[U-Boot] [PATCH v8 2/9] mips: ath79: add support for AR933x SOCs
This patch enable work for ar933x SOC.
Signed-off-by: Wills Wang wills.wang@live.com ---
Changes in v8: - Fix multi-line comment for ar933x
Changes in v7: - Use CKSEGxADDR instead of KSEGxADDR for ar933x
Changes in v6: - Remove board.c - Define magic value in ddr.c
Changes in v5: - Add ddr.c for ar933x
Changes in v4: - Add clk.c for ar933x
arch/mips/mach-ath79/Kconfig | 9 + arch/mips/mach-ath79/Makefile | 2 + arch/mips/mach-ath79/ar933x/Makefile | 7 + arch/mips/mach-ath79/ar933x/clk.c | 89 ++++++++ arch/mips/mach-ath79/ar933x/ddr.c | 333 ++++++++++++++++++++++++++++ arch/mips/mach-ath79/ar933x/lowlevel_init.S | 280 +++++++++++++++++++++++ 6 files changed, 720 insertions(+) create mode 100644 arch/mips/mach-ath79/ar933x/Makefile create mode 100644 arch/mips/mach-ath79/ar933x/clk.c create mode 100644 arch/mips/mach-ath79/ar933x/ddr.c create mode 100644 arch/mips/mach-ath79/ar933x/lowlevel_init.S
diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig index 7d8ce09..ab93d92 100644 --- a/arch/mips/mach-ath79/Kconfig +++ b/arch/mips/mach-ath79/Kconfig @@ -4,4 +4,13 @@ menu "QCA/Atheros 7xxx/9xxx platforms" config SYS_SOC default "ath79"
+config SOC_AR933X + bool + select SUPPORTS_BIG_ENDIAN + select SUPPORTS_CPU_MIPS32_R1 + select SUPPORTS_CPU_MIPS32_R2 + select MIPS_TUNE_24KC + help + This supports QCA/Atheros ar933x family SOCs. + endmenu diff --git a/arch/mips/mach-ath79/Makefile b/arch/mips/mach-ath79/Makefile index 6203cf0..9b9447e 100644 --- a/arch/mips/mach-ath79/Makefile +++ b/arch/mips/mach-ath79/Makefile @@ -5,3 +5,5 @@ obj-y += reset.o obj-y += cpu.o obj-y += dram.o + +obj-$(CONFIG_SOC_AR933X) += ar933x/ \ No newline at end of file diff --git a/arch/mips/mach-ath79/ar933x/Makefile b/arch/mips/mach-ath79/ar933x/Makefile new file mode 100644 index 0000000..fd74f0c --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/Makefile @@ -0,0 +1,7 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += clk.o +obj-y += ddr.o +obj-y += lowlevel_init.o diff --git a/arch/mips/mach-ath79/ar933x/clk.c b/arch/mips/mach-ath79/ar933x/clk.c new file mode 100644 index 0000000..9fcd496 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/clk.c @@ -0,0 +1,89 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/reset.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u32 ar933x_get_xtal(void) +{ + u32 val; + + val = get_bootstrap(); + if (val & AR933X_BOOTSTRAP_REF_CLK_40) + return 40000000; + else + return 25000000; +} + +int get_serial_clock(void) +{ + return ar933x_get_xtal(); +} + +int get_clocks(void) +{ + void __iomem *regs; + u32 val, xtal, pll, div; + + regs = map_physmem(AR71XX_PLL_BASE, AR71XX_PLL_SIZE, + MAP_NOCACHE); + xtal = ar933x_get_xtal(); + val = readl(regs + AR933X_PLL_CPU_CONFIG_REG); + + /* VCOOUT = XTAL * DIV_INT */ + div = (val >> AR933X_PLL_CPU_CONFIG_REFDIV_SHIFT) + & AR933X_PLL_CPU_CONFIG_REFDIV_MASK; + pll = xtal / div; + + /* PLLOUT = VCOOUT * (1/2^OUTDIV) */ + div = (val >> AR933X_PLL_CPU_CONFIG_NINT_SHIFT) + & AR933X_PLL_CPU_CONFIG_NINT_MASK; + pll *= div; + div = (val >> AR933X_PLL_CPU_CONFIG_OUTDIV_SHIFT) + & AR933X_PLL_CPU_CONFIG_OUTDIV_MASK; + if (!div) + div = 1; + pll >>= div; + + val = readl(regs + AR933X_PLL_CLK_CTRL_REG); + + /* CPU_CLK = PLLOUT / CPU_POST_DIV */ + div = ((val >> AR933X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT) + & AR933X_PLL_CLK_CTRL_CPU_POST_DIV_MASK) + 1; + gd->cpu_clk = pll / div; + + /* DDR_CLK = PLLOUT / DDR_POST_DIV */ + div = ((val >> AR933X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT) + & AR933X_PLL_CLK_CTRL_DDR_POST_DIV_MASK) + 1; + gd->mem_clk = pll / div; + + /* AHB_CLK = PLLOUT / AHB_POST_DIV */ + div = ((val >> AR933X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT) + & AR933X_PLL_CLK_CTRL_AHB_POST_DIV_MASK) + 1; + gd->bus_clk = pll / div; + + return 0; +} + +ulong get_bus_freq(ulong dummy) +{ + if (!gd->bus_clk) + get_clocks(); + return gd->bus_clk; +} + +ulong get_ddr_freq(ulong dummy) +{ + if (!gd->mem_clk) + get_clocks(); + return gd->mem_clk; +} diff --git a/arch/mips/mach-ath79/ar933x/ddr.c b/arch/mips/mach-ath79/ar933x/ddr.c new file mode 100644 index 0000000..74e8e80 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/ddr.c @@ -0,0 +1,333 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * Based on Atheros LSDK/QSDK + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/reset.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define DDR_CTRL_UPD_EMR3S BIT(5) +#define DDR_CTRL_UPD_EMR2S BIT(4) +#define DDR_CTRL_PRECHARGE BIT(3) +#define DDR_CTRL_AUTO_REFRESH BIT(2) +#define DDR_CTRL_UPD_EMRS BIT(1) +#define DDR_CTRL_UPD_MRS BIT(0) + +#define DDR_REFRESH_EN (1 << 14) +#define DDR_REFRESH_M 0x3ff +#define DDR_REFRESH(x) ((x) & 0x3ff) +#define DDR_REFRESH_VAL_25M (DDR_REFRESH_EN | DDR_REFRESH(390)) +#define DDR_REFRESH_VAL_40M (DDR_REFRESH_EN | DDR_REFRESH(624)) + +#define DDR_TRAS_S 0 +#define DDR_TRAS_M 0x1f +#define DDR_TRAS(x) ((x) << DDR_TRAS_S) +#define DDR_TRCD_M 0xf +#define DDR_TRCD_S 5 +#define DDR_TRCD(x) ((x) << DDR_TRCD_S) +#define DDR_TRP_M 0xf +#define DDR_TRP_S 9 +#define DDR_TRP(x) ((x) << DDR_TRP_S) +#define DDR_TRRD_M 0xf +#define DDR_TRRD_S 13 +#define DDR_TRRD(x) ((x) << DDR_TRRD_S) +#define DDR_TRFC_M 0x7f +#define DDR_TRFC_S 17 +#define DDR_TRFC(x) ((x) << DDR_TRFC_S) +#define DDR_TMRD_M 0xf +#define DDR_TMRD_S 23 +#define DDR_TMRD(x) ((x) << DDR_TMRD_S) +#define DDR_CAS_L_M 0x17 +#define DDR_CAS_L_S 27 +#define DDR_CAS_L(x) (((x) & DDR_CAS_L_M) << DDR_CAS_L_S) +#define DDR_OPEN (1 << 30) +#define DDR_CONF_REG_VAL (DDR_TRAS(16) | DDR_TRCD(6) | \ + DDR_TRP(6) | DDR_TRRD(4) | \ + DDR_TRFC(30) | DDR_TMRD(15) | \ + DDR_CAS_L(7) | DDR_OPEN) + +#define DDR_BURST_LEN_S 0 +#define DDR_BURST_LEN_M 0xf +#define DDR_BURST_LEN(x) ((x) << DDR_BURST_LEN_S) +#define DDR_BURST_TYPE (1 << 4) +#define DDR_CNTL_OE_EN (1 << 5) +#define DDR_PHASE_SEL (1 << 6) +#define DDR_CKE (1 << 7) +#define DDR_TWR_S 8 +#define DDR_TWR_M 0xf +#define DDR_TWR(x) ((x) << DDR_TWR_S) +#define DDR_TRTW_S 12 +#define DDR_TRTW_M 0x1f +#define DDR_TRTW(x) ((x) << DDR_TRTW_S) +#define DDR_TRTP_S 17 +#define DDR_TRTP_M 0xf +#define DDR_TRTP(x) ((x) << DDR_TRTP_S) +#define DDR_TWTR_S 21 +#define DDR_TWTR_M 0x1f +#define DDR_TWTR(x) ((x) << DDR_TWTR_S) +#define DDR_G_OPEN_L_S 26 +#define DDR_G_OPEN_L_M 0xf +#define DDR_G_OPEN_L(x) ((x) << DDR_G_OPEN_L_S) +#define DDR_HALF_WIDTH_LOW (1 << 31) +#define DDR_CONF2_REG_VAL (DDR_BURST_LEN(8) | DDR_CNTL_OE_EN | \ + DDR_CKE | DDR_TWR(6) | DDR_TRTW(14) | \ + DDR_TRTP(8) | DDR_TWTR(14) | \ + DDR_G_OPEN_L(7) | DDR_HALF_WIDTH_LOW) + +#define DDR2_CONF_TWL_S 10 +#define DDR2_CONF_TWL_M 0xf +#define DDR2_CONF_TWL(x) (((x) & DDR2_CONF_TWL_M) << DDR2_CONF_TWL_S) +#define DDR2_CONF_ODT BIT(9) +#define DDR2_CONF_TFAW_S 2 +#define DDR2_CONF_TFAW_M 0x3f +#define DDR2_CONF_TFAW(x) (((x) & DDR2_CONF_TFAW_M) << DDR2_CONF_TFAW_S) +#define DDR2_CONF_EN BIT(0) +#define DDR2_CONF_VAL (DDR2_CONF_TWL(2) | DDR2_CONF_ODT | \ + DDR2_CONF_TFAW(22) | DDR2_CONF_EN) + +#define DDR1_EXT_MODE_VAL 0x02 +#define DDR2_EXT_MODE_VAL 0x402 +#define DDR2_EXT_MODE_OCD_VAL 0x382 +#define DDR1_MODE_DLL_VAL 0x133 +#define DDR2_MODE_DLL_VAL 0x100 +#define DDR1_MODE_VAL 0x33 +#define DDR2_MODE_VAL 0xa33 +#define DDR_TAP_VAL0 0x08 +#define DDR_TAP_VAL1 0x09 + +void ddr_init(void) +{ + void __iomem *regs; + u32 val; + + regs = map_physmem(AR71XX_DDR_CTRL_BASE, AR71XX_DDR_CTRL_SIZE, + MAP_NOCACHE); + + writel(DDR_CONF_REG_VAL, regs + AR71XX_DDR_REG_CONFIG); + writel(DDR_CONF2_REG_VAL, regs + AR71XX_DDR_REG_CONFIG2); + + val = get_bootstrap(); + if (val & AR933X_BOOTSTRAP_DDR2) { + /* AHB maximum timeout */ + writel(0xfffff, regs + AR933X_DDR_REG_TIMEOUT_MAX); + + /* Enable DDR2 */ + writel(DDR2_CONF_VAL, regs + AR933X_DDR_REG_DDR2_CONFIG); + + /* Precharge All */ + writel(DDR_CTRL_PRECHARGE, regs + AR71XX_DDR_REG_CONTROL); + + /* Disable High Temperature Self-Refresh, Full Array */ + writel(0x00, regs + AR933X_DDR_REG_EMR2); + + /* Extended Mode Register 2 Set (EMR2S) */ + writel(DDR_CTRL_UPD_EMR2S, regs + AR71XX_DDR_REG_CONTROL); + + writel(0x00, regs + AR933X_DDR_REG_EMR3); + + /* Extended Mode Register 3 Set (EMR3S) */ + writel(DDR_CTRL_UPD_EMR3S, regs + AR71XX_DDR_REG_CONTROL); + + /* Enable DLL, Full strength, ODT Disabled */ + writel(0x00, regs + AR71XX_DDR_REG_EMR); + + /* Extended Mode Register