[U-Boot] [PATCH] sunxi: use CONFIG_DEFAULT_FDT_FILE everywhere
Currently, sunxi-common.h ignores CONFIG_DEFAULT_FDT_FILE and assumes the kernel fdtfile and the u-boot devicetree names are the same. Although this is typically the case, sometimes you might want to customize one of these differently, so it's useful to allow them to be different.
Fix this to use only CONFIG_DEFAULT_FDT_FILE as other boards do, and set CONFIG_DEFAULT_FDT_FILE in board files to be the same as the current fdtfile= setting.
Signed-off-by: Martin Kelly mkelly@xevo.com --- This patch is against u-boot master and thus conflicts with u-boot sunxi patch 31510b41f6b736fd03e2779a2585f85df39e667f ("sunxi: allow CONFIG_DEFAULT_FDT_FILE override"). If you would like me to apply this against the sunxi tree instead, I would be happy to do so and resend it.
Obviously, I cannot test a change like this on every board. Here's the tests I did:
- Booted on the nanopi neo plus2 (the board I do have). - Compile-tested every affected config. - To avoid missing anything I generated the config changes with the following Python script. This script mimics what the preprocessor was doing, but encodes it explicitly in the config. Reviewing the script is probably easier than reviewing each individual file:
#!/usr/bin/python3
import os
root = '/home/martin/u-boot/configs' for name in os.listdir(root): path = os.path.join(root, name) with open(path, 'r') as f: contents = f.read() if 'CONFIG_ARCH_SUNXI=y' not in contents: continue if 'CONFIG_DEFAULT_FDT_FILE=' in contents: # Make the script idempotent. continue
if 'CONFIG_MACH_SUN50I=y' in contents or 'CONFIG_MACH_SUN50I_H5=y' in contents: arm64 = True else: arm64 = False
lines = [] for line in contents.split('\n'): if line.startswith('CONFIG_DEFAULT_DEVICE_TREE='): split = line.split('=') assert(len(split) == 2) dtb = split[1]
if dtb[0] == '"' and dtb[-1] == '"': # Dequotify. dtb = dtb[1:-1]
dtb = '%s.dtb' % dtb if arm64: dtb = 'allwinner/%s' % dtb
lines.append('CONFIG_DEFAULT_FDT_FILE="%s"' % dtb) lines.append(line)
with open(path, 'w') as f: f.write('\n'.join(lines))
[end script]
configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/A20-Olimex-SOM204-EVB_defconfig | 1 + configs/A33-OLinuXino_defconfig | 1 + configs/Ainol_AW1_defconfig | 1 + configs/Ampe_A76_defconfig | 1 + configs/Auxtek-T003_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/Bananapi_M2_Ultra_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapi_m2m_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/CHIP_defconfig | 1 + configs/CHIP_pro_defconfig | 1 + configs/CSQ_CS908_defconfig | 1 + configs/Chuwi_V7_CW0825_defconfig | 1 + configs/Colombus_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard4_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Cubietruck_plus_defconfig | 1 + configs/Empire_electronix_d709_defconfig | 1 + configs/Empire_electronix_m712_defconfig | 1 + configs/Hummingbird_A31_defconfig | 1 + configs/Hyundai_A7HD_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Lamobo_R1_defconfig | 1 + configs/LicheePi_Zero_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Linksprite_pcDuino_defconfig | 1 + configs/MK808C_defconfig | 1 + configs/MSI_Primo73_defconfig | 1 + configs/MSI_Primo81_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000G_quad_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_I7_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Mele_M9_defconfig | 1 + configs/Merrii_A80_Optimus_defconfig | 1 + configs/Mini-X_defconfig | 1 + configs/Nintendo_NES_Classic_Edition_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/Sinlinx_SinA31s_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Sinovoip_BPI_M2_Plus_defconfig | 1 + configs/Sinovoip_BPI_M2_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 1 + configs/Sunchip_CX-A99_defconfig | 1 + configs/UTOO_P66_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 1 + configs/Wobo_i5_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/Yones_Toptech_BS1078_V2_defconfig | 1 + configs/a64-olinuxino_defconfig | 1 + configs/ba10_tv_box_defconfig | 1 + configs/bananapi_m1_plus_defconfig | 1 + configs/bananapi_m2_berry_defconfig | 1 + configs/bananapi_m64_defconfig | 1 + configs/colorfly_e708_q1_defconfig | 1 + configs/difrnce_dit4350_defconfig | 1 + configs/dserve_dsrv9703c_defconfig | 1 + configs/ga10h_v1_1_defconfig | 1 + configs/gt90h_v4_defconfig | 1 + configs/h8_homlet_v2_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/iNet_3F_defconfig | 1 + configs/iNet_3W_defconfig | 1 + configs/iNet_86VS_defconfig | 1 + configs/iNet_D978_rev2_defconfig | 1 + configs/icnova-a20-swac_defconfig | 1 + configs/inet1_defconfig | 1 + configs/inet86dz_defconfig | 1 + configs/inet97fv2_defconfig | 1 + configs/inet98v_rev2_defconfig | 1 + configs/inet9f_rev03_defconfig | 1 + configs/inet_q972_defconfig | 1 + configs/jesurun_q5_defconfig | 1 + configs/libretech_all_h3_cc_h2_plus_defconfig | 1 + configs/libretech_all_h3_cc_h3_defconfig | 1 + configs/libretech_all_h3_cc_h5_defconfig | 1 + configs/mixtile_loftq_defconfig | 1 + configs/mk802_a10s_defconfig | 1 + configs/mk802_defconfig | 1 + configs/mk802ii_defconfig | 1 + configs/nanopi_a64_defconfig | 1 + configs/nanopi_m1_defconfig | 1 + configs/nanopi_m1_plus_defconfig | 1 + configs/nanopi_neo2_defconfig | 1 + configs/nanopi_neo_air_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/nanopi_neo_plus2_defconfig | 1 + configs/orangepi_2_defconfig | 1 + configs/orangepi_lite_defconfig | 1 + configs/orangepi_one_defconfig | 1 + configs/orangepi_pc2_defconfig | 1 + configs/orangepi_pc_defconfig | 1 + configs/orangepi_pc_plus_defconfig | 1 + configs/orangepi_plus2e_defconfig | 1 + configs/orangepi_plus_defconfig | 1 + configs/orangepi_prime_defconfig | 1 + configs/orangepi_win_defconfig | 1 + configs/orangepi_zero_defconfig | 1 + configs/orangepi_zero_plus2_defconfig | 1 + configs/parrot_r16_defconfig | 1 + configs/pine64_plus_defconfig | 1 + configs/polaroid_mid2407pxe03_defconfig | 1 + configs/polaroid_mid2809pxe04_defconfig | 1 + configs/pov_protab2_ips9_defconfig | 1 + configs/q8_a13_tablet_defconfig | 1 + configs/q8_a23_tablet_800x480_defconfig | 1 + configs/q8_a33_tablet_1024x600_defconfig | 1 + configs/q8_a33_tablet_800x480_defconfig | 1 + configs/r7-tv-dongle_defconfig | 1 + configs/sopine_baseboard_defconfig | 1 + configs/sun8i_a23_evb_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 1 + configs/tbs_a711_defconfig | 1 + include/configs/sunxi-common.h | 8 +------- 133 files changed, 133 insertions(+), 7 deletions(-)
diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index feb1173c0b..83c7813999 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_CLK_FREQ=912000000 CONFIG_MMC0_CD_PIN="PH1" CONFIG_I2C1_ENABLE=y CONFIG_SATAPWR="PC3" +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-olinuxino-lime.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 9498a6d752..6ec7641f29 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PG1" CONFIG_MMC1_CD_PIN="PG13" CONFIG_MMC_SUNXI_SLOT_EXTRA=1 CONFIG_USB1_VBUS_PIN="PB10" +CONFIG_DEFAULT_FDT_FILE="sun5i-a10s-olinuxino-micro.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index ed507cdf0b..654a2ad59e 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_VIA_LCD_FORCE_SYNC_ACTIVE_HIGH=y CONFIG_VIDEO_LCD_POWER="PB10" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-olinuxino-micro.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 8e160d7cc4..d9b0b99aca 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_VIA_LCD_FORCE_SYNC_ACTIVE_HIGH=y CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-olinuxino.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 9d043e856a..6b5ccfb888 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -9,6 +9,7 @@ CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y CONFIG_SATAPWR="PC3" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-olinuxino-lime2-emmc.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2-emmc" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index f2997c6fe5..15c085bd32 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -8,6 +8,7 @@ CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y CONFIG_SATAPWR="PC3" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-olinuxino-lime2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index b7c13a6932..a4efb7642b 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_I2C1_ENABLE=y CONFIG_SATAPWR="PC3" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-olinuxino-lime.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A20-OLinuXino_MICRO-eMMC_defconfig b/configs/A20-OLinuXino_MICRO-eMMC_defconfig index f7e7cbab0a..f0ff837718 100644 --- a/configs/A20-OLinuXino_MICRO-eMMC_defconfig +++ b/configs/A20-OLinuXino_MICRO-eMMC_defconfig @@ -8,6 +8,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_I2C1_ENABLE=y CONFIG_VIDEO_VGA=y CONFIG_SATAPWR="PB8" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-olinuxino-micro.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 8dcbdc08f9..a5881577fa 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -9,6 +9,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_I2C1_ENABLE=y CONFIG_VIDEO_VGA=y CONFIG_SATAPWR="PB8" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-olinuxino-micro.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index a06499e2d0..589a59f981 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -10,6 +10,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_SATAPWR="PC3" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-olimex-som-evb.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig index 847945b649..110b4f1838 100644 --- a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig +++ b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig @@ -10,6 +10,7 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y CONFIG_SATAPWR="PC3" CONFIG_GMAC_TX_DELAY=4 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-olimex-som204-evb-emmc.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som204-evb-emmc" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A20-Olimex-SOM204-EVB_defconfig b/configs/A20-Olimex-SOM204-EVB_defconfig index e56f2c7110..5b00887d1a 100644 --- a/configs/A20-Olimex-SOM204-EVB_defconfig +++ b/configs/A20-Olimex-SOM204-EVB_defconfig @@ -9,6 +9,7 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y CONFIG_SATAPWR="PC3" CONFIG_GMAC_TX_DELAY=4 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-olimex-som204-evb.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som204-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A33-OLinuXino_defconfig b/configs/A33-OLinuXino_defconfig index 744e7ef511..1a55292370 100644 --- a/configs/A33-OLinuXino_defconfig +++ b/configs/A33-OLinuXino_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:16,ri:209,up:22,lo CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_BL_EN="PB2" CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_FDT_FILE="sun8i-a33-olinuxino.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index 3e47ca2466..70b4ee180a 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:40000,le:87,ri:112,up:38,lo CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-ainol-aw1.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-ainol-aw1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index b0d6047789..97f3b55105 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:45,ri:82,up:22,lo: CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-ampe-a76.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index ce4806cf5e..3b07eb8dc0 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=408 CONFIG_DRAM_EMR1=0 CONFIG_USB1_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_FDT_FILE="sun5i-a10s-auxtek-t003.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t003" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 5faf45c3d7..e957d90b48 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="PG13" +CONFIG_DEFAULT_FDT_FILE="sun5i-a10s-auxtek-t004.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t004" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Bananapi_M2_Ultra_defconfig b/configs/Bananapi_M2_Ultra_defconfig index 37cc2df5dc..d5098cb436 100644 --- a/configs/Bananapi_M2_Ultra_defconfig +++ b/configs/Bananapi_M2_Ultra_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="PH13" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_FDT_FILE="sun8i-r40-bananapi-m2-ultra.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-r40-bananapi-m2-ultra" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 7a9b5fe0e5..5703ef18b0 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=432 CONFIG_MACPWR="PH23" CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-bananapi.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Bananapi_m2m_defconfig b/configs/Bananapi_m2m_defconfig index 2032a4aef8..5b97fa12f3 100644 --- a/configs/Bananapi_m2m_defconfig +++ b/configs/Bananapi_m2m_defconfig @@ -8,6 +8,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="PB4" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB0_ID_DET="PH8" +CONFIG_DEFAULT_FDT_FILE="sun8i-r16-bananapi-m2m.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-bananapi-m2m" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 5a8ded0493..0cad1583dc 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -8,6 +8,7 @@ CONFIG_USB1_VBUS_PIN="PH0" CONFIG_USB2_VBUS_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-bananapro.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index c122944881..6e46310d7a 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN5I=y CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y CONFIG_USB0_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_FDT_FILE="sun5i-r8-chip.