[PATCH v1 0/3] add elog support for broadcom NS3 soc
This is fifth patch set series prepared on top of fourth patch set ("add optee support for broadcom NS3 soc").
This patch adds support for error logging and corresponding command.
Sheetal Tigadoli (1): common: ns3: add error logging support
Vladimir Olovyannikov (2): board: ns3: kconfig: extend board kconfig with specific commands cmd: bcm: add broadcom error log setup command
board/broadcom/bcmns3/Kconfig | 5 + cmd/Kconfig | 2 + cmd/Makefile | 2 + cmd/bcm/Kconfig | 12 + cmd/bcm/Makefile | 4 + cmd/bcm/elog.h | 64 +++++ cmd/bcm/logsetup.c | 432 ++++++++++++++++++++++++++++++++++ common/Kconfig | 8 + common/Makefile | 1 + common/bcm_elog.c | 49 ++++ common/console.c | 22 ++ configs/bcm_ns3_defconfig | 1 + include/bcm_elog.h | 37 +++ 13 files changed, 639 insertions(+) create mode 100644 cmd/bcm/Kconfig create mode 100644 cmd/bcm/Makefile create mode 100644 cmd/bcm/elog.h create mode 100644 cmd/bcm/logsetup.c create mode 100644 common/bcm_elog.c create mode 100644 include/bcm_elog.h
From: Sheetal Tigadoli sheetal.tigadoli@broadcom.com
Add error logging support in uboot for ns3 platform.
We log the bootup msgs from all bootstages(BL2, BL31, BL33, and Linux) on to DDR. When a watchdog is triggered from any of the bootstages, CRMU copies these logs to QSPI error logging space.
Later when doing the post-mortem analysis, we parse the QSPI error log space.
Signed-off-by: Sheetal Tigadoli sheetal.tigadoli@broadcom.com Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com --- common/Kconfig | 8 +++++++ common/Makefile | 1 + common/bcm_elog.c | 49 +++++++++++++++++++++++++++++++++++++++ common/console.c | 22 ++++++++++++++++++ configs/bcm_ns3_defconfig | 1 + include/bcm_elog.h | 37 +++++++++++++++++++++++++++++ 6 files changed, 118 insertions(+) create mode 100644 common/bcm_elog.c create mode 100644 include/bcm_elog.h
diff --git a/common/Kconfig b/common/Kconfig index 30cba15948..3980ba31e0 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -634,6 +634,14 @@ config SYS_STDIO_DEREGISTER removed (for example a USB keyboard) then this option can be enabled to ensure this is handled correctly.
+config BCM_ELOG + bool "Broadcom error logging support" + default n + help + Enables broadcom error logging support to be used with brcm + platforms, say Y to this option to enable the logging support. + If unsure, say N. + endmenu
menu "Logging" diff --git a/common/Makefile b/common/Makefile index 2e7a090588..dced769dcf 100644 --- a/common/Makefile +++ b/common/Makefile @@ -95,6 +95,7 @@ else obj-$(CONFIG_SPL_SERIAL_SUPPORT) += console.o endif else +obj-$(CONFIG_BCM_ELOG) += bcm_elog.o obj-y += console.o endif # CONFIG_SPL_BUILD
diff --git a/common/bcm_elog.c b/common/bcm_elog.c new file mode 100644 index 0000000000..8e89a500b9 --- /dev/null +++ b/common/bcm_elog.c @@ -0,0 +1,49 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 Broadcom. + */ + +#include <bcm_elog.h> + +/* Log one character */ +int log2ddr(const char ch) +{ + u32 offset, len; + uintptr_t base = BCM_ELOG_UBOOT_BASE; + + offset = readl(base + BCM_ELOG_OFF_OFFSET); + len = readl(base + BCM_ELOG_LEN_OFFSET); + writeb(ch, base + offset); + offset++; + + /* log buffer is now full and need to wrap around */ + if (offset >= BCM_ELOG_UBOOT_SIZE) + offset = BCM_ELOG_HEADER_LEN; + + /* only increment length when log buffer is not full */ + if (len < BCM_ELOG_UBOOT_SIZE - BCM_ELOG_HEADER_LEN) + len++; + + writel(offset, base + BCM_ELOG_OFF_OFFSET); + writel(len, base + BCM_ELOG_LEN_OFFSET); + + return 0; +} + +/* Routine to initialize error logging */ +void bcm_elog_init(uintptr_t base, uint32_t size) +{ + u32 val; + + /* + * If a valid signature is found, it means logging is already + * initialize. In this case, we should not re-initialize the entry + * header in the designated memory + */ + val = readl(base + BCM_ELOG_SIG_OFFSET); + if (val != BCM_ELOG_SIG_VAL) { + writel(base + BCM_ELOG_SIG_OFFSET, BCM_ELOG_SIG_VAL); + writel(base + BCM_ELOG_OFF_OFFSET, BCM_ELOG_HEADER_LEN); + writel(base + BCM_ELOG_LEN_OFFSET, 0); + } +} diff --git a/common/console.c b/common/console.c index e398530a13..a65fdc16c2 100644 --- a/common/console.c +++ b/common/console.c @@ -20,6 +20,10 @@ #include <env_internal.h> #include <watchdog.h>
+#ifdef CONFIG_BCM_ELOG +#include <bcm_elog.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
static int on_console(const char *name, const char *value, enum env_op op, @@ -536,6 +540,9 @@ void putc(const char c) if (!gd->have_console) return pre_console_putc(c);
+#ifdef CONFIG_BCM_ELOG + log2ddr(c); +#endif if (gd->flags & GD_FLG_DEVINIT) { /* Send to the standard output */ fputc(stdout, c); @@ -587,6 +594,17 @@ void puts(const char *s) if (!gd->have_console) return pre_console_puts(s);
+#ifdef CONFIG_BCM_ELOG + { + const char *tmp = s; + + while (*tmp) { + int c = *tmp++; + + log2ddr(c); + } + } +#endif if (gd->flags & GD_FLG_DEVINIT) { /* Send to the standard output */ fputs(stdout, s); @@ -790,6 +808,10 @@ int console_init_f(void)
print_pre_console_buffer(PRE_CONSOLE_FLUSHPOINT1_SERIAL);
+#ifdef CONFIG_BCM_ELOG + bcm_elog_init(BCM_ELOG_UBOOT_BASE, BCM_ELOG_UBOOT_SIZE); +#endif + return 0; }
diff --git a/configs/bcm_ns3_defconfig b/configs/bcm_ns3_defconfig index 13fe9d439e..a2201bf0c9 100644 --- a/configs/bcm_ns3_defconfig +++ b/configs/bcm_ns3_defconfig @@ -14,6 +14,7 @@ CONFIG_LOGLEVEL=7 CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y # CONFIG_SILENT_CONSOLE_UPDATE_ON_SET is not set +CONFIG_BCM_ELOG=y CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_HUSH_PARSER=y diff --git a/include/bcm_elog.h b/include/bcm_elog.h new file mode 100644 index 0000000000..7ba99f1cf7 --- /dev/null +++ b/include/bcm_elog.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 Broadcom. + * + */ + +#ifndef __BCM_ELOG_H__ +#define __BCM_ELOG_H__ + +#include <asm/io.h> +#include <linux/types.h> + +/* Default AP error logging base address */ +#ifndef ELOG_AP_UART_LOG_BASE +#define ELOG_AP_UART_LOG_BASE 0x8f110000 +#endif + +/* Reserve 16K to store error logs */ +#define BCM_ELOG_UBOOT_BASE ELOG_AP_UART_LOG_BASE +#define BCM_ELOG_UBOOT_SIZE 0x4000 + +/* error logging signature */ +#define BCM_ELOG_SIG_OFFSET 0x0000 +#define BCM_ELOG_SIG_VAL 0x75767971 + +/* current logging offset that points to where new logs should be added */ +#define BCM_ELOG_OFF_OFFSET 0x0004 + +/* current logging length (excluding header) */ +#define BCM_ELOG_LEN_OFFSET 0x0008 + +#define BCM_ELOG_HEADER_LEN 12 + +int log2ddr(const char ch); +void bcm_elog_init(uintptr_t base, uint32_t size); + +#endif /* __BCM_ELOG_H__ */
Hi Rayagonda,
On Sun, 17 May 2020 at 02:33, Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com wrote:
Is there a doc somewhere describing the format? If not you should add something to the top of your source file.