Set (EMRS) */ + writel(DDR_CTRL_UPD_EMRS, regs + AR71XX_DDR_REG_CONTROL); + + /* Reset DLL */ + writel(DDR2_MODE_DLL_VAL, regs + AR71XX_DDR_REG_MODE); + + /* Mode Register Set (MRS) */ + writel(DDR_CTRL_UPD_MRS, regs + AR71XX_DDR_REG_CONTROL); + + /* Precharge All */ + writel(DDR_CTRL_PRECHARGE, regs + AR71XX_DDR_REG_CONTROL); + + /* Auto Refresh */ + writel(DDR_CTRL_AUTO_REFRESH, regs + AR71XX_DDR_REG_CONTROL); + writel(DDR_CTRL_AUTO_REFRESH, regs + AR71XX_DDR_REG_CONTROL); + + /* Write recovery (WR) 6 clock, CAS Latency 3, Burst Length 8 */ + writel(DDR2_MODE_VAL, regs + AR71XX_DDR_REG_MODE); + /* Mode Register Set (MRS) */ + writel(DDR_CTRL_UPD_MRS, regs + AR71XX_DDR_REG_CONTROL); + + /* Enable OCD defaults, Enable DLL, Reduced Drive Strength */ + writel(DDR2_EXT_MODE_OCD_VAL, regs + AR71XX_DDR_REG_EMR); + + /* Extended Mode Register Set (EMRS) */ + writel(DDR_CTRL_UPD_EMRS, regs + AR71XX_DDR_REG_CONTROL); + + /* OCD exit, Enable DLL, Enable /DQS, Reduced Drive Strength */ + writel(DDR2_EXT_MODE_VAL, regs + AR71XX_DDR_REG_EMR); + /* Extended Mode Register Set (EMRS) */ + writel(DDR_CTRL_UPD_EMRS, regs + AR71XX_DDR_REG_CONTROL); + + /* Refresh time control */ + if (val & AR933X_BOOTSTRAP_REF_CLK_40) + writel(DDR_REFRESH_VAL_40M, regs + + AR71XX_DDR_REG_REFRESH); + else + writel(DDR_REFRESH_VAL_25M, regs + + AR71XX_DDR_REG_REFRESH); + + /* DQS 0 Tap Control */ + writel(DDR_TAP_VAL0, regs + AR71XX_DDR_REG_TAP_CTRL0); + + /* DQS 1 Tap Control */ + writel(DDR_TAP_VAL1, regs + AR71XX_DDR_REG_TAP_CTRL1); + + /* For 16-bit DDR */ + writel(0xff, regs + AR71XX_DDR_REG_RD_CYCLE); + } else { + /* AHB maximum timeout */ + writel(0xfffff, regs + AR933X_DDR_REG_TIMEOUT_MAX); + + /* Precharge All */ + writel(DDR_CTRL_PRECHARGE, regs + AR71XX_DDR_REG_CONTROL); + + /* Reset DLL, Burst Length 8, CAS Latency 3 */ + writel(DDR1_MODE_DLL_VAL, regs + AR71XX_DDR_REG_MODE); + + /* Forces an MRS update cycle in DDR */ + writel(DDR_CTRL_UPD_MRS, regs + AR71XX_DDR_REG_CONTROL); + + /* Enable DLL, Full strength */ + writel(DDR1_EXT_MODE_VAL, regs + AR71XX_DDR_REG_EMR); + + /* Extended Mode Register Set (EMRS) */ + writel(DDR_CTRL_UPD_EMRS, regs + AR71XX_DDR_REG_CONTROL); + + /* Precharge All */ + writel(DDR_CTRL_PRECHARGE, regs + AR71XX_DDR_REG_CONTROL); + + /* Normal DLL, Burst Length 8, CAS Latency 3 */ + writel(DDR1_MODE_VAL, regs + AR71XX_DDR_REG_MODE); + + /* Mode Register Set (MRS) */ + writel(DDR_CTRL_UPD_MRS, regs + AR71XX_DDR_REG_CONTROL); + + /* Refresh time control */ + if (val & AR933X_BOOTSTRAP_REF_CLK_40) + writel(DDR_REFRESH_VAL_40M, regs + + AR71XX_DDR_REG_REFRESH); + else + writel(DDR_REFRESH_VAL_25M, regs + + AR71XX_DDR_REG_REFRESH); + + /* DQS 0 Tap Control */ + writel(DDR_TAP_VAL0, regs + AR71XX_DDR_REG_TAP_CTRL0); + + /* DQS 1 Tap Control */ + writel(DDR_TAP_VAL1, regs + AR71XX_DDR_REG_TAP_CTRL1); + + /* For 16-bit DDR */ + writel(0xff, regs + AR71XX_DDR_REG_RD_CYCLE); + } +} + +void ddr_tap_tuning(void) +{ + void __iomem *regs; + u32 *addr_k0, *addr_k1, *addr; + u32 val, tap, upper, lower; + int i, j, dir, err, done; + + regs = map_physmem(AR71XX_DDR_CTRL_BASE, AR71XX_DDR_CTRL_SIZE, + MAP_NOCACHE); + + /* Init memory pattern */ + addr = (void *)CKSEG0ADDR(0x2000); + for (i = 0; i < 256; i++) { + val = 0; + for (j = 0; j < 8; j++) { + if (i & (1 << j)) { + if (j % 2) + val |= 0xffff0000; + else + val |= 0x0000ffff; + } + + if (j % 2) { + *addr++ = val; + val = 0; + } + } + } + + err = 0; + done = 0; + dir = 1; + tap = readl(regs + AR71XX_DDR_REG_TAP_CTRL0); + val = tap; + while (!done) { + err = 0; + + /* Update new DDR tap value */ + writel(val, regs + AR71XX_DDR_REG_TAP_CTRL0); + writel(val, regs + AR71XX_DDR_REG_TAP_CTRL1); + + /* Compare DDR with cache */ + for (i = 0; i < 2; i++) { + addr_k1 = (void *)CKSEG1ADDR(0x2000); + addr_k0 = (void *)CKSEG0ADDR(0x2000); + addr = (void *)CKSEG0ADDR(0x3000); + + while (addr_k0 < addr) { + if (*addr_k1++ != *addr_k0++) { + err = 1; + break; + } + } + + if (err) + break; + } + + if (err) { + /* Save upper/lower threshold if error */ + if (dir) { + dir = 0; + val--; + upper = val; + val = tap; + } else { + val++; + lower = val; + done = 1; + } + } else { + /* Try the next value until limitation */ + if (dir) { + if (val < 0x20) { + val++; + } else { + dir = 0; + upper = val; + val = tap; + } + } else { + if (!val) { + lower = val; + done = 1; + } else { + val--; + } + } + } + } + + /* compute an intermediate value and write back */ + val = (upper + lower) / 2; + writel(val, regs + AR71XX_DDR_REG_TAP_CTRL0); + val++; + writel(val, regs + AR71XX_DDR_REG_TAP_CTRL1); +} diff --git a/arch/mips/mach-ath79/ar933x/lowlevel_init.S b/arch/mips/mach-ath79/ar933x/lowlevel_init.S new file mode 100644 index 0000000..1b847f5 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/lowlevel_init.S @@ -0,0 +1,280 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * Based on Atheros LSDK/QSDK and u-boot_mod project + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <mach/ar71xx_regs.h> + +#define SET_BIT(val, bit) ((val) | (1 << (bit))) +#define SET_PLL_PD(val) SET_BIT(val, 30) +#define AHB_DIV_TO_4(val) SET_BIT(SET_BIT(val, 15), 16) +#define PLL_BYPASS(val) SET_BIT(val, 2) + +#define MK_PLL_CONF(divint, refdiv, range, outdiv) \ + (((0x3F & divint) << 10) | \ + ((0x1F & refdiv) << 16) | \ + ((0x1 & range) << 21) | \ + ((0x7 & outdiv) << 23) ) + +#define MK_CLK_CNTL(cpudiv, ddrdiv, ahbdiv) \ + (((0x3 & (cpudiv - 1)) << 5) | \ + ((0x3 & (ddrdiv - 1)) << 10) | \ + ((0x3 & (ahbdiv - 1)) << 15) ) + +/* + * PLL_CPU_CONFIG_VAL + * + * Bit30 is set (CPU_PLLPWD = 1 -> power down