[U-Boot] [PATCH 0/8] Enablement of PCIe controller for LX2-Rev2
LX2-Rev1 has MV PCIe controller which use pcie_layerscape_gen4 driver. LX2-Rev2 and other layerscape devices has SNP PCIe controller which use pcie_layerscape driver.
This patch set enables support for LX2-Rev2 and use pcie_layerscape or pcie_layerscape_gen4 driver based on SoC variant and SoC Version.
Wasim Khan (8): driver/pci : enable pcie layerscape code for pcie gen4 code pci: layerscape: Add stream_id_cur field to ls_pcie structure pci: layerscape: Update API names for layerscape fixup pci: layerscape: Update API names for layerscape gen4 fixup armv8: lx2160a: Add FSL_PEX_STREAM_ID_END for LX2160A pci: layerscape: Common device tree fixup for NXP SoCs pci: layerscape: Move streamId allocation to common device tree fixup pci: layerscape: device tree fixup based on SoC and Version
.../asm/arch-fsl-layerscape/stream_id_lsch3.h | 8 +- drivers/pci/Makefile | 5 +- drivers/pci/pcie_layerscape.c | 3 +- drivers/pci/pcie_layerscape.h | 3 +- drivers/pci/pcie_layerscape_fixup.c | 44 ++++---- drivers/pci/pcie_layerscape_fixup_common.c | 120 +++++++++++++++++++++ drivers/pci/pcie_layerscape_fixup_common.h | 23 ++++ drivers/pci/pcie_layerscape_gen4_fixup.c | 43 ++++---- 8 files changed, 191 insertions(+), 58 deletions(-) create mode 100644 drivers/pci/pcie_layerscape_fixup_common.c create mode 100644 drivers/pci/pcie_layerscape_fixup_common.h
lx2 rev2 has SNP controller. Enable pcie_layerscape code for CONFIG_PCIE_LAYERSCAPE_GEN4. Based on SoC and revision pcie controller probe will be invoked.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- drivers/pci/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index b1d3dc8..d6a9b8c 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -35,7 +35,7 @@ obj-$(CONFIG_PCIE_FSL) += pcie_fsl.o pcie_fsl_fixup.o obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape.o obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape_fixup.o obj-$(CONFIG_PCIE_LAYERSCAPE_GEN4) += pcie_layerscape_gen4.o \ - pcie_layerscape_gen4_fixup.o + pcie_layerscape_gen4_fixup.o pcie_layerscape.o obj-$(CONFIG_PCI_XILINX) += pcie_xilinx.o obj-$(CONFIG_PCIE_INTEL_FPGA) += pcie_intel_fpga.o obj-$(CONFIG_PCI_KEYSTONE) += pcie_dw_ti.o
-----Original Message----- From: Wasim Khan Sent: Friday, October 18, 2019 7:38 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de; Wasim Khan wasim.khan@nxp.com Subject: [PATCH 1/8] driver/pci : enable pcie layerscape code for pcie gen4 code
pcie_layerscape.o
Please check that there is no device which has both CONFIG_PCIE_LAYERSCAPE_GEN4 and CONFIG_PCIE_LAYERSCAPE defined. Can we think of better config name/re-organization considering all devices.
--priyankajain
obj-$(CONFIG_PCI_XILINX) += pcie_xilinx.o obj-$(CONFIG_PCIE_INTEL_FPGA) += pcie_intel_fpga.o obj-$(CONFIG_PCI_KEYSTONE) += pcie_dw_ti.o -- 2.7.4
Add stream_id_cur field to ls_pcie structure and initialize it with 0 for all pcie controllers. This field will be used for streamId calculation.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- drivers/pci/pcie_layerscape.c | 3 ++- drivers/pci/pcie_layerscape.h | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index db1375a..02f3825 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017 NXP + * Copyright 2017, 2019 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. * Layerscape PCIe driver */ @@ -339,6 +339,7 @@ static void ls_pcie_setup_ctrl(struct ls_pcie *pcie) dbi_writel(pcie, 0, PCIE_DBI_RO_WR_EN);
ls_pcie_disable_bars(pcie); + pcie->stream_id_cur = 0; }
static void ls_pcie_ep_setup_atu(struct ls_pcie *pcie) diff --git a/drivers/pci/pcie_layerscape.h b/drivers/pci/pcie_layerscape.h index ddfbba6..60efe89 100644 --- a/drivers/pci/pcie_layerscape.h +++ b/drivers/pci/pcie_layerscape.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2017 NXP + * Copyright 2017, 2019 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. * Layerscape PCIe driver */ @@ -144,6 +144,7 @@ struct ls_pcie { bool big_endian; bool enabled; int next_lut_index; + int stream_id_cur; int mode; };
-----Original Message----- From: Wasim Khan Sent: Friday, October 18, 2019 7:38 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de; Wasim Khan wasim.khan@nxp.com Subject: [PATCH 2/8] pci: layerscape: Add stream_id_cur field to ls_pcie structure
- Copyright 2017 NXP
- Copyright 2017, 2019 NXP
Better : 2017-2019
- Copyright 2014-2015 Freescale Semiconductor, Inc.
