[U-Boot] [PATCH v3] Allow AM335x MPU core clock speed to be specified in the board config file
Allow AM335x MPU core clock speed to be specified in the board config file. To use, add the following to the board's config file:-
#define CONFIG_SYS_MPUCLK <desired clock freq in Hz>
Signed-off-by: Mark Jackson mpfj@newflow.co.uk --- Changes in v3: - Changed from V_MPUCLK to CONFIG_SYS_MPUCLK - Added entry in README
Changes in v2: - Tweaked after comments from Peter Korsgaard
README | 4 ++++ arch/arm/include/asm/arch-am33xx/clocks_am33xx.h | 7 +++++-- 2 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/README b/README index d8cb394..ddf6df2 100644 --- a/README +++ b/README @@ -3820,6 +3820,10 @@ Low Level (hardware related) configuration options: If defined, the x86 reset vector code is included. This is not needed when U-Boot is running from Coreboot.
+- CONFIG_SYS_MPUCLK + Defines the MPU clock speed (in Hz). + + NOTE : currently only supported on AM335x platforms.
Freescale QE/FMAN Firmware Support: ----------------------------------- diff --git a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h index d748dd2..5f2939b 100644 --- a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h +++ b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h @@ -21,8 +21,11 @@
#define OSC (V_OSCK/1000000)
-/* MAIN PLL Fdll = 550 MHZ, */ -#define MPUPLL_M 550 +/* MAIN PLL Fdll = 550 MHz, by default */ +#ifndef CONFIG_SYS_MPUCLK +#define CONFIG_SYS_MPUCLK 550000000 +#endif +#define MPUPLL_M (CONFIG_SYS_MPUCLK/1000000) #define MPUPLL_N (OSC-1) #define MPUPLL_M2 1
Dear Mark Jackson,
Why do you claim an accuracy of Hz here, when in the code you silently throw away any sub-MHz parts anyway? Why not leaving it at MHz as it was before, and as used in the code?
On 04/03/13 11:14, Wolfgang Denk wrote:
Dear Mark Jackson,
I was simply copying the format of the existing V_OSCK defines, but I'm happy to change it.
Regards Mark J.
Mark Jackson