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" CONFIG_SPL_I2C_SUPPORT=y CONFIG_CMD_DFU=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 5d63fadef5..d6692588db 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y CONFIG_USB0_VBUS_PIN="PB10" +CONFIG_DEFAULT_FDT_FILE="sun5i-gr8-chip-pro.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-gr8-chip-pro" CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index b103e7e00d..3c50d8e17b 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_DEFAULT_FDT_FILE="sun6i-a31s-cs908.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 645a759fc2..68fb6e2be0 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_HITACHI_TX18D42VM=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-chuwi-v7-cw0825.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-chuwi-v7-cw0825" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index c85e47cb11..dc8de80807 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_I2C_SDA="PA23" CONFIG_VIDEO_LCD_PANEL_I2C_SCL="PA24" CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y +CONFIG_DEFAULT_FDT_FILE="sun6i-a31-colombus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index 418da63ba8..8d0dbf39b8 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" CONFIG_SATAPWR="PB8" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-cubieboard2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Cubieboard4_defconfig b/configs/Cubieboard4_defconfig index 16b1862334..fce80a8a11 100644 --- a/configs/Cubieboard4_defconfig +++ b/configs/Cubieboard4_defconfig @@ -11,6 +11,7 @@ CONFIG_USB0_ID_DET="PH16" CONFIG_USB1_VBUS_PIN="PH14" CONFIG_USB3_VBUS_PIN="PH15" CONFIG_AXP_GPIO=y +CONFIG_DEFAULT_FDT_FILE="sun9i-a80-cubieboard4.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-cubieboard4" # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 27223d201e..2de3b22539 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" CONFIG_SATAPWR="PB8" +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-cubieboard.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index f0bb4c9d5c..9ac131296f 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -10,6 +10,7 @@ CONFIG_USB0_ID_DET="PH19" CONFIG_VIDEO_VGA=y CONFIG_SATAPWR="PH12" CONFIG_GMAC_TX_DELAY=1 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-cubietruck.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index d76bc6748b..7c0d8f12ea 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -13,6 +13,7 @@ CONFIG_USB1_VBUS_PIN="PD29" CONFIG_USB2_VBUS_PIN="PL6" CONFIG_I2C0_ENABLE=y CONFIG_AXP_GPIO=y +CONFIG_DEFAULT_FDT_FILE="sun8i-a83t-cubietruck-plus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-cubietruck-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index bac5859130..df45dda8ff 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:45,ri:210,up:22,lo CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-empire-electronix-d709.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-d709" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index 47f3fe7e2e..737a41f5f9 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:45,ri:82,up:22,lo: CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-empire-electronix-m712.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-m712" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 24126fde28..afc4cf5555 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -7,6 +7,7 @@ CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" +CONFIG_DEFAULT_FDT_FILE="sun6i-a31-hummingbird.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index 72327c90fc..63b4b51906 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH9" CONFIG_VIDEO_LCD_BL_PWM="PB2" # CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW is not set CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-hyundai-a7hd.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-hyundai-a7hd" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index dfef071476..39901ddffc 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" CONFIG_SATAPWR="PB8" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-itead-ibox.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 9ed1f02d52..dd6409bfd0 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -7,6 +7,7 @@ CONFIG_MACPWR="PH23" CONFIG_MMC0_CD_PIN="PH10" CONFIG_SATAPWR="PB3" CONFIG_GMAC_TX_DELAY=4 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-lamobo-r1.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/LicheePi_Zero_defconfig b/configs/LicheePi_Zero_defconfig index 6cf0940776..44b30e19f2 100644 --- a/configs/LicheePi_Zero_defconfig +++ b/configs/LicheePi_Zero_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_V3S=y CONFIG_DRAM_CLK=360 CONFIG_DRAM_ZQ=14779 +CONFIG_DEFAULT_FDT_FILE="sun8i-v3s-licheepi-zero.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-v3s-licheepi-zero" # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 2df6761455..7958117e13 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=122 CONFIG_USB1_VBUS_PIN="PH11" CONFIG_SATAPWR="PH2" CONFIG_GMAC_TX_DELAY=3 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-pcduino3-nano.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index d7e9c26cbf..385d8a28cc 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=122 CONFIG_SATAPWR="PH2" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-pcduino3.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 500f885599..a3269f03f1 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-pcduino.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index 62768b8656..e0e5a0beae 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-mk808c.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-mk808c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index 309b384a4e..faef2a6885 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -8,6 +8,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-primo73.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-primo73" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 04b0b63259..8d4c5d1ced 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_LCD_MODE="x:768,y:1024,depth:18,pclk_khz:66000,le:56,ri:60,up:30,lo CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828=y +CONFIG_DEFAULT_FDT_FILE="sun6i-a31s-primo81.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-primo81" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 55c27b8435..9e109b8723 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_SPL=y CONFIG_MACH_SUN4I=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-marsboard.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index e084454293..f696eed503 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_ZQ=120 CONFIG_INITIAL_USB_SCAN_DELAY=2000 CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" +CONFIG_DEFAULT_FDT_FILE="sun6i-a31-mele-a1000g-quad.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 367f2aaf7a..f25d791f2c 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN4I=y CONFIG_MACPWR="PH15" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-a1000.