[U-Boot] [U-boot] [PATCH] mtd: nand: davinci: add header file for driver definitions
The definitions inside emif_defs.h concern davinci nand driver and should be in it's header. So create header file for davinci nand driver and move definitions from emif_defs.h to it.
Acked-by: Vitaly Andrianov vitalya@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com --- arch/arm/cpu/armv7/keystone/aemif.c | 2 +- arch/arm/include/asm/arch-keystone/aemif.h | 16 ++++++++++ arch/arm/include/asm/arch-keystone/nand_defs.h | 23 -------------- drivers/mtd/nand/davinci_nand.c | 3 +- .../emif_defs.h => drivers/mtd/nand/davinci_nand.h | 35 +++++++++------------- 5 files changed, 32 insertions(+), 47 deletions(-) create mode 100644 arch/arm/include/asm/arch-keystone/aemif.h delete mode 100644 arch/arm/include/asm/arch-keystone/nand_defs.h rename arch/arm/include/asm/arch-keystone/emif_defs.h => drivers/mtd/nand/davinci_nand.h (57%)
diff --git a/arch/arm/cpu/armv7/keystone/aemif.c b/arch/arm/cpu/armv7/keystone/aemif.c index 9b26886..9ba1549 100644 --- a/arch/arm/cpu/armv7/keystone/aemif.c +++ b/arch/arm/cpu/armv7/keystone/aemif.c @@ -10,7 +10,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/clock.h> -#include <asm/arch/emif_defs.h> +#include <../drivers/mtd/nand/davinci_nand.h>
#define AEMIF_CFG_SELECT_STROBE(v) ((v) ? 1 << 31 : 0) #define AEMIF_CFG_EXTEND_WAIT(v) ((v) ? 1 << 30 : 0) diff --git a/arch/arm/include/asm/arch-keystone/aemif.h b/arch/arm/include/asm/arch-keystone/aemif.h new file mode 100644 index 0000000..2dac747 --- /dev/null +++ b/arch/arm/include/asm/arch-keystone/aemif.h @@ -0,0 +1,16 @@ +/* + * emif definitions to re-use davinci emif driver on Keystone2 + * + * (C) Copyright 2012-2014 + * Texas Instruments Incorporated, <www.ti.com> + * (C) Copyright 2007 Sergey Kubushyn ksi@koi8.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _AEMIF_H_ +#define _AEMIF_H_ + +#include <asm/arch/hardware.h> + + +#endif diff --git a/arch/arm/include/asm/arch-keystone/nand_defs.h b/arch/arm/include/asm/arch-keystone/nand_defs.h deleted file mode 100644 index 58417db..0000000 --- a/arch/arm/include/asm/arch-keystone/nand_defs.h +++ /dev/null @@ -1,23 +0,0 @@ -/* - * nand driver definitions to re-use davinci nand driver on Keystone2 - * - * (C) Copyright 2012-2014 - * Texas Instruments Incorporated, <www.ti.com> - * (C) Copyright 2007 Sergey Kubushyn ksi@koi8.net - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _NAND_DEFS_H_ -#define _NAND_DEFS_H_ - -#include <asm/arch/hardware.h> -#include <linux/mtd/nand.h> - -#define MASK_CLE 0x4000 -#define MASK_ALE 0x2000 - -#define NAND_READ_START 0x00 -#define NAND_READ_END 0x30 -#define NAND_STATUS 0x70 - -#endif diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c index 75b03a7..bacf1f1 100644 --- a/drivers/mtd/nand/davinci_nand.c +++ b/drivers/mtd/nand/davinci_nand.c @@ -32,8 +32,7 @@ #include <common.h> #include <asm/io.h> #include <nand.h> -#include <asm/arch/nand_defs.h> -#include <asm/arch/emif_defs.h> +#include "davinci_nand.h"
/* Definitions for 4-bit hardware ECC */ #define NAND_TIMEOUT 10240 diff --git a/arch/arm/include/asm/arch-keystone/emif_defs.h b/drivers/mtd/nand/davinci_nand.h similarity index 57% rename from arch/arm/include/asm/arch-keystone/emif_defs.h rename to drivers/mtd/nand/davinci_nand.h index a3378aa..db8d896 100644 --- a/arch/arm/include/asm/arch-keystone/emif_defs.h +++ b/drivers/mtd/nand/davinci_nand.h @@ -1,16 +1,22 @@ /* - * emif definitions to re-use davinci emif driver on Keystone2 + * NAND Flash Driver * - * (C) Copyright 2012-2014 - * Texas Instruments Incorporated, <www.ti.com> - * (C) Copyright 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2006-2014 Texas Instruments. * - * SPDX-License-Identifier: GPL-2.0+ + * Based on Linux DaVinci NAND driver by TI. */ -#ifndef _EMIF_DEFS_H_ -#define _EMIF_DEFS_H_
-#include <asm/arch/hardware.h> +#ifndef _DAVINCI_NAND_H_ +#define _DAVINCI_NAND_H_ + +#include <linux/mtd/nand.h> + +#define MASK_CLE 0x4000 +#define MASK_ALE 0x2000 + +#define NAND_READ_START 0x00 +#define NAND_READ_END 0x30 +#define NAND_STATUS 0x70
struct davinci_emif_regs { uint32_t ercsr; @@ -57,17 +63,4 @@ struct davinci_emif_regs { #define DAVINCI_NANDFCR_4BIT_ECC_START (1 << 12) #define DAVINCI_NANDFCR_4BIT_CALC_START (1 << 13)
-/* Chip Select setup */ -#define DAVINCI_ABCR_STROBE_SELECT (1 << 31) -#define DAVINCI_ABCR_EXT_WAIT (1 << 30) -#define DAVINCI_ABCR_WSETUP(n) ((n) << 26) -#define DAVINCI_ABCR_WSTROBE(n) ((n) << 20) -#define DAVINCI_ABCR_WHOLD(n) ((n) << 17) -#define DAVINCI_ABCR_RSETUP(n) ((n) << 13) -#define DAVINCI_ABCR_RSTROBE(n) ((n) << 7) -#define DAVINCI_ABCR_RHOLD(n) ((n) << 4) -#define DAVINCI_ABCR_TA(n) ((n) << 2) -#define DAVINCI_ABCR_ASIZE_16BIT 1 -#define DAVINCI_ABCR_ASIZE_8BIT 0 - #endif
Ivan,
It is difficult to see what is done here. Can you rename the file in a separate patch? Do it similar to what is done in kernel where aemif driver concerns with bus configuration and nand drivers concerns with NAND part of the EMIF driver.
- emif definitions to re-use davinci emif driver on Keystone2
- (C) Copyright 2012-2014
- (C) Copyright 2007 Sergey Kubushyn ksi@koi8.net
- nand driver definitions to re-use davinci nand driver on Keystone2
- NAND Flash Driver
- Copyright (C) 2006-2014 Texas Instruments.
- Based on Linux DaVinci NAND driver by TI.
- #endif
Ivan,
Yes, you are right. I think there is no reason to rename it at all, as it'll be deleted in the following patch. I'll hold it as is and remove it in the patch "[U-boot] [PATCH] ARM: keystone: aemif: move aemif driver to drivers/memory/ti-aemif.c"
Thanks.
Ivan Khoronzhuk
Murali Karicheri
