[U-Boot-Users] Format of MMUCSR0 on 8540
I downloaded U-boot from CVS on Nov 14th and have compiled and run this on a TQM8540 board (with a Rev 2 MPC8540 chip).
However, I started stepping through this with the CodeWarrior debugger (and a FreeScale USB TAP - COP version) find that the "isync" in the following code from start.S is actually causing Interrupt 14 to be executed (TLBInstructionException).
/* * Invalidate MMU L1/L2 * * Note: There is a fixup earlier for Errata CPU4 on * Rev 1 parts that must precede this MMU invalidation. */ li r2, 0x001e mtspr MMUCSR0, r2 isync <------------------- Interrupt
Without CodeWarrior, I do eventually see the U-Boot command line appear on the serial port (however it did take several seconds after power on, more than I expected).
Checking the 8540RM manual, I see that there appear to be only two bits that need to be set to invalidate cache (page 633 on MMUCSR0).
Can anyone on the explain the presence of
0x001e
as opposed to
0x0006
in the above code?
Any suggestions as to why this exception arises. Has anyone seen it with An Abatron BDI2000 or not - as the case may be.
Thanks,
Charles.
-------------------------------------------------------------------------- Dr Charles J Gillan The Institute of Electronics, Communications and Information Technology (ECIT), Queen's University Belfast, Titanic Quarter Queens Road, Queens Island, Belfast, BT3 9DT Northern Ireland, UK Tel: +44 (0) 2890 971847 Fax: +44 (0) 2890 971702 --------------------------------------------------------------------------
0x001e
as opposed to
0x0006
in the above code?
It's flash invalidating ALL of the TLB arrays. A value of 0x6 will only do the L2 arrays.
Can you see what's in the following registers, ESR, SRR0, SRR1?
Also, if I remember correctly there are some patches to u-boot for it to work properly with the CodeWarrior JTAG debuggers.
- kumar
Thanks Kumar, for the information.
I stopped the code at the interrupt handler and see the following:
ESR = 0x00000000 SRR0 = 0xFFFC0E00 (the address set in IVOR14 was 0x0e00, TEXT_BASE = FFFC0000) SRR1 = 0x00000200
There is no information on page 6-18 of the 8540RM where these registers are defined. Does the SRR1 value have significance?
From where would I get these? Only FreeScale/Metrowerks ?
Charles.
-----Original Message----- From: Kumar Gala [mailto:galak@kernel.crashing.org] Sent: 18 November 2005 15:43 To: C.Gillan@ecit.qub.ac.uk Cc: u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] Format of MMUCSR0 on 8540
0x001e
as opposed to
0x0006
in the above code?
- kumar
following:
You need the e500 Core UM for these and all CPU registers. These regs are the exception save/restore registers. SRR0 is the address of the instruction that faulted and SRR1 is the MSR when the fault occurred.
Are you able to dump the TLBs out with the debugger you have? If so that would be useful.
Yeah. You'll have to get it from Freescale/Metrowerks. If you download the Freescale Linux "BSP" for 8540 it should have the patches.
- kumar
0x001e
as opposed to
0x0006
in the above code?
- kumar
This SF.Net email is sponsored by the JBoss Inc. Get Certified Today Register for a JBoss Training Course. Free Certification Exam for All Training Attendees Through End of 2005. For more info visit: http://ads.osdn.com/?ad_id=7628&alloc_id=16845&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
In message 977AA505-6DBA-4F85-ACB8-37B452CF9417@kernel.crashing.org you wrote:
Why doesn't Freescale post this stuff here on the list?
On Nov 18, 2005, at 2:11 PM, Wolfgang Denk wrote:
In message <977AA505-6DBA-4F85- ACB8-37B452CF9417@kernel.crashing.org> you wrote:
You would have to ask Freescale that :)
Ron, Neil you guys around??
- kumar
Charles J Gillan
Kumar Gala