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 4fa61d311f..fc81bd4ca5 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=120 CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" +CONFIG_DEFAULT_FDT_FILE="sun6i-a31-i7.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 9f48bd91e0..e06fd05f15 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-m3.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 6b198be6f6..123fdc9a85 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=122 CONFIG_MMC0_CD_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-m5.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index af89c50ee1..eb44ab3509 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=120 CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" +CONFIG_DEFAULT_FDT_FILE="sun6i-a31-m9.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index 329362d336..8a4dfccedf 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -11,6 +11,7 @@ CONFIG_USB0_ID_DET="PH3" CONFIG_USB1_VBUS_PIN="PH4" CONFIG_USB3_VBUS_PIN="PH5" CONFIG_AXP_GPIO=y +CONFIG_DEFAULT_FDT_FILE="sun9i-a80-optimus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-optimus" # CONFIG_CMD_FLASH is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index e32935e132..37580609ba 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-mini-xplus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mini-xplus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index 990bb25c41..4d2cb43a3b 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=15291 CONFIG_DRAM_ODT_EN=y CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_AXP_GPIO=y +CONFIG_DEFAULT_FDT_FILE="sun8i-r16-nintendo-nes-classic-edition.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-nintendo-nes-classic-edition" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 88e55495d5..fe650c2ff5 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -9,6 +9,7 @@ CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-orangepi.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 46f27be254..38745dfc1c 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -11,6 +11,7 @@ CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-orangepi-mini.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 9744aef096..88cc35d8c6 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -9,6 +9,7 @@ CONFIG_MMC3_PINS="PC" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_DEFAULT_FDT_FILE="sun6i-a31s-sina31s.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 9e6267200b..14ae36a60b 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:66000,le:90,ri:160,up:3,lo CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_FDT_FILE="sun8i-a33-sinlinx-sina33.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-sinlinx-sina33" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CMD_DFU=y diff --git a/configs/Sinovoip_BPI_M2_Plus_defconfig b/configs/Sinovoip_BPI_M2_Plus_defconfig index da5620a770..73c4b7a6c4 100644 --- a/configs/Sinovoip_BPI_M2_Plus_defconfig +++ b/configs/Sinovoip_BPI_M2_Plus_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-bananapi-m2-plus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-bananapi-m2-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 65d81a5284..de4c00b5fc 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_DEFAULT_FDT_FILE="sun6i-a31s-sinovoip-bpi-m2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index 479dd05dfb..8ed6463b4f 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -14,6 +14,7 @@ CONFIG_USB0_ID_DET="PH11" CONFIG_USB1_VBUS_PIN="PD24" CONFIG_AXP_GPIO=y CONFIG_SATAPWR="PD25" +CONFIG_DEFAULT_FDT_FILE="sun8i-a83t-bananapi-m3.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-bananapi-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y diff --git a/configs/Sunchip_CX-A99_defconfig b/configs/Sunchip_CX-A99_defconfig index 008af068d4..ef5a845e68 100644 --- a/configs/Sunchip_CX-A99_defconfig +++ b/configs/Sunchip_CX-A99_defconfig @@ -10,6 +10,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB0_VBUS_PIN="PH15" CONFIG_USB1_VBUS_PIN="PL7" CONFIG_USB3_VBUS_PIN="PL8" +CONFIG_DEFAULT_FDT_FILE="sun9i-a80-cx-a99.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-cx-a99" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index a666e419db..d2c2ce6c88 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -18,6 +18,7 @@ CONFIG_VIDEO_LCD_RESET="PG11" CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_TL059WV5C0=y +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-utoo-p66.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-utoo-p66" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index 9a431ee4cd..0542f7530d 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:210,up:22,lo CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-wexler-tab7200.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wexler-tab7200" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 8065ca2629..baeba63caf 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -9,6 +9,7 @@ CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-wits-pro-a20-dkt.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index 88ccfd406e..4ab93ad6dd 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PB3" CONFIG_USB1_VBUS_PIN="PG12" +CONFIG_DEFAULT_FDT_FILE="sun5i-a10s-wobo-i5.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-wobo-i5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index c49cbcbc3c..146c936962 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -17,6 +17,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" # CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW is not set CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-yones-toptech-bd1078.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-yones-toptech-bd1078" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index 87c13b0ea8..34e11c3bee 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun6i-a31s-yones-toptech-bs1078-v2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-yones-toptech-bs1078-v2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/a64-olinuxino_defconfig b/configs/a64-olinuxino_defconfig index b32df990a0..32448a226b 100644 --- a/configs/a64-olinuxino_defconfig +++ b/configs/a64-olinuxino_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN50I=y CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-a64-olinuxino.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index 88199c8e78..f48f2c35f9 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_EMR1=4 CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB2_VBUS_PIN="PH12" CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-ba10-tvbox.