[U-Boot] [PATCH 1/6] i2c: rcar_i2c: Fix u32 cast warnings
Signed-off-by: Ismael Luceno ismael.luceno@silicon-gears.com --- drivers/i2c/rcar_i2c.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 8d87c73713..bd7c37a207 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -34,9 +34,9 @@ #define RCAR_I2C_ICMSR_MNR BIT(6) #define RCAR_I2C_ICMSR_MAL BIT(5) #define RCAR_I2C_ICMSR_MST BIT(4) -#define RCAR_I2C_ICMSR_MDE BIT(3) +#define RCAR_I2C_ICMSR_MDE ((u32)BIT(3)) #define RCAR_I2C_ICMSR_MDT BIT(2) -#define RCAR_I2C_ICMSR_MDR BIT(1) +#define RCAR_I2C_ICMSR_MDR ((u32)BIT(1)) #define RCAR_I2C_ICMSR_MAT BIT(0) #define RCAR_I2C_ICSIER 0x10 #define RCAR_I2C_ICMIER 0x14
Signed-off-by: Ismael Luceno ismael.luceno@silicon-gears.com --- drivers/i2c/rcar_i2c.c | 40 ++++++++++++++++++++-------------------- 1 file changed, 20 insertions(+), 20 deletions(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index bd7c37a207..7212587234 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -18,33 +18,33 @@ #include <asm/io.h> #include <wait_bit.h>
-#define RCAR_I2C_ICSCR 0x00 -#define RCAR_I2C_ICMCR 0x04 -#define RCAR_I2C_ICMCR_MDBS BIT(7) -#define RCAR_I2C_ICMCR_FSCL BIT(6) -#define RCAR_I2C_ICMCR_FSDA BIT(5) -#define RCAR_I2C_ICMCR_OBPC BIT(4) -#define RCAR_I2C_ICMCR_MIE BIT(3) +#define RCAR_I2C_ICSCR 0x00 /* slave ctrl */ +#define RCAR_I2C_ICMCR 0x04 /* master ctrl */ +#define RCAR_I2C_ICMCR_MDBS BIT(7) /* non-fifo mode switch */ +#define RCAR_I2C_ICMCR_FSCL BIT(6) /* override SCL pin */ +#define RCAR_I2C_ICMCR_FSDA BIT(5) /* override SDA pin */ +#define RCAR_I2C_ICMCR_OBPC BIT(4) /* override pins */ +#define RCAR_I2C_ICMCR_MIE BIT(3) /* master if enable */ #define RCAR_I2C_ICMCR_TSBE BIT(2) -#define RCAR_I2C_ICMCR_FSB BIT(1) -#define RCAR_I2C_ICMCR_ESG BIT(0) -#define RCAR_I2C_ICSSR 0x08 -#define RCAR_I2C_ICMSR 0x0c +#define RCAR_I2C_ICMCR_FSB BIT(1) /* force stop bit */ +#define RCAR_I2C_ICMCR_ESG BIT(0) /* enable start bit gen */ +#define RCAR_I2C_ICSSR 0x08 /* slave status */ +#define RCAR_I2C_ICMSR 0x0c /* master status */ #define RCAR_I2C_ICMSR_MASK 0x7f -#define RCAR_I2C_ICMSR_MNR BIT(6) -#define RCAR_I2C_ICMSR_MAL BIT(5) -#define RCAR_I2C_ICMSR_MST BIT(4) +#define RCAR_I2C_ICMSR_MNR BIT(6) /* Nack */ +#define RCAR_I2C_ICMSR_MAL BIT(5) /* Arbitration lost */ +#define RCAR_I2C_ICMSR_MST BIT(4) /* Stop */ #define RCAR_I2C_ICMSR_MDE ((u32)BIT(3)) #define RCAR_I2C_ICMSR_MDT BIT(2) #define RCAR_I2C_ICMSR_MDR ((u32)BIT(1)) #define RCAR_I2C_ICMSR_MAT BIT(0) -#define RCAR_I2C_ICSIER 0x10 -#define RCAR_I2C_ICMIER 0x14 -#define RCAR_I2C_ICCCR 0x18 +#define RCAR_I2C_ICSIER 0x10 /* slave irq enable */ +#define RCAR_I2C_ICMIER 0x14 /* master irq enable */ +#define RCAR_I2C_ICCCR 0x18 /* clock dividers */ #define RCAR_I2C_ICCCR_SCGD_OFF 3 -#define RCAR_I2C_ICSAR 0x1c -#define RCAR_I2C_ICMAR 0x20 -#define RCAR_I2C_ICRXD_ICTXD 0x24 +#define RCAR_I2C_ICSAR 0x1c /* slave address */ +#define RCAR_I2C_ICMAR 0x20 /* master address */ +#define RCAR_I2C_ICRXD_ICTXD 0x24 /* data port */
struct rcar_i2c_priv { void __iomem *base;
Do the reset before clearing the MSR, otherwise it may result in a read or write operation instead if the start condition is repeated.
