Re: [U-Boot] MMC initialisation
Arghhh.... Didn't see the original message was not sent to the list... So my reply was neither...
On 06.01.2011 04:46, Reinhard Meyer wrote:
Dear �ڻ�,
Please, dear Henry, ALL u-boot related questions MUST go to the mailing list, too.
I will porting U-Boot mmc part to my own board, still use U-Boot as bootloader. First, I should research the source code of mmc part in U-Boot. I found top9000eval_xe board support mmc, and SoC same with mine, (arm926ejs) Mr. Reinhard Meyer is enthusiastic working here, Thanks a lot! Let me describe mmc driver init process: (version: u-boot.2010.12)
- arch/arm/lib/board.c -> board_init_r() -> mmc_initialize(bd);
- drivers/mmc/mmc.c -> int mmc_initialize(bd_t *bis)
- board/emk/top9000/top9000.c -> int board_mmc_init(bd_t *bd)
-> return atmel_mci_init((void *)AT91_BASE_MCI); 4. drivers/mmc/gen_atmel_mci.c -> int atmel_mci_init(void *regs)
mmc->init = mci_init; // mmc->init(mmc); // How it Implementation /* need to be able to pass these in on a board by board basis */
I am not sure what your question/problem is here.
If you wonder how and when mmc->init() is called, it is only called when the command "mmcinfo" is given.
This is sure not perfect, and discussions have been around about this. "common/cmd_mmc.c" would need some rework there...
However discussions are left open on how exactly changes should be done.
Best Regards, Reinhard
Reinhard Meyer