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-ba10-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/bananapi_m1_plus_defconfig b/configs/bananapi_m1_plus_defconfig index 539ed73495..ba25bb1bb7 100644 --- a/configs/bananapi_m1_plus_defconfig +++ b/configs/bananapi_m1_plus_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=432 CONFIG_MACPWR="PH23" CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-bananapi-m1-plus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi-m1-plus" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/bananapi_m2_berry_defconfig b/configs/bananapi_m2_berry_defconfig index 9d75108d04..2bc9a4b022 100644 --- a/configs/bananapi_m2_berry_defconfig +++ b/configs/bananapi_m2_berry_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=576 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="PH13" +CONFIG_DEFAULT_FDT_FILE="sun8i-v40-bananapi-m2-berry.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-v40-bananapi-m2-berry" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/bananapi_m64_defconfig b/configs/bananapi_m64_defconfig index 47f31c6d9d..3ab3866650 100644 --- a/configs/bananapi_m64_defconfig +++ b/configs/bananapi_m64_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN50I=y CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_MMC0_CD_PIN="PH13" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-a64-bananapi-m64.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-bananapi-m64" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index e9c82674a2..c2ebe1561d 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun6i-a31s-colorfly-e708-q1.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-colorfly-e708-q1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index a7cdf0fbf7..4764d52036 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_MODE="x:480,y:272,depth:18,pclk_khz:12000,le:1,ri:43,up:1,lo:12 CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-difrnce-dit4350.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-difrnce-dit4350" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index 8f469fbc34..1fd5e847ce 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-dserve-dsrv9703c.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-dserve-dsrv9703c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 02cc9677aa..dd1c803379 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun8i-a33-ga10h-v1.1.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index caff63eb59..419f0d3437 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_FDT_FILE="sun8i-a23-gt90h-v4.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-gt90h-v4" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index 80bdb20e8a..2b4434dd26 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -8,6 +8,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_USB0_VBUS_PIN="PL5" CONFIG_USB1_VBUS_PIN="PL6" CONFIG_AXP_GPIO=y +CONFIG_DEFAULT_FDT_FILE="sun8i-a83t-allwinner-h8homlet-v2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-allwinner-h8homlet-v2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index a3c4b0e76c..eb369ea003 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MACPWR="PH21" CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-i12-tvbox.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index b1d6ed11f1..cabc5c9335 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-inet-3f.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3f" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index bfd8f002e1..871bc16b1e 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:24,pclk_khz:65000,le:159,ri:160,up:22, CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-inet-3w.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3w" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index b370eacc05..8c3a50d610 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:45,ri:209,up:22,lo CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-inet-86vs.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-86vs" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index 29f807ab97..e3f71726be 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun8i-a33-inet-d978-rev2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-inet-d978-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 8fca6e81ed..02efaf208b 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -11,6 +11,7 @@ CONFIG_USB1_VBUS_PIN="PG10" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH22" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun7i-a20-icnova-swac.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 100d075960..c0f464fab9 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-inet1.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index 9d6e340f08..bb8b34103f 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_FDT_FILE="sun8i-a23-inet86dz.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-inet86dz" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index 4caf3075cd..43b7cdd0fd 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-inet97fv2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet97fv2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index 1eea0c66a5..8523919a85 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:45,ri:209,up:22,lo CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-inet-98v-rev2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index 46fa4ee775..017467d4d0 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-inet9f-rev03.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet9f-rev03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig index b928622813..752378dc3f 100644 --- a/configs/inet_q972_defconfig +++ b/configs/inet_q972_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:18,pclk_khz:65000,le:280,ri:20,up:22,l CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" +CONFIG_DEFAULT_FDT_FILE="sun6i-a31s-inet-q972.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-inet-q972" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 00bb745be2..0b93d60f34 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=312 CONFIG_MACPWR="PH19" CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-jesurun-q5.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/libretech_all_h3_cc_h2_plus_defconfig b/configs/libretech_all_h3_cc_h2_plus_defconfig index 0cbcd48aad..3e3963ba46 100644 --- a/configs/libretech_all_h3_cc_h2_plus_defconfig +++ b/configs/libretech_all_h3_cc_h2_plus_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_DEFAULT_FDT_FILE="sun8i-h2-plus-libretech-all-h3-cc.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-libretech-all-h3-cc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/libretech_all_h3_cc_h3_defconfig b/configs/libretech_all_h3_cc_h3_defconfig index 185facdf3e..ea7e0e0712 100644 --- a/configs/libretech_all_h3_cc_h3_defconfig +++ b/configs/libretech_all_h3_cc_h3_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-libretech-all-h3-cc.