- Layerscape PCIe driver
- pcie->stream_id_cur = 0;
Same as above
- int stream_id_cur; int mode;
-- 2.7.4
--priyankajain
Update API names for layerscape fixup.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- drivers/pci/pcie_layerscape_fixup.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/pci/pcie_layerscape_fixup.c b/drivers/pci/pcie_layerscape_fixup.c index 089e031..e0dcd97 100644 --- a/drivers/pci/pcie_layerscape_fixup.c +++ b/drivers/pci/pcie_layerscape_fixup.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017 NXP + * Copyright 2017, 2019 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. * Layerscape PCIe driver */ @@ -69,8 +69,8 @@ static void ls_pcie_lut_set_mapping(struct ls_pcie *pcie, int index, u32 devid, * msi-map = <[devid] [phandle-to-msi-ctrl] [stream-id] [count] * [devid] [phandle-to-msi-ctrl] [stream-id] [count]>; */ -static void fdt_pcie_set_msi_map_entry(void *blob, struct ls_pcie *pcie, - u32 devid, u32 streamid) +static void fdt_pcie_set_msi_map_entry_ls(void *blob, struct ls_pcie *pcie, + u32 devid, u32 streamid) { u32 *prop; u32 phandle; @@ -122,8 +122,8 @@ static void fdt_pcie_set_msi_map_entry(void *blob, struct ls_pcie *pcie, * iommu-map = <[devid] [phandle-to-iommu-ctrl] [stream-id] [count] * [devid] [phandle-to-iommu-ctrl] [stream-id] [count]>; */ -static void fdt_pcie_set_iommu_map_entry(void *blob, struct ls_pcie *pcie, - u32 devid, u32 streamid) +static void fdt_pcie_set_iommu_map_entry_ls(void *blob, struct ls_pcie *pcie, + u32 devid, u32 streamid) { u32 *prop; u32 iommu_map[4]; @@ -175,7 +175,7 @@ static void fdt_pcie_set_iommu_map_entry(void *blob, struct ls_pcie *pcie, } }
-static void fdt_fixup_pcie(void *blob) +static void fdt_fixup_pcie_ls(void *blob) { struct udevice *dev, *bus; struct ls_pcie *pcie; @@ -209,11 +209,11 @@ static void fdt_fixup_pcie(void *blob) ls_pcie_lut_set_mapping(pcie, index, bdf >> 8, streamid); /* update msi-map in device tree */ - fdt_pcie_set_msi_map_entry(blob, pcie, bdf >> 8, - streamid); + fdt_pcie_set_msi_map_entry_ls(blob, pcie, bdf >> 8, + streamid); /* update iommu-map in device tree */ - fdt_pcie_set_iommu_map_entry(blob, pcie, bdf >> 8, - streamid); + fdt_pcie_set_iommu_map_entry_ls(blob, pcie, bdf >> 8, + streamid); } } #endif @@ -279,7 +279,7 @@ void ft_pci_setup(void *blob, bd_t *bd) ft_pcie_ls_setup(blob, pcie);
#if defined(CONFIG_FSL_LSCH3) || defined(CONFIG_FSL_LSCH2) - fdt_fixup_pcie(blob); + fdt_fixup_pcie_ls(blob); #endif }
-----Original Message----- From: Wasim Khan Sent: Friday, October 18, 2019 7:38 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de; Wasim Khan wasim.khan@nxp.com Subject: [PATCH 3/8] pci: layerscape: Update API names for layerscape fixup
Better description woul be suffixing API name with _ls Why you need this change?
