[U-Boot] [RFC] mmc:fix: Increase the timeout value for SDHCI_send_command()
I'd like to ask for your opinion about the following problem:
TRATS # saveenv Saving Environment to MMC... Writing to MMC(0)... Controller never released inhibit bit(s). Controller never released inhibit bit(s). Controller never released inhibit bit(s). ... failed
The same is for e.g. ext4.
The provided patch seems to solve the problem, but I DO NOT think that increasing delay is an acceptable solution to any problem.
From a brief checking I can say that it happens when we are doing
consecutive MMC operations (i.e. many reads), and the 10ms timeout might be too short when eMMC firmware is forced to do some internal time consuming operations (e.g. flash blocks management, wear leveling). In this situation, the SDHCI_CMD_INHIBIT bit is set, which means that SDHCI controller didn't received response from eMMC.
One proposition would be to define the per device/per memory chip specific timeouts, to replace those defined at ./drivers/mmc/sdhci.c file.
I also assume, that timeouts cannot be removed, since we must detect if user pulls out a SD card or transmission has been broken.
I'm also wondering if we can tune the sdhci code to improve cooperation with eMMC devices (despite of the fact that this is NOT really needed at u-boot :-) ).
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Andy Fleming afleming@gmail.com --- drivers/mmc/sdhci.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index b9cbe34..0fd1337 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -137,8 +137,8 @@ int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, unsigned int timeout, start_addr = 0; unsigned int retry = 10000;
- /* Wait max 10 ms */ - timeout = 10; + /* Wait max 100 ms */ + timeout = 100;
sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_INT_STATUS); mask = SDHCI_CMD_INHIBIT | SDHCI_DATA_INHIBIT;
Dear Lukasz Majewski,
In message 1357665792-8141-1-git-send-email-l.majewski@samsung.com you wrote:
I cannot comment on the problem - only a bit about the proposed patch ;-)
From a brief checking I can say that it happens when we are doing consecutive MMC operations (i.e. many reads), and the 10ms timeout might be too short when eMMC firmware is forced to do some internal time consuming operations (e.g. flash blocks management, wear leveling). In this situation, the SDHCI_CMD_INHIBIT bit is set, which means that SDHCI controller didn't received response from eMMC.
Is there no way to ask the device and/or controller when it is done, so we can poll for ready state instead of adding delays, which will always have to be tailored for the so far known worst case, i. e. they will be always too long on all almost all systems.
- timeout = 10;
- /* Wait max 100 ms */
- timeout = 100;
We have cases where we struggle for sub-second boot times. Adding 100 ms delay here is clearly prohbitive. [Even the 10 ms are way too long IMHO.] There must be a better way to handle this.
Hi All,
I think this problem is produced when card is running write/erase operation. We used the mmc_send_status() into driver/mmc/mmc.c. When That command is sending, i found the inhibit released log.
I think problem that SDHCI_DATA_INHIBIT is set at every command. if didn't have data and response type is not busy-wait type, SDHCI_DATA_INHIBIT didn't need to set.
How about this? It is more reasonable than increasing timeout value.
@@ -141,7 +143,10 @@ int sdhci_send_command(struct mmc *mmc, struct mmc_cmd *cmd, timeout = 10;
sdhci_writel(host, SDHCI_INT_ALL_MASK, SDHCI_INT_STATUS); - mask = SDHCI_CMD_INHIBIT | SDHCI_DATA_INHIBIT; + mask = SDHCI_CMD_INHIBIT; + + if ((data != NULL) || (cmd->resp_type & MMC_RSP_BUSY)) + mask |= SDHCI_DATA_INHIBIT;
/* We shouldn't wait for data inihibit for stop commands, even though they might use busy signaling */
Best Regards, Jaehoon Chung
- timeout = 10;
- timeout = 100;
Hi Jaehoon,
Hi All,
- mask = SDHCI_CMD_INHIBIT;
- if ((data != NULL) || (cmd->resp_type & MMC_RSP_BUSY))
I will test this and let you know.
- timeout = 10;
- timeout = 100;
Hi Jaehoon,
Hi All,
Ive tested this code and data abort appears when used with ext4.
I think, that we need to look around for another solution.
- timeout = 10;
- timeout = 100;
Hi Wolfgang,
We are doing this already - the SDHCI_PRESENT_STATE register's bit 0 (SDHCI_CMD_INHIBIT) and bit 1 (DATA_INHIBIT) are for this purpose. Those indicate when host controller can send further command/data to the card.
Moreover, there are also timeouts in the case when someone pull out SD card inserted to the slot (or any other use case which I'm not aware).
- timeout = 10;
- timeout = 100;
That's why I'm asking.
It is strange that, when I'm increasing delay it works.
Maybe we will find some areas of optimization?
On Fri, Jan 11, 2013 at 8:49 PM, Lukasz Majewski l.majewski@samsung.com wrote:
Hi Wolfgang,
- timeout = 10;
- timeout = 100;
BTW: I am also finding the similar issue.
But when I enabled CONFIG_MMC_TRACE for log traces, i never see the issue..it's pretty much working fine. As per my latest debug, the issue is fire for CMD6 (SWITCH_FUNC).
May be we need to update the logic on this while loop...
Thanks, Jagan.
-- Best regards,
Lukasz Majewski
Samsung R&D Poland (SRPOL) | Linux Platform Group _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Wolfgang,
- timeout = 10;
- timeout = 100;
It's not important to enable the MMC_TRACE. It should be increased the delay.
Right, i also find the error log for CMD6. Could you test this point?
Thanks, Jagan.
-- Best regards,
Lukasz Majewski
Hi Jaehoon Chung,
Hi Wolfgang,
- timeout = 10;
- timeout = 100;
I found similar issue, no changes...
for masking data, the mask is ORed in CMD51 and CMD6 cases. mask |= SDHCI_DATA_INHIBIT;
But I have tried by putting the delay between the command transfer like..
if (host->quirks & SDHCI_QUIRK_WAIT_SEND_CMD) udelay(1000);
I just enabled the above quirks on my sdhci driver, everything work fine. But again I don't now does this delay really required?, or it may causes any harm?
Thanks, Jagan.
Thanks, Jagan.
-- Best regards,
Lukasz Majewski
Hi Jaehoon,
Hi Wolfgang,
- timeout = 10;
- timeout = 100;
You don't see problem, since CONFIG_MMC_TRACE causes extra delays to write log information to serial console.
I've tested it on trats, but mentioned errors also appear (with lower frequency though).
Yep.
Thanks, Jagan.
-- Best regards,
Lukasz Majewski
Hi Lukasz,
On 01/28/2013 04:02 PM, Lukasz Majewski wrote:
Hi Jaehoon,
Hi Wolfgang,
- timeout = 10;
- timeout = 100;
Right...So i mentioned that CONFIG_MMC_TRACE isn't important.(added delay).
Right..But I think that this patch is correct regardless of this problem. if you agree this, i will send the patch with this.
how about using get_timer()?
Yep.
Thanks, Jagan.
-- Best regards,
Lukasz Majewski
Jaehoon Chung
Jagan Teki
Lukasz Majewski