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-libretech-all-h3-cc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/libretech_all_h3_cc_h5_defconfig b/configs/libretech_all_h3_cc_h5_defconfig index 061bddc8fd..abf9b3831a 100644 --- a/configs/libretech_all_h3_cc_h5_defconfig +++ b/configs/libretech_all_h3_cc_h5_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN50I_H5=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-h5-libretech-all-h3-cc.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-libretech-all-h3-cc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 79d984ba7b..df9a4a0db4 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -7,6 +7,7 @@ CONFIG_MACPWR="PA21" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" +CONFIG_DEFAULT_FDT_FILE="sun6i-a31-mixtile-loftq.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index 5129b49506..1002877ec5 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_EMR1=0 CONFIG_USB1_VBUS_PIN="PB10" +CONFIG_DEFAULT_FDT_FILE="sun5i-a10s-mk802.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 81d121fb84..e0991cda99 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_USB2_VBUS_PIN="PH12" +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-mk802.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index 84ae234fdc..ed8c6a0609 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_SPL=y CONFIG_MACH_SUN4I=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-mk802ii.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802ii" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/nanopi_a64_defconfig b/configs/nanopi_a64_defconfig index 0a04911c81..0ed962bbab 100644 --- a/configs/nanopi_a64_defconfig +++ b/configs/nanopi_a64_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL=y CONFIG_MACH_SUN50I=y CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-a64-nanopi-a64.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-nanopi-a64" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/nanopi_m1_defconfig b/configs/nanopi_m1_defconfig index e0ae3c7c60..9324d7fceb 100644 --- a/configs/nanopi_m1_defconfig +++ b/configs/nanopi_m1_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-nanopi-m1.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/nanopi_m1_plus_defconfig b/configs/nanopi_m1_plus_defconfig index ee22364760..ebd06dd011 100644 --- a/configs/nanopi_m1_plus_defconfig +++ b/configs/nanopi_m1_plus_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="PH13" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-nanopi-m1-plus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/nanopi_neo2_defconfig b/configs/nanopi_neo2_defconfig index 35058186f5..eb5ed4d1f4 100644 --- a/configs/nanopi_neo2_defconfig +++ b/configs/nanopi_neo2_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN50I_H5=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881977 +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-h5-nanopi-neo2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-nanopi-neo2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/nanopi_neo_air_defconfig b/configs/nanopi_neo_air_defconfig index f953b71f03..8b50ffe2a4 100644 --- a/configs/nanopi_neo_air_defconfig +++ b/configs/nanopi_neo_air_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y # CONFIG_VIDEO_DE2 is not set +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-nanopi-neo-air.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-neo-air" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y diff --git a/configs/nanopi_neo_defconfig b/configs/nanopi_neo_defconfig index 66919e5a2b..f7da36a757 100644 --- a/configs/nanopi_neo_defconfig +++ b/configs/nanopi_neo_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y # CONFIG_VIDEO_DE2 is not set +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-nanopi-neo.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-neo" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y diff --git a/configs/nanopi_neo_plus2_defconfig b/configs/nanopi_neo_plus2_defconfig index 70798a8e9f..c0945299a4 100644 --- a/configs/nanopi_neo_plus2_defconfig +++ b/configs/nanopi_neo_plus2_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=3881977 CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-h5-nanopi-neo-plus2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-nanopi-neo-plus2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 577a32255b..7a92fa6fae 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_USB1_VBUS_PIN="PG13" +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-orangepi-2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/orangepi_lite_defconfig b/configs/orangepi_lite_defconfig index f3fd864a6d..d359212de0 100644 --- a/configs/orangepi_lite_defconfig +++ b/configs/orangepi_lite_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-orangepi-lite.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-lite" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 23f4973e5b..8f4a52699e 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-orangepi-one.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-one" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_pc2_defconfig b/configs/orangepi_pc2_defconfig index dd5f2c78ab..4037458377 100644 --- a/configs/orangepi_pc2_defconfig +++ b/configs/orangepi_pc2_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881977 CONFIG_MACPWR="PD6" CONFIG_SPL_SPI_SUNXI=y +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-h5-orangepi-pc2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-pc2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index 134db79e72..76a590618d 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=624 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-orangepi-pc.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/orangepi_pc_plus_defconfig b/configs/orangepi_pc_plus_defconfig index 01c1cd7736..c809d9c6a5 100644 --- a/configs/orangepi_pc_plus_defconfig +++ b/configs/orangepi_pc_plus_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=624 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-orangepi-pc-plus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index a6e61a5065..15ba27fdc6 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-orangepi-plus2e.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus2e" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 8e32b0af32..385a8026b2 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -9,6 +9,7 @@ CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PG13" CONFIG_SATAPWR="PG11" +CONFIG_DEFAULT_FDT_FILE="sun8i-h3-orangepi-plus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/orangepi_prime_defconfig b/configs/orangepi_prime_defconfig index df39caa903..d985638453 100644 --- a/configs/orangepi_prime_defconfig +++ b/configs/orangepi_prime_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN50I_H5=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881977 +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-h5-orangepi-prime.