[U-Boot-Users] Flawed ATAG passing
Hi.
While trying to get Linux (2.4.19-rmk7-pxa2 and 2.6.7-mm7) start with a ramdisk on a xm250 board, i discovered, that uboot 1.1.1 seems to have a problem passing the ATAGs to the kernel.
Here is some debug output with linux 2.6.7-mm7
u-Boot 1.1.1 (Jul 28 2004 - 17:11:18)
U-Boot code: A3F80000 -> A3F998AC BSS: -> A3F9DBD8 RAM Configuration: Bank #0: a0000000 64 MB Bank #1: a4000000 0 kB Bank #2: a8000000 0 kB Bank #3: ac000000 0 kB Flash: 32 MB In: serial Out: serial Err: serial Hit any key to stop autoboot: 3 2 1 0 Using MAC Address 00:40:42:01:65:AA BOOTP broadcast 1 got BOOTP packet (src=67, dst=68, len=300 want_len=300) Filtering pkt = 0 Bootfile: uImage [BOOTP] Checking extension (300 bytes)... [BOOTP] Processing extension 1... (4 bytes) [BOOTP] Processing extension 3... (4 bytes) [BOOTP] Processing extension 6... (4 bytes) [BOOTP] Processing extension 15... (16 bytes) [BOOTP] Processing extension 28... (4 bytes) [BOOTP] Received fields: NetOurSubnetMask : 255.255.255.0 NetOurGatewayIP : 192.168.0.1 Got good BOOTP TFTP from server 192.168.0.1; our IP address is 192.168.0.3 Filename 'uImage'. Load address: 0xa3000000 Loading: *T ################################################################# ################################################################# ########################### done Bytes transferred = 799312 (c3250 hex) ## Booting image at a3000000 ... Image Name: Linux-Image Created: 2004-07-28 18:10:20 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 799248 Bytes = 780.5 kB Load Address: a0200000 Entry Point: a0200000 Verifying Checksum ... OK OK ## Loading Ramdisk Image at 00200000 ... Image Name: initrd Created: 2004-07-27 16:09:34 UTC Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 2517544 Bytes = 2.4 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Initrd at 00200040. Size 2517544## Transferring control to Linux (at address a0200000) ... ## setup_start_tag ## setup_memory_tags start a0000000 size:04000000 ## setup_commandling_tag size:0000001c line: root=/dev/ram0 init=/linuxrc ## setup_initrd_args start:00200040, end:00466a68 ## setup_end_tag
Starting kernel ...
Uncompressing Linux......................................................... done, booting the kernel. Linux version 2.6.7-mm7 (chrkap@allesodernix) (gcc version 3.3.3) #21 Wed Jul 28 18:10:04 UTC 2004 CPU: XScale-PXA255 [69052d06] revision 6 (ARMv5TE) CPU: D undefined 5 cache CPU: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets CPU: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets Machine: Intel DBPXA250 Development Platform (aka Lubbock) parse_tags number of tags: 5 parsing tag: 0x54410001 parse_tag: tag 0x54410001 parse_tag_core parsing tag: 0x54410002 parse_tag: tag 0x54410002 parse_tag_mem32 start 0xa0000000 size 0x01000000 Memory policy: ECC disabled, Data cache writeback Memory clock: 99.53MHz (*27) Run Mode clock: 398.13MHz (*4) Turbo Mode clock: 398.13MHz (*1.0, inactive) On node 0 totalpages: 4096 DMA zone: 4096 pages, LIFO batch:1 Normal zone: 0 pages, LIFO batch:1 HighMem zone: 0 pages, LIFO batch:1 Built 1 zonelists Kernel command line: root=/dev/ram console=ttyS0,115200 PID hash table entries: 128 (order 7: 1024 bytes) Console: colour dummy device 80x30 Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 2048 (order: 1, 8192 bytes) Memory: 16MB = 16MB total Memory: 14376KB available (1366K code, 346K data, 76K init) Calibrating delay loop... 397.31 BogoMIPS Mount-cache hash table entries: 512 (order: 0, 4096 bytes) CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 NetWinder Floating Point Emulator V0.97 (double precision) ttyS0 at MMIO 0x40100000 (irq = 15) is a FFUART ttyS1 at MMIO 0x40200000 (irq = 14) is a BTUART ttyS2 at MMIO 0x40700000 (irq = 13) is a STUART RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize Using anticipatory io scheduler physmap flash device: 4000000 at 0 cfi_cmdset_0001: Erase suspend on write enabled Using buffer write method cmdlinepart partition parsing not available RedBoot partition parsing not available pxa2xx_udc: version 14-Dec-2003 usb0: Ethernet Gadget, version: St Patrick's Day 2004 usb0: using pxa2xx_udc, OUT ep2out-bulk IN ep1in-bulk usb0: MAC 1a:60:19:07:1a:f0 mice: PS/2 mouse device common for all mice NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 1024 bind 2048) NET: Registered protocol family 1 Kernel panic: VFS: Unable to mount root fs on unknown-block(1,0) ====
It seems that the kernel recieves all tags u-boot provided, but not all are parsed. Which seems strange, since none of the parse_tag_* functions in arch/arm/kernel/setup.c which are called by parse_tags(), can return something other than 0 which means that parse_tags() should read the next tag wich it doesn't.
Has anybody experienced something simmilar, is this a known issue?
Dear Christian,
Why do you think that U-Boot has problems when the Linux kernel is actually receiving all ATAGs?
It works fine (at least for 2.4.x kernels) on several boards; I didn't test 2.6.x so far.
How about adding a bit more debugging code to your Linux kerenl?
So your bootloader is passing fine the tags to kernel.
Here you are telling it to boot from ramdisk (maj 1, minor 0)
Your kernel fails to mount the ramdisk, since you have RAMDISK driver etc, then the next most likely reason is you are missing the filesystem support in your kernel. For exampel if your ramdisk in in ext2 format then make sure your kernel has ext2 support compiled in (not as a module).
-R
...or his kernel does not know how to deal with a ramdisk in flash memory (this has been discussed many times before; the next time it comes up I'll add it as a FAQ -- for now please see http://sourceforge.net/mailarchive/message.php?msg_id=6839224)
Christian Kapeller
Ralph Siemsen
