[U-Boot] Please pull u-boot-mpc85xx master
Tom,
The following changes since commit b149c4c399b111cec1ff7505ca9fabbeeb4fe394:
ARM:tegra20: Remove aes debug prints (2014-04-18 16:14:17 -0400)
git://git.denx.de/u-boot-mpc85xx.git master
for you to fetch changes up to 08ad9b068afb8842df4cd559c327f54a42811a8d:
ar8031: modify the config func of ar8031 to ar8021_config (2014-04-22 17:58:53 -0700)
---------------------------------------------------------------- Alexander Graf (6): fdt_support: split fdt_getprop_u32_default fdt_support: Add helper function to read "ranges" property PPC: 85xx: Remove IVOR reset PPC: 85xx: Generalize DDR TLB mapping function PPC 85xx: Add ELF entry point PPC 85xx: Add qemu-ppce500 machine
Aneesh Bansal (9): powerpc/p1010rdb: SECURE BOOT enabled for NAND powerpc/p1010rdb: SECURE BOOT- enable workaround for IFC errata A003399 powerpc/mpc8xxx: SECURE BOOT- Disable law 0 for non PBL platforms powerpc/mpc85xx: SECURE BOOT- Add secure boot target for BSC9132QDS powerpc/mpc85xx: SECURE BOOT- Add NAND secure boot target for BSC9132QDS powerpc/mpc85xx: SECURE BOOT- Add secure boot target for B4860QDS powerpc/mpc85xx: SECURE BOOT- Add secure boot target for T4240QDS and T4160QDS powerpc/mpc85xx: SECURE BOOT- Add secure boot target for T2080QDS powerpc/mpc85xx: SECURE BOOT- Add secure boot target for T1040QDS and T1040RDB
Codrin Ciubotariu (2): net/phy: Fix PHY id for VSC8514 powerpc/cpu/mpc85xx: Add MAC address for layer 2 switch
Haijun.Zhang (1): Powerpc/mpc8536DS: Increase SPI/SD uboot Image size to 768K
Nikhil Badola (4): fsl/usb: Fix phy type for Second USB controller fsl/usb: Workaround for USB erratum-A007075 fsl/usb: Increase TXFIFOTHRESH value for usb write in T4 Rev 2.0 powerpc/mpc85xx: Add Differential SYSCLK config support T1040
Prabhakar Kushwaha (19): board/b4860qds:Slow MDC clock to comply IEEE specs in PBI config driver/mmc: fix compile warnings powerpc/T1040: add mtdparts suppport for T104xRDB and T1040QDS board/t104xrdb: Add support of CPLD powerpc/mpc85xx: Remove QE firmware copy from NAND board/t1042rdb_pi: Disable CONFIG_QE and CONFIG_U_QE powerpc/mpc85xx: Move LAW_EN define outside of config powerpc/mpc85xx: Avoid hardcoding in SPL linker script powerpc:Add support of SPL non-relocation powerpc/mpc85xx:Disable non DDR LAWs before init_law driver/ifc: define nand_spl_load_image() for SPL driver/mtd/spi:Read 8KB data chunk during u-boot load in SPL driver: Add support of image load for MMC & SPI in SPL Makefile: Add support of CONFIG_SPL_FSL_PBL board/b4qds:Add support of 2 stage NAND boot-loader board/t104xrdb: Add support of NAND, SD, SPI boot for T104xRDB powerpc/mpc85xx:Avoid fix address of bootpg section powerpc/mpc85xx:Update MONITOR_LEN for 768KB u-boot size powerpc/mpc85xx:Update FM1 clock select and shift for B4420
Priyanka Jain (1): driver/net/fm/memac_phy: Initialize mdio_clock for SoCs wih FMANv3
Scott Wood (1): powerpc/85xx: Fix e6500 L2 cache stash IDs
Shaohui Xie (3): powerpc/t1040rdb: added a break in switch case powerpc/t4240: updated RCW and PBI for rev2.0 powerpc/T4QDS: add two stage boot of nand/sd
Shengzhou Liu (6): powerpc/t208xqds: fix nor chip selection when nand boot powerpc/T208xQDS: add mtdparts suppport powerpc/T208xRDB: add mtdparts suppport board/t208xqds: Add support of 2-stage NAND/SPI/SD boot board/t208xrdb: Add support of 2-stage NAND/SPI/SD boot board/t2080rdb: some update for t2080rdb
Tang Yuantian (4): mpc85xx: Add support for the supplement configuration unit register mpc85xx/t104x: Add deep sleep framework support mpc85xx: Add deep sleep support on T1040QDS mpc85xx: Add deep sleep support on T104xRDB