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-prime" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_win_defconfig b/configs/orangepi_win_defconfig index d7211b5823..e4f9431ca4 100644 --- a/configs/orangepi_win_defconfig +++ b/configs/orangepi_win_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN50I=y CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y CONFIG_SPL_SPI_SUNXI=y +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-a64-orangepi-win.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-orangepi-win" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_zero_defconfig b/configs/orangepi_zero_defconfig index 6afd4a3bfa..8a95a80e8f 100644 --- a/configs/orangepi_zero_defconfig +++ b/configs/orangepi_zero_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y # CONFIG_VIDEO_DE2 is not set CONFIG_SPL_SPI_SUNXI=y +CONFIG_DEFAULT_FDT_FILE="sun8i-h2-plus-orangepi-zero.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-zero" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y diff --git a/configs/orangepi_zero_plus2_defconfig b/configs/orangepi_zero_plus2_defconfig index fdb6bb4ed9..905ef7aa70 100644 --- a/configs/orangepi_zero_plus2_defconfig +++ b/configs/orangepi_zero_plus2_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881977 CONFIG_MMC0_CD_PIN="PH13" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-h5-orangepi-zero-plus2.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-h5-orangepi-zero-plus2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index 991e9b99aa..143c03e4bb 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -10,6 +10,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB0_ID_DET="PD10" CONFIG_USB1_VBUS_PIN="PD12" CONFIG_AXP_GPIO=y +CONFIG_DEFAULT_FDT_FILE="sun8i-r16-parrot.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-parrot" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 21ce06f370..9c4680d81b 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL=y CONFIG_MACH_SUN50I=y CONFIG_RESERVE_ALLWINNER_BOOT0_HEADER=y +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-a64-pine64-plus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 03931c8f05..86aece2e00 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_FDT_FILE="sun8i-a23-polaroid-mid2407pxe03.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2407pxe03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index f6ba2370db..23ab12e74c 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_FDT_FILE="sun8i-a23-polaroid-mid2809pxe04.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2809pxe04" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index fd829f57ea..36176b55af 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-pov-protab2-ips9.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pov-protab2-ips9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 0ef7e2c473..2c9c4cc3d2 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:40,up:31,lo: CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_DEFAULT_FDT_FILE="sun5i-a13-q8-tablet.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 18e0849853..40d735bed6 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_FDT_FILE="sun8i-a23-q8-tablet.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index 0b3973dadc..965eb779f9 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_FDT_FILE="sun8i-a33-q8-tablet.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index 322d01d8a4..a5d9888b3d 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" +CONFIG_DEFAULT_FDT_FILE="sun8i-a33-q8-tablet.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index 9a66ee90f9..ec0b9f15d8 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=384 CONFIG_USB1_VBUS_PIN="PG13" +CONFIG_DEFAULT_FDT_FILE="sun5i-a10s-r7-tv-dongle.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-r7-tv-dongle" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/sopine_baseboard_defconfig b/configs/sopine_baseboard_defconfig index 05436a1b43..c5cf267693 100644 --- a/configs/sopine_baseboard_defconfig +++ b/configs/sopine_baseboard_defconfig @@ -10,6 +10,7 @@ CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_SPL_SPI_SUNXI=y +CONFIG_DEFAULT_FDT_FILE="allwinner/sun50i-a64-pine64-plus.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/sun8i_a23_evb_defconfig b/configs/sun8i_a23_evb_defconfig index 4cb2798ce7..cb4cad3117 100644 --- a/configs/sun8i_a23_evb_defconfig +++ b/configs/sun8i_a23_evb_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=63351 CONFIG_USB0_VBUS_PIN="axp_drivebus" CONFIG_USB0_VBUS_DET="axp_vbus_detect" CONFIG_USB1_VBUS_PIN="PH7" +CONFIG_DEFAULT_FDT_FILE="sun8i-a23-evb.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-evb" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index d88dd4ebad..431f3ceffc 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -9,6 +9,7 @@ CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_FDT_FILE="sun4i-a10-gemei-g9.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-gemei-g9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C_SUPPORT=y diff --git a/configs/tbs_a711_defconfig b/configs/tbs_a711_defconfig index 3e3de4fbb3..882897fe38 100644 --- a/configs/tbs_a711_defconfig +++ b/configs/tbs_a711_defconfig @@ -11,6 +11,7 @@ CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_USB0_ID_DET="PH11" CONFIG_AXP_GPIO=y +CONFIG_DEFAULT_FDT_FILE="sun8i-a83t-tbs-a711.dtb" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-tbs-a711" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set # CONFIG_CMD_FLASH is not set diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b515e9bb1f..2bd814ef9f 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -500,17 +500,11 @@ extern int soft_i2c_gpio_scl; CONSOLE_STDIN_SETTINGS \ CONSOLE_STDOUT_SETTINGS
-#ifdef CONFIG_ARM64 -#define FDTFILE "allwinner/" CONFIG_DEFAULT_DEVICE_TREE ".dtb" -#else -#define FDTFILE CONFIG_DEFAULT_DEVICE_TREE ".dtb" -#endif - #define CONFIG_EXTRA_ENV_SETTINGS \ CONSOLE_ENV_SETTINGS \ MEM_LAYOUT_ENV_SETTINGS \ DFU_ALT_INFO_RAM \ - "fdtfile=" FDTFILE "\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "console=ttyS0,115200\0" \ SUNXI_MTDIDS_DEFAULT \ SUNXI_MTDPARTS_DEFAULT \
On 01.06.2018, at 02:59, Martin Kelly mkelly@xevo.com wrote:
Currently, sunxi-common.h ignores CONFIG_DEFAULT_FDT_FILE and assumes the kernel fdtfile and the u-boot devicetree names are the same. Although this is typically the case, sometimes you might want to customize one of these differently, so it's useful to allow them to be different.
Fix this to use only CONFIG_DEFAULT_FDT_FILE as other boards do, and set CONFIG_DEFAULT_FDT_FILE in board files to be the same as the current fdtfile= setting.
Signed-off-by: Martin Kelly mkelly@xevo.com
This patch is against u-boot master and thus conflicts with u-boot sunxi patch 31510b41f6b736fd03e2779a2585f85df39e667f ("sunxi: allow CONFIG_DEFAULT_FDT_FILE override"). If you would like me to apply this against the sunxi tree instead, I would be happy to do so and resend it.
