Re: [U-Boot] [PATCH 1/1] stm32: Convert serial driver to DM
Hi Kamil,
On 29 November 2015 at 03:38, Kamil Lulko kamil.lulko@gmail.com wrote:
Signed-off-by: Kamil Lulko kamil.lulko@gmail.com
arch/arm/Kconfig | 2 + arch/arm/include/asm/arch-stm32f4/stm32.h | 10 +- board/st/stm32f429-discovery/stm32f429-discovery.c | 13 +- doc/driver-model/serial-howto.txt | 1 - drivers/serial/serial_stm32.c | 201 ++++++++++----------- include/configs/stm32f429-discovery.h | 10 +- include/dm/platform_data/serial_stm32.h | 16 ++ 7 files changed, 135 insertions(+), 118 deletions(-) create mode 100644 include/dm/platform_data/serial_stm32.h
Looks good, a few nits below.
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6542c38..a611ad9 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -674,6 +674,8 @@ config ARCH_UNIPHIER config TARGET_STM32F429_DISCOVERY bool "Support STM32F429 Discovery" select CPU_V7M
select DM
select DM_SERIAL
config ARCH_ROCKCHIP bool "Support Rockchip SoCs" diff --git a/arch/arm/include/asm/arch-stm32f4/stm32.h b/arch/arm/include/asm/arch-stm32f4/stm32.h index 7ca6dc3..6b64d03 100644 --- a/arch/arm/include/asm/arch-stm32f4/stm32.h +++ b/arch/arm/include/asm/arch-stm32f4/stm32.h @@ -3,7 +3,7 @@
- Yuri Tikhonov, Emcraft Systems, yur@emcraft.com
- (C) Copyright 2015
- Kamil Lulko, rev13@wp.pl
- Kamil Lulko, kamil.lulko@gmail.com
@@ -106,6 +106,14 @@ struct stm32_flash_regs { #define STM32_FLASH_CR_SNB_OFFSET 3 #define STM32_FLASH_CR_SNB_MASK (15 << STM32_FLASH_CR_SNB_OFFSET)
- Peripheral base addresses
+#define STM32_USART1_BASE (STM32_APB2PERIPH_BASE + 0x1000) +#define STM32_USART2_BASE (STM32_APB1PERIPH_BASE + 0x4400) +#define STM32_USART3_BASE (STM32_APB1PERIPH_BASE + 0x4800) +#define STM32_USART6_BASE (STM32_APB2PERIPH_BASE + 0x1400)
enum clock { CLOCK_CORE, CLOCK_AHB, diff --git a/board/st/stm32f429-discovery/stm32f429-discovery.c b/board/st/stm32f429-discovery/stm32f429-discovery.c index f418186..8bc2d9e 100644 --- a/board/st/stm32f429-discovery/stm32f429-discovery.c +++ b/board/st/stm32f429-discovery/stm32f429-discovery.c @@ -6,7 +6,7 @@
- Pavel Boldin, Emcraft Systems, paboldin@emcraft.com
@@ -17,6 +17,8 @@ #include <asm/arch/stm32.h> #include <asm/arch/gpio.h> #include <asm/arch/fmc.h> +#include <dm/platdata.h> +#include <dm/platform_data/serial_stm32.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -263,6 +265,15 @@ int dram_init(void) return rv; }
+static const struct stm32_serial_platdata serial_platdata = {
.base = (struct stm32_usart *)STM32_USART1_BASE,
+U_BOOT_DEVICE(stm32_serials) = {
.name = "serial_stm32",
.platdata = &serial_platdata,
u32 get_board_rev(void) { return 0; diff --git a/doc/driver-model/serial-howto.txt b/doc/driver-model/serial-howto.txt index 60483a4..76ad629 100644 --- a/doc/driver-model/serial-howto.txt +++ b/doc/driver-model/serial-howto.txt @@ -18,7 +18,6 @@ is time for maintainers to start converting over the remaining serial drivers: serial_pxa.c serial_s3c24x0.c serial_sa1100.c
- serial_stm32.c serial_xuartlite.c usbtty.c
diff --git a/drivers/serial/serial_stm32.c b/drivers/serial/serial_stm32.c index 8b2830b..df2258e 100644 --- a/drivers/serial/serial_stm32.c +++ b/drivers/serial/serial_stm32.c @@ -1,45 +1,18 @@ /*
#include <common.h> +#include <dm.h> #include <asm/io.h> #include <serial.h> #include <asm/arch/stm32.h> +#include <dm/platform_data/serial_stm32.h>
- Set up the usart port
-#if (CONFIG_STM32_USART >= 1) && (CONFIG_STM32_USART <= 6) -#define USART_PORT (CONFIG_STM32_USART - 1) -#else -#define USART_PORT 0 -#endif -/*
- Set up the usart base address
- --STM32_USARTD_BASE means default setting
-#define STM32_USART1_BASE (STM32_APB2PERIPH_BASE + 0x1000) -#define STM32_USART2_BASE (STM32_APB1PERIPH_BASE + 0x4400) -#define STM32_USART3_BASE (STM32_APB1PERIPH_BASE + 0x4800) -#define STM32_USART6_BASE (STM32_APB2PERIPH_BASE + 0x1400) -#define STM32_USARTD_BASE STM32_USART1_BASE -/*
