[U-Boot] [RFC PATCH 11/21] dm: core: Allow uclasses to specific the private data for a device's children
In many cases the per-child private data for a device's children is defined by the uclass rather than the individual driver. For example, a SPI bus needs to store information about each of its children, but all SPI drivers store the same information. It makes sense to allow the uclass to define this data.
If the driver provides a size value for its per-child private data, then use it. Failng that, fall back to that provided by the uclass.
drivers/core/device-remove.c | 4 ++++ drivers/core/device.c | 4 ++++ include/dm/uclass.h | 4 ++++ test/dm/bus.c | 31 +++++++++++++++++++++++++++++-- 4 files changed, 41 insertions(+), 2 deletions(-)
diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index 56c358a..3a5f48d 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -126,6 +126,10 @@ void device_free(struct udevice *dev) } if (dev->parent) { size = dev->parent->driver->per_child_auto_alloc_size; + if (!size) { + size = dev->parent->uclass->uc_drv-> + per_child_auto_alloc_size; + } if (size) { free(dev->parent_priv); dev->parent_priv = NULL; diff --git a/drivers/core/device.c b/drivers/core/device.c index a149a7a..2639fcb 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -201,6 +201,10 @@ int device_probe_child(struct udevice *dev, void *parent_priv) /* Ensure all parents are probed */ if (dev->parent) { size = dev->parent->driver->per_child_auto_alloc_size; + if (!size) { + size = dev->parent->uclass->uc_drv-> + per_child_auto_alloc_size; + } if (size) { dev->parent_priv = calloc(1, size); if (!dev->parent_priv) { diff --git a/include/dm/uclass.h b/include/dm/uclass.h index 9000b22..ac6c850 100644 --- a/include/dm/uclass.h +++ b/include/dm/uclass.h @@ -63,6 +63,9 @@ struct udevice; * @per_device_auto_alloc_size: Each device can hold private data owned * by the uclass. If required this will be automatically allocated if this * value is non-zero. + * @per_child_auto_alloc_size: Each child device (of a parent in this + * uclass) can hold parent data for the device/uclass. This value is only + * used as a falback if this member is 0 in the driver. * @per_child_platdata_auto_alloc_size: A bus likes to store information about * its children. If non-zero this is the size of this data, to be allocated * in the child device's parent_platdata pointer. This value is only used as @@ -82,6 +85,7 @@ struct uclass_driver { int (*destroy)(struct uclass *class); int priv_auto_alloc_size; int per_device_auto_alloc_size; + int per_child_auto_alloc_size; int per_child_platdata_auto_alloc_size; const void *ops; uint32_t flags; diff --git a/test/dm/bus.c b/test/dm/bus.c index 972c449..e909697 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -192,7 +192,7 @@ DM_TEST(dm_test_bus_children_iterators, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
/* Test that the bus can store data about each child */ -static int dm_test_bus_parent_data(struct dm_test_state *dms) +static int test_bus_parent_data(struct dm_test_state *dms) { struct dm_test_parent_data *parent_data; struct udevice *bus, *dev; @@ -251,9 +251,36 @@ static int dm_test_bus_parent_data(struct dm_test_state *dms)
return 0; } - +/* Test that the bus can store data about each child */ +static int dm_test_bus_parent_data(struct dm_test_state *dms) +{ + return test_bus_parent_data(dms); +} DM_TEST(dm_test_bus_parent_data, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
+/* As above but the size is controlled by the uclass */ +static int dm_test_bus_parent_data_uclass(struct dm_test_state *dms) +{ + struct udevice *bus; + int size; + int ret; + + /* Set the driver size to 0 so that the uclass size is used */ + ut_assertok(uclass_find_device(UCLASS_TEST_BUS, 0, &bus)); + size = bus->driver->per_child_auto_alloc_size; + bus->uclass->uc_drv->per_child_auto_alloc_size = size; + bus->driver->per_child_auto_alloc_size = 0; + ret = test_bus_parent_data(dms); + if (ret) + return ret; + bus->uclass->uc_drv->per_child_auto_alloc_size = 0; + bus->driver->per_child_auto_alloc_size = size; + + return 0; +} +DM_TEST(dm_test_bus_parent_data_uclass, + DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + /* Test that the bus ops are called when a child is probed/removed */ static int dm_test_bus_parent_ops(struct dm_test_state *dms) {
