[U-Boot] [PATCH 03/13] ColdFire: Update uart_port_conf in serial driver
18 Mar
2010
18 Mar
'10
2:39 a.m.
Provide proper port passing from serial_init to uart_part_conf.
Signed-off-by: TsiChung Liew tsicliew@gmail.com --- drivers/serial/mcfuart.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/mcfuart.c b/drivers/serial/mcfuart.c index 0b53140..d93b24b 100644 --- a/drivers/serial/mcfuart.c +++ b/drivers/serial/mcfuart.c @@ -34,7 +34,7 @@
DECLARE_GLOBAL_DATA_PTR;
-extern void uart_port_conf(void); +extern void uart_port_conf(int port);
int serial_init(void) { @@ -43,7 +43,7 @@ int serial_init(void)
uart = (volatile uart_t *)(CONFIG_SYS_UART_BASE);
- uart_port_conf(); + uart_port_conf(CONFIG_SYS_UART_PORT);
/* write to SICR: SIM2 = uart mode,dcd does not affect rx */ uart->ucr = UART_UCR_RESET_RX;
1.6.2.5
5535
TsiChung Liew