- RCC USART specific definitions
- --RCC_ENR_USARTDEN means default setting
-#define RCC_ENR_USART1EN (1 << 4) -#define RCC_ENR_USART2EN (1 << 17) -#define RCC_ENR_USART3EN (1 << 18) -#define RCC_ENR_USART6EN (1 << 5) -#define RCC_ENR_USARTDEN RCC_ENR_USART1EN
-struct stm32_serial { +struct stm32_usart { u32 sr; u32 dr; u32 brr; @@ -49,120 +22,136 @@ struct stm32_serial { u32 gtpr; };
-#define USART_CR1_RE (1 << 2) -#define USART_CR1_TE (1 << 3) -#define USART_CR1_UE (1 << 13) +#define USART_CR1_RE (1 << 2) +#define USART_CR1_TE (1 << 3) +#define USART_CR1_UE (1 << 13)
#define USART_SR_FLAG_RXNE (1 << 5) -#define USART_SR_FLAG_TXE (1 << 7) +#define USART_SR_FLAG_TXE (1 << 7)
-#define USART_BRR_F_MASK 0xF +#define USART_BRR_F_MASK 0xF #define USART_BRR_M_SHIFT 4 #define USART_BRR_M_MASK 0xFFF0
-static const unsigned long usart_base[] = {
STM32_USART1_BASE,
STM32_USART2_BASE,
STM32_USART3_BASE,
STM32_USARTD_BASE,
STM32_USARTD_BASE,
STM32_USART6_BASE
-}; +#define MAX_SERIAL_PORTS 4
-static const unsigned long rcc_enr_en[] = {
RCC_ENR_USART1EN,
RCC_ENR_USART2EN,
RCC_ENR_USART3EN,
RCC_ENR_USARTDEN,
RCC_ENR_USARTDEN,
RCC_ENR_USART6EN
+#define RCC_ENR_USART1EN (1 << 4) +#define RCC_ENR_USART2EN (1 << 17) +#define RCC_ENR_USART3EN (1 << 18) +#define RCC_ENR_USART6EN (1 << 5)
+/* Array used to figure out which RCC bit needs to be set */ +static const unsigned long usart_port_rcc_pairs[MAX_SERIAL_PORTS][2] = {
{ STM32_USART1_BASE, RCC_ENR_USART1EN },
{ STM32_USART2_BASE, RCC_ENR_USART2EN },
{ STM32_USART3_BASE, RCC_ENR_USART3EN },
{ STM32_USART6_BASE, RCC_ENR_USART6EN }
-static void stm32_serial_setbrg(void) -{
serial_init();
-static int stm32_serial_init(void) +static int stm32_serial_setbrg(struct udevice *dev, int baudrate) {
struct stm32_serial *usart =
(struct stm32_serial *)usart_base[USART_PORT];
u32 clock, int_div, frac_div, tmp;
struct stm32_serial_platdata *plat = dev->platdata;
struct stm32_usart *const usart = plat->base;
if ((usart_base[USART_PORT] & STM32_BUS_MASK) ==
STM32_APB1PERIPH_BASE) {
setbits_le32(&STM32_RCC->apb1enr, rcc_enr_en[USART_PORT]);
if (((u32)usart & STM32_BUS_MASK) == STM32_APB1PERIPH_BASE) clock = clock_get(CLOCK_APB1);
} else if ((usart_base[USART_PORT] & STM32_BUS_MASK) ==
STM32_APB2PERIPH_BASE) {
setbits_le32(&STM32_RCC->apb2enr, rcc_enr_en[USART_PORT]);
else if (((u32)usart & STM32_BUS_MASK) == STM32_APB2PERIPH_BASE) clock = clock_get(CLOCK_APB2);
} else {
else return -1;
int_div = (25 * clock) / (4 * gd->baudrate);
int_div = (25 * clock) / (4 * baudrate); tmp = ((int_div / 100) << USART_BRR_M_SHIFT) & USART_BRR_M_MASK; frac_div = int_div - (100 * (tmp >> USART_BRR_M_SHIFT)); tmp |= (((frac_div * 16) + 50) / 100) & USART_BRR_F_MASK;
writel(tmp, &usart->brr);
setbits_le32(&usart->cr1, USART_CR1_RE | USART_CR1_TE | USART_CR1_UE); return 0;
-static int stm32_serial_getc(void) +static int stm32_serial_getc(struct udevice *dev) {
while ((readl(&usart->sr) & USART_SR_FLAG_RXNE) == 0)
if ((readl(&usart->sr) & USART_SR_FLAG_RXNE) == 0)
return -EAGAIN;
return readl(&usart->dr);
-static void stm32_serial_putc(const char c) +static int stm32_serial_putc(struct udevice *dev, const char c) {
if (c == '\n')
stm32_serial_putc('\r');
if ((readl(&usart->sr) & USART_SR_FLAG_TXE) == 0)
return -EAGAIN;
while ((readl(&usart->sr) & USART_SR_FLAG_TXE) == 0)
; writel(c, &usart->dr);
-static int stm32_serial_tstc(void) +static int stm32_serial_pending(struct udevice *dev, bool input) {
u8 ret;
ret = readl(&usart->sr) & USART_SR_FLAG_RXNE;
return ret;
if (input)
return readl(&usart->sr) & USART_SR_FLAG_RXNE;
This is supposed to return the number of characters, so you should probably return either 0 or 1 here.