+config BCM_ELOG
default n
Not needed
help
If unsure, say N.
endmenu
- Copyright 2020 Broadcom.
u32 offset, len;
This should really be in a driver. Have you looked at logging? See for example log_syslog.c which is an example of writing log info obtained from the log() function.
If that doesn't work then perhaps have a UCLASS_MISC driver that you can write to?
offset++;
len++;
u32 val;
Can't add this to common code, sorry.
Hopefully U-Boot's logging can help here?
log2ddr(c);
while (*tmp) {
int c = *tmp++;
log2ddr(c);
This should go in the devicetree node for your driver.
2.17.1
This, and the series that starts with "cmd: bcm: add nitro boot command" seem to conflict. Can you please resubmit any further outstanding patches? Thanks!
Hi Tom,
Rebased the patch and sent a v2 patch.
Thanks, Rayagonda
-- Tom
From: Vladimir Olovyannikov vladimir.olovyannikov@broadcom.com
Extend Kconfig for the board with board-specific commands selection.
Signed-off-by: Vladimir Olovyannikov vladimir.olovyannikov@broadcom.com Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com --- board/broadcom/bcmns3/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/broadcom/bcmns3/Kconfig b/board/broadcom/bcmns3/Kconfig index 84daad9415..10547f71de 100644 --- a/board/broadcom/bcmns3/Kconfig +++ b/board/broadcom/bcmns3/Kconfig @@ -12,6 +12,10 @@ config SYS_SOC config SYS_CONFIG_NAME default "bcm_ns3"
+config CMD_BCM_EXT_UTILS + bool "Enable Broadcom-specific u-boot commands" + default y + config CHIMP_OPTEE bool "Enable secure ChiMP firmware loading" depends on OPTEE
Please see below
U-Boot
What sort of commands? You could add some details here.
default y
config CHIMP_OPTEE bool "Enable secure ChiMP firmware loading" depends on OPTEE -- 2.17.1
Add broadcom error log setup command.
Some Broadcom platforms have ability to record event logs by SCP. - Add a logsetup command which is used to perform initial configuration of this log. Move this command to bcm/ directory to be used for Broadcom-specific U-boot commands. - Add support for Broadcom-specific commands to Kconfig and to Makefile in cmd/.
Signed-off-by: Vladimir Olovyannikov vladimir.olovyannikov@broadcom.com Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com --- board/broadcom/bcmns3/Kconfig | 1 + cmd/Kconfig | 2 + cmd/Makefile | 2 + cmd/bcm/Kconfig | 12 + cmd/bcm/Makefile | 4 + cmd/bcm/elog.h | 64 +++++ cmd/bcm/logsetup.c | 432 ++++++++++++++++++++++++++++++++++ 7 files changed, 517 insertions(+) create mode 100644 cmd/bcm/Kconfig create mode 100644 cmd/bcm/Makefile create mode 100644 cmd/bcm/elog.h create mode 100644 cmd/bcm/logsetup.c
diff --git a/board/broadcom/bcmns3/Kconfig b/board/broadcom/bcmns3/Kconfig index 10547f71de..6a8c7bc7db 100644 --- a/board/broadcom/bcmns3/Kconfig +++ b/board/broadcom/bcmns3/Kconfig @@ -15,6 +15,7 @@ config SYS_CONFIG_NAME config CMD_BCM_EXT_UTILS bool "Enable Broadcom-specific u-boot commands" default y + select CMD_BCM_LOGSETUP
config CHIMP_OPTEE bool "Enable secure ChiMP firmware loading" diff --git a/cmd/Kconfig b/cmd/Kconfig index 157a33081f..d7b34828fa 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2214,4 +2214,6 @@ config CMD_UBIFS help UBIFS is a file system for flash devices which works on top of UBI.