control for CPU PLL) + * After PLL configuration we need to clear this bit + * + * Values written into CPU PLL Configuration (CPU_PLL_CONFIG) + * + * bits 10..15 (6bit) DIV_INT (Integer part of the DIV to CPU PLL) + * => 32 (0x20) VCOOUT = XTAL * DIV_INT + * bits 16..20 (5bit) REFDIV (Reference clock divider) + * => 1 (0x1) [Must start at values 1] + * bits 21 (1bit) RANGE (VCO frequency range of the CPU PLL) + * => 0 (0x0) [Doesn't impact clock values] + * bits 23..25 (3bit) OUTDIV (Ratio between VCO and PLL output) + * => 1 (0x1) [0 is illegal!] + * PLLOUT = VCOOUT * (1/2^OUTDIV) + */ +/* DIV_INT=32 (25MHz*32/2=400MHz), REFDIV=1, RANGE=0, OUTDIV=1 */ +#define PLL_CPU_CONFIG_VAL_40M MK_PLL_CONF(20, 1, 0, 1) +/* DIV_INT=20 (40MHz*20/2=400MHz), REFDIV=1, RANGE=0, OUTDIV=1 */ +#define PLL_CPU_CONFIG_VAL_25M MK_PLL_CONF(32, 1, 0, 1) + +/* + * PLL_CLK_CONTROL_VAL + * + * In PLL_CLK_CONTROL_VAL bit 2 is set (BYPASS = 1 -> bypass PLL) + * After PLL configuration we need to clear this bit + * + * Values written into CPU Clock Control Register CLOCK_CONTROL + * + * bits 2 (1bit) BYPASS (Bypass PLL. This defaults to 1 for test. + * Software must enable the CPU PLL for normal and + * then set this bit to 0) + * bits 5..6 (2bit) CPU_POST_DIV => 0 (DEFAULT, Ratio = 1) + * CPU_CLK = PLLOUT / CPU_POST_DIV + * bits 10..11 (2bit) DDR_POST_DIV => 0 (DEFAULT, Ratio = 1) + * DDR_CLK = PLLOUT / DDR_POST_DIV + * bits 15..16 (2bit) AHB_POST_DIV => 1 (DEFAULT, Ratio = 2) + * AHB_CLK = PLLOUT / AHB_POST_DIV + * + */ +#define PLL_CLK_CONTROL_VAL MK_CLK_CNTL(1, 1, 2) + + .text + .set noreorder + +LEAF(lowlevel_init) + /* These three WLAN_RESET will avoid original issue */ + li t3, 0x03 +1: + li t0, CKSEG1ADDR(AR71XX_RESET_BASE) + lw t1, AR933X_RESET_REG_RESET_MODULE(t0) + ori t1, t1, 0x0800 + sw t1, AR933X_RESET_REG_RESET_MODULE(t0) + nop + lw t1, AR933X_RESET_REG_RESET_MODULE(t0) + li t2, 0xfffff7ff + and t1, t1, t2 + sw t1, AR933X_RESET_REG_RESET_MODULE(t0) + nop + addi t3, t3, -1 + bnez t3, 1b + nop + + li t2, 0x20 +2: + beqz t2, 1b + nop + addi t2, t2, -1 + lw t5, AR933X_RESET_REG_BOOTSTRAP(t0) + andi t1, t5, 0x10 + bnez t1, 2b + nop + + li t1, 0x02110E + sw t1, AR933X_RESET_REG_BOOTSTRAP(t0) + nop + + /* RTC Force Wake */ + li t0, CKSEG1ADDR(AR933X_RTC_BASE) + li t1, 0x03 + sw t1, AR933X_RTC_REG_FORCE_WAKE(t0) + nop + nop + + /* RTC Reset */ + li t1, 0x00 + sw t1, AR933X_RTC_REG_RESET(t0) + nop + nop + + li t1, 0x01 + sw t1, AR933X_RTC_REG_RESET(t0) + nop + nop + + /* Wait for RTC in on state */ +1: + lw t1, AR933X_RTC_REG_STATUS(t0) + andi t1, t1, 0x02 + beqz t1, 1b + nop + + /* Program ki/kd */ + li t0, CKSEG1ADDR(AR933X_SRIF_BASE) + andi t1, t5, 0x01 # t5 BOOT_STRAP + bnez t1, 1f + nop + li t1, 0x19e82f01 + b 2f + nop +1: + li t1, 0x18e82f01 +2: + sw