[GIT PULL] Please pull u-boot-imx-master-20240420
Hi Tom,
Please pull from u-boot-imx/master, thanks.
The following changes since commit af04f37a78c7e61597fb9ed6db2c8f8d7f8b0f92:
Merge tag 'u-boot-stm32-20240419' of https://source.denx.de/u-boot/custodians/u-boot-stm (2024-04-19 14:25:04 -0600)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20240420
for you to fetch changes up to 8b8c699d88171b0d40f072e114f32cce93cb2987:
imx8mm_venice_defconfig: Enable PCIe/NVMe support (2024-04-20 00:37:51 -0300)
u-boot-imx-master-20240420 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/20444
- Make i.MX93 boot less verbose. - Remove unneedd environment variables from Toradex i.MX boards. - Use gpio-hog on verdin-imx8mm/imx8mp. - Add PCIe support for i.MX8MM. - Add TPM support for imx8m*-venice. ---------------------------------------------------------------- Fabio Estevam (1): imx93: Move SoC and lifeclycle information to debug level
Francesco Dolcini (1): board: toradex: imx: Remove not needed env variables
Stefan Eichenberger (1): arm: dts: verdin-imx8mm/imx8mp: use gpio-hog for sleep moci
Tim Harvey (6): imx8m*-venice: enable TPM support board: gateworks: venice: fix dt adjustment for gw73xx baseboard for imx8mp imx8m*_venice_defconfig: enable ipv6, wget and tftpput clk: imx8mm: Add support for PCIe clocks pci: dw_imx: add support for IMX8MM imx8mm_venice_defconfig: Enable PCIe/NVMe support
arch/arm/dts/imx8mm-verdin-wifi-dev-u-boot.dtsi | 5 +++++ arch/arm/dts/imx8mp-verdin-wifi-dev-u-boot.dtsi | 4 ++++ board/freescale/imx93_evk/spl.c | 4 ++-- board/gateworks/venice/venice.c | 7 ++++--- board/phytec/phycore_imx93/spl.c | 4 ++-- board/variscite/imx93_var_som/spl.c | 4 ++-- configs/imx8mm_venice_defconfig | 21 +++++++++++++++++++ configs/imx8mn_venice_defconfig | 15 ++++++++++++++ configs/imx8mp_venice_defconfig | 15 ++++++++++++++ drivers/clk/imx/clk-imx8mm.c | 27 +++++++++++++++++++++++++ drivers/pci/pcie_dw_imx.c | 18 +++++++++++++++-- include/configs/apalis-imx8.h | 2 -- include/configs/apalis_imx6.h | 9 +-------- include/configs/colibri-imx6ull.h | 10 +++------ include/configs/colibri-imx8x.h | 2 -- include/configs/colibri_imx6.h | 9 +-------- include/configs/colibri_imx7.h | 11 +++------- include/configs/verdin-imx8mm.h | 3 --- include/configs/verdin-imx8mp.h | 5 ----- 19 files changed, 121 insertions(+), 54 deletions(-)
On Sat, Apr 20, 2024 at 03:33:22PM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
