[U-Boot] [PATCH v2] armv8: fsl-lsch2: add clock support for the second eSDHC
Layerscape began to use two eSDHC controllers, for example, LS1012A. They are same IP block with same reference clock. This patch is to add clock support for the second eSDHC.
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- Change in v2: update the Copyright information
arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 723d7eac5d..c5d1becd8b 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2015 Freescale Semiconductor, Inc. + * Copyright 2014-2016 Freescale Semiconductor, Inc. + * Copyright 2017-2019 NXP Semiconductors */
#include <common.h> @@ -250,6 +251,7 @@ unsigned int mxc_get_clock(enum mxc_clock clk) return get_i2c_freq(0); #if defined(CONFIG_FSL_ESDHC) case MXC_ESDHC_CLK: + case MXC_ESDHC2_CLK: return get_sdhc_freq(0); #endif case MXC_DSPI_CLK:
Yinbo Zhu
