RE: [U-Boot-Users] Fail Safe: Redundant U-boot Images in Flash??? ?
The code at the entry point needs to be small, reliable and never require an upgrade in the field. This code would run a CRC on the primary U-boot image
THe code at the entry point that is small, reliable and never requires an upgrade in the field is U-Boot. Just don't touch it. You don't have to.
...insert bullet, spin cylinder, point at foot, pull trigger...
Hopefully, we will never need to update. But if we do, it'd be nice to be able to reduce the risk of updating as much as possible.
What you typically do (assuming the hardware supports it) is to have two banks of flash memory that can be swapped using some jumper or switch or so.
When it costs a grand just to have a service tech walk in the door, this becomes an unacceptable option.
and never
touch it. You
don't have to.
to have
jumper or
switch or so.
What you guys are trying to do, I've done many times before. You should at least have a bit mask in nonvolatile memory somewhere that tells you the result of your operation. One bit tells the the "miniboot'" loader That this is the first time the image has beeen booted. Another bit is set when the new image comes up telling the miniboot loader that it came up ok. If the new image nerver get's to the point where it can set that bit and the "first time bit" is reset then the miniboot loader won't try and boot that image the second time around. I may have left some details out but basically it works for me...
SF.Net email is sponsored by: Tame your development challenges with Apache's Geronimo App Server. Download it for free - -and be entered to win a 42" plasma tv or your very own Sony(tm)PSP. Click here to play: http://sourceforge.net/geronimo.php _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
__________________________________ Yahoo! Mail - PC Magazine Editors' Choice 2005 http://mail.yahoo.com
Frank
