[U-Boot] [PATCH] Make it possible to allocate physical address 0 with lmb
LMB doesn't currently handle allocating regions based at physical address 0. This patch reworks the lmb_alloc functions to return all ones when allocation fails instead of zero so that callers can differentiate between a region allocated at zero and a failed allocation
Signed-off-by: Grant Likely grant.likely@secretlab.ca --- common/image.c | 8 ++++---- include/lmb.h | 1 + lib/lmb.c | 21 ++++++++++++++++----- 3 files changed, 21 insertions(+), 9 deletions(-)
diff --git a/common/image.c b/common/image.c index 11504de..c1757bd 100644 --- a/common/image.c +++ b/common/image.c @@ -1053,7 +1053,7 @@ int boot_ramdisk_high (struct lmb *lmb, ulong rd_data, ulong rd_len, else *initrd_start = (ulong)lmb_alloc (lmb, rd_len, 0x1000);
- if (*initrd_start == 0) { + if (*initrd_start == LMB_ALLOC_ERROR) { puts ("ramdisk - allocation error\n"); goto error; } @@ -1228,7 +1228,7 @@ int boot_relocate_fdt (struct lmb *lmb, ulong bootmap_base, of_start = (unsigned long)lmb_alloc_base(lmb, of_len, 0x1000, (CONFIG_SYS_BOOTMAPSZ + bootmap_base));
- if (of_start == 0) { + if (of_start == (unsigned long)LMB_ALLOC_ERROR) { puts("device tree - allocation error\n"); goto error; } @@ -1614,7 +1614,7 @@ int boot_get_cmdline (struct lmb *lmb, ulong *cmd_start, ulong *cmd_end, cmdline = (char *)(ulong)lmb_alloc_base(lmb, CONFIG_SYS_BARGSIZE, 0xf, CONFIG_SYS_BOOTMAPSZ + bootmap_base);
- if (cmdline == NULL) + if (cmdline == (char*)(ulong)LMB_ALLOC_ERROR) return -1;
if ((s = getenv("bootargs")) == NULL) @@ -1651,7 +1651,7 @@ int boot_get_kbd (struct lmb *lmb, bd_t **kbd, ulong bootmap_base) { *kbd = (bd_t *)(ulong)lmb_alloc_base(lmb, sizeof(bd_t), 0xf, CONFIG_SYS_BOOTMAPSZ + bootmap_base); - if (*kbd == NULL) + if (*kbd == (bd_t *)(ulong)LMB_ALLOC_ERROR) return -1;
**kbd = *(gd->bd); diff --git a/include/lmb.h b/include/lmb.h index 43082a3..f927b86 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -15,6 +15,7 @@ */
#define MAX_LMB_REGIONS 8 +#define LMB_ALLOC_ERROR ((phys_addr_t) ~0)
struct lmb_property { phys_addr_t base; diff --git a/lib/lmb.c b/lib/lmb.c index c5e75fb..de3c325 100644 --- a/lib/lmb.c +++ b/lib/lmb.c @@ -114,6 +114,9 @@ static long lmb_add_region(struct lmb_region *rgn, phys_addr_t base, phys_size_t unsigned long coalesced = 0; long adjacent, i;
+ debug("lmb_add_region(lmb=%x, base=%.8lx, size=%.8lx)\n", + (ulong)rgn, (ulong)base, (ulong)size); + if ((rgn->cnt == 1) && (rgn->region[0].size == 0)) { rgn->region[0].base = base; rgn->region[0].size = size; @@ -266,9 +269,11 @@ phys_addr_t lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phys_
alloc = __lmb_alloc_base(lmb, size, align, max_addr);
- if (alloc == 0) - printf("ERROR: Failed to allocate 0x%lx bytes below 0x%lx.\n", + if (alloc == LMB_ALLOC_ERROR) { + debug("ERROR: Failed to allocate 0x%lx bytes below 0x%lx.\n", (ulong)size, (ulong)max_addr); + lmb_dump_all(lmb); + }
return alloc; } @@ -289,10 +294,15 @@ phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phy phys_addr_t base = 0; phys_addr_t res_base;