Signed-off-by: Ismael Luceno ismael.luceno@silicon-gears.com --- drivers/i2c/rcar_i2c.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 7212587234..8cdd37c006 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -120,9 +120,11 @@ static int rcar_i2c_set_addr(struct udevice *dev, u8 chip, u8 read) }
writel((chip << 1) | read, priv->base + RCAR_I2C_ICMAR); - writel(0, priv->base + RCAR_I2C_ICMSR); + /* Reset */ writel(RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_MIE | RCAR_I2C_ICMCR_ESG, priv->base + RCAR_I2C_ICMCR); + /* Clear Status */ + writel(0, priv->base + RCAR_I2C_ICMSR);
ret = wait_for_bit_le32(priv->base + RCAR_I2C_ICMSR, mask, true, 100, true);
Signed-off-by: Ismael Luceno ismael.luceno@silicon-gears.com --- drivers/i2c/rcar_i2c.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 8cdd37c006..b4cc0c55b1 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -207,7 +207,7 @@ static int rcar_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) ret = rcar_i2c_write_common(dev, msg);
if (ret) - return -EREMOTEIO; + return ret; }
return ret;
Signed-off-by: Ismael Luceno ismael.luceno@silicon-gears.com --- drivers/i2c/rcar_i2c.c | 14 +++++--------- 1 file changed, 5 insertions(+), 9 deletions(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index b4cc0c55b1..5e04b68d95 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -144,10 +144,6 @@ static int rcar_i2c_read_common(struct udevice *dev, struct i2c_msg *msg) u32 icmcr = RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_MIE; int i, ret = -EREMOTEIO;
- ret = rcar_i2c_set_addr(dev, msg->addr, 1); - if (ret) - return ret; - for (i = 0; i < msg->len; i++) { if (msg->len - 1 == i) icmcr |= RCAR_I2C_ICMCR_FSB; @@ -174,10 +170,6 @@ static int rcar_i2c_write_common(struct udevice *dev, struct i2c_msg *msg) u32 icmcr = RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_MIE; int i, ret = -EREMOTEIO;
- ret = rcar_i2c_set_addr(dev, msg->addr, 0); - if (ret) - return ret; - for (i = 0; i < msg->len; i++) { writel(msg->buf[i], priv->base + RCAR_I2C_ICRXD_ICTXD); writel(icmcr, priv->base + RCAR_I2C_ICMCR); @@ -201,6 +193,10 @@ static int rcar_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) int ret;
for (; nmsgs > 0; nmsgs--, msg++) { + ret = rcar_i2c_set_addr(dev, msg->addr, 1); + if (ret) + return -EREMOTEIO; + if (msg->flags & I2C_M_RD) ret = rcar_i2c_read_common(dev, msg); else @@ -210,7 +206,7 @@ static int rcar_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, int nmsgs) return ret; }
- return ret; + return 0; }
static int rcar_i2c_probe_chip(struct udevice *dev, uint addr, uint flags)
- if (ret)
return ret;
- if (ret)
return ret;
if (ret)
return -EREMOTEIO;
Shouldn't you return ret here ? It seems like you fixed similar issue in 4/6.