+source cmd/bcm/Kconfig + endmenu diff --git a/cmd/Makefile b/cmd/Makefile index 974ad48b0a..f9925e3a34 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -191,6 +191,8 @@ obj-$(CONFIG_$(SPL_)CMD_TLV_EEPROM) += tlv_eeprom.o # core command obj-y += nvedit.o
+obj-$(CONFIG_CMD_BCM_EXT_UTILS) += bcm/ + obj-$(CONFIG_TI_COMMON_CMD_OPTIONS) += ti/
filechk_data_gz = (echo "static const char data_gz[] ="; cat $< | scripts/bin2c; echo ";") diff --git a/cmd/bcm/Kconfig b/cmd/bcm/Kconfig new file mode 100644 index 0000000000..189a45004e --- /dev/null +++ b/cmd/bcm/Kconfig @@ -0,0 +1,12 @@ +menu "Broadcom Extended Utilities" + +config CMD_BCM_LOGSETUP + bool "Command to setup logging on Broadcom boards" + depends on TARGET_BCMNS3 + default n + help + Support specific log setup on Broadcom SoCs. This command + allows checking if logging support is present, and update + log sections. + +endmenu diff --git a/cmd/bcm/Makefile b/cmd/bcm/Makefile new file mode 100644 index 0000000000..96dc8f7ad7 --- /dev/null +++ b/cmd/bcm/Makefile @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2020 Broadcom + +obj-$(CONFIG_CMD_BCM_LOGSETUP) += logsetup.o diff --git a/cmd/bcm/elog.h b/cmd/bcm/elog.h new file mode 100644 index 0000000000..cc36d8739a --- /dev/null +++ b/cmd/bcm/elog.h @@ -0,0 +1,64 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 Broadcom + */ + +#ifndef __ELOG_H__ +#define __ELOG_H__ + +#define GLOBAL_META_HDR_SIG 0x45524c47 +#define MAX_REC_COUNT 13 +#define MAX_REC_FORMAT 1 +#define MAX_SRC_TYPE 3 +#define MAX_NVM_TYPE 3 +/* A special type. Use defaults specified in CRMU config */ +#define NVM_DEFAULT 0xff + +/* Max. number of cmd parameters per elog spec */ +#define PARAM_COUNT 3 + +#define REC_DESC_LENGTH 8 + +enum { + LOG_SETUP_CMD_VALIDATE_META, + LOG_SETUP_CMD_WRITE_META, + LOG_SETUP_CMD_ERASE, + LOG_SETUP_CMD_READ, + LOG_SETUP_CMD_CHECK +}; + +#pragma pack(push, 1) + +struct meta_record { + u8 record_type; + u8 record_format; + u8 src_mem_type; + u8 alt_src_mem_type; + u8 nvm_type; + char rec_desc[REC_DESC_LENGTH]; + u64 src_mem_addr; + u64 alt_src_mem_addr; + u64 rec_addr; + u32 rec_size; + u32 sector_size; + u8 padding[3]; +}; + +struct global_header { + u32 signature; + u32 sector_size; + u8 revision; + u8 rec_count; + u16 padding; +}; + +struct log_setup { + u32 cmd; + u32 params[PARAM_COUNT]; + u32 result; + u32 ret_code; +}; + +#pragma pack(pop) + +#endif diff --git a/cmd/bcm/logsetup.c b/cmd/bcm/logsetup.c new file mode 100644 index 0000000000..271462311d --- /dev/null +++ b/cmd/bcm/logsetup.c @@ -0,0 +1,432 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2020 Broadcom + */ + +/* + * Create a binary file ready to be flashed + * as a global meta for logging, from a source file. + */ + +#include <common.h> +#include <malloc.h> +#include <string.h> +#include <asm/io.h> +#include <asm/system.h> +#include <linux/ctype.h> +#include <linux/delay.h> + +#include "elog.h" + +#define FILE_LINE_BUF_SIZE 1024 +#define GLOBAL_PARAM_COUNT 3 +#define REC_PARAM_COUNT 11 + +#define GLOBAL_NAME "GLOBAL" +#define RECORD_NAME "RECORD" + +#define MCU_IPC_MCU_CMD_ELOG_SETUP 0x84 +/* SPI write operations can be slow */ +#define DEFAULT_TIMEOUT_MS 10000 + +#define MCU_IPC_CMD_DONE_MASK 0x80000000 +#define MCU_IPC_CMD_REPLY_MASK 0x3fff0000 +#define MCU_IPC_CMD_REPLY_SHIFT 16 + +#define MIN_ARGS_COUNT 3 +#define MAX_ARGS_COUNT 5 +#define SEP_STR "," +#define SUPPORTED_CMD "-s" +#define CHK_HDR_CMD "-c" + +enum { + PARAM_GLOBAL, + PARAM_REC +}; + +static uintptr_t crmu_mbox0_address; + +/* + * Send a logging command to MCU patch for execution. + * + * Parameters: + * cmd: an IPC command code + * param: a pointer to parameters structure for IPC + * is_real_cmd: whether command produces a response in the structure. + * Only "support" command does not. + */ +static int send_crmu_log_cmd(u32 cmd, u32 param, int is_real_cmd) +{ + u32 timeout; + u32 val; + int ret = CMD_RET_FAILURE; + struct log_setup *setup; + + setup = (struct log_setup *)(uintptr_t)param; + timeout = DEFAULT_TIMEOUT_MS; + + writel(cmd, crmu_mbox0_address); + writel(param, crmu_mbox0_address + sizeof(u32)); + + do { + mdelay(1); + val = readl(is_real_cmd ? (uintptr_t)&setup->ret_code : + crmu_mbox0_address); + if (val & MCU_IPC_CMD_DONE_MASK) { + ret = CMD_RET_SUCCESS; + break; + } + + } while (timeout--); + + if (ret == CMD_RET_FAILURE) { + pr_err("CRMU cmd timeout!