[PATCH 1/1] examples: use QEMU compatible LOAD_ADDR on 32-bit ARM
On many 32-bit ARM boards including QEMU memory starts at 0x40000000.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- examples/api/Makefile | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/examples/api/Makefile b/examples/api/Makefile index 722c7e45904..f0f107562f1 100644 --- a/examples/api/Makefile +++ b/examples/api/Makefile @@ -9,11 +9,7 @@ ifeq ($(ARCH),powerpc) LOAD_ADDR = 0x40000 endif ifeq ($(ARCH),arm) -ifdef CONFIG_64BIT LOAD_ADDR = 0x40400000 -else -LOAD_ADDR = 0x1000000 -endif endif ifeq ($(ARCH),mips) ifdef CONFIG_64BIT
If we're going to start cleaning this area up and expecting it to work more broadly, is there a reason we can't use CONFIG_SYS_LOAD_ADDR or CONFIG_STANDALONE_LOAD_ADDR here?
Tom Rini trini@konsulko.com schrieb am Sa., 23. Nov. 2024, 16:24:
loadaddr == CONFIG_SYS_LOAD_ADDR on RISC-V QEMU. Command bootelf did not work for me, if the ELF binary had been loaded to its LOAD_ADDR.
I did not investigate yet why bootelf fails in this case.
Best regards
Heinrich
-- Tom
The examples, broadly speaking, do not run out of the box since they assume an address to be loaded in to memory at and run from, rather than a Kconfig entry. The next problem for RISC-V is that, well, there's no api/api_platform-riscv.c file (and forever ago I steered people away from adding that and instead adding EFI support, the patches are in patchwork somewhere).
https://patchwork.ozlabs.org/project/uboot/patch/20241123084754.59182-2-hein...
provides api_platform.c for RISC-V. This patch is only about ARM.
Best regards
Heinrich
Yeah. For everyone we need to move this to Kconfig and it should likely be STANDALONE_LOAD_ADDR being re-used and not a new symbol. Hard coded might-work addresses are a leftover of pre-Kconfig days.
The following seems to work in the Makefile:
LOAD_ADDR:=${shell printf 0x%X $$(( $(CONFIG_SYS_LOAD_ADDR) + 0x3000000 ))}
I just need to check which offset to use.
Best regards
Heinrich