2017-2019
streamid);
/* update iommu-map in device tree */streamid);
streamid);
}streamid);
- fdt_fixup_pcie_ls(blob);
#endif }
-- 2.7.4
--priyankajain
Hi Priyanka,
-----Original Message----- From: Priyanka Jain Sent: Monday, October 21, 2019 11:13 AM To: Wasim Khan wasim.khan@nxp.com; Z.q. Hou zhiqiang.hou@nxp.com Cc: u-boot@lists.denx.de Subject: RE: [PATCH 3/8] pci: layerscape: Update API names for layerscape fixup
OK. Will update the description. We have organized the code into common DT fixup and layerscape/layerscape_gen4 specific fixup.
2017-2019
*pcie,
streamid);
streamid);
}streamid);
#endif }
-- 2.7.4
--priyankajain
Update API names for layerscape gen4 fixup.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- drivers/pci/pcie_layerscape_gen4_fixup.c | 20 ++++++++++++-------- 1 file changed, 12 insertions(+), 8 deletions(-)
diff --git a/drivers/pci/pcie_layerscape_gen4_fixup.c b/drivers/pci/pcie_layerscape_gen4_fixup.c index 1c9e575..fe478db 100644 --- a/drivers/pci/pcie_layerscape_gen4_fixup.c +++ b/drivers/pci/pcie_layerscape_gen4_fixup.c @@ -64,8 +64,9 @@ static void ls_pcie_g4_lut_set_mapping(struct ls_pcie_g4 *pcie, int index, * msi-map = <[devid] [phandle-to-msi-ctrl] [stream-id] [count] * [devid] [phandle-to-msi-ctrl] [stream-id] [count]>; */ -static void fdt_pcie_set_msi_map_entry(void *blob, struct ls_pcie_g4 *pcie, - u32 devid, u32 streamid) +static void fdt_pcie_set_msi_map_entry_ls_gen4(void *blob, + struct ls_pcie_g4 *pcie, + u32 devid, u32 streamid) { u32 *prop; u32 phandle; @@ -106,8 +107,9 @@ static void fdt_pcie_set_msi_map_entry(void *blob, struct ls_pcie_g4 *pcie, * iommu-map = <[devid] [phandle-to-iommu-ctrl] [stream-id] [count] * [devid] [phandle-to-iommu-ctrl] [stream-id] [count]>; */ -static void fdt_pcie_set_iommu_map_entry(void *blob, struct ls_pcie_g4 *pcie, - u32 devid, u32 streamid) +static void fdt_pcie_set_iommu_map_entry_ls_gen4(void *blob, + struct ls_pcie_g4 *pcie, + u32 devid, u32 streamid) { u32 *prop; u32 iommu_map[4]; @@ -145,7 +147,7 @@ static void fdt_pcie_set_iommu_map_entry(void *blob, struct ls_pcie_g4 *pcie, fdt_appendprop(blob, nodeoff, "iommu-map", iommu_map, 16); }
-static void fdt_fixup_pcie(void *blob) +static void fdt_fixup_pcie_ls_gen4(void *blob) { struct udevice *dev, *bus; struct ls_pcie_g4 *pcie; @@ -176,9 +178,11 @@ static void fdt_fixup_pcie(void *blob) /* map PCI b.d.f to streamID in LUT */ ls_pcie_g4_lut_set_mapping(pcie, index, bdf >> 8, streamid); /* update msi-map in device tree */ - fdt_pcie_set_msi_map_entry(blob, pcie, bdf >> 8, streamid); + fdt_pcie_set_msi_map_entry_ls_gen4(blob, pcie, bdf >> 8, + streamid); /* update iommu-map in device tree */ - fdt_pcie_set_iommu_map_entry(blob, pcie, bdf >> 8, streamid); + fdt_pcie_set_iommu_map_entry_ls_gen4(blob, pcie, bdf >> 8, + streamid); } } #endif @@ -238,7 +242,7 @@ void ft_pci_setup(void *blob, bd_t *bd) ft_pcie_layerscape_gen4_setup(blob, pcie);
#if defined(CONFIG_FSL_LSCH3) || defined(CONFIG_FSL_LSCH2) - fdt_fixup_pcie(blob); + fdt_fixup_pcie_ls_gen4(blob); #endif }
