[U-Boot] [PATCH v1] rockchip: video: mipi: Modify variable type for arm32 compatibility
Some address relevant varibable is defined originally as u64. To compatible with arm32, this patch change them to "void __iomem *" type.
Signed-off-by: Eric Gao eric.gao@rock-chips.com
drivers/video/rockchip/rk_mipi.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_mipi.c index ad00397..af7656e 100644 --- a/drivers/video/rockchip/rk_mipi.c +++ b/drivers/video/rockchip/rk_mipi.c @@ -76,13 +76,13 @@ static int rk_mipi_read_timing(struct udevice *dev, * use define in rk_mipi.h directly for this parameter * @val: value that will be write to specified bits of register */ -static void rk_mipi_dsi_write(u32 regs, u32 reg, u32 val) +static void rk_mipi_dsi_write(void __iomem *regs, u32 reg, u32 val) { u32 dat; u32 mask; u32 offset = (reg >> OFFSET_SHIFT) & 0xff; u32 bits = (reg >> BITS_SHIFT) & 0xff; - u64 addr = (reg >> ADDR_SHIFT) + regs; + void __iomem *addr = (reg >> ADDR_SHIFT) + regs;
/* Mask for specifiled bits,the corresponding bits will be clear */ mask = ~((0xffffffff << offset) & (0xffffffff >> (32 - offset - bits))); @@ -108,7 +108,7 @@ static int rk_mipi_dsi_enable(struct udevice *dev, int node, timing_node; int val; struct rk_mipi_priv *priv = dev_get_priv(dev); - u64 regs = (u64)priv->regs; + void __iomem *regs = priv->regs; struct display_plat *disp_uc_plat = dev_get_uclass_platdata(dev); u32 txbyte_clk = priv->txbyte_clk; u32 txesc_clk = priv->txesc_clk; @@ -224,7 +224,7 @@ static int rk_mipi_dsi_enable(struct udevice *dev, }
/* rk mipi dphy write function. It is used to write test data to dphy */ -static void rk_mipi_phy_write(u32 regs, unsigned char test_code, +static void rk_mipi_phy_write(void __iomem *regs, unsigned char test_code, unsigned char *test_data, unsigned char size) { int i = 0; @@ -253,7 +253,7 @@ static int rk_mipi_phy_enable(struct udevice *dev) { int i; struct rk_mipi_priv *priv = dev_get_priv(dev); - u64 regs = (u64)priv->regs; + void __iomem *regs = priv->regs; u64 fbdiv; u64 prediv = 1; u32 max_fbdiv = 512;
Just a few nitpicks regarding typing the pointers and base-addresses.
- @val: value that will be write to specified bits of register
I’d tend towards a uintptr_t here…
- void __iomem *addr = (reg >> ADDR_SHIFT) + regs;
The register at that address is a u32, so why not make it ‘u32 __iomem *addr’?
- void __iomem *regs = priv->regs; struct display_plat *disp_uc_plat = dev_get_uclass_platdata(dev); u32 txbyte_clk = priv->txbyte_clk; u32 txesc_clk = priv->txesc_clk;
Based on a different discussion I had in the USB context a few days back, I’d tend towards ‘uintptr_t’ when we just want to pass an integer representation of a base-address around.
- void __iomem *regs = priv->regs; u64 fbdiv; u64 prediv = 1; u32 max_fbdiv = 512;
-- 1.9.1
Dr. Philipp Tomsich
Eric Gao