Obviously, I cannot test a change like this on every board. Here's the tests I did:
- Booted on the nanopi neo plus2 (the board I do have).
- Compile-tested every affected config.
- To avoid missing anything I generated the config changes with the following
Python script. This script mimics what the preprocessor was doing, but encodes it explicitly in the config. Reviewing the script is probably easier than reviewing each individual file:
#!/usr/bin/python3
import os
root = '/home/martin/u-boot/configs' for name in os.listdir(root): path = os.path.join(root, name) with open(path, 'r') as f: contents = f.read() if 'CONFIG_ARCH_SUNXI=y' not in contents: continue if 'CONFIG_DEFAULT_FDT_FILE=' in contents: # Make the script idempotent. continue
if 'CONFIG_MACH_SUN50I=y' in contents or 'CONFIG_MACH_SUN50I_H5=y' in contents: arm64 = True else: arm64 = False
lines = [] for line in contents.split('\n'): if line.startswith('CONFIG_DEFAULT_DEVICE_TREE='): split = line.split('=') assert(len(split) == 2) dtb = split[1]
if dtb[0] == '"' and dtb[-1] == '"': # Dequotify. dtb = dtb[1:-1] dtb = '%s.dtb' % dtb if arm64: dtb = 'allwinner/%s' % dtb lines.append('CONFIG_DEFAULT_FDT_FILE="%s"' % dtb) lines.append(line)
with open(path, 'w') as f: f.write('\n'.join(lines))
[end script]
Looks fine to me. My only note would be that your script adds CONFIG_DEFAULT_FDT_FILE at a different line as when generated by savedefconfig.
- To avoid missing anything I generated the config changes with the following Python script. This script mimics what the preprocessor was doing, but encodes it explicitly in the config. Reviewing the script is probably easier than reviewing each individual file:
#!/usr/bin/python3
import os
if 'CONFIG_MACH_SUN50I=y' in contents or 'CONFIG_MACH_SUN50I_H5=y' in contents: arm64 = True else: arm64 = False lines = [] for line in contents.split('\n'): if line.startswith('CONFIG_DEFAULT_DEVICE_TREE='): split = line.split('=') assert(len(split) == 2) dtb = split[1] if dtb[0] == '"' and dtb[-1] == '"': # Dequotify. dtb = dtb[1:-1] dtb = '%s.dtb' % dtb if arm64: dtb = 'allwinner/%s' % dtb lines.append('CONFIG_DEFAULT_FDT_FILE="%s"' % dtb) lines.append(line) with open(path, 'w') as f: f.write('\n'.join(lines))
[end script]
Good point. I might as well change that to avoid unnecessary churn when you run savedefconfig.
I'd really prefer not to do that. There's going to be a long trail of defconfig that will be sent at pretty much the same time that are not going to have it and that will go unnotice for some time.
And there's obviously the useless churn in all the defconfig that are not in the case where it makes sense to override DEFAULT_FDT_FILE.
Why not create a Kconfig boolean that allows to select whether or not you want DEFAULT_FDT_FILE to be DEFAULT_DEVICE_TREE + .dtb or a custom value.
Maxime
Maxime
I can see the issues with new defconfigs, but I'm not sure if it will really be that bad. If we apply this patch against sunxi master, then shouldn't new patches get tested and rebased against it? In that case, if they have not set DEFAULT_FDT_FILE, it will default to "", the boards won't boot, and the mistake must be fixed prior to merging.
Alternatively if we add the Kconfig boolean, we need to worry about what happens when people have DEFAULT_FDT_FILE set already. I guess we would need to default the new Kconfig boolean to be custom in order to keep those configs from breaking. But if we do that, sunxi will break by default (since sunxi configs don't have the value set).
What would you suggest the default value of the new boolean to be?
Personally, though I think it could be a bit painful through the next merge window, I think fixing this to operate the same way as the rest of the boards is the right long-term decision.
That said, I'll add the boolean if others disagree and we figure out the right default value to avoid breaking existing configs.
Unless one has tested it with a version prior to your patch, and sends it. Not a lot of people are testing with the next branch in the various trees.
config DEFAULT_FDT_FILE_USE_DEFAULT_DEVICE_TREE bool "whatever" default y if ARCH_ROCKCHIP default y if ARCH_SUNXI
and in the headers
#ifdef CONFIG_DEFAULT_FDT_FILE_USE_DEFAULT_DEVICE_TREE #define CONFIG_DEFAULT_FDT_FILE CONFIG_DEFAULT_DEVICE_TREE ".dtb" #endif
And that's done.
So far, I've seen two platforms using this, the two representing a significant part of the total defconfig number, using the exact same value for both. Surely that means there's room for improvement.
Maxime
[snip as the thread is getting long]
and in the headers
And that's done.
I didn't know Kconfig can set different default values for each architecture like that; that does indeed solve the problem. However, I don't think it's a good idea to have sunxi use an alternate mechanism than the other boards.
To be clear, are you proposing a general config option that would apply to every board? In that case, the header logic would be in a global header rather than a board-specific one.
Maxime
and in the headers
And that's done.
Yes, that's what I had in mind.
Maxime
and in the headers
And that's done.
Maxime
OK, I can see the merits of that, though I think there's tradeoffs both ways.
Before I go ahead with a patch, Jagan: which approach would you prefer?
(ping Jagan)
and in the headers
And that's done.
Maxime
Jagan, do you prefer Maxime's proposed approach, or my original patch? I am happy to go either way but want to confirm before proceeding.
Martin Kelly
Maxime Ripard
