[U-Boot-Users] [PATCH] bf537-stamp: remove already defined is_zero_ether_addr and is_multicast_ether_addr
and move is_valid_ether_addr board file
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
diff --git a/board/bf537-stamp/bf537-stamp.c b/board/bf537-stamp/bf537-stamp.c index b3d8bda..6954b30 100644 --- a/board/bf537-stamp/bf537-stamp.c +++ b/board/bf537-stamp/bf537-stamp.c @@ -30,8 +30,25 @@ #include <command.h> #include <asm/blackfin.h> #include <asm/io.h> +#include <net.h> #include "ether_bf537.h"
+/** + * is_valid_ether_addr - Determine if the given Ethernet address is valid + * @addr: Pointer to a six-byte array containing the Ethernet address + * + * Check that the Ethernet address (MAC) is not 00:00:00:00:00:00, is not + * a multicast address, and is not FF:FF:FF:FF:FF:FF. + * + * Return true if the address is valid. + */ +static inline int is_valid_ether_addr(const u8 * addr) +{ + /* FF:FF:FF:FF:FF:FF is a multicast address so we don't need to + * explicitly check for it here. */ + return !is_multicast_ether_addr(addr) && !is_zero_ether_addr(addr); +} + DECLARE_GLOBAL_DATA_PTR;
#define POST_WORD_ADDR 0xFF903FFC diff --git a/board/bf537-stamp/ether_bf537.h b/board/bf537-stamp/ether_bf537.h index 64240ba..22fc392 100644 --- a/board/bf537-stamp/ether_bf537.h +++ b/board/bf537-stamp/ether_bf537.h @@ -69,42 +69,3 @@ void SoftResetPHY(void); void DumpPHYRegs(void);
int SetupSystemRegs(int *opmode); - -/** - * is_zero_ether_addr - Determine if give Ethernet address is all zeros. - * @addr: Pointer to a six-byte array containing the Ethernet address - * - * Return true if the address is all zeroes. - */ -static inline int is_zero_ether_addr(const u8 * addr) -{ - return !(addr[0] | addr[1] | addr[2] | addr[3] | addr[4] | addr[5]); -} - -/** - * is_multicast_ether_addr - Determine if the Ethernet address is a multicast. - * @addr: Pointer to a six-byte array containing the Ethernet address - * - * Return true if the address is a multicast address. - * By definition the broadcast address is also a multicast address. - */ -static inline int is_multicast_ether_addr(const u8 * addr) -{ - return (0x01 & addr[0]); -} - -/** - * is_valid_ether_addr - Determine if the given Ethernet address is valid - * @addr: Pointer to a six-byte array containing the Ethernet address - * - * Check that the Ethernet address (MAC) is not 00:00:00:00:00:00, is not - * a multicast address, and is not FF:FF:FF:FF:FF:FF. - * - * Return true if the address is valid. - */ -static inline int is_valid_ether_addr(const u8 * addr) -{ - /* FF:FF:FF:FF:FF:FF is a multicast address so we don't need to - * explicitly check for it here. */ - return !is_multicast_ether_addr(addr) && !is_zero_ether_addr(addr); -}
