[U-Boot] [PATCH 4/5] standard SCI support
h8300 have simlar sh serial I/F. It without FIFO. This changes support of no FIFO.
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- drivers/serial/serial_sh.c | 74 +++++++++++++++++++++++++++++++--- drivers/serial/serial_sh.h | 93 +++++++++++++++----------------------------- 2 files changed, 98 insertions(+), 69 deletions(-)
diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index fcf69ab..b6c800d 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -39,18 +39,73 @@ # error "Default SCIF doesn't set....." #endif
-#if defined(CONFIG_SCIF_A) - #define SCIF_BASE_PORT PORT_SCIFA +#if defined(CONFIG_SCI) +# define PORT_TYPE PORT_SCI +#elif defined(CONFIG_SCIF_A) +# define PORT_TYPE PORT_SCIFA #else - #define SCIF_BASE_PORT PORT_SCIF +# define PORT_TYPE PORT_SCIF #endif
static struct uart_port sh_sci = { .membase = (unsigned char*)SCIF_BASE, .mapbase = SCIF_BASE, - .type = SCIF_BASE_PORT, + .type = PORT_TYPE, };
+/* TDRE / RDRF emulation for RX610 */ +/* RX610's SCI don't have TDRE and RDRF in SSR + This part emulate these flags of IR */ +#if defined(CONFIG_CPU_RX610) + +#define port_to_irq(port) ((((port)->mapbase - 0x88240) / 8) + 214) +#define read_ir(irq) __raw_readb((unsigned char *)(0x00087000 + (irq))) +#define clear_ir(irq) __raw_writeb(0, (unsigned char *)(0x00087000 + (irq))) + +#define write_ier(flg, irq) \ +do { \ + unsigned char ier = __raw_readb((unsigned char *)(0x00087200 + ((irq) >> 3))); \ + ier &= ~(1 << ((irq) & 7)); \ + if (flg) \ + ier |= (1 << ((irq) & 7)); \ + __raw_writeb(ier, (unsigned char *)(0x00087200 + ((irq) >> 3))); \ +} while(0) + + +static unsigned int sci_SCxSR_in(struct uart_port *port) +{ + int irq = port_to_irq(port); + unsigned char ssr; + ssr = __raw_readb(port->membase + 4); + ssr &= ~0xc0; + /* map to RXI -> RDRF and TXI -> TDRE */ + ssr |= read_ir(irq + 1) << 6 | read_ir(irq + 2) << 7; + return ssr; +} + +static void sci_SCxSR_out(struct uart_port *port, unsigned int value) +{ + int irq = port_to_irq(port); + /* clear ir */ + if ((value & 0x84) != 0x84) + clear_ir(irq + 2); + if ((value & 0x40) == 0) + clear_ir(irq + 1); + value |= 0xc0; /* b7 and b6 is always 1 */ + value &= ~0x01; /* b0 is always 0 */ + __raw_writeb(value, port->membase + 4); +} + +static void sci_SCSCR_out(struct uart_port *port, unsigned int value) +{ + int irq = port_to_irq(port); + write_ier(value & 0x40, irq + 1); + write_ier(value & 0x80, irq + 2); + /* TXI and RXI always enabled */ + __raw_writeb(value | 0xc0, port->membase + 2); +} +#endif + void serial_setbrg(void) { DECLARE_GLOBAL_DATA_PTR; @@ -99,6 +154,11 @@ static int scif_rxfill(struct uart_port *port) else return sci_in(port, SCRFDR); } +#elif defined(CONFIG_SCI) +static int scif_rxfill(struct uart_port *port) +{ + return (sci_in(port, SCxSR) & SCxSR_RDxF(port))?1:0; +} #else static int scif_rxfill(struct uart_port *port) { @@ -115,12 +175,12 @@ void serial_raw_putc(const char c) { while (1) { /* Tx fifo is empty */ - if (sci_in(&sh_sci, SCxSR) & SCxSR_TEND(&sh_sci)) + if (sci_in(&sh_sci, SCxSR) & SCxSR_TXRDY(&sh_sci)) break; }
sci_out(&sh_sci, SCxTDR, c); - sci_out(&sh_sci, SCxSR, sci_in(&sh_sci, SCxSR) & ~SCxSR_TEND(&sh_sci)); + sci_out(&sh_sci, SCxSR, sci_in(&sh_sci, SCxSR) & ~SCxSR_TXRDY(&sh_sci)); }
