[U-Boot] [PATCH 1/3] mpc8569mds: fix CONFIG_ENV_SIZE
CONFIG_ENV_SIZE of MPC8569MDS was wrongly set to CONFIG_ENV_SECT_SIZE which is 128KB, so it took longer time to do crc32 calculation for ENV than it should do. It causes the bootup for MPC8569MDS significantly slow. This patch fixs it to 0x2000(8KB), also fix the comment for CONFIG_ENV_SECT_SIZE to correct size.
Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- include/configs/MPC8569MDS.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 8ffd458..936f1af 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -505,8 +505,8 @@ extern unsigned long get_clock_freq(void); #else #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 256K(one sector) for env */ -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ +#define CONFIG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */
The original code maps boot flash as non-cacheable region. When calling relocate_code in flash to copy u-boot from flash to ddr, every loop copy command is read from flash. The flash read speed will be the bottleneck, which consuming long time to do this operation. To resovle this, map the boot flash as write-through cache via tlb. And set tlb to remap the flash after code executing in ddr, to confirm flash erase operation properly done.
Signed-off-by: Kai.Jiang Kai.Jiang@freescale.com --- board/freescale/mpc8569mds/mpc8569mds.c | 25 +++++++++++++++++++++++++ board/freescale/mpc8569mds/tlb.c | 15 ++++++++++----- include/configs/MPC8569MDS.h | 3 ++- 3 files changed, 37 insertions(+), 6 deletions(-)
diff --git a/board/freescale/mpc8569mds/mpc8569mds.c b/board/freescale/mpc8569mds/mpc8569mds.c index 01b7dcb..7028ce8 100644 --- a/board/freescale/mpc8569mds/mpc8569mds.c +++ b/board/freescale/mpc8569mds/mpc8569mds.c @@ -211,6 +211,31 @@ int board_early_init_f (void) return 0; }
+int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_NAND_BASE; + const u8 flash_esel = 0; + + /* + * Remap Boot flash to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_NAND_BASE, /* tlb, epn, rpn */ + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, /* perms, wimge */ + 0, flash_esel, /* ts, esel */ + BOOKE_PAGESZ_64M, 1); /* tsize, iprot */ + + return 0; +} + int checkboard (void) { printf ("Board: 8569 MDS\n"); diff --git a/board/freescale/mpc8569mds/tlb.c b/board/freescale/mpc8569mds/tlb.c index 73dcc3e..f852fc3 100644 --- a/board/freescale/mpc8569mds/tlb.c +++ b/board/freescale/mpc8569mds/tlb.c @@ -1,5 +1,5 @@ /* - * Copyright 2009 Freescale Semiconductor, Inc. + * Copyright 2009-2010 Freescale Semiconductor, Inc. * * (C) Copyright 2000 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -46,15 +46,20 @@ struct fsl_e_tlb_entry tlb_table[] = {
/* TLB 1 Initializations */ /* - * TLBe 0: 64M Non-cacheable, guarded + * TLBe 0: 64M write-through, guarded * Out of reset this entry is only 4K. - * 0xfc000000 256K NAND FLASH (CS3) - * 0xfe000000 32M NOR FLASH (CS0) + * 0xfc000000 32MB NAND FLASH (CS3) + * 0xfe000000 32MB NOR FLASH (CS0) */ +#ifdef CONFIG_NAND_SPL SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), +#else + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_W|MAS2_G, 0, 0, BOOKE_PAGESZ_64M, 1), - +#endif /* * TLBe 1: 256KB Non-cacheable, guarded * 0xf8000000 32K BCSR diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 936f1af..95c0a9f 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2009 Freescale Semiconductor, Inc. + * Copyright (C) 2009-2010 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -74,6 +74,7 @@ extern unsigned long get_clock_freq(void); #define CONFIG_ENABLE_36BIT_PHYS 1
#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */ +#define CONFIG_BOARD_EARLY_INIT_R 1 #define CONFIG_HWCONFIG
#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */
On Sep 29, 2010, at 12:31 PM, Haiying.Wang@freescale.com Haiying.Wang@freescale.com wrote:
applied to 85xx
- k
Enable half drive strength, set RTT to 60Ohm and set write leveling override.
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- board/freescale/mpc8569mds/ddr.c | 16 +++++++++++++--- 1 files changed, 13 insertions(+), 3 deletions(-)
diff --git a/board/freescale/mpc8569mds/ddr.c b/board/freescale/mpc8569mds/ddr.c index e938788..e3f5b4a 100644 --- a/board/freescale/mpc8569mds/ddr.c +++ b/board/freescale/mpc8569mds/ddr.c @@ -77,8 +77,18 @@ void fsl_ddr_board_options(memctl_options_t *popts, popts->write_data_delay = 2;
/* - * Factors to consider for half-strength driver enable: - * - number of DIMMs installed + * Enable half drive strength */ - popts->half_strength_driver_enable = 0; + popts->half_strength_driver_enable = 1; + + /* Write leveling override */ + popts->wrlvl_en = 1; + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xa; + popts->wrlvl_start = 0x4; + + /* Rtt and Rtt_W override */ + popts->rtt_override = 1; + popts->rtt_override_value = DDR3_RTT_60_OHM; + popts->rtt_wr_override_value = 0; /* Rtt_WR= dynamic ODT off */ }
applied to 85xx
- k
Kumar Gala