Add FSL_PEX_STREAM_ID_END and remove FSL_PEX_STREAM_ID_NUM for lx2160a.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h index 93bdcc4..e518fa2 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2015-2018 NXP + * Copyright 2015-2019 NXP * Copyright 2014 Freescale Semiconductor, Inc. * */ @@ -83,14 +83,12 @@ /* PCI - programmed in PEXn_LUT */ #define FSL_PEX_STREAM_ID_START 7
-#ifdef CONFIG_ARCH_LX2160A -#define FSL_PEX_STREAM_ID_NUM (0x100) -#endif - #if defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LS1028A) #define FSL_PEX_STREAM_ID_END 22 #elif defined(CONFIG_ARCH_LS1088A) #define FSL_PEX_STREAM_ID_END 18 +#elif defined(CONFIG_ARCH_LX2160A) +#define FSL_PEX_STREAM_ID_END (0x100) #endif
Add Common device tree fixup for NXP SoCs. Based on SoC and revision call pcie_layerscape or pcie_layerscape_gen4 fixup.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- drivers/pci/Makefile | 5 +++-- drivers/pci/pcie_layerscape_fixup.c | 5 +++-- drivers/pci/pcie_layerscape_fixup_common.c | 22 ++++++++++++++++++++++ drivers/pci/pcie_layerscape_fixup_common.h | 21 +++++++++++++++++++++ drivers/pci/pcie_layerscape_gen4_fixup.c | 7 ++++--- 5 files changed, 53 insertions(+), 7 deletions(-) create mode 100644 drivers/pci/pcie_layerscape_fixup_common.c create mode 100644 drivers/pci/pcie_layerscape_fixup_common.h
diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index d6a9b8c..78820b6 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -33,9 +33,10 @@ obj-$(CONFIG_PCI_AARDVARK) += pci-aardvark.o obj-$(CONFIG_PCIE_DW_MVEBU) += pcie_dw_mvebu.o obj-$(CONFIG_PCIE_FSL) += pcie_fsl.o pcie_fsl_fixup.o obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape.o -obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape_fixup.o +obj-$(CONFIG_PCIE_LAYERSCAPE) += pcie_layerscape_fixup.o pcie_layerscape_fixup_common.o obj-$(CONFIG_PCIE_LAYERSCAPE_GEN4) += pcie_layerscape_gen4.o \ - pcie_layerscape_gen4_fixup.o pcie_layerscape.o + pcie_layerscape_gen4_fixup.o pcie_layerscape.o \ + pcie_layerscape_fixup_common.o pcie_layerscape_fixup.o obj-$(CONFIG_PCI_XILINX) += pcie_xilinx.o obj-$(CONFIG_PCIE_INTEL_FPGA) += pcie_intel_fpga.o obj-$(CONFIG_PCI_KEYSTONE) += pcie_dw_ti.o diff --git a/drivers/pci/pcie_layerscape_fixup.c b/drivers/pci/pcie_layerscape_fixup.c index e0dcd97..3d563d5 100644 --- a/drivers/pci/pcie_layerscape_fixup.c +++ b/drivers/pci/pcie_layerscape_fixup.c @@ -17,6 +17,7 @@ #include <asm/arch/clock.h> #endif #include "pcie_layerscape.h" +#include "pcie_layerscape_fixup_common.h"
#if defined(CONFIG_FSL_LSCH3) || defined(CONFIG_FSL_LSCH2) /* @@ -271,7 +272,7 @@ static void ft_pcie_ls_setup(void *blob, struct ls_pcie *pcie) }
/* Fixup Kernel DT for PCIe */ -void ft_pci_setup(void *blob, bd_t *bd) +void ft_pci_setup_ls(void *blob, bd_t *bd) { struct ls_pcie *pcie;
@@ -284,7 +285,7 @@ void ft_pci_setup(void *blob, bd_t *bd) }
