[PATCH 1/2] misc: ele_mu: Update ELE MU to get TR/RR number from HW
The MU parameter register can provide the TR and RR number. For i.MX95 which has 8 RR is different with i.MX93 and i.MX8ULP, so update the driver to read the PAR for exact TR and RR number.
Also update compatible string for i.MX95 ELE MU.
Cc: Alice Guo alice.guo@nxp.com Cc: Marek Vasut marex@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com --- drivers/misc/imx_ele/ele_mu.c | 25 +++++++++++++++---------- 1 file changed, 15 insertions(+), 10 deletions(-)
diff --git a/drivers/misc/imx_ele/ele_mu.c b/drivers/misc/imx_ele/ele_mu.c index 0cf81f33ba5..f5ba3a4ffa5 100644 --- a/drivers/misc/imx_ele/ele_mu.c +++ b/drivers/misc/imx_ele/ele_mu.c @@ -21,8 +21,6 @@ struct imx8ulp_mu {
#define MU_SR_TE0_MASK BIT(0) #define MU_SR_RF0_MASK BIT(0) -#define MU_TR_COUNT 8 -#define MU_RR_COUNT 4
void mu_hal_init(ulong base) { @@ -36,10 +34,11 @@ int mu_hal_sendmsg(ulong base, u32 reg_index, u32 msg) { struct mu_type *mu_base = (struct mu_type *)base; u32 mask = MU_SR_TE0_MASK << reg_index; - u32 val; + u32 val, tr_num; int ret;
- assert(reg_index < MU_TR_COUNT); + tr_num = readl(&mu_base->par) & 0xFF; + assert(reg_index < tr_num);
debug("sendmsg tsr 0x%x\n", readl(&mu_base->tsr));
@@ -61,11 +60,12 @@ int mu_hal_receivemsg(ulong base, u32 reg_index, u32 *msg) { struct mu_type *mu_base = (struct mu_type *)base; u32 mask = MU_SR_RF0_MASK << reg_index; - u32 val; + u32 val, rr_num; int ret; u32 count = 10;
- assert(reg_index < MU_RR_COUNT); + rr_num = (readl(&mu_base->par) & 0xFF00) >> 8; + assert(reg_index < rr_num);
debug("receivemsg rsr 0x%x\n", readl(&mu_base->rsr));
@@ -96,7 +96,7 @@ static int imx8ulp_mu_read(struct mu_type *base, void *data) { struct ele_msg *msg = (struct ele_msg *)data; int ret; - u8 count = 0; + u8 count = 0, rr_num;
if (!msg) return -EINVAL; @@ -113,9 +113,11 @@ static int imx8ulp_mu_read(struct mu_type *base, void *data) return -EINVAL; }
+ rr_num = (readl(&base->par) & 0xFF00) >> 8; + /* Read remaining words */ while (count < msg->size) { - ret = mu_hal_receivemsg((ulong)base, count % MU_RR_COUNT, + ret = mu_hal_receivemsg((ulong)base, count % rr_num, &msg->data[count - 1]); if (ret) return ret; @@ -129,7 +131,7 @@ static int imx8ulp_mu_write(struct mu_type *base, void *data) { struct ele_msg *msg = (struct ele_msg *)data; int ret; - u8 count = 0; + u8 count = 0, tr_num;
if (!msg) return -EINVAL; @@ -144,9 +146,11 @@ static int imx8ulp_mu_write(struct mu_type *base, void *data) return ret; count++;
+ tr_num = readl(&base->par) & 0xFF; + /* Write remaining words */ while (count < msg->size) { - ret = mu_hal_sendmsg((ulong)base, count % MU_TR_COUNT, + ret = mu_hal_sendmsg((ulong)base, count % tr_num, msg->data[count - 1]); if (ret) return ret; @@ -229,6 +233,7 @@ static struct misc_ops imx8ulp_mu_ops = { static const struct udevice_id imx8ulp_mu_ids[] = { { .compatible = "fsl,imx8ulp-mu" }, { .compatible = "fsl,imx93-mu-s4" }, + { .compatible = "fsl,imx95-mu-ele" }, { } };
Applied both, thanks.
Fabio Estevam
Peng Fan (OSS)
