if (sc_err) { /* DX has two A35 cores disabled */ return (val & 0xf) != 0x0; }
The other changes in this commit are correct.
sc_misc_otp_fuse_read() returns 0 on a successful fuse read.
This inversion causes board_mem_get_layout() to report incorrect RAM size.
Go back the original error check logic to fix the problem.
Fixes: aa6e698a7acd ("imx: toradex/colibri-imx8x: correct SCU API usage") Reported-by: Hiago De Franco hiago.franco@toradex.com Signed-off-by: Fabio Estevam festevam@gmail.com --- board/toradex/colibri-imx8x/colibri-imx8x.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/toradex/colibri-imx8x/colibri-imx8x.c b/board/toradex/colibri-imx8x/colibri-imx8x.c index 2c673a4a6b06..6fc8076163c6 100644 --- a/board/toradex/colibri-imx8x/colibri-imx8x.c +++ b/board/toradex/colibri-imx8x/colibri-imx8x.c @@ -46,7 +46,7 @@ static int is_imx8dx(void) u32 val = 0; int sc_err = sc_misc_otp_fuse_read(-1, 6, &val);
- if (sc_err) { + if (!sc_err) { /* DX has two A35 cores disabled */ return (val & 0xf) != 0x0; }
Subject: [PATCH] colibri-imx8x: Fix sc_misc_otp_fuse_read() error check
Reviewed-by: Peng Fan peng.fan@nxp.com
- if (sc_err) {
- if (!sc_err) { /* DX has two A35 cores disabled */ return (val & 0xf) != 0x0; }
-- 2.34.1
Hi Fabio
Thanks!
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
- if (sc_err) {
- if (!sc_err) {
Cheers
Marcel
On 13.03.2024 08:09, Marcel Ziswiler wrote:
Hi Fabio
Thanks!
Tested-by: Hiago De Franco hiago.franco@toradex.com # Toradex Colibri iMX8X 1GB
- if (sc_err) {
- if (!sc_err) {
Cheers
Marcel
Applied for u-boot-imx/master, thanks.
Fabio Estevam
Hiago De Franco
Marcel Ziswiler
Peng Fan
