[U-Boot] [PATCH 0/2] warp7: add UART6 support
This small series adds support for using the console on UART6 on the WaRP7 board.
The board retains current functionality: UART6 is not used by default and needs it needs to be enabled in defconfig.
[PATCH 1/2] serial: mxc: support DTE mode [PATCH 2/2] warp7: add support for console on UART6 and mikroBus
board/warp7/Kconfig | 9 +++++++++ board/warp7/warp7.c | 6 ++++++ drivers/serial/Kconfig | 7 +++++++ drivers/serial/serial_mxc.c | 10 ++++++++-- include/configs/warp7.h | 8 +++++++- 5 files changed, 37 insertions(+), 3 deletions(-)
Add DTE mode support via Kconfig on the MXC uart.
Signed-off-by: Ryan Harkin ryan.harkin@linaro.org Reviewed-by: Bryan O'Donoghue bryan.odonoghue@linaro.org --- drivers/serial/Kconfig | 7 +++++++ drivers/serial/serial_mxc.c | 10 ++++++++-- 2 files changed, 15 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 122b8e7..0df57c0 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -597,4 +597,11 @@ config SYS_SDMR depends on MPC8XX_CONS default 0
+config SERIAL_MXC_DTE_MODE + bool "Use DTE mode for the MXC UART" + default n + help + This is used to set DTE mode on the serial console controlled by + serial_mxc.c. + endmenu diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index cce80a8..e7ea30c 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -111,6 +111,12 @@ #define TXTL 2 /* reset default */ #define RXTL 1 /* reset default */
+#ifdef CONFIG_SERIAL_MXC_DTE_MODE +#define MXC_DTE_MODE true +#else +#define MXC_DTE_MODE false +#endif + DECLARE_GLOBAL_DATA_PTR;
struct mxc_uart { @@ -189,7 +195,7 @@ static void mxc_serial_setbrg(void) if (!gd->baudrate) gd->baudrate = CONFIG_BAUDRATE;
- _mxc_serial_setbrg(mxc_base, clk, gd->baudrate, false); + _mxc_serial_setbrg(mxc_base, clk, gd->baudrate, MXC_DTE_MODE); }
static int mxc_serial_getc(void) @@ -367,7 +373,7 @@ static inline void _debug_uart_init(void)
_mxc_serial_init(base); _mxc_serial_setbrg(base, CONFIG_DEBUG_UART_CLOCK, - CONFIG_BAUDRATE, false); + CONFIG_BAUDRATE, MXC_DTE_MODE); }
static inline void _debug_uart_putc(int ch)
Hi Ryan,
Make use of the driver model, there DTE is supported already today: https://lists.denx.de/pipermail/u-boot/2016-July/259573.html
-- Stefan
- bool "Use DTE mode for the MXC UART"
- default n
- help
serial_mxc.c.
- _mxc_serial_setbrg(mxc_base, clk, gd->baudrate, MXC_DTE_MODE);
Hi Stefan,
Thanks for looking so quickly.
On 19 January 2018 at 12:23, Stefan Agner stefan.agner@toradex.com wrote:
Hi Ryan,
My change would be useful for other non-DM users of serial_mxc.c, of course. Not just WaRP7.
I don't have any objection to WaRP7 moving to DM, although that isn't my call, but moving using the driver model is not a straight-forward change, is it? WaRP7 today doesn't use it.
Do you have an example of a board using this driver that switched using the driver model? I'd like to see the scale of the changes needed.
Regards, Ryan.
-- Stefan
default n
help
serial_mxc.c.
Hi Ryan,
On 19 January 2018 at 06:21, Ryan Harkin ryan.harkin@linaro.org wrote:
Hi Stefan,
Hi Ryan,
We are planning to require that board use CONFIG_BLK fairly soon, and that likely means conversion to device tree I don't think it makes sense to accept patches like this. If the board can be converted, then let's do it!
It probably requires:
- Adding a DT (with u-boot,dm-pre-reloc as needed) - Checking that stdio-path is correct
Hi Simon,
On 22 January 2018 at 00:29, Simon Glass sjg@chromium.org wrote:
Hi Ryan,
Hi Stefan,
wrote:
Hi Ryan,
course.
