[RFC PATCH] tools: kwbimage: Allow to disable compilation of kwbimage on non-mvebu platforms
kwbimage depends on libcrypto. 32-bit mvebu platforms (except Orion and Discovery, which are not in mach-mvebu) require kwimage for building SPL.
Some users want to compile u-boot tools without libcrypto.
Therefore add a new symbol CONFIG_TOOLS_KWBIMAGE which controls compilation of kwbimage and define correct dependences between mvebu, kwbimage and libcrypto targets.
This allows disabling of kwbimage compilation on non-mvebu platforms.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/mach-mvebu/Kconfig | 1 + tools/Kconfig | 5 +++++ tools/Makefile | 5 ++++- 3 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 54dff9986b41..1ccbccea1dda 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -15,6 +15,7 @@ config ARMADA_32BIT select SPL_SIMPLE_BUS if SPL select SUPPORT_SPL select TRANSLATION_OFFSET + select TOOLS_KWBIMAGE if SPL
config ARMADA_64BIT bool diff --git a/tools/Kconfig b/tools/Kconfig index 91ce8ae3e516..40866c5713d9 100644 --- a/tools/Kconfig +++ b/tools/Kconfig @@ -25,6 +25,11 @@ config TOOLS_LIBCRYPTO This selection does not affect target features, such as runtime FIT signature verification.
+config TOOLS_KWBIMAGE + bool "Enable kwbimage support in host tools" + default y + depends on TOOLS_LIBCRYPTO + config TOOLS_FIT def_bool y help diff --git a/tools/Makefile b/tools/Makefile index 75d8fe71d668..08f1f5a51fb3 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -118,7 +118,6 @@ dumpimage-mkimage-objs := aisimage.o \ imximage.o \ imx8image.o \ imx8mimage.o \ - kwbimage.o \ lib/md5.o \ lpc32xximage.o \ mxsimage.o \ @@ -150,6 +149,10 @@ dumpimage-mkimage-objs := aisimage.o \ $(RSA_OBJS-y) \ $(AES_OBJS-y)
+ifdef CONFIG_TOOLS_KWBIMAGE +dumpimage-mkimage-objs += kwbimage.o +endif + dumpimage-objs := $(dumpimage-mkimage-objs) dumpimage.o mkimage-objs := $(dumpimage-mkimage-objs) mkimage.o fit_info-objs := $(dumpimage-mkimage-objs) fit_info.o
Thanks for sending this patch!
- select TOOLS_KWBIMAGE if SPL
- bool "Enable kwbimage support in host tools"
- default y
- depends on TOOLS_LIBCRYPTO
This symbol needs to select TOOLS_LIBCRYPTO. Otherwise that option can still be deselected by the user, and the build fails when doing so:
$ make CROSS_COMPILE=arm-linux-musleabi- db-mv784mp-gp_defconfig # # configuration written to .config # $ make CROSS_COMPILE=arm-linux-musleabi- nconfig scripts/kconfig/nconf Kconfig $ make CROSS_COMPILE=arm-linux-musleabi- scripts/kconfig/conf --syncconfig Kconfig
WARNING: unmet direct dependencies detected for TOOLS_KWBIMAGE Depends on [n]: TOOLS_LIBCRYPTO [=n] Selected by [y]: - ARMADA_32BIT [=y] && ARM [=y] && ARCH_MVEBU [=y] && SPL [=y]
WARNING: unmet direct dependencies detected for TOOLS_KWBIMAGE Depends on [n]: TOOLS_LIBCRYPTO [=n] Selected by [y]: - ARMADA_32BIT [=y] && ARM [=y] && ARCH_MVEBU [=y] && SPL [=y] CFG u-boot.cfg GEN include/autoconf.mk.dep CFG spl/u-boot.cfg GEN include/autoconf.mk GEN spl/include/autoconf.mk ===================== WARNING ====================== This board does not use CONFIG_DM_I2C (Driver Model for I2C drivers). Please update the board to use CONFIG_DM_I2C before the v2022.04 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ==================================================== CFGCHK u-boot.cfg HOSTLD tools/dumpimage HOSTLD tools/mkimage ld: tools/kwbimage.o: in function `kwb_compute_pubkey_hash': kwbimage.c:(.text+0x1a00): undefined reference to `EVP_MD_CTX_new' ld: kwbimage.c:(.text+0x1a10): undefined reference to `EVP_MD_CTX_reset' ld: kwbimage.c:(.text+0x1a18): undefined reference to `EVP_sha256' [and more linker errors]
Regards, Samuel
Hello!
- default y
Yes, that it truth. But in case user does not have openssl installed then it show another compile / link error.
