[PATCH] doc: FIT image: Clarify format and simplify syntax
** Introduction
There are currently four ways to load an OS image with u-boot 1. SPL -> u-boot -> bootm 2. SPL blue falcon mode 3. "Basic" FIT image (CONFIG_LOAD_FIT) 4. "Full-featured" FIT image (CONFIG_LOAD_FIT_FULL)
These four code paths were developed independently, and share very little code. (3) and (4), behave very differently, are littered with special cases. They even have different DTS syntax and properties.
The cause of this divergence is that the FIT format specification leaves a number of things open to interpretation. The purpose of this change is to enable the reduction of code size, duplication, and complexity by updating and streamlining the FIT format.
We are only marginally concerned with backwards compatibility, because we don't have inter-compatibility. For example, CONFIG_LOAD_FIT is able to load images that CONFIG_LOAD_FIT_FULL won't. This is a direct result of the incompatible syntax between the two implementations.
Ideally, these changes would enable "simple" FIT to be a subset of the "full" fit implementation, and share most code. These changes should also eliminate the need for falcon mode (although we are not advocating for the removal of falcon mode at this time).
** Description of changes
* The "configurations" node is now mandatory
Guessing how to load components based on their "os" and "type" invites confusion and superfluous heuristics. Instead, require each FIT image to be explicit on how components should be loaded.
* Eliminate "ramdisk", "setup", "standalone", and "fpga" properties
Having too many special purpose properties requires special-casing FIT loading code. When a special property can be handled by another property, it is redundant. - A "ramdisk" is identical to a loadable. Thus ramdisk images should be placed under "loadables". - A "setup" node can be achieved by using a "kernel" or "firmware" property instead. - "standalone" is used for u-boot nodes. The correct property to use in this case is "firmware". - "fpga" is a loadable
* Prioritize control between "firmware" and "kernel"
"firmware" and "kernel" are special nodes in that control is passed to the "entry-point" of the image. Both can be present, for example, an OP-TEE firmware with a linux kernel. When both are present, control is passed to the "firmware" image.
** Further generalizations (not included herein)
The "firmware" and "kernel" properties could be generalized as a "next-boot-stage", or similar name. This "next" stage would be special in that it is both executable, and is the stage that is passed control. For example, "next-stage" could be an op-tee image, with linux as a loadable, or a u-boot image.
Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- doc/uImage.FIT/source_file_format.txt | 33 ++++++++++++--------------- 1 file changed, 14 insertions(+), 19 deletions(-)
diff --git a/doc/uImage.FIT/source_file_format.txt b/doc/uImage.FIT/source_file_format.txt index 884a58456f..2e7e11747c 100644 --- a/doc/uImage.FIT/source_file_format.txt +++ b/doc/uImage.FIT/source_file_format.txt @@ -126,12 +126,10 @@ Root node of the uImage Tree should have the following layout: load addresses supplied within sub-image nodes. May be omitted when no entry or load addresses are used.
- Mandatory node: + Mandatory nodes: - images : This node contains a set of sub-nodes, each of them representing single component sub-image (like kernel, ramdisk, etc.). At least one sub-image is required. - - Optional node: - configurations : Contains a set of available configuration nodes and defines a default configuration.
@@ -169,8 +167,8 @@ the '/images' node should have the following layout: to "none".
Conditionally mandatory property: - - os : OS name, mandatory for types "kernel" and "ramdisk". Valid OS names - are: "openbsd", "netbsd", "freebsd", "4_4bsd", "linux", "svr4", "esix", + - os : OS name, mandatory for types "kernel". Valid OS names are: + "openbsd", "netbsd", "freebsd", "4_4bsd", "linux", "svr4", "esix", "solaris", "irix", "sco", "dell", "ncr", "lynxos", "vxworks", "psos", "qnx", "u_boot", "rtems", "unity", "integrity". - arch : Architecture name, mandatory for types: "standalone", "kernel", @@ -179,10 +177,13 @@ the '/images' node should have the following layout: "sparc64", "m68k", "microblaze", "nios2", "blackfin", "avr32", "st200", "sandbox". - entry : entry point address, address size is determined by - '#address-cells' property of the root node. Mandatory for for types: - "standalone" and "kernel". + '#address-cells' property of the root node. + Mandatory for types: "firmware", and "kernel". - load : load address, address size is determined by '#address-cells' - property of the root node. Mandatory for types: "standalone" and "kernel". + property of the root node. + Mandatory for types: "firmware", and "kernel". + - compatible : compatible method for loading image. + Mandatory for types: "fpga", and images that do not specify a load address.
Optional nodes: - hash-1 : Each hash sub-node represents separate hash or checksum @@ -205,9 +206,8 @@ o hash-1 6) '/configurations' node -------------------------
-The 'configurations' node is optional. If present, it allows to create a -convenient, labeled boot configurations, which combine together kernel images -with their ramdisks and fdt blobs. +The 'configurations' node creates convenient, labeled boot configurations, +which combine together kernel images with their ramdisks and fdt blobs.
The 'configurations' node has has the following structure:
@@ -236,27 +236,22 @@ Each configuration has the following structure: o config-1 |- description = "configuration description" |- kernel = "kernel sub-node unit name" - |- ramdisk = "ramdisk sub-node unit name" |- fdt = "fdt sub-node unit-name" [, "fdt overlay sub-node unit-name", ...] - |- fpga = "fpga sub-node unit-name" |- loadables = "loadables sub-node unit-name" |- compatible = "vendor,board-style device tree compatible string"
Mandatory properties: - description : Textual configuration description. - - kernel : Unit name of the corresponding kernel image (image sub-node of a - "kernel" type). + - kernel or firmware: Unit name of the corresponding kernel or firmware + (u-boot, op-tee, etc) image. If both "kernel" and "firmware" are specified, + control is passed to the firmware image.
Optional properties: - - ramdisk : Unit name of the corresponding ramdisk image (component image - node of a "ramdisk" type). - fdt : Unit name of the corresponding fdt blob (component image node of a "fdt type"). Additional fdt overlay nodes can be supplied which signify that the resulting device tree blob is generated by the first base fdt blob with all subsequent overlays applied. - - setup : Unit name of the corresponding setup binary (used for booting - an x86 kernel). This contains the setup.bin file built by the kernel. - fpga : Unit name of the corresponding fpga bitstream blob (component image node of a "fpga type"). - loadables : Unit name containing a list of additional binaries to be
On Tue, Dec 15, 2020 at 01:15:43PM -0600, Alexandru Gagniuc wrote:
** Introduction
- SPL -> u-boot -> bootm
- SPL blue falcon mode
- "Basic" FIT image (CONFIG_LOAD_FIT)
- "Full-featured" FIT image (CONFIG_LOAD_FIT_FULL)
- The "configurations" node is now mandatory
- Eliminate "ramdisk", "setup", "standalone", and "fpga" properties
- Prioritize control between "firmware" and "kernel"
Alexandru Gagniuc