Not just WaRP7.
change, is
I'm not the maintainer of this board. I'm only making this patch so I can put it into our test farm. But I'm interested in giving it a go. In fact, I started already after Stefan's email. And bricked my board :-)
the
I take it we add the DT from the upstream linux kernel? The upstream DT doesn't define UART6, the one I want to use. I have a patch for the kernel that I have not attempted to send upstream yet.
What approach should I take? - upstream my patch to the kernel first - use the DT from upstream kernel as-is and add a separate patch in the u-boot tree - use the DT from upstream kernel as-is and squash in my patch
Or something else?
Updating the DT from upstream will possibly mean updating the DTs for all other iMX7 boards [1], because the include/dt-bindings stuff has changed slightly, as well as the imx7s.dtsi file. I have no way of testing the other boards, but I guess their maintainers can help there.
That's probably what bricked my board...
Cheers, Ryan.
[1] There only appear to be two iMX7 board in u-boot already: arch/arm/dts/imx7d.dtsi:44:#include "imx7s.dtsi" arch/arm/dts/imx7-colibri.dts:9:#include "imx7d.dtsi" arch/arm/dts/imx7d-sdb.dts:9:#include "imx7d.dtsi"
Add support to route the serial console on the NXP WaRP7 board to UART6 and the mikroBus.
To use UART6 on the WaRP7 board, I add the following lines to configs/warp7_defconfig:
+CONFIG_MXC_CONSOLE_NUM=6 +CONFIG_SERIAL_MXC_DTE_MODE=y
Signed-off-by: Ryan Harkin ryan.harkin@linaro.org Reviewed-by: Bryan O'Donoghue bryan.odonoghue@linaro.org --- board/warp7/Kconfig | 9 +++++++++ board/warp7/warp7.c | 6 ++++++ include/configs/warp7.h | 8 +++++++- 3 files changed, 22 insertions(+), 1 deletion(-)
diff --git a/board/warp7/Kconfig b/board/warp7/Kconfig index 61c33fb..5fb4824 100644 --- a/board/warp7/Kconfig +++ b/board/warp7/Kconfig @@ -6,4 +6,13 @@ config SYS_BOARD config SYS_CONFIG_NAME default "warp7"
+config MXC_CONSOLE_NUM + int "UART used for the console" + default 1 + help + The UART used for the console, expressed as a 1-based integer. + This is also used to set the console variable passed to the kernel. + Currently, only UART1 and UART6 are supported. Specifying a value + other than 6 will result in using UART1. + endif diff --git a/board/warp7/warp7.c b/board/warp7/warp7.c index d422d63..d345b0e 100644 --- a/board/warp7/warp7.c +++ b/board/warp7/warp7.c @@ -67,6 +67,11 @@ static iomux_v3_cfg_t const uart1_pads[] = { MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), };
+static iomux_v3_cfg_t const uart6_pads[] = { + MX7D_PAD_ECSPI1_MOSI__UART6_DTE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX7D_PAD_ECSPI1_SCLK__UART6_DTE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + static iomux_v3_cfg_t const usdhc3_pads[] = { MX7D_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX7D_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -84,6 +89,7 @@ static iomux_v3_cfg_t const usdhc3_pads[] = { static void setup_iomux_uart(void) { imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + imx_iomux_v3_setup_multiple_pads(uart6_pads, ARRAY_SIZE(uart6_pads)); };
static struct fsl_esdhc_cfg usdhc_cfg[1] = { diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 11f1bc3..271667d 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -13,7 +13,13 @@
#define PHYS_SDRAM_SIZE SZ_512M
+#if (CONFIG_MXC_CONSOLE_NUM == 6) +#define CONFIG_MXC_UART_BASE UART6_IPS_BASE_ADDR +#define CONSOLE "ttymxc5" +#else #define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR +#define CONSOLE "ttymxc0" +#endif
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (35 * SZ_1M) @@ -31,7 +37,7 @@ CONFIG_DFU_ENV_SETTINGS \ "script=boot.scr\0" \ "image=zImage\0" \ - "console=ttymxc0\0" \ + "console=" CONSOLE "\0" \ "ethact=usb_ether\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \
Tested-by: Bryan O'Donoghue bryan.odonoghue@linaro.org
Bryan O'Donoghue
Ryan Harkin
Stefan Agner