- if (msg->flags & I2C_M_RD) ret = rcar_i2c_read_common(dev, msg); else
- return ret;
Is this change valid ?
- if (ret)
return ret;
- if (ret)
return ret;
if (ret)
return -EREMOTEIO;
Correct. Thanks.
- return ret;
Yes, ret is always checked, so it can only be 0.
- if (ret)
return ret;
- if (ret)
return ret;
if (ret)
return -EREMOTEIO;
Correct. Thanks.
- return ret;
OK
Signed-off-by: Ismael Luceno ismael.luceno@silicon-gears.com --- drivers/i2c/rcar_i2c.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/i2c/rcar_i2c.c b/drivers/i2c/rcar_i2c.c index 5e04b68d95..b829e8b20d 100644 --- a/drivers/i2c/rcar_i2c.c +++ b/drivers/i2c/rcar_i2c.c @@ -68,7 +68,7 @@ static int rcar_i2c_finish(struct udevice *dev) return ret; }
-static void rcar_i2c_recover(struct udevice *dev) +static int rcar_i2c_recover(struct udevice *dev) { struct rcar_i2c_priv *priv = dev_get_priv(dev); u32 mcr = RCAR_I2C_ICMCR_MDBS | RCAR_I2C_ICMCR_OBPC; @@ -93,6 +93,9 @@ static void rcar_i2c_recover(struct udevice *dev) udelay(5); writel(mcra | RCAR_I2C_ICMCR_FSCL, priv->base + RCAR_I2C_ICMCR); udelay(5); + + u32 val = readl(priv->base + RCAR_I2C_ICMSR); + return val & RCAR_I2C_ICMCR_FSDA; }
static int rcar_i2c_set_addr(struct udevice *dev, u8 chip, u8 read) @@ -108,12 +111,11 @@ static int rcar_i2c_set_addr(struct udevice *dev, u8 chip, u8 read) writel(0, priv->base + RCAR_I2C_ICMSR); writel(priv->icccr, priv->base + RCAR_I2C_ICCCR);
+ /* Wait for the bus */ ret = wait_for_bit_le32(priv->base + RCAR_I2C_ICMCR, RCAR_I2C_ICMCR_FSDA, false, 2, true); if (ret) { - rcar_i2c_recover(dev); - val = readl(priv->base + RCAR_I2C_ICMSR); - if (val & RCAR_I2C_ICMCR_FSDA) { + if (rcar_i2c_recover(dev)) { dev_err(dev, "Bus busy, aborting\n"); return ret; }
Why is this change needed ? A commit message explaining it would help a lot.
- u32 val = readl(priv->base + RCAR_I2C_ICMSR);
- return val & RCAR_I2C_ICMCR_FSDA;
Declare all your variables at the beginning of the function, I believe the compiler would even complain about this.
- /* Wait for the bus */ ret = wait_for_bit_le32(priv->base + RCAR_I2C_ICMCR, RCAR_I2C_ICMCR_FSDA, false, 2, true); if (ret) {
}if (rcar_i2c_recover(dev)) { dev_err(dev, "Bus busy, aborting\n"); return ret;
It's cosmetic. Any call to the recover function would need to do the same check afterwards, so it' sensible to make it part of the function.
The default mode is -std=gnu11 since GCC 5, and the Makefile defines CSTD_FLAG to that too.
This needs to be in the commit message then.
Hello Ismael,
the patch is missing commit message, please fix globally.
I sent this patch [1] two days ago, I believe it fixes the same issue, can you rebase the series on top of it ?
[1] http://patchwork.ozlabs.org/patch/1050650/
Hello Ismael,
I'll rebase.
BTW, if the ICFBSCR only needs to be written to once, it would make sense to do it at the end of rcar_i2c_set_speed.
Hello Ismael,
I'll rebase.
Can you prepare a patch please ?
