[PATCH 1/4] mmc: octeontx_hsmmc: Add support for MIPS Octeon
Until now, the Octeontx MMC driver did only support the ARM Octeon TX/Tx2 platforms. This patch adds support for the MIPS Octeon platform to this driver. Here a short summary of the changes:
- Enable driver compilation for MIPS Octeon, including the MMC related header file - Reorder header inclusion - Switch to using the clk framework to get the input clock - Remove some functions for MIPS Octeon, as some registers don't exist here
Signed-off-by: Stefan Roese sr@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Aaron Williams awilliams@marvell.com Cc: Chandrakala Chavva cchavva@marvell.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- .../include/mach/cvmx-mio-emm-defs.h | 614 ++++++++++++++++++ drivers/mmc/Kconfig | 10 +- drivers/mmc/octeontx_hsmmc.c | 195 ++++-- 3 files changed, 763 insertions(+), 56 deletions(-) create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-mio-emm-defs.h
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-mio-emm-defs.h b/arch/mips/mach-octeon/include/mach/cvmx-mio-emm-defs.h new file mode 100644 index 0000000000..3572a5965e --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-mio-emm-defs.h @@ -0,0 +1,614 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 Marvell International Ltd. + */ + +#ifndef __CVMX_MIO_EMM_DEFS_H__ +#define __CVMX_MIO_EMM_DEFS_H__ + +static inline u64 MIO_EMM_DMA_FIFO_CFG(void) +{ + return 0x160; +} + +static inline u64 MIO_EMM_DMA_FIFO_ADR(void) +{ + return 0x170; +} + +static inline u64 MIO_EMM_DMA_FIFO_CMD(void) +{ + return 0x178; +} + +static inline u64 MIO_EMM_DMA_CFG(void) +{ + return 0x180; +} + +static inline u64 MIO_EMM_DMA_ADR(void) +{ + return 0x188; +} + +static inline u64 MIO_EMM_DMA_INT(void) +{ + return 0x190; +} + +static inline u64 MIO_EMM_CFG(void) +{ + return 0x2000; +} + +static inline u64 MIO_EMM_MODEX(u64 a) +{ + return 0x2008 + 8 * a; +} + +static inline u64 MIO_EMM_SWITCH(void) +{ + return 0x2048; +} + +static inline u64 MIO_EMM_DMA(void) +{ + return 0x2050; +} + +static inline u64 MIO_EMM_CMD(void) +{ + return 0x2058; +} + +static inline u64 MIO_EMM_RSP_STS(void) +{ + return 0x2060; +} + +static inline u64 MIO_EMM_RSP_LO(void) +{ + return 0x2068; +} + +static inline u64 MIO_EMM_RSP_HI(void) +{ + return 0x2070; +} + +static inline u64 MIO_EMM_INT(void) +{ + return 0x2078; +} + +static inline u64 MIO_EMM_WDOG(void) +{ + return 0x2088; +} + +static inline u64 MIO_EMM_SAMPLE(void) +{ + return 0x2090; +} + +static inline u64 MIO_EMM_STS_MASK(void) +{ + return 0x2098; +} + +static inline u64 MIO_EMM_RCA(void) +{ + return 0x20a0; +} + +static inline u64 MIO_EMM_BUF_IDX(void) +{ + return 0x20e0; +} + +static inline u64 MIO_EMM_BUF_DAT(void) +{ + return 0x20e8; +} + +/* Dummy implementation, not documented on MIPS Octeon */ +static inline u64 MIO_EMM_DEBUG(void) +{ + return 0x20f8; +} + +/** + * mio_emm_access_wdog + */ +union mio_emm_access_wdog { + u64 u; + struct mio_emm_access_wdog_s { + uint64_t reserved_32_63 : 32; + uint64_t clk_cnt : 32; + } s; +}; + +/** + * mio_emm_buf_dat + * + * MIO_EMM_BUF_DAT = MIO EMMC Data buffer access Register + * + */ +union mio_emm_buf_dat { + u64 u; + struct mio_emm_buf_dat_s { + uint64_t dat : 64; + } s; +}; + +/** + * mio_emm_buf_idx + * + * MIO_EMM_BUF_IDX = MIO EMMC Data buffer address Register + * + */ +union mio_emm_buf_idx { + u64 u; + struct mio_emm_buf_idx_s { + uint64_t