[U-Boot] [PATCH v3] ARM: tegra: Add Tegra20 SPI device nodes
Add the device tree node for the SPI controllers found on Tegra20 SOCs.
Signed-off-by: Mirza Krak mirza.krak@hostmobility.com ---
Changes in v2: * Dropped tegra30-slink compatible string, based on comment from Thierry Reding on v1 patch
Changes in v3: * Copy/paste spi device nodes from Linux (4.1.6)
Did an attempt of copying tegra20.dtsi from Linux but it broke USB and LCD from what I could see on my Colibri T20, and I dropped that as it was out of scope of my patch.
arch/arm/dts/tegra20.dtsi | 57 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 57 insertions(+)
diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index b8c8a923017e..e68d7be4785f 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -320,6 +320,63 @@ clocks = <&tegra_car 47>, <&tegra_car 124>; };
+ spi@7000d400 { + compatible = "nvidia,tegra20-slink"; + reg = <0x7000d400 0x200>; + interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&tegra_car TEGRA20_CLK_SBC1>; + resets = <&tegra_car 41>; + reset-names = "spi"; + dmas = <&apbdma 15>, <&apbdma 15>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + spi@7000d600 { + compatible = "nvidia,tegra20-slink"; + reg = <0x7000d600 0x200>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&tegra_car TEGRA20_CLK_SBC2>; + resets = <&tegra_car 44>; + reset-names = "spi"; + dmas = <&apbdma 16>, <&apbdma 16>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + spi@7000d800 { + compatible = "nvidia,tegra20-slink"; + reg = <0x7000d800 0x200>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&tegra_car TEGRA20_CLK_SBC3>; + resets = <&tegra_car 46>; + reset-names = "spi"; + dmas = <&apbdma 17>, <&apbdma 17>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + spi@7000da00 { + compatible = "nvidia,tegra20-slink"; + reg = <0x7000da00 0x200>; + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&tegra_car TEGRA20_CLK_SBC4>; + resets = <&tegra_car 68>; + reset-names = "spi"; + dmas = <&apbdma 18>, <&apbdma 18>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + kbc@7000e200 { compatible = "nvidia,tegra20-kbc"; reg = <0x7000e200 0x0078>; -- 2.1.0
Mirza Krak