York Sun (5): driver/fsl_ifc: Add a function to finalize CS0 address binding driver/ddr/fsl: Add DDR4 support to Freescale DDR driver mpc85xx/T1040QDS_D4: Add DDR4 support powerpc/mpc85xx: Add workaround for erratum A007212 drivers/ddr: Fix possible out of bounds error
Zhao Qiang (5): QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and CONFIG_SYS_QE_FW_ADDR QE/U-QE: Add U-QE support t1040rdb/qe: add QE support for T1040RDB T1040QDS/U-QE: Add u-qe support to t1040qds ar8031: modify the config func of ar8031 to ar8021_config
vijay rai (2): powerpc/t104xrdb: Unification of T104xRDB header files powerpc/85xx: Enhance get_sys_info() to check clocking mode
Makefile | 19 + README | 37 +- arch/powerpc/cpu/mpc85xx/Makefile | 2 + arch/powerpc/cpu/mpc85xx/cmd_errata.c | 23 + arch/powerpc/cpu/mpc85xx/cpu.c | 10 +- arch/powerpc/cpu/mpc85xx/cpu_init.c | 161 +++++- arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 8 +- arch/powerpc/cpu/mpc85xx/fdt.c | 41 +- arch/powerpc/cpu/mpc85xx/fixed_ivor.S | 63 --- arch/powerpc/cpu/mpc85xx/qe_io.c | 2 +- arch/powerpc/cpu/mpc85xx/release.S | 3 - arch/powerpc/cpu/mpc85xx/speed.c | 36 +- arch/powerpc/cpu/mpc85xx/start.S | 34 +- arch/powerpc/cpu/mpc85xx/t1040_ids.c | 1 + arch/powerpc/cpu/mpc85xx/tlb.c | 49 +- arch/powerpc/cpu/mpc85xx/u-boot-nand.lds | 8 +- arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 19 +- arch/powerpc/cpu/mpc85xx/u-boot.lds | 7 +- arch/powerpc/cpu/mpc8xxx/law.c | 52 +- arch/powerpc/include/asm/config_mpc85xx.h | 29 +- arch/powerpc/include/asm/fsl_errata.h | 16 + arch/powerpc/include/asm/fsl_liodn.h | 4 + arch/powerpc/include/asm/fsl_secure_boot.h | 12 + arch/powerpc/include/asm/immap_85xx.h | 35 +- arch/powerpc/include/asm/mmu.h | 8 + arch/powerpc/lib/board.c | 16 + board/freescale/b4860qds/Makefile | 9 +- board/freescale/b4860qds/b4_pbi.cfg | 3 + board/freescale/b4860qds/ddr.c | 5 +- board/freescale/b4860qds/spl.c | 114 ++++ board/freescale/b4860qds/tlb.c | 10 + board/freescale/qemu-ppce500/Makefile | 9 + board/freescale/qemu-ppce500/qemu-ppce500.c | 348 ++++++++++++ board/freescale/t1040qds/ddr.c | 17 +- board/freescale/t1040qds/ddr.h | 37 +- board/freescale/t1040qds/t1040qds.c | 39 ++ board/freescale/t104xrdb/Makefile | 8 +- board/freescale/t104xrdb/README | 73 +++ board/freescale/t104xrdb/cpld.c | 112 ++++ board/freescale/t104xrdb/cpld.h | 40 ++ board/freescale/t104xrdb/ddr.c | 5 +- board/freescale/t104xrdb/eth.c | 1 + board/freescale/t104xrdb/spl.c | 122 ++++ board/freescale/t104xrdb/t1040_rcw.cfg | 7 + board/freescale/t104xrdb/t1042_rcw.cfg | 7 + board/freescale/t104xrdb/t104x_pbi.cfg | 26 + board/freescale/t104xrdb/t104xrdb.c | 23 + board/freescale/t104xrdb/tlb.c | 12 + board/freescale/t208xqds/Makefile | 5 + board/freescale/t208xqds/ddr.c | 7 +- board/freescale/t208xqds/spl.c | 137 +++++ board/freescale/t208xqds/tlb.c | 7 + board/freescale/t208xrdb/Makefile | 5 + board/freescale/t208xrdb/README | 86 ++- board/freescale/t208xrdb/cpld.h | 4 +- board/freescale/t208xrdb/ddr.c | 8 +- board/freescale/t208xrdb/spl.c | 107 ++++ board/freescale/t208xrdb/t208xrdb.c | 2 +- board/freescale/t208xrdb/tlb.c | 4 +- board/freescale/t4qds/Makefile | 6 +- board/freescale/t4qds/ddr.c | 6 +- board/freescale/t4qds/spl.c | 141 +++++ board/freescale/t4qds/t4_pbi.cfg | 14 - board/freescale/t4qds/t4_rcw.cfg | 6 +- board/freescale/t4qds/tlb.c | 8 +- boards.cfg | 55 +- common/ddr_spd.c | 45 +- common/fdt_support.c | 132 ++++- doc/README.b4860qds | 36 ++ doc/README.t4240qds | 53 ++ drivers/ddr/fsl/Makefile | 19 +- drivers/ddr/fsl/ctrl_regs.c | 743 +++++++++++++++++++++++-- drivers/ddr/fsl/ddr4_dimm_params.c | 300 ++++++++++ drivers/ddr/fsl/fsl_ddr_gen4.c | 234 ++++++++ drivers/ddr/fsl/interactive.c | 391 ++++++++++++- drivers/ddr/fsl/lc_common_dimm_params.c | 407 ++++++++------ drivers/ddr/fsl/main.c | 31 +- drivers/ddr/fsl/mpc85xx_ddr_gen3.c | 52 +- drivers/ddr/fsl/options.c | 142 ++--- drivers/ddr/fsl/util.c | 26 +- drivers/misc/fsl_ifc.c | 7 + drivers/mmc/fsl_esdhc_spl.c | 32 +- drivers/mtd/nand/fsl_ifc_spl.c | 13 - drivers/mtd/spi/fsl_espi_spl.c | 29 +- drivers/net/fm/fm.c | 12 +- drivers/net/fm/memac_phy.c | 12 + drivers/net/phy/atheros.c | 2 +- drivers/net/phy/vitesse.c | 2 +- drivers/qe/qe.c | 2 +- drivers/qe/qe.h | 2 + drivers/usb/host/ehci-fsl.c | 38 +- include/common_timing_params.h | 23 +- include/configs/B4860QDS.h | 74 ++- include/configs/BSC9131RDB.h | 2 +- include/configs/BSC9132QDS.h | 13 +- include/configs/C29XPCIE.h | 2 +- include/configs/MPC8536DS.h | 4 +- include/configs/MPC8569MDS.h | 2 +- include/configs/P1010RDB.h | 8 +- include/configs/P1022DS.h | 2 +- include/configs/P1023RDB.h | 4 +- include/configs/P1023RDS.h | 6 +- include/configs/P1_P2_RDB.h | 2 +- include/configs/P2020DS.h | 2 +- include/configs/P2041RDB.h | 12 +- include/configs/T1040QDS.h | 38 +- include/configs/T1040RDB.h | 687 ----------------------- include/configs/{T1042RDB_PI.h => T104xRDB.h} | 216 +++++-- include/configs/T208xQDS.h | 166 ++++-- include/configs/T208xRDB.h | 139 ++++- include/configs/T4240EMU.h | 2 +- include/configs/T4240QDS.h | 105 +++- include/configs/corenet_ds.h | 12 +- include/configs/km/km8309-common.h | 2 +- include/configs/km/kmp204x-common.h | 2 +- include/configs/p1_p2_rdb_pc.h | 4 +- include/configs/p1_twr.h | 4 +- include/configs/qemu-ppce500.h | 206 +++++++ include/configs/t4qds.h | 19 +- include/ddr_spd.h | 226 +++++++- include/e500.h | 3 + include/fdt_support.h | 4 + include/fsl_ddr.h | 7 +- include/fsl_ddr_dimm_params.h | 77 ++- include/fsl_ddr_sdram.h | 67 ++- include/fsl_ddrc_version.h | 18 + include/fsl_esdhc.h | 1 + include/fsl_ifc.h | 1 + include/fsl_immap.h | 35 +- include/fsl_usb.h | 5 + include/spi_flash.h | 1 + include/usb/ehci-fsl.h | 7 + nand_spl/board/freescale/mpc8536ds/Makefile | 6 +- nand_spl/board/freescale/mpc8569mds/Makefile | 6 +- nand_spl/board/freescale/mpc8572ds/Makefile | 6 +- nand_spl/board/freescale/p1023rds/Makefile | 6 +- nand_spl/board/freescale/p1_p2_rdb/Makefile | 6 +- 137 files changed, 5777 insertions(+), 1555 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc85xx/fixed_ivor.S create mode 100644 board/freescale/b4860qds/spl.c create mode 100644 board/freescale/qemu-ppce500/Makefile create mode 100644 board/freescale/qemu-ppce500/qemu-ppce500.c create mode 100644 board/freescale/t104xrdb/cpld.c create mode 100644 board/freescale/t104xrdb/cpld.h create mode 100644 board/freescale/t104xrdb/spl.c create mode 100644 board/freescale/t104xrdb/t1040_rcw.cfg create mode 100644 board/freescale/t104xrdb/t1042_rcw.cfg create mode 100644 board/freescale/t104xrdb/t104x_pbi.cfg create mode 100644 board/freescale/t208xqds/spl.c create mode 100644 board/freescale/t208xrdb/spl.c create mode 100644 board/freescale/t4qds/spl.c create mode 100644 drivers/ddr/fsl/ddr4_dimm_params.c create mode 100644 drivers/ddr/fsl/fsl_ddr_gen4.c delete mode 100644 include/configs/T1040RDB.h rename include/configs/{T1042RDB_PI.h => T104xRDB.h} (78%) create mode 100644 include/configs/qemu-ppce500.h create mode 100644 include/fsl_ddrc_version.h
Thanks,
York
On Wed, Apr 23, 2014 at 03:45:05PM -0700, York Sun wrote:
Tom,
York Sun