reserved_17_63 : 47; + uint64_t inc : 1; + uint64_t reserved_7_15 : 9; + uint64_t buf_num : 1; + uint64_t offset : 6; + } s; +}; + +/** + * mio_emm_cfg + * + * MIO_EMM_CFG = MIO EMMC Configuration Register + * + */ +union mio_emm_cfg { + u64 u; + struct mio_emm_cfg_s { + uint64_t reserved_17_63 : 47; + uint64_t boot_fail : 1; + uint64_t reserved_4_15 : 12; + uint64_t bus_ena : 4; + } s; +}; + +/** + * mio_emm_cmd + * + * MIO_EMM_CMD = MIO EMMC Command Register + * + */ +union mio_emm_cmd { + u64 u; + struct mio_emm_cmd_s { + uint64_t reserved_63_63 : 1; + uint64_t skip_busy : 1; + uint64_t bus_id : 2; + uint64_t cmd_val : 1; + uint64_t reserved_56_58 : 3; + uint64_t dbuf : 1; + uint64_t offset : 6; + uint64_t reserved_43_48 : 6; + uint64_t ctype_xor : 2; + uint64_t rtype_xor : 3; + uint64_t cmd_idx : 6; + uint64_t arg : 32; + } s; +}; + +/** + * mio_emm_dma + * + * MIO_EMM_DMA = MIO EMMC DMA config Register + * + */ +union mio_emm_dma { + u64 u; + struct mio_emm_dma_s { + uint64_t reserved_63_63 : 1; + uint64_t skip_busy : 1; + uint64_t bus_id : 2; + uint64_t dma_val : 1; + uint64_t sector : 1; + uint64_t dat_null : 1; + uint64_t thres : 6; + uint64_t rel_wr : 1; + uint64_t rw : 1; + uint64_t multi : 1; + uint64_t block_cnt : 16; + uint64_t card_addr : 32; + } s; +}; + +/** + * mio_emm_dma_adr + * + * This register sets the address for eMMC/SD flash transfers to/from memory. Sixty-four-bit + * operations must be used to access this register. This register is updated by the DMA + * hardware and can be reloaded by the values placed in the MIO_EMM_DMA_FIFO_ADR. + */ +union mio_emm_dma_adr { + u64 u; + struct mio_emm_dma_adr_s { + uint64_t reserved_42_63 : 22; + uint64_t adr : 42; + } s; +}; + +/** + * mio_emm_dma_cfg + * + * This register controls the internal DMA engine used with the eMMC/SD flash controller. Sixty- + * four-bit operations must be used to access this register. This register is updated by the + * hardware DMA engine and can also be reloaded by writes to the MIO_EMM_DMA_FIFO_CMD register. + */ +union mio_emm_dma_cfg { + u64 u; + struct mio_emm_dma_cfg_s { + uint64_t en : 1; + uint64_t rw : 1; + uint64_t clr : 1; + uint64_t reserved_60_60 : 1; + uint64_t swap32 : 1; + uint64_t swap16 : 1; + uint64_t swap8 : 1; + uint64_t endian : 1; + uint64_t size : 20; + uint64_t reserved_0_35 : 36; + } s; +}; + +/** + * mio_emm_dma_fifo_adr + * + * This register specifies the internal address that is loaded into the eMMC internal DMA FIFO. + * The FIFO is used to queue up operations for the MIO_EMM_DMA_CFG/MIO_EMM_DMA_ADR when the DMA + * completes successfully. + */ +union mio_emm_dma_fifo_adr { + u64 u; + struct mio_emm_dma_fifo_adr_s { + uint64_t reserved_42_63 : 22; + uint64_t adr : 39; + uint64_t reserved_0_2 : 3; + } s; +}; + +/** + * mio_emm_dma_fifo_cfg + * + * This register controls DMA FIFO operations. + * + */ +union mio_emm_dma_fifo_cfg { + u64 u; + struct mio_emm_dma_fifo_cfg_s { + uint64_t reserved_17_63 : 47; + uint64_t clr : 1; + uint64_t reserved_13_15 : 3; + uint64_t int_lvl : 5; + uint64_t reserved_5_7 : 3; + uint64_t count : 5; + } s; +}; + +/** + * mio_emm_dma_fifo_cmd + * + * This register specifies a command that is loaded into the eMMC internal DMA FIFO. The FIFO is + * used to queue up operations for the MIO_EMM_DMA_CFG/MIO_EMM_DMA_ADR when the DMA completes + * successfully. Writes to this register store both the MIO_EMM_DMA_FIFO_CMD and the + * MIO_EMM_DMA_FIFO_ADR contents into the FIFO and increment the MIO_EMM_DMA_FIFO_CFG[COUNT] + * field. + * + * Note: This register has a similar format to MIO_EMM_DMA_CFG with the exception + * that the EN and CLR fields are absent. These are supported in MIO_EMM_DMA_FIFO_CFG. + */ +union mio_emm_dma_fifo_cmd { + u64 u; + struct mio_emm_dma_fifo_cmd_s { + uint64_t reserved_63_63 : 1; + uint64_t rw : 1; + uint64_t reserved_61_61 : 1; + uint64_t intdis : 1; + uint64_t swap32 : 1; + uint64_t swap16 : 1; + uint64_t swap8 : 1; + uint64_t endian : 1; + uint64_t size : 20; + uint64_t reserved_0_35 : 36; + } s; +}; + +/** + * mio_emm_dma_int + * + * Sixty-four-bit operations must be used to access this register. + * + */ +union mio_emm_dma_int { + u64 u; + struct mio_emm_dma_int_s { + uint64_t reserved_2_63 : 62; + uint64_t fifo : 1; + uint64_t done : 1; + } s; +}; + +/** + * mio_emm_dma_int_w1s + */ +union mio_emm_dma_int_w1s { + u64 u; + struct mio_emm_dma_int_w1s_s { + uint64_t reserved_2_63 : 62; + uint64_t fifo : 1; + uint64_t done : 1; + } s; +}; + +/** + * mio_emm_int + * + * MIO_EMM_INT = MIO EMMC Interrupt Register + * + */ +union mio_emm_int { + u64 u; + struct mio_emm_int_s { + uint64_t reserved_7_63 : 57; + uint64_t switch_err : 1; + uint64_t switch_done : 1; + uint64_t dma_err : 1; + uint64_t cmd_err : 1; + uint64_t dma_done : 1; + uint64_t cmd_done : 1; + uint64_t buf_done : 1; + } s; +}; + +/** + * mio_emm_int_en + * + * MIO_EMM_INT_EN = MIO EMMC Interrupt enable Register + * + */ +union mio_emm_int_en { + u64 u; + struct mio_emm_int_en_s { + uint64_t reserved_7_63 : 57; + uint64_t switch_err : 1; + uint64_t switch_done : 1; + uint64_t dma_err : 1; + uint64_t cmd_err : 1; + uint64_t dma_done : 1; + uint64_t cmd_done : 1; + uint64_t buf_done : 1; + } s; +}; + +/** + * mio_emm_int_w1s + */ +union mio_emm_int_w1s { + u64 u; + struct mio_emm_int_w1s_s { + uint64_t reserved_7_63 : 57; + uint64_t switch_err : 1; + uint64_t switch_done : 1; + uint64_t dma_err : 1; + uint64_t cmd_err : 1; + uint64_t dma_done : 1; + uint64_t cmd_done : 1; + uint64_t buf_done : 1; + } s; +}; + +/** + * mio_emm_mode# + * + * MIO_EMM_MODE = MIO EMMC Operating mode Register + * + */ +union mio_emm_modex { + u64 u; + struct mio_emm_modex_s { + uint64_t reserved_49_63 : 15; + uint64_t hs_timing : 1; + uint64_t reserved_43_47 : 5; + uint64_t bus_width : 3; + uint64_t reserved_36_39 : 4; + uint64_t power_class : 4; + uint64_t clk_hi : 16; + uint64_t clk_lo : 16; + } s; +}; + +/** + * mio_emm_rca + */ +union mio_emm_rca { + u64 u; + struct mio_emm_rca_s { + uint64_t reserved_16_63 : 48; + uint64_t card_rca : 16; + } s; +}; + +/** + * mio_emm_rsp_hi + * + * MIO_EMM_RSP_HI = MIO EMMC Response data high Register + * + */ +union mio_emm_rsp_hi { + u64 u; + struct mio_emm_rsp_hi_s { + uint64_t dat : 64; + } s; +}; + +/** + * mio_emm_rsp_lo + * + * MIO_EMM_RSP_LO = MIO EMMC Response data low Register + * + */ +union mio_emm_rsp_lo { + u64 u; + struct mio_emm_rsp_lo_s { + uint64_t dat : 64; + } s; +}; + +/** + * mio_emm_rsp_sts + * + * MIO_EMM_RSP_STS = MIO EMMC Response status Register + * + */ +union mio_emm_rsp_sts { + u64 u; + struct mio_emm_rsp_sts_s { + uint64_t reserved_62_63 : 2; + uint64_t bus_id : 2; + uint64_t cmd_val : 1; + uint64_t switch_val : 1; + uint64_t dma_val : 1; + uint64_t dma_pend : 1; + uint64_t acc_timeout : 1; + uint64_t reserved_29_54 : 26; + uint64_t dbuf_err : 1; + uint64_t