#else /* !CONFIG_OF_BOARD_SETUP */ -void ft_pci_setup(void *blob, bd_t *bd) +void ft_pci_setup_ls(void *blob, bd_t *bd) { } #endif diff --git a/drivers/pci/pcie_layerscape_fixup_common.c b/drivers/pci/pcie_layerscape_fixup_common.c new file mode 100644 index 0000000..6f46363 --- /dev/null +++ b/drivers/pci/pcie_layerscape_fixup_common.c @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + * + */ + +#include <common.h> +#include <asm/arch/clock.h> +#include <asm/arch/soc.h> +#include "pcie_layerscape_fixup_common.h" + +void ft_pci_setup(void *blob, bd_t *bd) +{ + uint svr; + + svr = SVR_SOC_VER(get_svr()); + + if (svr == SVR_LX2160A && IS_SVR_REV(get_svr(), 1, 0)) + ft_pci_setup_ls_gen4(blob, bd); + else + ft_pci_setup_ls(blob, bd); +} diff --git a/drivers/pci/pcie_layerscape_fixup_common.h b/drivers/pci/pcie_layerscape_fixup_common.h new file mode 100644 index 0000000..b24893e --- /dev/null +++ b/drivers/pci/pcie_layerscape_fixup_common.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + * + * Layerscape PCIe driver + */ +#ifndef _PCIE_LAYERSCAPE_FIXUP_COMMON_H_ +#define _PCIE_LAYERSCAPE_FIXUP_COMMON_H_ + +#include <common.h> + +void ft_pci_setup_ls(void *blob, bd_t *bd); +#ifdef CONFIG_PCIE_LAYERSCAPE_GEN4 +void ft_pci_setup_ls_gen4(void *blob, bd_t *bd); +#else +static void ft_pci_setup_ls_gen4(void *blob, bd_t *bd) +{ +} +#endif + +#endif //_PCIE_LAYERSCAPE_FIXUP_COMMON_H_ diff --git a/drivers/pci/pcie_layerscape_gen4_fixup.c b/drivers/pci/pcie_layerscape_gen4_fixup.c index fe478db..480d242 100644 --- a/drivers/pci/pcie_layerscape_gen4_fixup.c +++ b/drivers/pci/pcie_layerscape_gen4_fixup.c @@ -19,6 +19,7 @@ #include <asm/arch/clock.h> #endif #include "pcie_layerscape_gen4.h" +#include "pcie_layerscape_fixup_common.h"
#if defined(CONFIG_FSL_LSCH3) || defined(CONFIG_FSL_LSCH2) /* @@ -37,7 +38,7 @@ static int ls_pcie_g4_next_streamid(struct ls_pcie_g4 *pcie) { int stream_id = pcie->stream_id_cur;
- if (stream_id > FSL_PEX_STREAM_ID_NUM) + if (stream_id > FSL_PEX_STREAM_ID_END) return -EINVAL;
pcie->stream_id_cur++; @@ -234,7 +235,7 @@ static void ft_pcie_layerscape_gen4_setup(void *blob, struct ls_pcie_g4 *pcie) }
/* Fixup Kernel DT for PCIe */ -void ft_pci_setup(void *blob, bd_t *bd) +void ft_pci_setup_ls_gen4(void *blob, bd_t *bd) { struct ls_pcie_g4 *pcie;
@@ -247,7 +248,7 @@ void ft_pci_setup(void *blob, bd_t *bd) }
#else /* !CONFIG_OF_BOARD_SETUP */ -void ft_pci_setup(void *blob, bd_t *bd) +void ft_pci_setup_ls_gen4(void *blob, bd_t *bd) { } #endif
Move streamId allocation to layerscape common device tree fixup. Calculate streamId based on SoC variant.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- drivers/pci/pcie_layerscape_fixup.c | 16 ++++------------ drivers/pci/pcie_layerscape_fixup_common.c | 22 ++++++++++++++++++++++ drivers/pci/pcie_layerscape_fixup_common.h | 1 + drivers/pci/pcie_layerscape_gen4_fixup.c | 18 ++++-------------- 4 files changed, 31 insertions(+), 26 deletions(-)
diff --git a/drivers/pci/pcie_layerscape_fixup.c b/drivers/pci/pcie_layerscape_fixup.c index 3d563d5..ae4594e 100644 --- a/drivers/pci/pcie_layerscape_fixup.c +++ b/drivers/pci/pcie_layerscape_fixup.c @@ -31,17 +31,6 @@ static int ls_pcie_next_lut_index(struct ls_pcie *pcie) return -ENOSPC; /* LUT is full */ }
