[U-Boot] [PATCH] mpc8xxx: improve LAW error messages when setting up DDR
When setting up the LAWs for the DDR, if there was an error, you got the not-so-helpful error text "ERROR" and nothing else. Not only is it non-informative, but it is also pretty frustrating trying to grep for "ERROR" in the source.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- cpu/mpc8xxx/ddr/util.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/cpu/mpc8xxx/ddr/util.c b/cpu/mpc8xxx/ddr/util.c index 4451989..d0f61a8 100644 --- a/cpu/mpc8xxx/ddr/util.c +++ b/cpu/mpc8xxx/ddr/util.c @@ -89,16 +89,16 @@ __fsl_ddr_set_lawbar(const common_timing_params_t *memctl_common_params, ? LAW_TRGT_IF_DDR_INTRLV : LAW_TRGT_IF_DDR_1;
if (set_ddr_laws(base, size, lawbar1_target_id) < 0) { - printf("ERROR\n"); + printf("set_lawbar: ERROR (%d)\n", memctl_interleaved); return ; } } else if (ctrl_num == 1) { if (set_ddr_laws(base, size, LAW_TRGT_IF_DDR_2) < 0) { - printf("ERROR\n"); + printf("set_lawbar: ERROR (ctrl #2)\n"); return ; } } else { - printf("unexpected controller number %u in %s\n", + printf("set_lawbar: unexpected controller number %u in %s\n", ctrl_num, __FUNCTION__); } }
Hi Paul,
printf("ERROR\n");
} } else if (ctrl_num == 1) { if (set_ddr_laws(base, size, LAW_TRGT_IF_DDR_2) < 0) {printf("set_lawbar: ERROR (%d)\n", memctl_interleaved); return ;
printf("ERROR\n");
This error would print out #2 for the 2nd controller...
return ; }
} else {
But this error would print out 2 for the 3rd controller. Either convention is going to be confusing, but it'd be nice if they were at least consistent.
__func__ is preferred over __FUNCTION__, maybe you could update it also?
Wouldn't this message look at bit funny with the title being "set_lawbar:" but then also including the full "__fsl_ddr_set_lawbar" in the same message? And neither of the other errors include the printing of __func__? Hopefully I'll never see the errors, so proceed as you see fit:)
Best, Peter
Peter Tyser wrote:
Hi Paul,
printf("ERROR\n");
printf("ERROR\n");
I was thinking 1 based counting for the messages presented to the end user instead of the internal zero based, but...
return ; }
} else {
...as you point out, it then is inconsistent. I'll fix that.
I never got to see this last one either, just the "ERROR" ones, fortunately (?) but you make a good point - while in there, they might as well all be standardized on func. I'll do that too.
Thanks, Paul.
Best, Peter
v2: sync ctrl #'s; use __func__ as per Peter's comments.
cpu/mpc8xxx/ddr/util.c | 9 +++++---- 1 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/cpu/mpc8xxx/ddr/util.c b/cpu/mpc8xxx/ddr/util.c index 4451989..1e2d921 100644 --- a/cpu/mpc8xxx/ddr/util.c +++ b/cpu/mpc8xxx/ddr/util.c @@ -89,17 +89,18 @@ __fsl_ddr_set_lawbar(const common_timing_params_t *memctl_common_params, ? LAW_TRGT_IF_DDR_INTRLV : LAW_TRGT_IF_DDR_1;
if (set_ddr_laws(base, size, lawbar1_target_id) < 0) { - printf("ERROR\n"); + printf("%s: ERROR (ctrl #0, intrlv=%d)\n", __func__, + memctl_interleaved); return ; } } else if (ctrl_num == 1) { if (set_ddr_laws(base, size, LAW_TRGT_IF_DDR_2) < 0) { - printf("ERROR\n"); + printf("%s: ERROR (ctrl #1)\n", __func__); return ; } } else { - printf("unexpected controller number %u in %s\n", - ctrl_num, __FUNCTION__); + printf("%s: unexpected DDR controller number (%u)\n", __func__, + ctrl_num); } }
applied to 85xx
-k
Kumar Gala
Paul Gortmaker
Peter Tyser