reserved_24_27 : 4; + uint64_t dbuf : 1; + uint64_t blk_timeout : 1; + uint64_t blk_crc_err : 1; + uint64_t rsp_busybit : 1; + uint64_t stp_timeout : 1; + uint64_t stp_crc_err : 1; + uint64_t stp_bad_sts : 1; + uint64_t stp_val : 1; + uint64_t rsp_timeout : 1; + uint64_t rsp_crc_err : 1; + uint64_t rsp_bad_sts : 1; + uint64_t rsp_val : 1; + uint64_t rsp_type : 3; + uint64_t cmd_type : 2; + uint64_t cmd_idx : 6; + uint64_t cmd_done : 1; + } s; +}; + +/** + * mio_emm_sample + */ +union mio_emm_sample { + u64 u; + struct mio_emm_sample_s { + uint64_t reserved_26_63 : 38; + uint64_t cmd_cnt : 10; + uint64_t reserved_10_15 : 6; + uint64_t dat_cnt : 10; + } s; +}; + +/** + * mio_emm_sts_mask + */ +union mio_emm_sts_mask { + u64 u; + struct mio_emm_sts_mask_s { + uint64_t reserved_32_63 : 32; + uint64_t sts_msk : 32; + } s; +}; + +/** + * mio_emm_switch + * + * MIO_EMM_SWITCH = MIO EMMC Operating mode switch Register + * + */ +union mio_emm_switch { + u64 u; + struct mio_emm_switch_s { + uint64_t reserved_62_63 : 2; + uint64_t bus_id : 2; + uint64_t switch_exe : 1; + uint64_t switch_err0 : 1; + uint64_t switch_err1 : 1; + uint64_t switch_err2 : 1; + uint64_t reserved_49_55 : 7; + uint64_t hs_timing : 1; + uint64_t reserved_43_47 : 5; + uint64_t bus_width : 3; + uint64_t reserved_36_39 : 4; + uint64_t power_class : 4; + uint64_t clk_hi : 16; + uint64_t clk_lo : 16; + } s; +}; + +/** + * mio_emm_wdog + * + * MIO_EMM_WDOG = MIO EMMC Watchdog Register + * + */ +union mio_emm_wdog { + u64 u; + struct mio_emm_wdog_s { + uint64_t reserved_26_63 : 38; + uint64_t clk_cnt : 26; + } s; +}; + +/* + * The following structs are only available to enable compilation of the common + * MMC driver. These registers do not exist on MIPS Octeon. + */ + +/** + * Register (RSL) mio_emm_timing + * + * eMMC Timing Register This register determines the number of tap delays + * the EMM_DAT, EMM_DS, and EMM_CMD lines are transmitted or received in + * relation to EMM_CLK. These values should only be changed when the eMMC + * bus is idle. + */ +union mio_emm_timing { + u64 u; + struct mio_emm_timing_s { + u64 data_out_tap : 6; + u64 reserved_6_15 : 10; + u64 data_in_tap : 6; + u64 reserved_22_31 : 10; + u64 cmd_out_tap : 6; + u64 reserved_38_47 : 10; + u64 cmd_in_tap : 6; + u64 reserved_54_63 : 10; + } s; +}; + +/** + * Register (RSL) mio_emm_debug + * + * eMMC Debug Register + */ +union mio_emm_debug { + u64 u; + struct mio_emm_debug_s { + u64 clk_on : 1; + u64 reserved_1_7 : 7; + u64 cmd_sm : 4; + u64 data_sm : 4; + u64 dma_sm : 4; + u64 emmc_clk_disable : 1; + u64 rdsync_rst : 1; + u64 reserved_22_63 : 42; + } s; +}; + +#endif diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index f8ca52efb6..d17c636e65 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -316,13 +316,13 @@ config MMC_PCI If you have an MMC controller on a PCI bus, say Y here.
config MMC_OCTEONTX - bool "Marvell OcteonTX Multimedia Card Interface support" - depends on (ARCH_OCTEONTX || ARCH_OCTEONTX2) + bool "Marvell Octeon Multimedia Card Interface support" + depends on (ARCH_OCTEON || ARCH_OCTEONTX || ARCH_OCTEONTX2) depends on DM_MMC help - This selects the OcteonTX Multimedia card Interface. - If you have an OcteonTX/TX2 board with a Multimedia Card slot, - say Y here. + This selects the Octeon Multimedia card Interface. + If you have an OcteonTX/TX2 or MIPS Octeon board with a + Multimedia Card slot, say Y here.
If unsure, say N.