void serial_putc(const char c) @@ -156,7 +216,7 @@ int serial_getc_check(void)
status = sci_in(&sh_sci, SCxSR);
- if (status & SCIF_ERRORS) + if (status & SCxSR_ERRORS(&sh_sci)) handle_error(); if (sci_in(&sh_sci, SCLSR) & SCxSR_ORER(&sh_sci)) handle_error(); diff --git a/drivers/serial/serial_sh.h b/drivers/serial/serial_sh.h index e19593c..069aa36 100644 --- a/drivers/serial/serial_sh.h +++ b/drivers/serial/serial_sh.h @@ -14,13 +14,6 @@ struct uart_port { #define PORT_SCIFA 83 #define PORT_SCIFB 93
-#if defined(CONFIG_H83007) || defined(CONFIG_H83068) -#include <asm/regs306x.h> -#endif -#if defined(CONFIG_H8S2678) -#include <asm/regs267x.h> -#endif - #if defined(CONFIG_CPU_SH7706) || \ defined(CONFIG_CPU_SH7707) || \ defined(CONFIG_CPU_SH7708) || \ @@ -126,12 +119,20 @@ struct uart_port { # define SCLSR2\ ((port->mapbase)+SCIF_LSR2_OFFS) /* 16 bit SCIF */ # define SCSCR_INIT(port) 0x38 /* TIE=0,RIE=0, TE=1,RE=1,REIE=1 */ -#elif defined(CONFIG_H83007) || defined(CONFIG_H83068) +#elif defined(CONFIG_CPU_H83007) || \ + defined(CONFIG_CPU_H83068) || \ + defined(CONFIG_CPU_H83069) # define SCSCR_INIT(port) 0x30 /* TIE=0,RIE=0,TE=1,RE=1 */ # define H8300_SCI_DR(ch) (*(volatile char *)(P1DR + h8300_sci_pins[ch].port)) -#elif defined(CONFIG_H8S2678) +# define SCIF0_BASE 0xffffb0 +# define SCIF1_BASE 0xffffb8 +# define SCIF2_BASE 0xffffc0 +#elif defined(CONFIG_CPU_H8S2678) # define SCSCR_INIT(port) 0x30 /* TIE=0,RIE=0,TE=1,RE=1 */ # define H8300_SCI_DR(ch) (*(volatile char *)(P1DR + h8300_sci_pins[ch].port)) +# define SCIF0_BASE 0xffff78 +# define SCIF1_BASE 0xffff80 +# define SCIF2_BASE 0xffff88 #elif defined(CONFIG_CPU_SH7757) # define SCSPTR0 0xfe4b0020 # define SCSPTR1 0xfe4b0020 @@ -202,6 +203,15 @@ struct uart_port { # define SCSPTR3 0xffc60020 /* 16 bit SCIF */ # define SCIF_ORER 0x0001 /* Overrun error bit */ # define SCSCR_INIT(port) 0x38 /* TIE=0,RIE=0,TE=1,RE=1,REIE=1 */ +#elif defined(CONFIG_RX) +# define SCSPTR0 0x00088240 /* 8 bit SCI */ +# define SCSPTR1 0x00088248 /* 8 bit SCI */ +# define SCSPTR2 0x00088250 /* 8 bit SCI */ +# define SCSPTR3 0x00088258 /* 8 bit SCI */ +# define SCSPTR4 0x00088260 /* 8 bit SCI */ +# define SCSPTR5 0x00088268 /* 8 bit SCI */ +# define SCSPTR6 0x00088270 /* 8 bit SCI */ +# define SCSCR_INIT(port) 0x38 /* TIE=0,RIE=0,TE=1,RE=1,REIE=1 */ #else # error CPU subtype not defined #endif @@ -299,6 +309,8 @@ struct uart_port { ((port)->type == PORT_SCI) ? 0x00 : SCIF_BRK) #define SCxSR_ORER(port)\ (((port)->type == PORT_SCI) ? SCI_ORER : SCIF_ORER) +#define SCxSR_TXRDY(port)\ + (((port)->type == PORT_SCI) ? SCI_TDRE : SCIF_TEND)
#if defined(CONFIG_CPU_SH7705) || \ defined(CONFIG_CPU_SH7720) || \ @@ -369,7 +381,7 @@ static inline void sci_##name##_out(struct uart_port *port,\
#ifdef CONFIG_H8300 /* h8300 don't have SCIF */ -#define CPU_SCIF_FNS(name) \ +#define CPU_SCIF_FNS(name, scif_offset, scif_size) \ static inline unsigned int sci_##name##_in(struct uart_port *port) {\ return 0;\ }\ @@ -437,7 +449,7 @@ static inline void sci_##name##_out(struct uart_port *port,\ sh4_scif_offset, sh4_scif_size) \ CPU_SCIF_FNS(name, sh3_scif_offset, sh3_scif_size) #endif -#elif defined(__H8300H__) || defined(__H8300S__) +#elif defined(CONFIG_H8300) || defined(CONFIG_RX) #define SCIx_FNS(name, sh3_sci_offset, sh3_sci_size,\ sh4_sci_offset, sh4_sci_size, \ sh3_scif_offset, sh3_scif_size,\ @@ -446,7 +458,7 @@ static inline void sci_##name##_out(struct uart_port *port,\ CPU_SCI_FNS(name, h8_sci_offset, h8_sci_size) #define SCIF_FNS(name, sh3_scif_offset, sh3_scif_size,\ sh4_scif_offset, sh4_scif_size) \ - CPU_SCIF_FNS(name) + CPU_SCIF_FNS(name, 0, 0) #elif defined(CONFIG_CPU_SH7723) || defined(CONFIG_CPU_SH7724) #define SCIx_FNS(name, sh4_scifa_offset, sh4_scifa_size,\ sh4_scif_offset, sh4_scif_size) \ @@ -512,6 +524,13 @@ SCIF_FNS(SCFER, 0x10, 16) SCIF_FNS(SCFCR, 0x18, 16) SCIF_FNS(SCFDR, 0x1c, 16) SCIF_FNS(SCLSR, 0x24, 16) +#elif defined(CONFIG_CPU_RX610) +SCIx_FNS(SCSMR, 0x00, 8, 0x00, 8, 0x00, 8, 0x00, 16, 0x00, 8) +SCIx_FNS(SCBRR, 0x02, 8, 0x04, 8, 0x02, 8, 0x04, 8, 0x01, 8) +SCIx_FNS(SCxTDR, 0x06, 8, 0x0c, 8, 0x06, 8, 0x0C, 8, 0x03, 8) +SCIx_FNS(SCxRDR, 0x0a, 8, 0x14, 8, 0x0A, 8, 0x14, 8, 0x05, 8) +SCIF_FNS(SCFCR, 0x0c, 8, 0x18, 16) +SCIF_FNS(SCLSR, 0, 0, 0x28, 16) #else /* reg SCI/SH3 SCI/SH4 SCIF/SH3 SCIF/SH4 SCI/H8*/ /* name off sz off sz off sz off sz off sz*/ @@ -552,48 +571,6 @@ SCIF_FNS(SCLSR, 0, 0, 0x24, 16) #define sci_in(port, reg) sci_##reg##_in(port) #define sci_out(port, reg, value) sci_##reg##_out(port, value)
-/* H8/300 series SCI pins assignment */ -#if defined(__H8300H__) || defined(__H8300S__) -static const struct __attribute__((packed)) { - int port; /* GPIO port no */ - unsigned short rx, tx; /* GPIO bit no */ -} h8300_sci_pins[] = { -#if defined(CONFIG_H83007) || defined(CONFIG_H83068) - { /* SCI0 */ - .port = H8300_GPIO_P9, - .rx = H8300_GPIO_B2, - .tx = H8300_GPIO_B0, - }, - { /* SCI1 */ - .port = H8300_GPIO_P9, - .rx = H8300_GPIO_B3, - .tx = H8300_GPIO_B1, - }, - { /* SCI2 */ - .port = H8300_GPIO_PB, - .rx = H8300_GPIO_B7, - .tx = H8300_GPIO_B6, - } -#elif defined(CONFIG_H8S2678) - { /* SCI0 */ - .port = H8300_GPIO_P3, - .rx = H8300_GPIO_B2, - .tx = H8300_GPIO_B0, - }, - { /* SCI1 */ - .port = H8300_GPIO_P3, - .rx = H8300_GPIO_B3, - .tx = H8300_GPIO_B1, - }, - { /* SCI2 */ - .port = H8300_GPIO_P5, - .rx = H8300_GPIO_B1, - .tx = H8300_GPIO_B0, - } -#endif -}; -#endif - #if defined(CONFIG_CPU_SH7706) || \ defined(CONFIG_CPU_SH7707) || \ defined(CONFIG_CPU_SH7708) || \ @@ -616,12 +593,6 @@ static inline int sci_rxd_in(struct uart_port *port) return __raw_readb(SCSPTR1)&0x01 ? 1 : 0; /* SCI */ return 1; } -#elif defined(__H8300H__) || defined(__H8300S__) -static inline int sci_rxd_in(struct uart_port *port) -{ - int ch = (port->mapbase - SMR0) >> 3; - return (H8300_SCI_DR(ch) & h8300_sci_pins[ch].rx) ? 1 : 0; -} #else /* default case for non-SCI processors */ static inline int sci_rxd_in(struct uart_port *port) { @@ -683,8 +654,6 @@ static inline int scbrr_calc(struct uart_port port, int bps, int clk) return ((clk*2)+16*bps)/(16*bps)-1; } #define SCBRR_VALUE(bps, clk) scbrr_calc(sh_sci, bps, clk) -#elif defined(__H8300H__) || defined(__H8300S__) -#define SCBRR_VALUE(bps, clk) (((clk*1000/32)/bps)-1) #else /* Generic SH */ #define SCBRR_VALUE(bps, clk) ((clk+16*bps)/(32*bps)-1) #endif
2011/3/2 Yoshinori Sato ysato@users.sourceforge.jp:
- .type = PORT_TYPE,
- This part emulate these flags of IR */
<snip>
<snip>
<snip>
Why do you use CPU_RX610 and CONFIG_RX ? Is these necessary for support of H8300 support?
Best regards, Nobuhiro
Nobuhiro Iwamatsu
Yoshinori Sato