+ debug("lmb_alloc_base(lmb=%lx, size=%lx, align=%li, max_addr=%lx)\n", + (ulong)lmb, (ulong)size, (ulong)align, (ulong)max_addr); + for (i = lmb->memory.cnt-1; i >= 0; i--) { phys_addr_t lmbbase = lmb->memory.region[i].base; phys_size_t lmbsize = lmb->memory.region[i].size;
+ debug("--loop i=%i, lmbbase=%lx, lmbsize=%lx\n", + i, (ulong)lmbbase, (ulong)lmbsize); if (lmbsize < size) continue; if (max_addr == LMB_ALLOC_ANYWHERE) @@ -303,14 +313,15 @@ phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phy } else continue;
- while (base && lmbbase <= base) { + while (lmbbase <= base) { j = lmb_overlaps_region(&lmb->reserved, base, size); + debug("----loop base=%lx, j=%i\n", (ulong)base, j); if (j < 0) { /* This area isn't reserved, take it */ if (lmb_add_region(&lmb->reserved, base, lmb_align_up(size, align)) < 0) - return 0; + return LMB_ALLOC_ERROR; return base; } res_base = lmb->reserved.region[j].base; @@ -319,7 +330,7 @@ phys_addr_t __lmb_alloc_base(struct lmb *lmb, phys_size_t size, ulong align, phy base = lmb_align_down(res_base - size, align); } } - return 0; + return LMB_ALLOC_ERROR; }
int lmb_is_reserved(struct lmb *lmb, phys_addr_t addr)
On Wed, Jan 26, 2011 at 9:57 AM, Grant Likely grant.likely@secretlab.ca wrote:
Oops, sent this one out too early. It will not apply against current mainline since it it based on an older tree. Still, please take a look and let me know it this looks appropriate. I'll get this rebased and retested against top of tree.
g.
- if (*initrd_start == LMB_ALLOC_ERROR) {
- if (of_start == (unsigned long)LMB_ALLOC_ERROR) {
- if (cmdline == (char*)(ulong)LMB_ALLOC_ERROR)
return -1;
- if (*kbd == NULL)
- if (*kbd == (bd_t *)(ulong)LMB_ALLOC_ERROR)
return -1;
- debug("lmb_add_region(lmb=%x, base=%.8lx, size=%.8lx)\n",
- (ulong)rgn, (ulong)base, (ulong)size);
- if (alloc == 0)
- if (alloc == LMB_ALLOC_ERROR) {
- debug("ERROR: Failed to allocate 0x%lx bytes below 0x%lx.\n",
- lmb_dump_all(lmb);
- debug("lmb_alloc_base(lmb=%lx, size=%lx, align=%li, max_addr=%lx)\n",
- (ulong)lmb, (ulong)size, (ulong)align, (ulong)max_addr);
- debug("--loop i=%i, lmbbase=%lx, lmbsize=%lx\n",
- i, (ulong)lmbbase, (ulong)lmbsize);
- while (lmbbase <= base) {
- debug("----loop base=%lx, j=%i\n", (ulong)base, j);
- return LMB_ALLOC_ERROR;
Dear Grant Likely,
In message 20110126165340.14306.98359.stgit@localhost6.localdomain6 you wrote:
- if (alloc == 0)
lmb_dump_all(lmb);
Do you intentionally change the printf() into a debug() here? If yes, what is your rationale for not printing a proper error message in production code?
On Wed, Jan 26, 2011 at 11:30 AM, Wolfgang Denk wd@denx.de wrote:
Dear Grant Likely,
- if (alloc == 0)
No, that was a mistake. I'll correct it.
g.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "I knew then (in 1970) that a 4-kbyte minicomputer would cost as much as a house. So I reasoned that after college, I'd have to live cheaply in an apartment and put all my money into owning a computer." - Apple co-founder Steve Wozniak, EE Times, June 6, 1988, pg 45
Grant Likely