diff --git a/drivers/mmc/octeontx_hsmmc.c b/drivers/mmc/octeontx_hsmmc.c index 442ca493d7..2e569a9e0f 100644 --- a/drivers/mmc/octeontx_hsmmc.c +++ b/drivers/mmc/octeontx_hsmmc.c @@ -1,13 +1,12 @@ // SPDX-License-Identifier: GPL-2.0 /* * Copyright (C) 2019 Marvell International Ltd. - * - * https://spdx.org/licenses */
-//#define DEBUG +#include <clk.h> #include <cpu_func.h> #include <dm.h> +#include <dm/device-internal.h> #include <dm/lists.h> #include <env.h> #include <errno.h> @@ -19,23 +18,31 @@ #include <part.h> #include <pci.h> #include <pci_ids.h> +#include <power/regulator.h> #include <time.h> #include <watchdog.h> - +#include <asm/io.h> #include <linux/delay.h> #include <linux/kernel.h> #include <linux/libfdt.h>
+#if defined(CONFIG_ARCH_OCTEON) +#include <mach/octeon-model.h> +#include <mach/cvmx-regs.h> +#include <mach/cvmx-mio-emm-defs.h> +#else #include <asm/arch/board.h> #include <asm/arch/clock.h> #include <asm/arch/csrs/csrs-mio_emm.h> -#include <asm/io.h> -#include <dm/device-internal.h> - -#include <power/regulator.h> +#endif
#include "octeontx_hsmmc.h"
+/* Use dummy implementation for MIPS Octeon to always return false */ +#if defined(CONFIG_ARCH_OCTEON) +#define otx_is_soc(ver) 0 +#endif + #define MMC_TIMEOUT_SHORT 20 /* in ms */ #define MMC_TIMEOUT_LONG 1000 #define MMC_TIMEOUT_ERASE 10000 @@ -71,16 +78,18 @@ #define MMC_DEFAULT_TAP_DELAY 4 #define TOTAL_NO_OF_TAPS 512 static void octeontx_mmc_switch_to(struct mmc *mmc); -static int octeontx_mmc_configure_delay(struct mmc *mmc); -static void octeontx_mmc_set_timing(struct mmc *mmc); static void set_wdog(struct mmc *mmc, u64 us); static void do_switch(struct mmc *mmc, union mio_emm_switch emm_switch); static int octeontx_mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data); -static int octeontx2_mmc_calc_delay(struct mmc *mmc, int delay); +static int octeontx_mmc_configure_delay(struct mmc *mmc); static int octeontx_mmc_calibrate_delay(struct mmc *mmc); +#if !defined(CONFIG_ARCH_OCTEON) +static int octeontx2_mmc_calc_delay(struct mmc *mmc, int delay); +static void octeontx_mmc_set_timing(struct mmc *mmc); static int octeontx_mmc_set_input_bus_timing(struct mmc *mmc); static int octeontx_mmc_set_output_bus_timing(struct mmc *mmc); +#endif
static bool host_probed;
@@ -338,6 +347,7 @@ static void mmc_print_status(u32 status) } #endif
+#if !defined(CONFIG_ARCH_OCTEON) /** * Print out all of the register values where mmc is optional * @@ -687,6 +697,12 @@ static void octeontx_mmc_print_registers(struct mmc *mmc) if (print) octeontx_mmc_print_registers2(mmc, mmc_to_host(mmc)); } +#else +static void octeontx_mmc_print_registers(struct mmc *mmc) +{ + return; +} +#endif
static const struct octeontx_sd_mods octeontx_cr_types[] = { { {0, 0}, {0, 0}, {0, 0} }, /* CMD0 */ @@ -838,14 +854,17 @@ static void octeontx_mmc_track_switch(struct mmc *mmc, u32 cmd_arg) break; case EXT_CSD_HS_TIMING: slot->want_switch.s.hs_timing = 0; +#if !defined(CONFIG_ARCH_OCTEON) slot->want_switch.s.hs200_timing = 0; slot->want_switch.s.hs400_timing = 0; +#endif switch (val & 0xf) { case 0: break; case 1: slot->want_switch.s.hs_timing = 1; break; +#if !defined(CONFIG_ARCH_OCTEON) case 2: if (!slot->is_asim && !slot->is_emul) slot->want_switch.s.hs200_timing = 1; @@ -854,6 +873,7 @@ static void octeontx_mmc_track_switch(struct mmc *mmc, u32 cmd_arg) if (!slot->is_asim && !slot->is_emul) slot->want_switch.s.hs400_timing = 1; break; +#endif default: pr_err("%s(%s): Unsupported timing mode 0x%x\n", __func__, mmc->dev->name, val & 0xf); @@ -2413,7 +2433,10 @@ static u32 octeontx_mmc_calc_clk_period(struct mmc *mmc) struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); struct octeontx_mmc_host *host = slot->host;
- return DIV_ROUND_UP(host->sys_freq, mmc->clock); + if (mmc->clock) + return DIV_ROUND_UP(host->sys_freq, mmc->clock); + + return 0; }
