[U-Boot-Users] PPC970FX 64-bit processor
U-Boot is running as a 64-bit binary on the IBM-970FX (PPC64 CPU arch), on one of Marvell evaluation boards (Pythagoras family)!!!
Some of the *NEW* components I've added to U-Boot: /include/asm-ppc64, /include/ppc970, /include/ppc64_asm.tmpl, /cpu/ppc970, /lib_ppc64
I want to add 64-bit support to some of the *COMMON* files, starting with cmd_mem.c. The commands are followed with [.b, .w, .l] represents display option: 8-bit, 16-bit, and 32-bit, accordingly. Will it be ok to change it to [.b, .s, .w, .l] for 8, 16, 32, and 64? If it is not acceptable what do you suggest? new cmd_mem64.c? other?
Regards, Tzachi Perelstein
In 64-bit mode both 'long' and 'long long' types are 8 bytes. Therefore I think that [.l] and [.ll] is not good enough for 64-bit users. I can be even more explicitly and suggest [.8, .16, .32, .64]. What do you think?
I know I'm old-fashioned, but how about "[.b, .w, .l, .ll]"?
Too much typing, and not backwards compatible.
It would break compatibility with existing scripts and documentation of everyone else. I think we should maintain earlier definitions at least for existing 32-bit implementations.
Best regards, Tolunay
John W. Linville wrote:
I think I like that even better.
John
The SF.Net email is sponsored by: Beat the post-holiday blues Get a FREE limited edition SourceForge.net t-shirt from ThinkGeek. It's fun and FREE -- well, almost....http://www.thinkgeek.com/sfshirt _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Perhaps...if that is the prevailing logic, then I think my original proposal (just adding a .ll) makes the most sense.
Still, I think the bit-width based modifiers is the cleaner solution.
Tzachi, perhaps you can #ifdef the cli code to only use the [.8, ..., .64] for new and/or 64-bit platforms?
Just a thought...
John
In message 5C4013D09582FF41833487F21C085CF991ADCE@Hqexch02.il.marvell.com you wrote:
Congratulations!!!!
No, this is not acceptable, as it would break backwards compatibility.
The BDI2000 telnet interface (which was one of my references for the "b" and "w" suffixes) uses "d" for "double" to access 64 bit objects. I think we should do the same and add ".d" [=> .b, .w, .l, .d].
------_=_NextPart_001_01C4F726.CC47ACA6 Content-Type: text/html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
And *please* don't post HTML to this list.
That would satisfy me...
John
participants (5)
John W. Linville
Tolunay Orkun
Tzachi Perelstein
tzachi perelstein