-/* returns the next available streamid for pcie, -errno if failed */ -static int ls_pcie_next_streamid(void) -{ - static int next_stream_id = FSL_PEX_STREAM_ID_START; - - if (next_stream_id > FSL_PEX_STREAM_ID_END) - return -EINVAL; - - return next_stream_id++; -} - static void lut_writel(struct ls_pcie *pcie, unsigned int value, unsigned int offset) { @@ -192,10 +181,13 @@ static void fdt_fixup_pcie_ls(void *blob) bus = bus->parent; pcie = dev_get_priv(bus);
- streamid = ls_pcie_next_streamid(); + streamid = pcie_next_streamid(pcie->stream_id_cur, pcie->idx); + if (streamid < 0) { debug("ERROR: no stream ids free\n"); continue; + } else { + pcie->stream_id_cur++; }
index = ls_pcie_next_lut_index(pcie); diff --git a/drivers/pci/pcie_layerscape_fixup_common.c b/drivers/pci/pcie_layerscape_fixup_common.c index 6f46363..e5c63a7 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.c +++ b/drivers/pci/pcie_layerscape_fixup_common.c @@ -20,3 +20,25 @@ void ft_pci_setup(void *blob, bd_t *bd) else ft_pci_setup_ls(blob, bd); } + +#ifdef CONFIG_ARCH_LX2160A +/* returns the next available streamid for pcie, -errno if failed */ +int pcie_next_streamid(int currentid, int idx) +{ + if (currentid > FSL_PEX_STREAM_ID_END) + return -EINVAL; + + return currentid | ((idx + 1) << 11); +} +#else +/* returns the next available streamid for pcie, -errno if failed */ +int pcie_next_streamid(int currentid, int idx) +{ + static int next_stream_id = FSL_PEX_STREAM_ID_START; + + if (next_stream_id > FSL_PEX_STREAM_ID_END) + return -EINVAL; + + return next_stream_id++; +} +#endif diff --git a/drivers/pci/pcie_layerscape_fixup_common.h b/drivers/pci/pcie_layerscape_fixup_common.h index b24893e..0ab02b6 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.h +++ b/drivers/pci/pcie_layerscape_fixup_common.h @@ -17,5 +17,6 @@ static void ft_pci_setup_ls_gen4(void *blob, bd_t *bd) { } #endif +int pcie_next_streamid(int currentid, int id);
#endif //_PCIE_LAYERSCAPE_FIXUP_COMMON_H_ diff --git a/drivers/pci/pcie_layerscape_gen4_fixup.c b/drivers/pci/pcie_layerscape_gen4_fixup.c index 480d242..28cfc9a 100644 --- a/drivers/pci/pcie_layerscape_gen4_fixup.c +++ b/drivers/pci/pcie_layerscape_gen4_fixup.c @@ -33,19 +33,6 @@ static int ls_pcie_g4_next_lut_index(struct ls_pcie_g4 *pcie) return -ENOSPC; /* LUT is full */ }
-/* returns the next available streamid for pcie, -errno if failed */ -static int ls_pcie_g4_next_streamid(struct ls_pcie_g4 *pcie) -{ - int stream_id = pcie->stream_id_cur; - - if (stream_id > FSL_PEX_STREAM_ID_END) - return -EINVAL; - - pcie->stream_id_cur++; - - return stream_id | ((pcie->idx + 1) << 11); -} - /* * Program a single LUT entry */ @@ -162,10 +149,13 @@ static void fdt_fixup_pcie_ls_gen4(void *blob) bus = bus->parent; pcie = dev_get_priv(bus);
- streamid = ls_pcie_g4_next_streamid(pcie); + streamid = pcie_next_streamid(pcie->stream_id_cur, pcie->idx); + if (streamid < 0) { debug("ERROR: no stream ids free\n"); continue; + } else { + pcie->stream_id_cur++; }
index = ls_pcie_g4_next_lut_index(pcie);
lx2 rev2 requires device tree fixup as it has SNP pcie controller. Add device tree fixup for lx2 rev2 based on SoC and Version.