static int octeontx_mmc_set_ios(struct udevice *dev) @@ -2489,14 +2512,18 @@ static int octeontx_mmc_set_ios(struct udevice *dev) case UHS_SDR25: case UHS_SDR50: case UHS_SDR104: +#if !defined(CONFIG_ARCH_OCTEON) emm_switch.s.hs200_timing = 1; +#endif break; case MMC_HS_400: is_hs400 = true; fallthrough; case UHS_DDR50: case MMC_DDR_52: +#if !defined(CONFIG_ARCH_OCTEON) emm_switch.s.hs400_timing = 1; +#endif break; default: pr_err("%s(%s): Unsupported mode 0x%x\n", __func__, dev->name, @@ -2522,17 +2549,21 @@ static int octeontx_mmc_set_ios(struct udevice *dev) mmc->selected_mode); }
+#if !defined(CONFIG_ARCH_OCTEON) debug(" Trying switch 0x%llx w%d hs:%d hs200:%d hs400:%d\n", emm_switch.u, emm_switch.s.bus_width, emm_switch.s.hs_timing, emm_switch.s.hs200_timing, emm_switch.s.hs400_timing); +#endif
set_wdog(mmc, 1000); do_switch(mmc, emm_switch); mdelay(100); mode.u = read_csr(mmc, MIO_EMM_MODEX(slot->bus_id)); +#if !defined(CONFIG_ARCH_OCTEON) debug("%s(%s): mode: 0x%llx w:%d, hs:%d, hs200:%d, hs400:%d\n", __func__, dev->name, mode.u, mode.s.bus_width, mode.s.hs_timing, mode.s.hs200_timing, mode.s.hs400_timing); +#endif
err = octeontx_mmc_configure_delay(mmc);
@@ -2578,6 +2609,26 @@ static int octeontx_mmc_get_wp(struct udevice *dev) return val; }
+#if defined(CONFIG_ARCH_OCTEON) +static int octeontx_mmc_configure_delay(struct mmc *mmc) +{ + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + union mio_emm_sample emm_sample; + + debug("%s(%s)\n", __func__, mmc->dev->name); + + emm_sample.u = 0; + emm_sample.s.cmd_cnt = slot->cmd_cnt; + emm_sample.s.dat_cnt = slot->dat_cnt; + write_csr(mmc, MIO_EMM_SAMPLE(), emm_sample.u); + + return 0; +} + +static void octeontx_mmc_io_drive_setup(struct mmc *mmc) +{ +} +#else static void octeontx_mmc_set_timing(struct mmc *mmc) { union mio_emm_timing timing; @@ -2613,7 +2664,8 @@ static int octeontx_mmc_configure_delay(struct mmc *mmc)
- if (IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { + if (IS_ENABLED(CONFIG_ARCH_OCTEON) || + IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { union mio_emm_sample emm_sample;
emm_sample.u = 0; @@ -2759,6 +2811,28 @@ static int octeontx_mmc_configure_delay(struct mmc *mmc) return 0; }
+/** + * Set the IO drive strength and slew + * + * @param mmc mmc device + */ +static void octeontx_mmc_io_drive_setup(struct mmc *mmc) +{ + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX2)) { + struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); + union mio_emm_io_ctl io_ctl; + + if (slot->drive < 0 || slot->slew < 0) + return; + + io_ctl.u = 0; + io_ctl.s.drive = slot->drive; + io_ctl.s.slew = slot->slew; + write_csr(mmc, MIO_EMM_IO_CTL(), io_ctl.u); + } +} +#endif + /** * Sets the MMC watchdog timer in microseconds * @@ -2784,27 +2858,6 @@ static void set_wdog(struct mmc *mmc, u64 us) write_csr(mmc, MIO_EMM_WDOG(), wdog.u); }
-/** - * Set the IO drive strength and slew - * - * @param mmc mmc device - */ -static void octeontx_mmc_io_drive_setup(struct mmc *mmc) -{ - if (!IS_ENABLED(CONFIG_ARCH_OCTEONTX)) { - struct octeontx_mmc_slot *slot = mmc_to_slot(mmc); - union mio_emm_io_ctl io_ctl; - - if (slot->drive < 0 || slot->slew < 0) - return; - - io_ctl.u = 0; - io_ctl.s.drive = slot->drive; - io_ctl.s.slew = slot->slew; - write_csr(mmc, MIO_EMM_IO_CTL(), io_ctl.u); - } -} - /** * Print switch errors * @@ -2858,6 +2911,31 @@ static void do_switch(struct mmc *mmc, union mio_emm_switch emm_switch) read_csr(mmc, MIO_EMM_RSP_LO())); }
+/** + * Calibrates the delay based on the internal clock + * + * @param mmc Pointer to mmc data structure + * + * @return 0 for success or -ETIMEDOUT on error + * + * NOTE: On error a default value will be calculated. + */ +#if defined(CONFIG_ARCH_OCTEON) +static int octeontx_mmc_set_input_bus_timing(struct mmc *mmc) +{ + return 0; +} + +static int octeontx_mmc_set_output_bus_timing(struct mmc *mmc) +{ + return 0; +} + +static int octeontx_mmc_calibrate_delay(struct mmc *mmc) +{ + return 0; +} +#else /** * Given a delay in ps, return the tap delay count * @@ -2883,15 +2961,6 @@ static int octeontx2_mmc_calc_delay(struct mmc *mmc, int delay) return min_t(int, DIV_ROUND_UP(delay, host->timing_taps), 63); }
