[PATCH 1/1] efi_selftest: enable CONFIG_CMD_POWEROFF
For automating testing we should be able to power off the test system. The implementation of EFI_RESET_SHUTDOWN requires the do_poweroff() function which is only available if CONFIG_CMD_POWEROFF=y.
Enable CONFIG_CMD_POWEROFF if PSCI reset is available.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/lib/efi_selftest/Kconfig b/lib/efi_selftest/Kconfig index d20f5899af..478140330b 100644 --- a/lib/efi_selftest/Kconfig +++ b/lib/efi_selftest/Kconfig @@ -3,6 +3,7 @@ config CMD_BOOTEFI_SELFTEST depends on CMD_BOOTEFI imply FAT imply FAT_WRITE + imply CMD_POWEROFF if PSCI_RESET || SYSRESET_PSCI help This adds a UEFI test application to U-Boot that can be executed via the 'bootefi selftest' command. It provides extended tests of -- 2.24.1