\n"); + return ret; + } + + /* Obtain status */ + val = (val & MCU_IPC_CMD_REPLY_MASK) >> MCU_IPC_CMD_REPLY_SHIFT; + if (val) + ret = CMD_RET_FAILURE; + + return ret; +} + +static char *get_next_param(char **str, char *delimiter) +{ + char *ret = strsep(str, delimiter); + + if (!ret) + return NULL; + + return strim(ret); +} + +static int count_chars(char *str, char delimiter) +{ + int count = 0; + + if (!str || (!strlen(str))) + return 0; + + do { + if (*str == delimiter) + count++; + + str++; + } while (*str); + + /* Need to consider leftovers (if any) after the last delimiter */ + count++; + + return count; +} + +static int do_setup(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct global_header global; + struct log_setup setup = {0}; + u8 *temp; + u8 *ptr = NULL; + char *buf; + u32 line_no = 0; + u32 expected_meta_size; + u32 data_size; + u32 log_offset = 0; + u32 num_recs = 0; + u32 addr; + int global_ready = 0; + int ret = CMD_RET_FAILURE; + int force = 0; + + if (argc < MIN_ARGS_COUNT || argc > MAX_ARGS_COUNT) + return CMD_RET_USAGE; + + /* Usage: addr or (-s/-c) mbox0_addr [data_size] [force] */ + crmu_mbox0_address = simple_strtoul(argv[2], NULL, 16); + if (!crmu_mbox0_address) { + pr_err("Invalid CRMU mbox0 address\n"); + return ret; + } + + if (argc == MIN_ARGS_COUNT) { + if (strncmp(argv[1], SUPPORTED_CMD, 2) == 0) + return send_crmu_log_cmd(MCU_IPC_MCU_CMD_ELOG_SETUP, + LOG_SETUP_CMD_CHECK, + 0 + ); + + if (strncmp(argv[1], CHK_HDR_CMD, 2) == 0) + return send_crmu_log_cmd(MCU_IPC_MCU_CMD_ELOG_SETUP, + (uintptr_t)&setup, + 1 + ); + } + + /* Expect 1st parameter as a pointer to metadata */ + addr = simple_strtoul(argv[1], NULL, 16); + if (!addr) { + pr_err("Address 0x0 is not allowed\n"); + return ret; + } + + data_size = simple_strtoul(argv[3], NULL, 16); + if (!data_size) { + pr_err("Invalid source size\n"); + return ret; + } + + if (argc == MAX_ARGS_COUNT) + force = simple_strtoul(argv[MAX_ARGS_COUNT - 1], NULL, 10); + + memset(&global, 0, sizeof(struct global_header)); + expected_meta_size = sizeof(struct global_header) + + MAX_REC_COUNT * sizeof(struct meta_record); + + temp = (u8 *)malloc(expected_meta_size); + if (!temp) + return ret; + + memset(temp, 0, expected_meta_size); + + ptr = temp; + buf = (char *)(uintptr_t)addr; + /* End of file mark */ + buf[data_size] = '\0'; + + do { + char *type_name; + u32 entry_type; + char *line; + char *value; + + line_no++; + line = get_next_param(&buf, "\n"); + if (!line) + break; + + if ((!strlen(line)) || line[0] == '#') + continue; + + value = get_next_param(&line, "="); + + if (!value || (!strlen(value))) { + pr_err("Invalid format of line %d\n", line_no); + goto free_params; + } + + type_name = GLOBAL_NAME; + + if (!strncasecmp(value, type_name, strlen(GLOBAL_NAME))) { + entry_type = PARAM_GLOBAL; + } else { + type_name = RECORD_NAME; + if (!strncasecmp(value, + type_name, + strlen(RECORD_NAME) + ) + ) { + entry_type = PARAM_REC; + } else { + pr_err("Unknown type %s, line %d\n", + value, + line_no + ); + goto free_params; + } + } + + if (global_ready && entry_type == PARAM_GLOBAL) { + /* Multiple globals are not allowed */ + pr_err("Multiple GLOBAL records, line %d\n", line_no); + goto free_params; + } + + if (entry_type == PARAM_GLOBAL) { + /* Parse Global and create global record in outfile */ + if (count_chars(line, ',') != GLOBAL_PARAM_COUNT) { + pr_err("Invalid GLOBAL format, line %d\n", + line_no + ); + goto free_params; + } + + global.sector_size = + simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + global.revision = + (u8)simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + log_offset = simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + + if (!global.sector_size) { + pr_err("Invalid GLOBAL, line %d\n", line_no); + goto free_params; + } + + global.signature = GLOBAL_META_HDR_SIG; + global_ready = 1; + + /* Shift to the first RECORD header */ + log_offset += 2 * global.sector_size; + ptr += sizeof(struct global_header); + } else { + struct meta_record rec = {0}; + char *desc; + char *rec_addr_str; + int auto_addr = 0; + + if (count_chars(line, ',') != REC_PARAM_COUNT) { + pr_err("Invalid RECORD, line %d\n", line_no); + goto free_params; + } + + rec.record_type = (u8)simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + rec.record_format = (u8)simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + rec.src_mem_type = (u8)simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + rec.alt_src_mem_type = (u8)simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + rec.nvm_type = (u8)simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + desc = get_next_param(&line, SEP_STR); + if (desc) + desc = strim(desc); + + rec.src_mem_addr = (u64)simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + rec.alt_src_mem_addr = (u64)simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + rec_addr_str = get_next_param(&line, SEP_STR); + if (rec_addr_str) + rec_addr_str = strim(rec_addr_str); + + if (!strcmp(rec_addr_str, "auto")) + auto_addr = 1; + else + rec.rec_addr = (u64)simple_strtoul + (rec_addr_str, + NULL, + 0 + ); + + rec.rec_size = simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + rec.sector_size = simple_strtoul + (get_next_param(&line, SEP_STR), + NULL, + 0 + ); + if (auto_addr) { + rec.rec_addr = (u64)log_offset; + log_offset += rec.rec_size; + } + + /* Sanity checks */ + if (rec.record_type > MAX_REC_COUNT || + rec.record_format > MAX_REC_FORMAT || + (rec.nvm_type > MAX_NVM_TYPE && + rec.nvm_type != NVM_DEFAULT) || + !rec.rec_size || + !rec.sector_size || + (!desc || !strlen(desc) || + (strlen(desc) > sizeof(rec.rec_desc) + 1) + ) + ) { + pr_err("Invalid RECORD %s, line %d\n", + desc ? desc : " (no desc)", line_no + ); + goto free_params; + } + + memset(rec.rec_desc, ' ', sizeof(rec.rec_desc)); + memcpy(rec.rec_desc, desc, strlen(desc)); + memcpy(ptr, &rec, sizeof(struct meta_record)); + ptr += sizeof(struct meta_record); + num_recs++; + } + + } while (buf && ((uintptr_t)buf < (addr + data_size))); + + if (!num_recs) { + pr_err("No RECORD entry!\n"); + goto free_params; + } + + if (!global_ready) { + pr_err("Global entry was not found!\n"); + goto free_params; + } + + if (num_recs > MAX_REC_COUNT) { + pr_err("Too many records (max %d)\n", MAX_REC_COUNT); + goto free_params; + } + + /* Recalculate new expected size */ + if (num_recs != MAX_REC_COUNT) { + expected_meta_size = sizeof(struct global_header) + + num_recs * sizeof(struct meta_record); + } + + global.rec_count = num_recs; + memcpy(temp, &global, sizeof(struct global_header)); + + setup.params[0] = (uintptr_t)temp; + setup.params[1] = expected_meta_size; + + /* Apply the command via CRMU mailboxes and read the result. */ + setup.cmd = (force) ? LOG_SETUP_CMD_WRITE_META : + LOG_SETUP_CMD_VALIDATE_META; + + /* Finally, request the MCU patch to perform the command */ + ret = send_crmu_log_cmd(MCU_IPC_MCU_CMD_ELOG_SETUP, + (uintptr_t)(&setup), + 1 + ); + +free_params: + free(temp); + + return ret; +} + +U_BOOT_CMD(logsetup, 5, 1, do_setup, "setup Broadcom MCU logging subsystem", + "\taddr mbox0_addr [data_size] [force]\nor\n\t -s(or -c) mbox0_addr" + );
Hi Rayagonda,
+enum {
LOG_SETUP_CMD_READ,
LOG_SETUP_CMD_CHECK
Please use __packed on each struct instead
Structures need comments about what each member is for.