-/** - * Calibrates the delay based on the internal clock - * - * @param mmc Pointer to mmc data structure - * - * @return 0 for success or -ETIMEDOUT on error - * - * NOTE: On error a default value will be calculated. - */ static int octeontx_mmc_calibrate_delay(struct mmc *mmc) { union mio_emm_calb emm_calb; @@ -3141,6 +3210,7 @@ static int octeontx_mmc_set_output_bus_timing(struct mmc *mmc)
return 0; } +#endif
static void octeontx_mmc_set_clock(struct mmc *mmc) { @@ -3389,8 +3459,10 @@ static u32 xlate_voltage(u32 voltage) { u32 volt = 0;
- /* Convert to millivolts */ - voltage /= 1000; + /* Convert to millivolts. Only necessary on ARM Octeon TX/TX2 */ + if (!IS_ENABLED(CONFIG_ARCH_OCTEON)) + voltage /= 1000; + if (voltage >= 1650 && voltage <= 1950) volt |= MMC_VDD_165_195; if (voltage >= 2000 && voltage <= 2100) @@ -3736,6 +3808,8 @@ static int octeontx_mmc_host_probe(struct udevice *dev) { struct octeontx_mmc_host *host = dev_get_priv(dev); union mio_emm_int emm_int; + struct clk clk; + int ret; u8 rev;
debug("%s(%s): Entry host: %p\n", __func__, dev->name, host); @@ -3745,12 +3819,20 @@ static int octeontx_mmc_host_probe(struct udevice *dev) return -ENODEV; } memset(host, 0, sizeof(*host)); - host->base_addr = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, - PCI_REGION_MEM); - if (!host->base_addr) { - pr_err("%s: Error: MMC base address not found\n", __func__); - return -1; + + /* Octeon TX & TX2 use PCI based probing */ + if (device_is_compatible(dev, "cavium,thunder-8890-mmc")) { + host->base_addr = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + if (!host->base_addr) { + pr_err("%s: Error: MMC base address not found\n", + __func__); + return -1; + } + } else { + host->base_addr = dev_remap_addr(dev); } + host->dev = dev; debug("%s(%s): Base address: %p\n", __func__, dev->name, host->base_addr); @@ -3760,10 +3842,12 @@ static int octeontx_mmc_host_probe(struct udevice *dev) } host->node = dev_ofnode(dev); host->last_slotid = -1; +#if !defined(CONFIG_ARCH_OCTEON) if (otx_is_platform(PLATFORM_ASIM)) host->is_asim = true; if (otx_is_platform(PLATFORM_EMULATOR)) host->is_emul = true; +#endif host->dma_wait_delay = ofnode_read_u32_default(dev_ofnode(dev), "marvell,dma-wait-delay", 1); @@ -3776,7 +3860,15 @@ static int octeontx_mmc_host_probe(struct udevice *dev) writeq(emm_int.u, host->base_addr + MIO_EMM_INT());
debug("%s(%s): Getting I/O clock\n", __func__, dev->name); - host->sys_freq = octeontx_get_io_clock(); + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) + return ret; + + ret = clk_enable(&clk); + if (ret) + return ret; + + host->sys_freq = clk_get_rate(&clk); debug("%s(%s): I/O clock %llu\n", __func__, dev->name, host->sys_freq);
if (IS_ENABLED(CONFIG_ARCH_OCTEONTX2)) { @@ -3882,6 +3974,7 @@ static int octeontx_mmc_host_child_pre_probe(struct udevice *dev)
static const struct udevice_id octeontx_hsmmc_host_ids[] = { { .compatible = "cavium,thunder-8890-mmc" }, + { .compatible = "cavium,octeon-7360-mmc" }, { } };
Add the MMC DT node to the Octeon CN73xx dtsi file.
Signed-off-by: Stefan Roese sr@denx.de Cc: Aaron Williams awilliams@marvell.com Cc: Chandrakala Chavva cchavva@marvell.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- arch/mips/dts/mrvl,cn73xx.dtsi | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/arch/mips/dts/mrvl,cn73xx.dtsi b/arch/mips/dts/mrvl,cn73xx.dtsi index 40eb85ee0c..27cdfd0a2c 100644 --- a/arch/mips/dts/mrvl,cn73xx.dtsi +++ b/arch/mips/dts/mrvl,cn73xx.dtsi @@ -134,6 +134,33 @@ clocks = <&clk OCTEON_CLK_IO>; };
+ mmc: mmc@1180000002000 { + compatible = "cavium,octeon-7890-mmc", + "cavium,octeon-7360-mmc"; + reg = <0x11800 0x00000000 0x0 0x2100>; + #address-cells = <1>; + #size-cells = <0>; + /* EMM_INT_BUF_DONE, + EMM_INT_CMD_DONE, + EMM_INT_DMA_DONE, + EMM_INT_CMD_ERR, + EMM_INT_DMA_ERR, + EMM_INT_SWITCH_DONE, + EMM_INT_SWITCH_ERR, + EMM_DMA_DONE, + EMM_DMA_FIFO*/ + interrupts = <0x09040 1>, + <0x09041 1>, + <0x09042 1>, + <0x09043 1>, + <0x09044 1>, + <0x09045 1>, + <0x09046 1>, + <0x09000 1>, + <0x09001 1>; + clocks = <&clk OCTEON_CLK_IO>; + }; + spi: spi@1070000001000 { compatible = "cavium,octeon-3010-spi"; reg = <0x10700 0x00001000 0x0 0x100>;
Add the MMC DT node to the Octeon EBB7304 DT file including the regulator node for the MMC power supply.
