[U-Boot] [PATCH v4 0/3] net: phy: Force master mode for RTL8211C on some boards
This patch is required to get reliable 1000BASE-T operation on some boards using the RTL8211C(L) PHY.
Following discussions on v2 of this patch, I have removed the incorrect check for the RTL8211C(L). Affected boards now have to define CONFIG_RTL8211X_PHY_FORCE_MASTER to benefit from the fix.
Note that this patch requires Karsten Merkers '[PATCH] net: phy: Realtek RTL8211B/C PHY ID fix' as well as Hans de Goede's recent u-boot-sunxi pull request, specifically 1eae8f66ff749409eb96e2f3f3387c56232d0b8a and fc8991c61c393ce6a9d3dfc97cb56dbbd9e8cbba.
Michael
Changes in v4: - Squashed previously separate commit introducing KCONFIG variable into commit containing main code change (Hans de Goede's suggestion) - Changed KCONFIG description according to Karsten Merker's suggestions plus some clarification of my own - Changed commit message according to Karsten Merker's suggestions - Changed commit summary according to Chen-Yu Tsai's suggestion, modified to fit the 70 character limit - Changed commit summary according to Chen-Yu Tsai's suggestion, modified to fit the 70 character limit
Changes in v3: - Remove incorrect detection of RTL8211CL and use #ifdef instead (thanks to Karsten Merker) - Introduced constants for register bits
Changes in v2: - Removed accidental inclusion of Karsten's patch in my first submission of this series. - Fix a typo in the code: 6 -> &
Michael Haas (3): net: phy: Optionally force master mode for RTL PHY sunxi: A20-Olimex-SOM-EVB: Force 8211CL to master sunxi: A20-OLinuXino-Lime2: Force 8211CL to master
configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + drivers/net/Kconfig | 21 +++++++++++++++++++++ drivers/net/phy/realtek.c | 13 ++++++++++++- 4 files changed, 35 insertions(+), 1 deletion(-)
This patch introduces CONFIG_RTL8211X_PHY_FORCE_MASTER. If this define is set, RTL8211x PHYs (except for the RTL8211F) will have their 1000BASE-T master/slave autonegotiation disabled and forced to master mode.
This is helpful for PHYs like the RTL8211C which produce unstable links in slave mode. Such problems have been found on the A20-Olimex-SOM-EVB and A20-OLinuXino-Lime2.
There is no proper way to identify affected PHYs in software as the RTL8211C shares its UID with the RTL8211B. Thus, this fix requires the introduction of an #ifdef.
CC: fradav@gmail.com CC: merker@debian.org CC: hdegoede@redhat.com CC: ijc@hellion.org.uk CC: joe.hershberger@ni.com
Signed-off-by: Michael Haas haas@computerlinguist.org Tested-by: Karsten Merker merker@debian.org
drivers/net/Kconfig | 21 +++++++++++++++++++++ drivers/net/phy/realtek.c | 13 ++++++++++++- 2 files changed, 33 insertions(+), 1 deletion(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 2a229b8..8a95fbd 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -13,6 +13,27 @@ config PHYLIB help Enable Ethernet PHY (physical media interface) support.
+config RTL8211X_PHY_FORCE_MASTER + bool "Ethernet PHY RTL8211x: force 1000BASE-T master mode" + depends on PHYLIB + help + Force master mode for 1000BASE-T on RTl8211x PHYs (except for RTL8211F). + This can work around link stability and data + corruption issues on gigabit links which can occur in slave mode on + certain PHYs, e.g. on the RTL8211C(L). + + Please note that two directly connected devices (i.e. via + crossover cable) will not be able to establish a link between each other + if they both force master mode. Multiple devices forcing + master mode when connected by a network switch do not pose a + problem as the switch configures its affected ports into slave + mode. + This option only affects gigabit links. If you must establish a direct + connection between two devices which both force master mode, try forcing + the link speed to 100MBit/s. + + If unsure, say N. + menuconfig NETDEVICES bool "Network device support" depends on NET diff --git a/drivers/net/phy/realtek.c b/drivers/net/phy/realtek.c index 259a87f..359ec50 100644 --- a/drivers/net/phy/realtek.c +++ b/drivers/net/phy/realtek.c @@ -12,6 +12,10 @@
#define PHY_AUTONEGOTIATE_TIMEOUT 5000
+/* RTL8211x 1000BASE-T Control Register */ +#define MIIM_RTL8211x_CTRL1000T_MSCE (1 << 12); +#define MIIM_RTL8211X_CTRL1000T_MASTER (1 << 11); + /* RTL8211x PHY Status Register */ #define MIIM_RTL8211x_PHY_STATUS 0x11 #define MIIM_RTL8211x_PHYSTAT_SPEED 0xc000 @@ -53,7 +57,14 @@ static int rtl8211x_config(struct phy_device *phydev) */ phy_write(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211x_PHY_INER, MIIM_RTL8211x_PHY_INTR_DIS); - +#ifdef CONFIG_RTL8211X_PHY_FORCE_MASTER + unsigned int reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_CTRL1000); + /* force manual master/slave configuration */ + reg |= MIIM_RTL8211x_CTRL1000T_MSCE; + /* force master mode */ + reg |= MIIM_RTL8211X_CTRL1000T_MASTER; + phy_write(phydev, MDIO_DEVAD_NONE, MII_CTRL1000, reg); +#endif /* read interrupt status just to clear it */ phy_read(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211x_PHY_INER);
Force master mode for 1000BASE-T operation on the A20-Olimex-SOM-EVB.
Karsten Merker reports that this change is necessary to get a reliable link at gigabit speeds.
Signed-off-by: Michael Haas haas@computerlinguist.org ---
Changes in v4: - Changed commit summary according to Chen-Yu Tsai's suggestion, modified to fit the 70 character limit
configs/A20-Olimex-SOM-EVB_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 66d8f98..68de5f2 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -19,3 +19,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_CMD_GPIO=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_RTL8211X_PHY_FORCE_MASTER=y
Force master mode on the A20-OLinuXino-Lime2. This change is required to get a reliable link at gigabit speeds.
configs/A20-OLinuXino-Lime2_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 95c67d6..3bd4fa7 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -16,3 +16,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_CMD_GPIO=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_RTL8211X_PHY_FORCE_MASTER=y
Michael Haas
