[PATCH] bootstage: Add SPL support
Allow usage of the bootstage facilities in SPL.
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- common/Kconfig.boot | 9 +++++++++ include/bootstage.h | 2 +- 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/common/Kconfig.boot b/common/Kconfig.boot index 902a5b8fbea..c230b5c76e4 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -667,6 +667,15 @@ config SHOW_BOOT_PROGRESS -150 common/cmd_nand.c Incorrect FIT image format 151 common/cmd_nand.c FIT image format OK
+config SPL_SHOW_BOOT_PROGRESS + bool "Show boot progress in a board-specific manner" + depends on SPL + help + Defining this option allows to add some board-specific code (calling + a user-provided function show_boot_progress(int) that enables you to + show the system's boot progress on some display (for example, some + LEDs) on your board. For details see SHOW_BOOT_PROGRESS. + endmenu
menu "Boot media" diff --git a/include/bootstage.h b/include/bootstage.h index f837a387c8c..8d1989ac0e5 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -220,7 +220,7 @@ enum bootstage_id { */ ulong timer_get_boot_us(void);
-#if defined(USE_HOSTCC) || !CONFIG_IS_ENABLED(BOOTSTAGE) +#if defined(USE_HOSTCC) || !CONFIG_IS_ENABLED(SHOW_BOOT_PROGRESS) #define show_boot_progress(val) do {} while (0) #else /**
Signed-off-by: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org Reviewed-by: Simon Glass sjg@chromium.org
This breaks a large number of platforms unfortunately, starting with sandbox_spl but also cortina_presidio-asic-emmc and likely many others.
