[U-Boot] [PATCH] buildman: Deal more nicely with invalid build-status file
The 'done' files created by buildman may end up being empty if buildman runs out of disk space while writing them. At present buildman dies with an exception when using -s to check the build status. Fix this.
Seriesl-cc: trini
tools/buildman/builder.py | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index 6a6c83bf336..fbb236676c7 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -673,7 +673,12 @@ class Builder: environment = {} if os.path.exists(done_file): with open(done_file, 'r') as fd: - return_code = int(fd.readline()) + try: + return_code = int(fd.readline()) + except ValueError: + # The file may be empty due to running out of disk space. + # Try a rebuild + return_code = 1 err_lines = [] err_file = self.GetErrFile(commit_upto, target) if os.path.exists(err_file):
Seriesl-cc: trini
Applied to u-boot-dm, thanks!
