[PATCH] ARM: renesas: Set CONFIG_SYS_TEXT_BASE=0x0 on R-Car Gen3
Since R-Car Gen3 already enables position independent build, also set CONFIG_SYS_TEXT_BASE=0x0 to finalize the switch. This is possible since 534f0fbd65 ("arm64: Fix relocation of env_addr if POSITION_INDEPENDENT=y") fixed current env_get_char() crash with CONFIG_SYS_TEXT_BASE=0x0 .
This change permits us to start U-Boot from any location in DRAM instead of specific TEXT_BASE.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- configs/rcar3_salvator-x_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/rcar3_salvator-x_defconfig b/configs/rcar3_salvator-x_defconfig index bb0bcfefe2..709e6435ae 100644 --- a/configs/rcar3_salvator-x_defconfig +++ b/configs/rcar3_salvator-x_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_RMOBILE=y -CONFIG_SYS_TEXT_BASE=0x50000000 +CONFIG_SYS_TEXT_BASE=0x0 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xFFFE0000 CONFIG_DM_GPIO=y
