[PATCH] rpi: Add identifiers for the new RPi 5 series
The Raspberry Pi foundation have released the Raspberry Pi 500, CM5 an CM5 lite devices so add the assoicated revision identifers so we can detect them.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- board/raspberrypi/rpi/rpi.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 18be244aa79..1e43c631898 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -193,6 +193,21 @@ static const struct rpi_model rpi_models_new_scheme[] = { DTB_DIR "bcm2712-rpi-5-b.dtb", true, }, + [0x18] = { + "Compute Module 5", + DTB_DIR "bcm2712-rpi-cm5-cm5io.dtb", + true, + }, + [0x19] = { + "500", + DTB_DIR "bcm2712-rpi-500.dtb", + true, + }, + [0x1A] = { + "Compute Module 5 Lite", + DTB_DIR "bcm2712-rpi-cm5l-cm5io.dtb", + true, + }, };
static const struct rpi_model rpi_models_old_scheme[] = {
Acked-by: Matthias Brugger mbrugger@suse.com
[0x18] = {
"Compute Module 5",
true,
[0x19] = {
"500",
true,
[0x1A] = {
true,
Hi Peter,
Would it be possible to get the information below from the devicetree on the FAT partition? This is passed to U-Boot at runtime.
Since we already have the DT internally, do we need fdtfile? There are mechanisms for using U-Boot's devicetree when booting.
[0x18] = {
"Compute Module 5",
true,
[0x19] = {
"500",
true,
[0x1A] = {
true,
2.47.1
Matthias Brugger
Peter Robinson