u8 record_type;
u8 record_format;
u8 src_mem_type;
u8 nvm_type;
u64 src_mem_addr;
u64 rec_addr;
u32 rec_size;
u32 sector_size;
u8 padding[3];
u32 signature;
u32 sector_size;
u8 revision;
u8 rec_count;
u16 padding;
+struct log_setup {
u32 cmd;
u32 result;
u32 ret_code;
+#pragma pack(pop)
- Create a binary file ready to be flashed
- as a global meta for logging, from a source file.
+#include "elog.h"
+enum {
PARAM_GLOBAL,
PARAM_REC
- Send a logging command to MCU patch for execution.
- Parameters:
- cmd: an IPC command code
- param: a pointer to parameters structure for IPC
- is_real_cmd: whether command produces a response in the structure.
Please use the U-Boot style. Also add @return
u32 timeout;
u32 val;
do {
mdelay(1);
break;
Drop blank line.
Normally timeouts in U-Boot are done like this:
ulong start = get_timer(0);
do { ... if (get_timer(start) > DEFAULT_TIMEOUT_MS) { // print message return CMD_RET_FAILURE; } while (1)
return ret;
/* Obtain status */
if (val)
return ret;
if (!ret)
return NULL;
return strim(ret);
int count = 0;
do {
count++;
str++;
} while (*str);
count++;
return count;
u8 *temp;
u8 *ptr = NULL;
char *buf;
u32 line_no = 0;
u32 data_size;
u32 log_offset = 0;
u32 num_recs = 0;
u32 addr;
int force = 0;
return ret;
0
Can you close up more of this on the same line? Please fix globally.
(uintptr_t)&setup,
1
if (!addr) {
return ret;
if (!data_size) {
return ret;
if (!temp)
return ret;
ptr = temp;
do {
char *type_name;
u32 entry_type;
char *line;
char *value;
line_no++;
if (!line)
break;
continue;
goto free_params;
} else {
type_name,
strlen(RECORD_NAME)
} else {
value,
line_no
goto free_params;
goto free_params;
line_no
goto free_params;
simple_strtoul
NULL,
0
global.revision =
(u8)simple_strtoul
NULL,
0
NULL,
0
goto free_params;
global_ready = 1;
} else {
char *desc;
char *rec_addr_str;
int auto_addr = 0;
goto free_params;
NULL,
0
NULL,
0
NULL,
0
NULL,
0
NULL,
0
if (desc)
desc = strim(desc);
NULL,
0
NULL,
0
if (rec_addr_str)
auto_addr = 1;
else
(rec_addr_str,
NULL,
0
NULL,
0
NULL,
0
if (auto_addr) {
/* Sanity checks */
!rec.rec_size ||
!rec.sector_size ||
goto free_params;
num_recs++;
Consider putting the inner loop in a function. This function is too long!
if (!num_recs) {
goto free_params;
goto free_params;
goto free_params;
1
+free_params:
free(temp);
return ret;
Seems like there needs to be more docs on what these things mean. Could be in the help or in this source file, perhaps?
-- 2.17.1
Rayagonda Kokatanur