And I do not know what is the better "user experience". If build system should throw warnings (like below) about unmet dependences (user chose something which cannot be satisfied by build system) with link errors. Or if build system should silently enable openssl symbols, even when they were explicitly disabled by user (via config file) and then throw compile error about missing header files.
I do not have opinion which of these two option is better.
Of course changing "depends on" to "select" is not a problem.
I known that these warning lines come from kconfig tools... But should not they be rather fatal errors? As it indicates issues with configuration.
Regards, Samuel
Hello,
Am Thu, Oct 21, 2021 at 11:33:04AM +0200 schrieb Pali Rohár:
Indeed. Build of master (v2022.01-rc3) fails like this, if there are no OpenSSL headers on the host, and although CONFIG_TOOLS_LIBCRYPTO is not set:
HOSTCC tools/kwbimage.o /home/adahl/src/u-boot/tools/kwbimage.c:18:10: fatal error: openssl/bn.h: Datei oder Verzeichnis nicht gefunden #include <openssl/bn.h> ^~~~~~~~~~~~~~ compilation terminated.
This is already broken with U-Boot v2021.10. What's the state of this patch?
Greets Alex
- default y
dumpimage-objs := $(dumpimage-mkimage-objs) dumpimage.o mkimage-objs := $(dumpimage-mkimage-objs) mkimage.o fit_info-objs := $(dumpimage-mkimage-objs) fit_info.o -- 2.20.1
I have sent it to ML for discussion as one of the possible solution for this problem. I guess that decision how to solve it up to maintainers.
Anyway, I have tested it on Debian and works fine for me.
Hei hei,
- default y
FWIW:
Tested-by: Alexander Dahl ada@thorsis.com
Greets Alex
Hello,
Am Dienstag, 30. November 2021, 17:06:11 CEST schrieb Alexander Dahl:
config ARMADA_64BIT
bool
- default y
config TOOLS_FIT
def_bool y help
FWIW:
After migrating some boards from u-boot v2021.10 to v2022.01 I found this is still an issue. Build for example at91 board fails if CONFIG_TOOLS_LIBCRYPTO is disabled and build host has no openssl headers installed. (Error output below.)
Could anyone please have a look at this patch again? I don't need host tools linked with openssl. When building with ptxdist, this only increases build time (for the additional host-openssl) for no benefit.
(Actually I don't need kwbimage for my target at all, why is it built for platforms not needing it in the first place?)
HOSTLD tools/mkimage /usr/bin/ld: tools/kwbimage.o: in function `openssl_err': kwbimage.c:(.text+0x9a): undefined reference to `ERR_get_error' /usr/bin/ld: kwbimage.c:(.text+0xb6): undefined reference to `ERR_error_string' /usr/bin/ld: tools/kwbimage.o: in function `kwb_compute_pubkey_hash': kwbimage.c:(.text+0x119): undefined reference to `EVP_MD_CTX_new' /usr/bin/ld: kwbimage.c:(.text+0x12d): undefined reference to `EVP_MD_CTX_reset' /usr/bin/ld: kwbimage.c:(.text+0x132): undefined reference to `EVP_sha256' /usr/bin/ld: kwbimage.c:(.text+0x13d): undefined reference to `EVP_DigestInit' /usr/bin/ld: kwbimage.c:(.text+0x158): undefined reference to `EVP_DigestUpdate' /usr/bin/ld: kwbimage.c:(.text+0x16c): undefined reference to `EVP_DigestFinal' /usr/bin/ld: kwbimage.c:(.text+0x17a): undefined reference to `EVP_MD_CTX_reset' /usr/bin/ld: kwbimage.c:(.text+0x182): undefined reference to `EVP_MD_CTX_free' /usr/bin/ld: tools/kwbimage.o: in function `kwb_export_pubkey': kwbimage.c:(.text+0x222): undefined reference to `RSA_get0_key' /usr/bin/ld: kwbimage.c:(.text+0x233): undefined reference to `RSA_get0_key' /usr/bin/ld: kwbimage.c:(.text+0x265): undefined reference to `BN_num_bits' /usr/bin/ld: kwbimage.c:(.text+0x27a): undefined reference to `BN_num_bits' /usr/bin/ld: kwbimage.c:(.text+0x2ee): undefined reference to `BN_bn2bin' /usr/bin/ld: kwbimage.c:(.text+0x30b): undefined reference to `BN_bn2bin' /usr/bin/ld: tools/kwbimage.o: in function `kwb_load_rsa_key': kwbimage.c:(.text+0x4a1): undefined reference to `PEM_read_RSAPrivateKey' /usr/bin/ld: tools/kwbimage.o: in function `kwb_sign': kwbimage.c:(.text+0x174d): undefined reference to `EVP_PKEY_new' /usr/bin/ld: kwbimage.c:(.text+0x1764): undefined reference to `EVP_PKEY_set1_RSA' /usr/bin/ld: kwbimage.c:(.text+0x1774): undefined reference to `EVP_PKEY_size' /usr/bin/ld: kwbimage.c:(.text+0x1784): undefined reference to `EVP_MD_CTX_new' /usr/bin/ld: kwbimage.c:(.text+0x1798): undefined reference to `EVP_MD_CTX_reset' /usr/bin/ld: kwbimage.c:(.text+0x179d): undefined reference to `EVP_sha256' /usr/bin/ld: kwbimage.c:(.text+0x17a8): undefined reference to `EVP_DigestInit' /usr/bin/ld: kwbimage.c:(.text+0x17be): undefined reference to `EVP_DigestUpdate' /usr/bin/ld: kwbimage.c:(.text+0x17d9): undefined reference to `EVP_SignFinal' /usr/bin/ld: kwbimage.c:(.text+0x17eb): undefined reference to `EVP_MD_CTX_reset' /usr/bin/ld: kwbimage.c:(.text+0x17f3): undefined reference to `EVP_MD_CTX_free' /usr/bin/ld: kwbimage.c:(.text+0x17fb): undefined reference to `EVP_PKEY_free' /usr/bin/ld: kwbimage.c:(.text+0x181a): undefined reference to `EVP_PKEY_free' /usr/bin/ld: kwbimage.c:(.text+0x1882): undefined reference to `EVP_MD_CTX_free' /usr/bin/ld: tools/kwbimage.o: in function `kwb_verify': kwbimage.c:(.text+0x18fe): undefined reference to `EVP_PKEY_new' /usr/bin/ld: kwbimage.c:(.text+0x1915): undefined reference to `EVP_PKEY_set1_RSA' /usr/bin/ld: kwbimage.c:(.text+0x1925): undefined reference to `EVP_PKEY_size' /usr/bin/ld: kwbimage.c:(.text+0x1935): undefined reference to `EVP_MD_CTX_new' /usr/bin/ld: kwbimage.c:(.text+0x1949): undefined reference to `EVP_MD_CTX_reset' /usr/bin/ld: kwbimage.c:(.text+0x194e): undefined reference to `EVP_sha256' /usr/bin/ld: kwbimage.c:(.text+0x1959): undefined reference to `EVP_DigestInit' /usr/bin/ld: kwbimage.c:(.text+0x196f): undefined reference to `EVP_DigestUpdate' /usr/bin/ld: kwbimage.c:(.text+0x198a): undefined reference to `EVP_VerifyFinal' /usr/bin/ld: kwbimage.c:(.text+0x19aa): undefined reference to `EVP_MD_CTX_free' /usr/bin/ld: kwbimage.c:(.text+0x19c3): undefined reference to `EVP_PKEY_free' /usr/bin/ld: kwbimage.c:(.text+0x1a8f): undefined reference to `EVP_MD_CTX_reset' /usr/bin/ld: kwbimage.c:(.text+0x1a97): undefined reference to `EVP_MD_CTX_free' /usr/bin/ld: kwbimage.c:(.text+0x1a9f): undefined reference to `EVP_PKEY_free' /usr/bin/ld: tools/kwbimage.o: in function `kwb_sign_csk_with_kak': kwbimage.c:(.text+0x233d): undefined reference to `d2i_RSAPublicKey' /usr/bin/ld: tools/kwbimage.o: in function `EVP_MD_CTX_cleanup': kwbimage.c:(.text+0xe51): undefined reference to `EVP_MD_CTX_reset' collect2: error: ld returned 1 exit status make[2]: *** [scripts/Makefile.host:104: tools/mkimage] Fehler 1 make[1]: *** [/mnt/data/adahl/src/u-boot/Makefile:1810: tools] Fehler 2 make[1]: Verzeichnis „/home/adahl/build/u-boot/v2022.01.x“ wird verlassen make: *** [Makefile:177: sub-make] Fehler 2
Greets Alex
Reviewing / accepting this patch is up to the u-boot maintainers, not me. I just provided this patch as I think it could be useful.
This is because mkimage is generic tool which supports all image formats supported by U-Boot. For example on x86 host it allows users to build different ARM images, not only x86. I guess this is primary intended for Linux distributions to support all U-Boot targets...
Alexander Dahl
Pali Rohár
Samuel Holland