E.g.
return readl(&usart->sr) & USART_SR_FLAG_RXNE ? 1 : 0;
else
return !(readl(&usart->sr) & USART_SR_FLAG_TXE);
-static struct serial_device stm32_serial_drv = {
.name = "stm32_serial",
.start = stm32_serial_init,
.stop = NULL,
You can omit that line
.setbrg = stm32_serial_setbrg,
.putc = stm32_serial_putc,
.puts = default_serial_puts,
.getc = stm32_serial_getc,
.tstc = stm32_serial_tstc,
-void stm32_serial_initialize(void) +static int stm32_serial_probe(struct udevice *dev) {
serial_register(&stm32_serial_drv);
unsigned char usart_port = 0xFF;
Please use int (and perhaps -1) instead of unsigned char. There is no benefit to forcing 8-bits on a 32-bit machine. In fact it may make the generated code worse.
unsigned int i;
for (i = 0; i < MAX_SERIAL_PORTS; i++) {
if ((u32)usart == usart_port_rcc_pairs[i][0]) {
usart_port = i;
break;
-__weak struct serial_device *default_serial_console(void) -{
return &stm32_serial_drv;
if (usart_port == 0xFF)
return -1;
-EINVAL
usart_port_rcc_pairs[usart_port][1]);
Is this some sort of pinmux setting? Shouldn't you add the required setting to the platdata instead of comparing against a physical address?
else
return -1;
-EINVAL
-1 is -EPERM which probably isn't what you want.
+static const struct dm_serial_ops stm32_serial_ops = {
.pending = stm32_serial_pending,
+U_BOOT_DRIVER(serial_stm32) = {
.id = UCLASS_SERIAL,
.ops = &stm32_serial_ops,
.probe = stm32_serial_probe,
.flags = DM_FLAG_PRE_RELOC,
+}; diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 8191fb2..3e80861 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -1,6 +1,6 @@ /*
@@ -51,14 +51,6 @@
#define CONFIG_STM32_GPIO #define CONFIG_STM32_SERIAL -/*
- Configuration of the USART
- 1: TX:PA9 RX:PA10
- 2: TX:PD5 RX:PD6
- 3: TX:PC10 RX:PC11
- 6: TX:PG14 RX:PG9
-#define CONFIG_STM32_USART 1
#define CONFIG_STM32_HSE_HZ 8000000
diff --git a/include/dm/platform_data/serial_stm32.h b/include/dm/platform_data/serial_stm32.h new file mode 100644 index 0000000..d1cfcbe --- /dev/null +++ b/include/dm/platform_data/serial_stm32.h @@ -0,0 +1,16 @@ +/*
+#ifndef __SERIAL_STM32_H +#define __SERIAL_STM32_H
+/* Information about a serial port */ +struct stm32_serial_platdata {
struct stm32_usart *base; /* address of registers in physical memory */
+#endif /* __SERIAL_STM32_H */
2.5.0
Hi Simon,
This is the clock gating. The problem is that depending on which bus the peripheral sits on (e.g. APB1, APB2), different register will be used to enable peripheral's clock. I think figuring out the bus within the driver (at least until there is a proper clk driver) is better than relying on board/dt to provide the correct data. At later stage I plan to move clock gating code out of drivers to clk driver, but even there I think this physical address <-> bus lookup could be used.
Regarding other points, thanks for the review - I will send v2 shortly.
/Kamil
Kamil Lulko