Signed-off-by: Wasim Khan wasim.khan@nxp.com --- drivers/pci/pcie_layerscape_fixup.c | 1 + drivers/pci/pcie_layerscape_fixup_common.c | 76 ++++++++++++++++++++++++++++++ drivers/pci/pcie_layerscape_fixup_common.h | 1 + 3 files changed, 78 insertions(+)
diff --git a/drivers/pci/pcie_layerscape_fixup.c b/drivers/pci/pcie_layerscape_fixup.c index ae4594e..fb3c5bf 100644 --- a/drivers/pci/pcie_layerscape_fixup.c +++ b/drivers/pci/pcie_layerscape_fixup.c @@ -208,6 +208,7 @@ static void fdt_fixup_pcie_ls(void *blob) fdt_pcie_set_iommu_map_entry_ls(blob, pcie, bdf >> 8, streamid); } + pcie_board_fix_fdt(blob); } #endif
diff --git a/drivers/pci/pcie_layerscape_fixup_common.c b/drivers/pci/pcie_layerscape_fixup_common.c index e5c63a7..f42faa2 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.c +++ b/drivers/pci/pcie_layerscape_fixup_common.c @@ -21,6 +21,82 @@ void ft_pci_setup(void *blob, bd_t *bd) ft_pci_setup_ls(blob, bd); }
+int lx2_board_fix_fdt(void *fdt) +{ + char *reg_name, *old_str, *new_str; + const char *reg_names; + int names_len, old_str_len, new_str_len, remaining_str_len; + struct str_map { + char *old_str; + char *new_str; + } reg_names_map[] = { + { "csr_axi_slave", "regs" }, + { "config_axi_slave", "config" } + }; + int off = -1, i; + u32 val; + + off = fdt_node_offset_by_compatible(fdt, -1, "fsl,lx2160a-pcie"); + while (off != -FDT_ERR_NOTFOUND) { + fdt_setprop(fdt, off, "compatible", "fsl,ls2088a-pcie", + strlen("fsl,ls2088a-pcie") + 1); + + reg_names = fdt_getprop(fdt, off, "reg-names", &names_len); + if (!reg_names) + continue; + reg_name = (char *)reg_names; + remaining_str_len = names_len - (reg_name - reg_names); + i = 0; + while ((i < ARRAY_SIZE(reg_names_map)) && remaining_str_len) { + old_str = reg_names_map[i].old_str; + new_str = reg_names_map[i].new_str; + old_str_len = strlen(old_str); + new_str_len = strlen(new_str); + if (memcmp(reg_name, old_str, old_str_len) == 0) { + /* first only leave required bytes for new_str + * and copy rest of the string after it + */ + memcpy(reg_name + new_str_len, + reg_name + old_str_len, + remaining_str_len - old_str_len); + + /* Now copy new_str */ + memcpy(reg_name, new_str, new_str_len); + names_len -= old_str_len; + names_len += new_str_len; + i++; + } + + reg_name = memchr(reg_name, '\0', remaining_str_len); + if (!reg_name) + break; + reg_name += 1; + + remaining_str_len = names_len - (reg_name - reg_names); + } + fdt_setprop(fdt, off, "reg-names", reg_names, names_len); + fdt_delprop(fdt, off, "apio-wins"); + fdt_delprop(fdt, off, "ppio-wins"); + val = cpu_to_fdt32(0x4); + fdt_setprop(fdt, off, "num-lanes", &val, sizeof(val)); + off = fdt_node_offset_by_compatible(fdt, off, + "fsl,lx2160a-pcie"); + } + return 0; +} + +int pcie_board_fix_fdt(void *fdt) +{ + uint svr; + + svr = SVR_SOC_VER(get_svr()); + + if (svr == SVR_LX2160A && IS_SVR_REV(get_svr(), 2, 0)) + return lx2_board_fix_fdt(fdt); + + return 0; +} + #ifdef CONFIG_ARCH_LX2160A /* returns the next available streamid for pcie, -errno if failed */ int pcie_next_streamid(int currentid, int idx) diff --git a/drivers/pci/pcie_layerscape_fixup_common.h b/drivers/pci/pcie_layerscape_fixup_common.h index 0ab02b6..ef0f0a7 100644 --- a/drivers/pci/pcie_layerscape_fixup_common.h +++ b/drivers/pci/pcie_layerscape_fixup_common.h @@ -18,5 +18,6 @@ static void ft_pci_setup_ls_gen4(void *blob, bd_t *bd) } #endif int pcie_next_streamid(int currentid, int id); +int pcie_board_fix_fdt(void *fdt);
Priyanka Jain
Wasim Khan