Signed-off-by: Stefan Roese sr@denx.de Cc: Aaron Williams awilliams@marvell.com Cc: Chandrakala Chavva cchavva@marvell.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- arch/mips/dts/mrvl,octeon-ebb7304.dts | 57 +++++++++++++++++++++++++++ 1 file changed, 57 insertions(+)
diff --git a/arch/mips/dts/mrvl,octeon-ebb7304.dts b/arch/mips/dts/mrvl,octeon-ebb7304.dts index 993b4f6890..1bb34e1329 100644 --- a/arch/mips/dts/mrvl,octeon-ebb7304.dts +++ b/arch/mips/dts/mrvl,octeon-ebb7304.dts @@ -6,16 +6,36 @@ /dts-v1/;
#include "mrvl,cn73xx.dtsi" +#include <dt-bindings/gpio/gpio.h>
/ { model = "cavium,ebb7304"; compatible = "cavium,ebb7304";
aliases { + mmc0 = &mmc0; + mmc1 = &mmc1; serial0 = &uart0; spi0 = &spi; };
+ regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + /* Power on GPIO 8, active high */ + reg_mmc_3v3: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "mmc-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio 8 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + }; + chosen { stdout-path = &uart0; }; @@ -137,3 +157,40 @@ */ power = <&gpio 21 0>; }; + +&mmc { + status = "okay"; + + /* The board has two MMC slots + * If both are occupied, the speed must be reduced, + * as extra data-line load increases slew time, + * and dat-skew adjustment does not help significantly. + */ + mmc0: mmc-slot@0 { + compatible = "cavium,octeon-6130-mmc-slot", "mmc-slot"; + reg = <0>; + vqmmc-supply = <®_mmc_3v3>; + voltage-ranges = <3300 3300>; + //spi-max-frequency = <52000000>; // just one + spi-max-frequency = <37000000>; // both slots + /* bus width can be 1, 4 or 8 */ + bus-width = <8>; /* new std property */ + cavium,bus-max-width = <8>; /* custom property */ + wp-gpios = <&gpio 22 0>; /* active high */ + cd-gpios = <&gpio 23 1>; /* active low */ + }; + + mmc1: mmc-slot@1 { + compatible = "cavium,octeon-6130-mmc-slot", "mmc-slot"; + reg = <1>; + vqmmc-supply = <®_mmc_3v3>; + voltage-ranges = <3300 3300>; + //spi-max-frequency = <52000000>; // just one + spi-max-frequency = <37000000>; // both slots + /* bus width can be 1, 4 or 8 */ + bus-width = <8>; /* new std property */ + cavium,bus-max-width = <8>; /* custom property */ + wp-gpios = <&gpio 24 0>; /* active high */ + cd-gpios = <&gpio 25 1>; /* active low */ + }; +};
Enable MMC support including the regulator support on Octeon EBB7304.
Signed-off-by: Stefan Roese sr@denx.de Cc: Aaron Williams awilliams@marvell.com Cc: Chandrakala Chavva cchavva@marvell.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- configs/octeon_ebb7304_defconfig | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/configs/octeon_ebb7304_defconfig b/configs/octeon_ebb7304_defconfig index a98d73a268..c9ac8789c6 100644 --- a/configs/octeon_ebb7304_defconfig +++ b/configs/octeon_ebb7304_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y CONFIG_CMD_MTD=y CONFIG_CMD_PART=y CONFIG_CMD_PCI=y @@ -27,9 +28,12 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x1FBFE000 -CONFIG_BLK=y CONFIG_CLK=y # CONFIG_INPUT is not set +CONFIG_MISC=y +CONFIG_MMC=y +CONFIG_DM_MMC=y +CONFIG_MMC_OCTEONTX=y CONFIG_MTD=y CONFIG_DM_MTD=y CONFIG_MTD_NOR_FLASH=y @@ -45,6 +49,8 @@ CONFIG_SPI_FLASH_STMICRO=y # CONFIG_NETDEVICES is not set CONFIG_PCI=y CONFIG_DM_PCI=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_RAM=y CONFIG_RAM_OCTEON=y CONFIG_RAM_OCTEON_DDR4=y
Stefan Roese
