[PATCH] qemu-riscv64_smode: fix extlinux (define preboot)
Commit 37304aaf60bf ("Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to Kconfig") removed preboot commands in RISC-V targets and broke extlinux support as reported by Fu Wei wefu@redhat.com.
The patch finishes migration of CONFIG_USE_PREBOOT and CONFIG_REBOOT to Kconfig.
Signed-off-by: David Abdurachmanov david.abdurachmanov@sifive.com Signed-off-by: Dimitri John Ledkov dimitri.ledkov@canonical.com ---
Original patch author is David Abdurachmanov
Previously this was submitted in 2019 https://patchwork.ozlabs.org/project/uboot/patch/20190821190720.4286-1-david...
Since then the sifive fu540 portion of this change was merged, but not the qemu one.
Submitting the qemu portion again. Without this change, qemu smode cannot boot Ubuntu's riscv64 cloud images with extlinux.conf.
configs/qemu-riscv64_smode_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/qemu-riscv64_smode_defconfig b/configs/qemu-riscv64_smode_defconfig index 0000564e41..cb674c6a75 100644 --- a/configs/qemu-riscv64_smode_defconfig +++ b/configs/qemu-riscv64_smode_defconfig @@ -14,3 +14,5 @@ CONFIG_CMD_NVEDIT_EFI=y CONFIG_OF_PRIOR_STAGE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM_MTD=y +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="setenv fdt_addr ${fdtcontroladdr}; fdt addr ${fdtcontroladdr};"
Hi Dimitri,
Could you add a "Fixes" tag and a "Reported-by" tag as suggested by Bin?
The config option should be inserted using "make savedefconfig".
e.g. $ make menuconfig choose the config option desired $ make savedefconfig $ cp defconfig configs/qemu-riscv64_smode_defconfig
Thanks!
Best regards, Leo
-- 2.30.2
On Mon, Jul 26, 2021 at 8:55 AM Leo Liang ycliang@andestech.com wrote:
Hi Dimitri,
done in v2
done in v3
Thanks!
Best regards, Leo
-- 2.30.2
Dimitri John Ledkov
Leo Liang