t1, AR933X_SRIF_DDR_DPLL2_REG(t0) + + /* Program phase shift */ + lw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + li t2, 0xc07fffff + and t1, t1, t2 + li t2, 0x800000 + or t1, t1, t2 + sw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + nop + + /* in some cases, the SoC doesn't start with higher clock on AHB */ + li t0, CKSEG1ADDR(AR71XX_PLL_BASE) + li t1, AHB_DIV_TO_4(PLL_BYPASS(PLL_CLK_CONTROL_VAL)) + sw t1, AR933X_PLL_CLK_CTRL_REG(t0) + nop + + /* Set SETTLE_TIME in CPU PLL */ + andi t1, t5, 0x01 # t5 BOOT_STRAP + bnez t1, 1f + nop + li t1, 0x0352 + b 2f + nop +1: + li t1, 0x0550 +2: + sw t1, AR71XX_PLL_REG_SEC_CONFIG(t0) + nop + + /* Set nint, frac, refdiv, outdiv, range according to xtal */ +0: + andi t1, t5, 0x01 # t5 BOOT_STRAP + bnez t1, 1f + nop + li t1, SET_PLL_PD(PLL_CPU_CONFIG_VAL_25M) + b 2f + nop +1: + li t1, SET_PLL_PD(PLL_CPU_CONFIG_VAL_40M) +2: + sw t1, AR933X_PLL_CPU_CONFIG_REG(t0) + nop +1: + lw t1, AR933X_PLL_CPU_CONFIG_REG(t0) + li t2, 0x80000000 + and t1, t1, t2 + bnez t1, 1b + nop + + /* Put frac bit19:10 configuration */ + li t1, 0x1003E8 + sw t1, AR933X_PLL_DITHER_FRAC_REG(t0) + nop + + /* Clear PLL power down bit in CPU PLL configuration */ + andi t1, t5, 0x01 # t5 BOOT_STRAP + bnez t1, 1f + nop + li t1, PLL_CPU_CONFIG_VAL_25M + b 2f + nop +1: + li t1, PLL_CPU_CONFIG_VAL_40M +2: + sw t1, AR933X_PLL_CPU_CONFIG_REG(t0) + nop + + /* Wait for PLL update -> bit 31 in CPU_PLL_CONFIG should be 0 */ +1: + lw t1, AR933X_PLL_CPU_CONFIG_REG(t0) + li t2, 0x80000000 + and t1, t1, t2 + bnez t1, 1b + nop + + /* Confirm DDR PLL lock */ + li t3, 100 + li t4, 0 + +2: + addi t4, t4, 1 + bgt t4, t3, 0b + nop + + li t3, 5 +3: + /* Clear do_meas */ + li t0, CKSEG1ADDR(AR933X_SRIF_BASE) + lw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + li t2, 0xBFFFFFFF + and t1, t1, t2 + sw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + nop + + li t2, 10 +1: + subu t2, t2, 1 + bnez t2, 1b + nop + + /* Set do_meas */ + li t2, 0x40000000 + or t1, t1, t2 + sw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + nop + + /* Check meas_done */ +1: + lw t1, AR933X_SRIF_DDR_DPLL4_REG(t0) + andi t1, t1, 0x8 + beqz t1, 1b + nop + + lw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + li t2, 0x007FFFF8 + and t1, t1, t2 + srl t1, t1, 3 + li t2, 0x4000 + bgt t1, t2, 2b + nop + addi t3, t3, -1 + bnez t3, 3b + nop + + /* clear PLL bypass (bit 2) in CPU CLOCK CONTROL register */ + li t0, CKSEG1ADDR(AR71XX_PLL_BASE) + li t1, PLL_CLK_CONTROL_VAL + sw t1, AR933X_PLL_CLK_CTRL_REG(t0) + nop + + nop + jr ra + nop + END(lowlevel_init)
Changes in v8:
Changes in v7:
Changes in v6:
- Remove board.c
Changes in v5:
Changes in v4:
Use the BIT() macro consistently ;-)
Changes in v8:
Changes in v7:
Changes in v6:
- Remove board.c
Changes in v5:
Changes in v4:
OK.
Wills Wang
